RTEMS 6.1-rc2
Data Structures | Macros | Typedefs
This header file defines the GR740 Temperatur Sensor Controller register block interface. More...
#include <stdint.h>
struct  gr740_thsens
 This structure defines the GR740 Temperatur Sensor Controller register block memory map. More...
#define GR740_THSENS_CTRL_DIV_SHIFT   16
#define GR740_THSENS_CTRL_DIV_MASK   0x3ff0000U
#define GR740_THSENS_CTRL_DIV_GET(_reg)
#define GR740_THSENS_CTRL_DIV_SET(_reg, _val)
#define GR740_THSENS_CTRL_DIV(_val)
#define GR740_THSENS_CTRL_ALEN   0x100U
#define GR740_THSENS_CTRL_PDN   0x80U
#define GR740_THSENS_CTRL_DCORRECT_SHIFT   2
#define GR740_THSENS_CTRL_DCORRECT_MASK   0x7cU
#define GR740_THSENS_CTRL_DCORRECT_GET(_reg)
#define GR740_THSENS_CTRL_DCORRECT_SET(_reg, _val)
#define GR740_THSENS_CTRL_DCORRECT(_val)
#define GR740_THSENS_CTRL_SRSTN   0x2U
#define GR740_THSENS_CTRL_CLKEN   0x1U
#define GR740_THSENS_STATUS_MAX_SHIFT   24
#define GR740_THSENS_STATUS_MAX_MASK   0x7f000000U
#define GR740_THSENS_STATUS_MAX_GET(_reg)
#define GR740_THSENS_STATUS_MAX_SET(_reg, _val)
#define GR740_THSENS_STATUS_MAX(_val)
#define GR740_THSENS_STATUS_MIN_SHIFT   16
#define GR740_THSENS_STATUS_MIN_MASK   0x7f0000U
#define GR740_THSENS_STATUS_MIN_GET(_reg)
#define GR740_THSENS_STATUS_MIN_SET(_reg, _val)
#define GR740_THSENS_STATUS_MIN(_val)
#define GR740_THSENS_STATUS_SCLK   0x8000U
#define GR740_THSENS_STATUS_WE   0x400U
#define GR740_THSENS_STATUS_UPD   0x200U
#define GR740_THSENS_STATUS_ALACT   0x100U
#define GR740_THSENS_STATUS_DATA_SHIFT   0
#define GR740_THSENS_STATUS_DATA_MASK   0x7fU
#define GR740_THSENS_STATUS_DATA_GET(_reg)
#define GR740_THSENS_STATUS_DATA_SET(_reg, _val)
#define GR740_THSENS_STATUS_DATA(_val)
#define GR740_THSENS_THRES_THRES_SHIFT   0
#define GR740_THSENS_THRES_THRES_MASK   0x7fU
#define GR740_THSENS_THRES_THRES_GET(_reg)
#define GR740_THSENS_THRES_THRES_SET(_reg, _val)
#define GR740_THSENS_THRES_THRES(_val)
typedef struct gr740_thsens gr740_thsens
