10#include "fsl_common.h"
22#define FSL_SRC_DRIVER_VERSION (MAKE_VERSION(2, 1, 1))
25#define SRC_SLICE_ADDRESS_OFFSET (0x200U)
27#define SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET (0x0U)
28#define SRC_SLICE_CONTROL_REGISTER_OFFSET (0x4U)
29#define SRC_SLICE_SETPOINT_CONFIG_REGISTER_OFFSET (0x8U)
30#define SRC_SLICE_DOMAIN_CONFIG_REGISTER_OFFSET (0x0CU)
31#define SRC_SLICE_STATUS_REGISTER_OFFSET (0x10U)
33#define SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, registerOffset) \
34 (((uint32_t)base) + SRC_SLICE_ADDRESS_OFFSET + ((uint32_t)(sliceName) << 5UL) + (registerOffset))
36#define SRC_SLICE_STAT_UNDER_RST_MASK (0x1U)
37#define SRC_SLICE_STAT_RST_BY_HW_MASK (0x4U)
38#define SRC_SLICE_STAT_RST_BY_SW_MASK (0x8U)
40#define SRC_WHITE_LIST_VALUE(coreName) (1UL << (uint32_t)(coreName))
41#define SRC_ASSIGN_LIST_VALUE(coreName) (1UL << (uint32_t)(coreName))
43#define SRC_SLICE_AUTHEN_DOMAIN_MODE_MASK (0x1U)
44#define SRC_SLICE_AUTHEN_SETPOINT_MODE_MASK (0x2U)
46#define SRC_SLICE_AUTHEN_LOCK_MODE_MASK (0x80U)
47#define SRC_SLICE_AUTHEN_LOCK_MODE_SHIFT (7U)
48#define SRC_SLICE_AUTHEN_LOCK_MODE(x) \
49 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_MODE_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_MODE_MASK)
51#define SRC_SLICE_AUTHEN_ASSIGN_LIST_MASK (0xF00U)
52#define SRC_SLICE_AUTHEN_ASSIGN_LIST_SHIFT (8U)
53#define SRC_SLICE_AUTHEN_ASSIGN_LIST(x) \
54 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_ASSIGN_LIST_SHIFT)) & SRC_SLICE_AUTHEN_ASSIGN_LIST_MASK)
56#define SRC_SLICE_AUTHEN_LOCK_ASSIGN_MASK (0x8000U)
57#define SRC_SLICE_AUTHEN_LOCK_ASSIGN_SHIFT (15)
58#define SRC_SLICE_AUTHEN_LOCK_ASSIGN(x) \
59 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_ASSIGN_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_ASSIGN_MASK)
61#define SRC_SLICE_AUTHEN_WHITE_LIST_MASK (0xF0000U)
62#define SRC_SLICE_AUTHEN_WHITE_LIST_SHIFT (16U)
63#define SRC_SLICE_AUTHEN_WHITE_LIST(x) \
64 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_WHITE_LIST_SHIFT)) & SRC_SLICE_AUTHEN_WHITE_LIST_MASK)
66#define SRC_SLICE_AUTHEN_LOCK_LIST_MASK (0x800000U)
67#define SRC_SLICE_AUTHEN_LOCK_LIST_SHIFT (23U)
68#define SRC_SLICE_AUTHEN_LOCK_LIST(x) \
69 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_LIST_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_LIST_MASK)
71#define SRC_SLICE_AUTHEN_USER_MASK (0x1000000U)
72#define SRC_SLICE_AUTHEN_USER_SHIFT (24U)
73#define SRC_SLICE_AUTHEN_USER(x) \
74 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_USER_SHIFT)) & SRC_SLICE_AUTHEN_USER_MASK)
76#define SRC_SLICE_AUTHEN_NONSECURE_MASK (0x2000000U)
77#define SRC_SLICE_AUTHEN_NONSECURE_SHIFT (25U)
78#define SRC_SLICE_AUTHEN_NONSECURE(x) \
79 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_NONSECURE_SHIFT)) & SRC_SLICE_AUTHEN_NONSECURE_MASK)
81#define SRC_SLICE_AUTHEN_LOCK_SETTING_MASK (0x80000000U)
82#define SRC_SLICE_AUTHEN_LOCK_SETTING_SHIFT (31U)
83#define SRC_SLICE_AUTHEN_LOCK_SETTING(x) \
84 (((uint32_t)(((uint32_t)(x)) << SRC_SLICE_AUTHEN_LOCK_SETTING_SHIFT)) & SRC_SLICE_AUTHEN_LOCK_SETTING_MASK)
306#if defined(__cplusplus)
338static inline uint32_t SRC_GetBootConfig(
SRC_Type *base)
349static inline uint8_t SRC_GetBootMode(
SRC_Type *base)
