RTEMS 6.1-rc2
gmacb_phy.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
54#ifndef _GMACB_PHY_H
55#define _GMACB_PHY_H
56
57
58/*---------------------------------------------------------------------------
59 * Headers
60 *---------------------------------------------------------------------------*/
61
62#include "board.h"
63
64/*---------------------------------------------------------------------------
65 * Definitions
66 *---------------------------------------------------------------------------*/
67
69#define GMACB_RESET_LENGTH 0xD
70
71/*---------------------------------------------------------------------------
72 * Types
73 *---------------------------------------------------------------------------*/
74
75
77typedef struct _GMacb {
81 uint32_t retryMax;
83 uint8_t phyAddress;
85
86/*---------------------------------------------------------------------------
87 * Exported functions
88 *---------------------------------------------------------------------------*/
89extern void GMACB_SetupTimeout(GMacb *pMacb, uint32_t toMax);
90
91extern void GMACB_Init(GMacb *pMacb, sGmacd *pGmacd, uint8_t phyAddress);
92
93extern uint8_t GMACB_InitPhy(
94 GMacb *pMacb,
95 uint32_t mck,
96 const Pin *pResetPins,
97 uint32_t nbResetPins,
98 const Pin *pEmacPins,
99 uint32_t nbEmacPins);
100
101extern uint8_t GMACB_AutoNegotiate(GMacb *pMacb);
102
103extern uint8_t GMACB_GetLinkSpeed(GMacb *pMacb, uint8_t applySettings);
104
105extern uint8_t GMACB_Send(GMacb *pMacb, void *pBuffer, uint32_t size);
106
107extern uint32_t GMACB_Poll(GMacb *pMacb, uint8_t *pBuffer, uint32_t size);
108
109extern void GMACB_DumpRegisters(GMacb *pMacb);
110
111extern uint8_t GMACB_ResetPhy(GMacb *pMacb);
112
113#endif // #ifndef _GMACB_H
114
struct _GMacb GMacb
Definition: gmacb_phy.h:77
sGmacd * pGmacd
Definition: gmacb_phy.h:79
uint8_t phyAddress
Definition: gmacb_phy.h:83
uint32_t retryMax
Definition: gmacb_phy.h:81
Definition: gmacd.h:185
Definition: pio.h:172
