RTEMS 6.1-rc2
gr1553rt.h
2
3/* GR1553B RT driver
4 *
5 * COPYRIGHT (c) 2010.
6 * Cobham Gaisler AB.
7 *
8 * Redistribution and use in source and binary forms, with or without
9 * modification, are permitted provided that the following conditions
10 * are met:
11 * 1. Redistributions of source code must retain the above copyright
12 * notice, this list of conditions and the following disclaimer.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27 * POSSIBILITY OF SUCH DAMAGE.
28 */
29
30#ifndef __GR1553RT_H__
31#define __GR1553RT_H__
32
33/* CONFIG OPTION: Maximum number of LIST IDs supported.
34 * There are two lists per RT subaddress, one for RX one
35 * for TX.
36 */
37#define RTLISTID_MAX 64
38
39/* CONFIG OPTION: Maximum number of Interrupt handlers per device supported
40 * max is 256 supported, and minimum is 1.
41 */
42#define RTISR_MAX 64
43
44/* CONFIG OPTION: Maximum number of transfer (RX/TX) descriptors supported.
45 *
46 * Set this option to zero to allow flexible number of descriptors,
47 * requires dynamically allocation of driver structures.
48 */
49/*#define RTBD_MAX 4096*/
50#define RTBD_MAX 0
51
52#ifdef __cplusplus
53extern "C" {
54#endif
55
56/* Register GR1553B driver needed by RT driver */
57extern void gr1553rt_register(void);
58
59struct gr1553rt_list;
60
61/* Descriptor read/written by hardware.
62 *
63 * Must be aligned to 16 byte boundary
64 */
66 volatile unsigned int ctrl; /* 0x00 Control/Status word */
67 volatile unsigned int dptr; /* 0x04 Data Pointer */
68 volatile unsigned int next; /* 0x08 Next Descriptor in list */
69 volatile unsigned int unused; /* 0x0C UNUSED BY HARDWARE */
70};
71
72/* Sub address table entry, the hardware access */
74 volatile unsigned int ctrl; /* 0x00 SUBADDRESS CONTROL WORD */
75 volatile unsigned int txptr; /* 0x04 TRANSMIT BD POINTER */
76 volatile unsigned int rxptr; /* 0x08 RECEIVE BD POINTER */
77 volatile unsigned int unused; /* 0x0C UNUSED BY HARDWARE */
78};
79
80/* Configuration of a RT-SubAddress-List */
82 unsigned int bd_cnt; /* Number of hw-descriptors in list */
83};
84
85/* A TX or RX subaddress descriptor list */
87 short listid; /* ID/NUMBER of List. -1 unassigned */
88 short subadr; /* SubAddress. -1 when not scheduled */
89 void *rt; /* Scheduled on Device */
90 struct gr1553rt_list_cfg *cfg; /* List configuration */
91 int bd_cnt; /* Number of Descriptors */
92
93 /* !!Must be last in data structure!!
94 * !!Array must at least be of length bd_cnt!!
95 */
96 unsigned short bds[0]; /* Array of BDIDs */
97};
98
99/* GR1553B-RT Driver configuration options used when calling gr1553rt_config().
100 *
101 * Note that if not custom addresses are given the driver will dynamically
102 * allocate memory for buffers.
103 * Note that if custom addresses with the LSB set, the address will be
104 * interpreted as a address accessible by hardware, and translated
105 * into an address used by CPU.
106 */
108 unsigned char rtaddress; /* RT Address 0..30 */
109
110 /*** MODE CODE CONFIG ***/
111 unsigned int modecode; /* Mode codes enable/disable/IRQ/EV-Log.
112 * Each modecode has a 2-bit cfg field.
113 * See Mode Code Control Register in
114 * hardware manual.
115 */
116
117 /*** TIME CONFIG ***/
118 unsigned short time_res; /* Time tag resolution in us */
119
120 /*** SUBADDRESS TABLE CONFIG ***/
121 void *satab_buffer; /* Optional Custom buffer. Must be
122 * At least 16*32 bytes, and be aligned
123 * to 10-bit (1KB) boundary. Set to NULL
124 * to make driver allocate buffer.
