11#include "fsl_common.h"
27#define FSL_TEMPMON_DRIVER_VERSION (MAKE_VERSION(2, 1, 1))
51#if defined(__cplusplus)
89static inline void TEMPMON_StartMeasure(
TEMPMON_Type *base)
91 base->TEMPSENSE0 |= TEMPMON_TEMPSENSE0_MEASURE_TEMP_MASK;
99static inline void TEMPMON_StopMeasure(
TEMPMON_Type *base)
101 base->TEMPSENSE0 &= ~TEMPMON_TEMPSENSE0_MEASURE_TEMP_MASK;
121#if defined(__cplusplus)
int8_t lowAlarmTemp
Definition: fsl_tempmon.h:36
struct _tempmon_config tempmon_config_t
TEMPMON temperature structure.
int8_t panicAlarmTemp
Definition: fsl_tempmon.h:35
uint16_t frequency
Definition: fsl_tempmon.h:33
void TEMPMON_Deinit(TEMPMON_Type *base)
Deinitializes the TEMPMON module.
Definition: fsl_tempmon.c:92
enum _tempmon_alarm_mode tempmon_alarm_mode
TEMPMON alarm mode.
_tempmon_alarm_mode
TEMPMON alarm mode.
Definition: fsl_tempmon.h:41
void TEMPMON_SetTempAlarm(TEMPMON_Type *base, int8_t tempVal, tempmon_alarm_mode alarmMode)
Set the temperature count (raw sensor output) that will generate an alarm interrupt.
Definition: fsl_tempmon.c:160
void TEMPMON_GetDefaultConfig(tempmon_config_t *config)
Gets the default configuration structure.
Definition: fsl_tempmon.c:109
void TEMPMON_Init(TEMPMON_Type *base, const tempmon_config_t *config)
Initializes the TEMPMON module.
Definition: fsl_tempmon.c:53
int8_t highAlarmTemp
Definition: fsl_tempmon.h:34
float TEMPMON_GetCurrentTemperature(TEMPMON_Type *base)
Get current temperature with the fused temperature calibration data.
Definition: fsl_tempmon.c:132
@ kTEMPMON_LowAlarmMode
Definition: fsl_tempmon.h:44
@ kTEMPMON_PanicAlarmMode
Definition: fsl_tempmon.h:43
@ kTEMPMON_HighAlarmMode
Definition: fsl_tempmon.h:42
Definition: MIMXRT1052.h:43104
Definition: fsl_tempmon.h:32
Definition: deflate.c:114
