uint8_t | GMAC_IsIdle (Gmac *pGmac) |
void | GMAC_PHYMaintain (Gmac *pGmac, uint8_t bPhyAddr, uint8_t bRegAddr, uint8_t bRW, uint16_t wData) |
uint16_t | GMAC_PHYData (Gmac *pGmac) |
uint8_t | GMAC_SetMdcClock (Gmac *pGmac, uint32_t mck) |
| Set MDC clock according to current board clock. Per 802.3, MDC should be less then 2.5MHz.
void | GMAC_EnableMdio (Gmac *pGmac) |
| Enable MDI with PHY.
void | GMAC_DisableMdio (Gmac *pGmac) |
void | GMAC_EnableMII (Gmac *pGmac) |
| Enable MII mode for GMAC, called once after auto negotiate.
void | GMAC_EnableGMII (Gmac *pGmac) |
| Enable GMII mode for GMAC, called once after auto negotiate.
void | GMAC_EnableRGMII (Gmac *pGmac, uint32_t duplex, uint32_t speed) |
| Enable RGMII mode for GMAC, called once after auto negotiate.
void | GMAC_SetLinkSpeed (Gmac *pGmac, uint8_t speed, uint8_t fullduplex) |
| Setup the GMAC for the link : speed 100M/10M and Full/Half duplex.
uint32_t | GMAC_SetLocalLoopBack (Gmac *pGmac) |
| set local loop back
uint32_t | GMAC_GetItMask (Gmac *pGmac, gmacQueList_t queueIdx) |
uint32_t | GMAC_GetTxStatus (Gmac *pGmac) |
void | GMAC_ClearTxStatus (Gmac *pGmac, uint32_t dwStatus) |
uint32_t | GMAC_GetRxStatus (Gmac *pGmac) |
void | GMAC_ClearRxStatus (Gmac *pGmac, uint32_t dwStatus) |
void | GMAC_ReceiveEnable (Gmac *pGmac, uint8_t bEnaDis) |
void | GMAC_TransmitEnable (Gmac *pGmac, uint8_t bEnaDis) |
void | GMAC_SetRxQueue (Gmac *pGmac, uint32_t dwAddr, gmacQueList_t queueIdx) |
uint32_t | GMAC_GetRxQueue (Gmac *pGmac, gmacQueList_t queueIdx) |
void | GMAC_SetTxQueue (Gmac *pGmac, uint32_t dwAddr, gmacQueList_t queueIdx) |
uint32_t | GMAC_GetTxQueue (Gmac *pGmac, gmacQueList_t queueIdx) |
void | GMAC_NetworkControl (Gmac *pGmac, uint32_t bmNCR) |
uint32_t | GMAC_GetNetworkControl (Gmac *pGmac) |
void | GMAC_EnableIt (Gmac *pGmac, uint32_t dwSources, gmacQueList_t queueIdx) |
void | GMAC_DisableAllQueueIt (Gmac *pGmac, uint32_t dwSources) |
void | GMAC_EnableAllQueueIt (Gmac *pGmac, uint32_t dwSources) |
void | GMAC_DisableIt (Gmac *pGmac, uint32_t dwSources, gmacQueList_t queueIdx) |
uint32_t | GMAC_GetItStatus (Gmac *pGmac, gmacQueList_t queueIdx) |
void | GMAC_SetAddress (Gmac *pGmac, uint8_t bIndex, uint8_t *pMacAddr) |
void | GMAC_SetAddress32 (Gmac *pGmac, uint8_t bIndex, uint32_t dwMacT, uint32_t dwMacB) |
void | GMAC_SetAddress64 (Gmac *pGmac, uint8_t bIndex, uint64_t ddwMac) |
void | GMAC_ClearStatistics (Gmac *pGmac) |
void | GMAC_IncreaseStatistics (Gmac *pGmac) |
void | GMAC_StatisticsWriteEnable (Gmac *pGmac, uint8_t bEnaDis) |
void | GMAC_Configure (Gmac *pGmac, uint32_t dwCfg) |
void | GMAC_SetDMAConfig (Gmac *pGmac, uint32_t dwDmaCfg, gmacQueList_t queueIdx) |
uint32_t | GMAC_GetDMAConfig (Gmac *pGmac, gmacQueList_t queueIdx) |
uint32_t | GMAC_GetConfigure (Gmac *pGmac) |
void | GMAC_TransmissionStart (Gmac *pGmac) |
void | GMAC_TransmissionHalt (Gmac *pGmac) |
void | GMAC_ClearScreener1Reg (Gmac *pGmac, gmacQueList_t queueIdx) |
void | GMAC_WriteScreener1Reg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t regVal) |
void | GMAC_ClearScreener2Reg (Gmac *pGmac, gmacQueList_t queueIdx) |
void | GMAC_WriteScreener2Reg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t regVal) |
void | GMAC_WriteEthTypeReg (Gmac *pGmac, gmacQueList_t queueIdx, uint16_t etherType) |
void | GMAC_WriteCompareReg (Gmac *pGmac, gmacQueList_t queueIdx, uint32_t c0Reg, uint16_t c1Reg) |
void | GMAC_EnableCbsQueA (Gmac *pGmac) |
void | GMAC_DisableCbsQueA (Gmac *pGmac) |
void | GMAC_EnableCbsQueB (Gmac *pGmac) |
void | GMAC_DisableCbsQueB (Gmac *pGmac) |
void | GMAC_ConfigIdleSlopeA (Gmac *pGmac, uint32_t idleSlopeA) |
void | GMAC_ConfigIdleSlopeB (Gmac *pGmac, uint32_t idleSlopeB) |
void | GMAC_SetTsuTmrIncReg (Gmac *pGmac, uint32_t nanoSec) |
uint16_t | GMAC_GetPtpEvtMsgRxdMsbSec (Gmac *pGmac) |
uint32_t | GMAC_GetPtpEvtMsgRxdLsbSec (Gmac *pGmac) |
uint32_t | GMAC_GetPtpEvtMsgRxdNanoSec (Gmac *pGmac) |
void | GMAC_SetTsuCompare (Gmac *pGmac, uint32_t seconds47, uint32_t seconds31, uint32_t nanosec) |
void | GMAC_SetTsuCompareNanoSec (Gmac *pGmac, uint32_t nanosec) |
void | GMAC_SetTsuCompareSec31 (Gmac *pGmac, uint32_t seconds31) |
void | GMAC_SetTsuCompareSec47 (Gmac *pGmac, uint16_t seconds47) |
uint32_t | GMAC_GetRxEvtFrameSec (Gmac *pGmac) |
uint32_t | GMAC_GetRxEvtFrameNsec (Gmac *pGmac) |
uint32_t | GMAC_GetRxPeerEvtFrameSec (Gmac *pGmac) |
uint32_t | GMAC_GetRxPeerEvtFrameNsec (Gmac *pGmac) |
uint32_t | GMAC_GetTxEvtFrameSec (Gmac *pGmac) |
uint32_t | GMAC_GetTxEvtFrameNsec (Gmac *pGmac) |
uint32_t | GMAC_GetTxPeerEvtFrameSec (Gmac *pGmac) |
uint32_t | GMAC_GetTxPeerEvtFrameNsec (Gmac *pGmac) |