351 return (uint8_t)((base->SBMR2 & SRC_SBMR2_BMOD_MASK) >> SRC_SBMR2_BMOD_SHIFT);
363 SRC_SBMR2_BT_FUSE_SEL_SHIFT);
372static inline uint8_t SRC_GetSECConfigFuseState(
SRC_Type *base)
374 return (uint8_t)((base->SBMR2 & SRC_SBMR2_SEC_CONFIG_MASK) >> SRC_SBMR2_SEC_CONFIG_SHIFT);
403static inline uint32_t SRC_GetResetStatusFlags(
SRC_Type *base)
414static inline void SRC_ClearGlobalSystemResetStatus(
SRC_Type *base, uint32_t mask)
454 uint32_t authRegAddr;
456 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
460 *(
volatile uint32_t *)authRegAddr |= SRC_SLICE_AUTHEN_USER_MASK;
464 *(
volatile uint32_t *)authRegAddr &= ~SRC_SLICE_AUTHEN_USER_MASK;
479 uint32_t authRegAddr;
481 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
485 *(
volatile uint32_t *)authRegAddr |= SRC_SLICE_AUTHEN_NONSECURE_MASK;
489 *(
volatile uint32_t *)authRegAddr &= ~SRC_SLICE_AUTHEN_NONSECURE_MASK;
503 uint32_t authRegAddr;
505 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
507 *(
volatile uint32_t *)authRegAddr |= SRC_SLICE_AUTHEN_LOCK_SETTING_MASK;
519 uint32_t authRegAddr;
521 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
523 *(
volatile uint32_t *)authRegAddr = ((*(
volatile uint32_t *)authRegAddr) & (~SRC_SLICE_AUTHEN_WHITE_LIST_MASK)) |
524 SRC_SLICE_AUTHEN_WHITE_LIST(domainId);
537 uint32_t authRegAddr;
539 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
541 *(
volatile uint32_t *)authRegAddr |= SRC_SLICE_AUTHEN_LOCK_LIST_MASK;
554 uint32_t authRegAddr;
556 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
558 *(
volatile uint32_t *)authRegAddr) & (~SRC_SLICE_AUTHEN_ASSIGN_LIST_MASK)) |
559 SRC_SLICE_AUTHEN_ASSIGN_LIST(assignList);
572 uint32_t authRegAddr;
574 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
576 *(
volatile uint32_t *)authRegAddr |= SRC_SLICE_AUTHEN_LOCK_ASSIGN_MASK;
590 uint32_t authRegAddr;
592 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
597 *(
598 ((*(
volatile uint32_t *)authRegAddr) & (~SRC_SLICE_AUTHEN_DOMAIN_MODE_MASK)) |
599 SRC_SLICE_AUTHEN_SETPOINT_MODE_MASK;
603 *(
volatile uint32_t *)authRegAddr &= ~SRC_SLICE_AUTHEN_SETPOINT_MODE_MASK;
618 uint32_t authRegAddr;
620 authRegAddr = SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_AUTHENTICATION_REGISTER_OFFSET);
625 *(
626 ((*(
volatile uint32_t *)authRegAddr) & (~SRC_SLICE_AUTHEN_SETPOINT_MODE_MASK)) |
627 SRC_SLICE_AUTHEN_DOMAIN_MODE_MASK;
631 *(
volatile uint32_t *)authRegAddr &= ~SRC_SLICE_AUTHEN_DOMAIN_MODE_MASK;
678 return (*(
volatile uint32_t *)(SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_STATUS_REGISTER_OFFSET)) &
679 (SRC_SLICE_STAT_RST_BY_HW_MASK | SRC_SLICE_STAT_RST_BY_SW_MASK));
691 *(
volatile uint32_t *)SRC_GET_SLICE_REGISTER_ADDRESS(base, sliceName, SRC_SLICE_STATUS_REGISTER_OFFSET) = mask;
725static inline void SRC_SetGeneralPurposeRegister(
SRC_Type *base,
729 base->GPR[index] = value;
741 assert((uint8_t)index < (uint8_t)SRC_GPR_COUNT);
743 return base->GPR[index];
748#if defined(__cplusplus)
enum _src_global_system_reset_mode src_global_system_reset_mode_t
The enumeration of global system reset mode.
enum _src_boot_fuse_selection src_boot_fuse_selection_t
The enumeration of the boot fuse selection.
struct _src_setpoint_authentication src_setpoint_authentication_t
The structure of setpoint authentication.
