RTEMS
6.1-rc2
SAMS70
Board Support Packages
ARM
Atmel/Microchip SAM E70, S70, V70 and V71
Contributed Code
AHB Bus Matrix
Advanced Encryption Standard
Analog Comparator Controller
Analog Front-End Controller
Chip Identifier
Digital-to-Analog Converter Controller
Embedded Flash Controller
Extensible DMA Controller
General Purpose Backup Registers
High Speed MultiMedia Card Interface
Image Sensor Interface
Integrity Check Monitor
Parallel Input/Output Controller
Power Management Controller
Pulse Width Modulation Controller
Quad Serial Peripheral Interface
Real-time Clock
Real-time Timer
Reinforced Safety Watchdog Timer
Reset Controller
SAMS70J19 definitions
SAMS70J20 definitions
SAMS70J21 definitions
SAMS70N19 definitions
SAMS70N20 definitions
SAMS70N21 definitions
SAMS70Q19 definitions
SAMS70Q20 definitions
SAMS70Q21 definitions
SDRAM Controller
Static Memory Controller
Supply Controller
Synchronous Serial Controller
Timer Counter
True Random Number Generator
Two-wire Interface High Speed
USB High-Speed Interface
USB Transmitter Interface Macrocell
Universal Asynchronous Receiver Transmitter
Universal Synchronous Asynchronous Receiver Transmitter
Watchdog Timer
