RTEMS 6.1-rc2
This group contains the FTMCTRL interfaces. More...
Modules | |
Memory configuration register 1 (MCFG1) | |
This group contains register bit definitions. | |
Memory configuration register 3 (MCFG3) | |
Memory configuration register 5 (MCFG5) | |
Memory configuration register 7 (MCFG7) | |
Files | |
file | ftmctrl-regs.h |
This header file defines the FTMCTRL register block interface. | |
struct | ftmctrl |
This structure defines the FTMCTRL register block memory map. More... | |
Typedefs | |
typedef struct ftmctrl | ftmctrl |
This structure defines the FTMCTRL register block memory map. | |