125 */
126
127 /*** EVENT LOG CONFIG ***/
128 void *evlog_buffer; /* Optional Custom buffer */
129 int evlog_size; /* Length, must be a multiple of 2.
130 * If set to ZERO event log is disabled
131 */
132
133 /*** TRANSFER DESCRIPTOR CONFIG ***/
134 int bd_count; /* Number of transfer descriptors shared
135 * by all RX/TX sub-addresses */
136 void *bd_buffer; /* Optional Custom descriptor area.
137 * Must hold bd_count*32 bytes.
138 * If NULL, descriptors will be
139 * allocated dynamically. */
140};
141
142/* GR1553B-RT status indication, copied from the RT registers and stored
143 * here. Used when calling the gr1553rt_status() function.
144 */
146 unsigned int status; /* RT Status word */
147 unsigned int bus_status; /* BUS Status */
148 unsigned short synctime; /* Time Tag of last sync with data */
149 unsigned short syncword; /* Data of last mode code synchronize
150 * with data. */
151 unsigned short time_res; /* Time resolution (set by config) */
152 unsigned short time; /* Current Time Tag */
153};
154
155/* ISR callback definition for ERRORs detected in the GR1553B-RT interrupt
156 * handler.
157 *
158 * \param err Inidicate Error type. The IRQ flag register bit mask:
159 * Bit 9 - RT DMA ERROR
160 * Bit 10 - RT Table access error
161 * \param data Custom data assigned by user
162 */
163typedef void (*gr1553rt_irqerr_t)(int err, void *data);
164
165/* ISR callback definition for modecodes that are configured to generate
166 * an IRQ. The callback is called from within the GR1553B-RT interrupt
167 * handler.
168 *
169 * \param mcode Mode code that caused this IRQ
170 * \param entry The raw Eventlog Entry
171 * \param data Custom data assigned by user
172 */
173typedef void (*gr1553rt_irqmc_t)(int mcode, unsigned int entry, void *data);
174
175/* Transfer ISR callback definition. Called from GR1553B-RT interrupt handler
176 * when an interrupt has been generated and a event logged due to a 1553
177 * transfer to this RT.
178 *
179 * \param list List (Subaddress/TransferType) that caused IRQ
180 * \param entry The raw Eventlog Entry
181 * \param bd_next Next Descriptor-entry index in the list (Subaddress/tr-type)
182 * This can be used to process all descriptors upto entry_next.
183 * \param data Custom data assigned by user
184 */
185typedef void (*gr1553rt_irq_t)(
186 struct gr1553rt_list *list,
187 unsigned int entry,
188 int bd_next,
189 void *data
190 );
191
192/* Configure a list according to configuration. Assign the list
193 * to a device, however not to a RT sub address yet. The rt
194 * is stored within list.
195 *
196 * \param rt RT Device driver identification, stored within list.
197 * \param list The list to configure
198 * \param cfg Configuration for list. Pointer to configuration is
199 * stored within list for later use.
200 */
201extern int gr1553rt_list_init
202 (
203 void *rt,
204 struct gr1553rt_list **plist,
205 struct gr1553rt_list_cfg *cfg
206 );
207
208/* Assign an Error Interrupt handler. Before the handler is called the
209 * RT hardware is stopped/disabled. The handler is optional, if not assigned
210 * the ISR will still stop the RT upon error.
211 *
212 * Errors detected by the interrupt handler:
213 * - DMA error
214 * - Subaddress table access error
215 *
216 * \param func ISR called when an error causes an interrupt.
217 * \param data Custom data given as an argument when calling ISR
218 */
219extern int gr1553rt_irq_err
220 (
221 void *rt,
222 gr1553rt_irqerr_t func,
223 void *data
224 );
225
226/* Assign a ModeCode Interrupt handler callback. Called when a 1553 modecode
227 * transfer is logged and cause an IRQ. The modecode IRQ generation is
228 * configured from "struct gr1553rt_cfg" when calling gr1553rt_config().
229 *
230 * \param func ISR called when a modecode causes an interrupt.
