RTEMS 6.1-rc2
This group contains the GRCAN interfaces. More...
Modules | |
Configuration Register (CanCONF) | |
This group contains register bit definitions. | |
Control Register (CanCTRL) | |
Receive Channel Address Register (CanRxADDR) | |
Receive Channel Code Register (CanRxCODE) | |
Receive Channel Control Register (CanRxCTRL) | |
Receive Channel Interrupt Register (CanRxIRQ) | |
Receive Channel Mask Register (CanRxMASK) | |
Receive Channel Read Register (CanRxRD) | |
Receive Channel Size Register (CanRxSIZE) | |
Receive Channel Write Register (CanRxWR) | |
SYNC Code Filter Register (CanCODE) | |
SYNC Mask Filter Register (CanMASK) | |
Status Register (CanSTAT) | |
Transmit Channel Address Register (CanTxADDR) | |
Transmit Channel Control Register (CanTxCTRL) | |
Transmit Channel Interrupt Register (CanTxIRQ) | |
Transmit Channel Read Register (CanTxRD) | |
Transmit Channel Size Register (CanTxSIZE) | |
Transmit Channel Write Register (CanTxWR) | |
Files | |
file | grcan-regs.h |
This header file defines the GRCAN register block interface. | |
struct | grcan |
This structure defines the GRCAN register block memory map. More... | |
Typedefs | |
typedef struct grcan | grcan |
This structure defines the GRCAN register block memory map. | |
