RTEMS 6.1-rc2
#define EXTI_LINE_0   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x00U)
#define EXTI_LINE_1   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x01U)
#define EXTI_LINE_2   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x02U)
#define EXTI_LINE_3   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x03U)
#define EXTI_LINE_4   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x04U)
#define EXTI_LINE_5   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x05U)
#define EXTI_LINE_6   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x06U)
#define EXTI_LINE_7   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x07U)
#define EXTI_LINE_8   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x08U)
#define EXTI_LINE_9   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x09U)
#define EXTI_LINE_10   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0AU)
#define EXTI_LINE_11   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0BU)
#define EXTI_LINE_12   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0CU)
#define EXTI_LINE_13   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0DU)
#define EXTI_LINE_14   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0EU)
#define EXTI_LINE_15   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0FU)
#define EXTI_LINE_16   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x10U)
#define EXTI_LINE_17   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x11U)
#define EXTI_LINE_18   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x12U)
#define EXTI_LINE_19   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x13U)
#define EXTI_LINE_20   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x14U)
#define EXTI_LINE_21   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x15U)
#define EXTI_LINE_22   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x16U)
#define EXTI_LINE_23   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
#define EXTI_LINE_24   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x18U)
#define EXTI_LINE_25   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x19U)
#define EXTI_LINE_26   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU)
#define EXTI_LINE_27   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1BU)
#define EXTI_LINE_28   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU)
#define EXTI_LINE_29   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU)
#define EXTI_LINE_30   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU)
#define EXTI_LINE_31   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU)
#define EXTI_LINE_32   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x00U)
#define EXTI_LINE_33   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x01U)
#define EXTI_LINE_34   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x02U)
#define EXTI_LINE_35   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x03U)
#define EXTI_LINE_36   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x04U)
#define EXTI_LINE_37   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x05U)
#define EXTI_LINE_38   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x06U)
#define EXTI_LINE_39   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x07U)
#define EXTI_LINE_40   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x08U)
#define EXTI_LINE_41   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x09U)
#define EXTI_LINE_42   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU)
#define EXTI_LINE_43   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0BU)
#define EXTI_LINE_44   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0CU)
#define EXTI_LINE_45   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0DU)
#define EXTI_LINE_46   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0EU)
#define EXTI_LINE_47   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0FU)
#define EXTI_LINE_48   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x10U)
#define EXTI_LINE_49   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x11U)
#define EXTI_LINE_50   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x12U)
#define EXTI_LINE_51   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x13U)
#define EXTI_LINE_52   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x14U)
#define EXTI_LINE_53   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x15U)
#define EXTI_LINE_54   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x16U)
#define EXTI_LINE_55   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
#define EXTI_LINE_56   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x18U)
#define EXTI_LINE_57   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x19U)
#define EXTI_LINE_58   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU)
#define EXTI_LINE_59   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x1BU)
#define EXTI_LINE_60   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU)
#define EXTI_LINE_61   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU)
#define EXTI_LINE_62   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU)
#define EXTI_LINE_63   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU)
#define EXTI_LINE_64   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x00U)
#define EXTI_LINE_65   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x01U)
#define EXTI_LINE_66   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x02U)
#define EXTI_LINE_67   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x03U)
#define EXTI_LINE_68   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x04U)
#define EXTI_LINE_69   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x05U)
#define EXTI_LINE_70   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x06U)
#define EXTI_LINE_71   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x07U)
#define EXTI_LINE_72   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x08U)
#define EXTI_LINE_73   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x09U)
#define EXTI_LINE_74   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU)
#define EXTI_LINE_75   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0BU)
#define EXTI_LINE_76   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0CU)
#define EXTI_LINE_77   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0DU)
#define EXTI_LINE_78   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0EU)
#define EXTI_LINE_79   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0FU)
#define EXTI_LINE_80   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x10U)
#define EXTI_LINE_81   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x11U)
#define EXTI_LINE_82   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x12U)
#define EXTI_LINE_83   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x13U)
#define EXTI_LINE_84   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x14U)
#define EXTI_LINE_85   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x15U)
#define EXTI_LINE_86   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x16U)
#define EXTI_LINE_87   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