_src_core_name
System core.
Definition: fsl_soc_src.h:90
void SRC_LockSliceMode(SRC_Type *base, src_reset_slice_name_t sliceName)
Locks the value of SETPOINT_MODE and DOMAIN_MODE for the selected reset slice.
Definition: fsl_soc_src.c:108
_src_setpoint_selection
The enumeration of setpoint.
Definition: fsl_soc_src.h:207
Definition: fsl_soc_src.h:99
enum _src_reset_slice_name src_reset_slice_name_t
The enumeration of the slice name.
struct _src_domain_mode_authentication src_domain_mode_authentication_t
The stucture of domain mode authentication.
_src_slice_reset_source
The enumeration of the reset source of each slice.
Definition: fsl_soc_src.h:288
_src_slice_reset_state
The enumeration of the reset state of each slice.
Definition: fsl_soc_src.h:297
_src_global_system_reset_status_flags
The enumeration of reset status flags.
Definition: fsl_soc_src.h:126
Definition: fsl_soc_src.h:175
_src_global_system_reset_source
The enumeration of global system reset sources.
Definition: fsl_soc_src.h:108
void SRC_AssertSliceSoftwareReset(SRC_Type *base, src_reset_slice_name_t sliceName)
Asserts software reset for the selected slice.
Definition: fsl_soc_src.c:86
enum _src_core_name src_core_name_t
System core.
void SRC_SetSliceDomainModeConfig(SRC_Type *base, src_reset_slice_name_t sliceName, uint32_t domainConfig)
Sets domain mode configuration for the selected reset slice.
Definition: fsl_soc_src.c:146
enum _src_global_system_reset_source src_global_system_reset_source_t
src_slice_reset_state_t SRC_GetSliceResetState(SRC_Type *base, src_reset_slice_name_t sliceName)
Gets the reset state of the selected slice.
Definition: fsl_soc_src.c:166
_src_domain_mode_selection
The enumeration of the domain mode.
Definition: fsl_soc_src.h:192
Definition: fsl_soc_src.h:166
void SRC_SetGlobalSystemResetMode(SRC_Type *base, src_global_system_reset_source_t resetSource, src_global_system_reset_mode_t resetMode)
Sets the reset mode of global system reset source.
Definition: fsl_soc_src.c:67
void SRC_SetSliceSetPointConfig(SRC_Type *base, src_reset_slice_name_t sliceName, uint32_t setpointConfig)
Sets setpoint configuration for the selected reset slice.
Definition: fsl_soc_src.c:126
enum _src_slice_reset_state src_slice_reset_state_t
void SRC_ReleaseCoreReset(SRC_Type *base, src_core_name_t coreName)
Releases related core reset operation.
Definition: fsl_soc_src.c:44
enum _src_general_purpose_register_index src_general_purpose_register_index_t
The index of each general purpose register.
Definition: fsl_soc_src.h:230
@ kSRC_CM7Core
Definition: fsl_soc_src.h:91
@ kSRC_CM4Core
Definition: fsl_soc_src.h:92
@ kSRC_SetPoint12AssertReset
Definition: fsl_soc_src.h:220
@ kSRC_SetPoint10AssertReset
Definition: fsl_soc_src.h:218
@ kSRC_SetPoint15AssertReset
Definition: fsl_soc_src.h:223
@ kSRC_SetPoint9AssertReset
Definition: fsl_soc_src.h:217
@ kSRC_SetPoint8AssertReset
Definition: fsl_soc_src.h:216
@ kSRC_SetPoint6AssertReset
Definition: fsl_soc_src.h:214
@ kSRC_SetPoint3AssertReset
Definition: fsl_soc_src.h:211
@ kSRC_SetPoint13AssertReset
Definition: fsl_soc_src.h:221
@ kSRC_SetPoint0AssertReset
Definition: fsl_soc_src.h:208
@ kSRC_SetPoint11AssertReset
Definition: fsl_soc_src.h:219