231 * \param data Custom data given as an argument when calling ISR
232 */
233extern int gr1553rt_irq_mc
234 (
235 void *rt,
236 gr1553rt_irqmc_t func,
237 void *data
238 );
239
240/* Assign transfer interrupt handler callback. Called when a RX or TX
241 * transfer is logged and cause an interrupt, the function is called
242 * from the GR1553B-RT driver's ISR, in interrupt context.
243 *
244 * The callback can be installed per subaddress and transfer type.
245 * Subaddress 0 and 31 are not valid (gr1553rt_irq_mc() for modecodes).
246 *
247 * \param subadr Select subaddress (1-30)
248 * \param tx 1=TX subaddress, 0=RX subaddress
249 * \param func ISR called when subaddress of spcified transfer type
250 * causes an interrupt.
251 * \param data Custom data given as an argument when calling ISR
252 */
253extern int gr1553rt_irq_sa
254 (
255 void *rt,
256 int subadr,
257 int tx,
258 gr1553rt_irq_t func,
259 void *data
260 );
261
262#define GR1553RT_BD_FLAGS_IRQEN (1<<30)
263/* Initialize a descriptor entry in a list. This is typically done
264 * prior to scheduling the list.
265 *
266 * \param entry_no Entry number in list (descriptor index in list)
267 * \param flags Enable IRQ when descriptor is accessed by setting
268 * argument GR1553RT_BD_FLAGS_IRQEN. Enabling IRQ on a
269 * descriptor basis will override SA-table IRQ config.
270 * \param dptr Data Pointer to RX or TX operation. The LSB indicate
271 * if the address must be translated into Hardware address
272 * - this is useful when a buffer close to CPU is used
273 * as a data pointer and the RT core is located over PCI.
274 * \param next Next Entry in list. Set to 0xffff for end of list. Set
275 * 0xfffe for next entry in list, wrap around to entry
276 * zero if entry_no is last descriptor in list (circular).
277 */
278extern int gr1553rt_bd_init(
279 struct gr1553rt_list *list,
280 unsigned short entry_no,
281 unsigned int flags,
282 uint16_t *dptr,
283 unsigned short next
284 );
285
286/* Manipulate/Read Control/Status and Data Pointer words of a buffer descriptor.
287 * If status is zero, the control/status word is accessed. If dptr is non-zero
288 * the data pointer word is accessed.
289 *
290 * \param list The list that the descriptor is located at
291 *
292 * \param entry_no The descriptor number accessed
293 *
294 * \param status IN/OUT. If zero no effect. If pointer is non-zero the
295 * value pointed to:
296 * IN: Written to Control/Status
297 * OUT: the value of the Control/Status word before writing.
298 *
299 * \param dptr IN/OUT. If zero no effect. If pointer is non-zero, the
300 * value pointed to:
301 * IN: non-zero: Descriptor data pointer will be updated with
302 * this value. Note that the LSB indicate if the address
303 * must be translated into hardware-aware address.
304 * OUT: The old data pointer is stored here.
305 */
306extern int gr1553rt_bd_update(
307 struct gr1553rt_list *list,
308 int entry_no,
309 unsigned int *status,
310 uint16_t **dptr
311 );
312
313/* Get the next/current descriptor processed of a RT sub-address.
314 *
315 * \param subadr RT Subaddress
316 * \param txeno Pointer to where TX descriptor number is stored.
317 * \param rxeno Pointer to where RX descriptor number is stored.
318 */
319extern int gr1553rt_indication(void *rt, int subadr, int *txeno, int *rxeno);
320
321/* Take a GR1553RT hardware device identified by minor.
322 * A pointer is returned that is used internally by the GR1553RT
323 * driver, it is used as an input parameter 'rt' to all other
324 * functions that manipulate the hardware.
325 *
326 * This function initializes the RT hardware to a stopped/disable level.
327 */
328extern void *gr1553rt_open(int minor);
329
330/* Close and stop/disable the RT hardware. */
331extern void gr1553rt_close(void *rt);
332
333/* Configure the RT. The RT device must be configured once before
334 * started. A started RT device can not be configured.
