RTEMS 6.1-rc2
gr_cpci_gr740.h
2
3/* GR-CPCI-GR740 PCI Peripheral driver
4 *
5 * COPYRIGHT (c) 2017.
6 * Cobham Gaisler AB.
7 *
8 * Redistribution and use in source and binary forms, with or without
9 * modification, are permitted provided that the following conditions
10 * are met:
11 * 1. Redistributions of source code must retain the above copyright
12 * notice, this list of conditions and the following disclaimer.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27 * POSSIBILITY OF SUCH DAMAGE.
28 *
29 * Configures the GR-CPIC-GR740 interface PCI board in peripheral
30 * mode. This driver provides a AMBA PnP bus by using the general part
31 * of the AMBA PnP bus driver (ambapp_bus.c).
32 *
33 *
34 * Driver resource options:
35 * NAME DEFAULT VALUE
36 * ahbmst2pci _RAM_START AMBA->PCI translation PCI base address
37 * ambaFreq 250000000 (250MHz) AMBA system frequency of GR740
38 * cgEnMask 0x1f (all) Clock gating enable mask
39 *
40 * TODO/UNTESTED
41 * Interrupt testing
42 * bar0 RESOURCE 0x00000000 L2-Cache SDRAM memory
43 * bar1 RESOURCE 0xf0000000 L2-Cache registers
44 */
45
46#ifndef __GR_CPCI_GR740_H__
47#define __GR_CPCI_GR740_H__
48
49#include <drvmgr/drvmgr.h>
50
51#ifdef __cplusplus
52extern "C" {
53#endif
54
55/* An array of pointers to GR-CPCI-GR740 resources. The resources will be
56 * used by the drivers controlling the cores on the GR-CPCI-GR740 target
57 * AMBA bus.
58 *
59 * The gr_cpci_gr740_resources is declared weak so that the user can override the
60 * default configuration. The array must be terminated with a NULL resource.
61 */
62extern struct drvmgr_bus_res *gr_cpci_gr740_resources[];
63
64/* Options to gr_cpci_gr740_print function */
65#define GR_CPCI_GR740_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
66
67/* Print information about all GR-CPCI-GR740 PCI boards */
68void gr_cpci_gr740_print(int options);
69
70/* Print information about one GR-CPCI-GR740 PCI board */
71void gr_cpci_gr740_print_dev(struct drvmgr_dev *dev, int options);
72
73/* Register GR-CPCI-GR740 driver */
74void gr_cpci_gr740_register_drv(void);
75
76#ifdef __cplusplus
77}
78#endif
79
80#endif
Driver Manager Interface.
Definition: drvmgr.h:238
Definition: drvmgr.h:297