335 *
336 * \param rt The RT to configure
337 * \param cfg Configuration parameters
338 */
339extern int gr1553rt_config(void *rt, struct gr1553rt_cfg *cfg);
340
341/* Schedule a RX or TX list on a sub address. If a list has already been
342 * schduled on the subaddress and on the same transfer type (RX/TX), the
343 * old list is replaced with the list given here.
344 *
345 * \param subadr Subaddress to schedule list on
346 * \param tx Subaddress transfer type: 1=TX, 0=RX
347 * \param list Preconfigued RT list scheduled
348 */
349extern void gr1553rt_sa_schedule(
350 void *rt,
351 int subadr,
352 int tx,
353 struct gr1553rt_list *list
354 );
355
356/* Set SubAdress options. One may for example Enable or Disable a sub
357 * address RX and/or TX. See hardware manual for SA-Table configuration
358 * options.
359 *
360 * \param subadr SubAddress to configure
361 * \param mask Bit mask of option-bits written to subaddress config
362 * \param options The new options written to subaddress config.
363 *
364 */
365extern void gr1553rt_sa_setopts(
366 void *rt,
367 int subadr,
368 unsigned int mask,
369 unsigned int options
370 );
371
372/* Get The Subaddress and transfer type of a scheduled list. Normally the
373 * application knows which subaddress the list is for.
374 *
375 * \param list List to lookup information for
376 * \param subadr Pointer to where the subaddress is stored
377 * \param tx Transfer type is stored here. 1=TX, 0=RX.
378 */
379extern void gr1553rt_list_sa(
380 struct gr1553rt_list *list,
381 int *subadr,
382 int *tx
383 );
384
385/* Start RT Communication
386 *
387 * Interrupts will be enabled. The RT enabled and the "RT-run-time"
388 * part of the API will be opened for the user and parts that need the
389 * RT to be stopped are no longer available. After the RT has been
390 * started the configuration function can not be called.
391 */
392extern int gr1553rt_start(void *rt);
393
394/* Get Status of the RT core. See data structure gr1553rt_status for more
395 * information about the result. It can be used to read out:
396 * - time information
397 * - sync information
398 * - bus & RT status
399 *
400 * \param status Pointer to where the status words will be stored. They
401 * are stored according to the gr1553rt_status data structure.
402 */
403extern void gr1553rt_status(void *rt, struct gr1553rt_status *status);
404
405/* Stop RT communication. Only possible to stop an already started RT device.
406 * Interrupts are disabled and the RT Enable bit cleared.
407 */
408extern void gr1553rt_stop(void *rt);
409
410/* Set RT vector and/or bit word.
411 *
412 * - Vector Word is used in response to "Transmit vector word" BC commands
413 * - Bit Word is used in response to "Transmit bit word" BC commands
414 *
415 *
416 * \param mask Bit-Mask, bits that are 1 will result in that bit in the
417 * words register being overwritten with the value of words
418 * \param words Bits 31..16: Bit Word. Bits 15..0: Vector Word.
419 *
420 * Operation:
421 * hw_words = (hw_words & ~mask) | (words & mask)
422 */
423extern void gr1553rt_set_vecword(
424 void *rt,
425 unsigned int mask,
426 unsigned int words
427 );
428
429/* Set selectable bits of the "Bus Status Register". The bits written
430 * is determined by the "mask" bit-mask. Operation:
431 *
432 * bus_status = (bus_status & ~mask) | (sts & mask)
433 *
434 */
435extern void gr1553rt_set_bussts(void *rt, unsigned int mask, unsigned int sts);
436
437/* Read up to MAX number of entries in eventlog log.
438 *
439 * \param dst Destination address for event log entries
440 * \param max Maximal number of event log entries that an be stored into dst
441 *
442 * Return
443 * negative Failure
444 * zero No entries available at the moment
445 * positive Number of entries copied into dst
446 */
447extern int gr1553rt_evlog_read(void *rt, unsigned int *dst, int max);
448
449#ifdef __cplusplus
450}
451#endif
452
453#endif
Definition: mmu-config.c:53
Definition: gr1553rt.h:65
Definition: gr1553rt.h:107
Definition: gr1553rt.h:81
Definition: gr1553rt.h:86
Definition: gr1553rt.h:73
Definition: gr1553rt.h:145