@ kSRC_SetPoint2AssertReset
Definition: fsl_soc_src.h:210
@ kSRC_SetPoint5AssertReset
Definition: fsl_soc_src.h:213
@ kSRC_SetPoint7AssertReset
Definition: fsl_soc_src.h:215
@ kSRC_SetPoint14AssertReset
Definition: fsl_soc_src.h:222
@ kSRC_SetPoint1AssertReset
Definition: fsl_soc_src.h:209
@ kSRC_SetPoint4AssertReset
Definition: fsl_soc_src.h:212
@ kSRC_SerialDownloaderBootFlow
Definition: fsl_soc_src.h:100
@ kSRC_NormalBootFlow
Definition: fsl_soc_src.h:101
@ kSRC_SoftwareReset
Definition: fsl_soc_src.h:289
@ kSRC_PowerModeTransferReset
Definition: fsl_soc_src.h:290
@ kSRC_SliceResetInProcess
Definition: fsl_soc_src.h:299
@ kSRC_SliceResetFinished
Definition: fsl_soc_src.h:298
@ kSRC_M4CoreM7LockUpResetFlag
Definition: fsl_soc_src.h:157
@ kSRC_M4CoreCSUResetFlag
Definition: fsl_soc_src.h:147
@ kSRC_M7CoreOverVoltageResetFlag
Definition: fsl_soc_src.h:141
@ kSRC_M4CoreM7RequestResetFlag
Definition: fsl_soc_src.h:156
@ kSRC_M7CoreM4LockUpResetFlag
Definition: fsl_soc_src.h:140
@ kSRC_M7CoreM7LockUpResetFlag
Definition: fsl_soc_src.h:129
@ kSRC_M4CoreOverVoltageResetFlag
Definition: fsl_soc_src.h:158
@ kSRC_M7CoreIppUserResetFlag
Definition: fsl_soc_src.h:131
@ kSRC_M7CoreIppResetFlag
Definition: fsl_soc_src.h:127
@ kSRC_M7CoreTempsenseResetFlag
Definition: fsl_soc_src.h:138
@ kSRC_M4CoreIppUserResetFlag
Definition: fsl_soc_src.h:148
@ kSRC_M4CoreM4RequestResetFlag
Definition: fsl_soc_src.h:145
@ kSRC_M7CoreJtagResetFlag
Definition: fsl_soc_src.h:134
@ kSRC_M4CoreCdogResetFlag
Definition: fsl_soc_src.h:159
@ kSRC_M4CoreJtagSWResetFlag
Definition: fsl_soc_src.h:152
@ kSRC_M4CoreIppResetFlag
Definition: fsl_soc_src.h:144
@ kSRC_M4CoreWdogResetFlag
Definition: fsl_soc_src.h:150
@ kSRC_M7CoreCdogResetFlag
Definition: fsl_soc_src.h:142
@ kSRC_M7CoreM4RequestResetFlag
Definition: fsl_soc_src.h:139
@ kSRC_M4CoreWdog4ResetFlag
Definition: fsl_soc_src.h:154
@ kSRC_M7CoreCSUResetFlag
Definition: fsl_soc_src.h:130
@ kSRC_M7CoreWdogResetFlag
Definition: fsl_soc_src.h:133
@ kSRC_M4CoreWdog3ResetFlag
Definition: fsl_soc_src.h:153
@ kSRC_M4CoreM4LockUpResetFlag
Definition: fsl_soc_src.h:146
@ kSRC_M4CoreTempsenseResetFlag
Definition: fsl_soc_src.h:155
@ kSRC_M7CoreJtagSWResetFlag
Definition: fsl_soc_src.h:135
@ kSRC_M4CoreJtagResetFlag
Definition: fsl_soc_src.h:151
@ kSRC_M7CoreWdog3ResetFlag
Definition: fsl_soc_src.h:136
@ kSRC_M7CoreM7RequestResetFlag
Definition: fsl_soc_src.h:128
@ kSRC_M7CoreWdog4ResetFlag
Definition: fsl_soc_src.h:137
@ kSRC_MegaSlice
Definition: fsl_soc_src.h:176
@ kSRC_M4DebugSlice
Definition: fsl_soc_src.h:182
@ kSRC_Usbphy1Slice
Definition: fsl_soc_src.h:184
@ kSRC_WakeUpSlice
Definition: fsl_soc_src.h:178
@ kSRC_M7DebugSlice
Definition: fsl_soc_src.h:183
@ kSRC_M4CoreSlice
Definition: fsl_soc_src.h:180
@ kSRC_LpsrSlice
Definition: fsl_soc_src.h:179
@ kSRC_Usbphy2Slice
Definition: fsl_soc_src.h:185
@ kSRC_DisplaySlice
Definition: fsl_soc_src.h:177
@ kSRC_M7CoreSlice
Definition: fsl_soc_src.h:181
@ kSRC_JageSoftwareReset
Definition: fsl_soc_src.h:118
@ kSRC_M4RequestReset
Definition: fsl_soc_src.h:114
@ kSRC_WdogReset
Definition: fsl_soc_src.h:109
@ kSRC_Wdog4Reset
Definition: fsl_soc_src.h:111
@ kSRC_TempsenseReset
Definition: fsl_soc_src.h:116
@ kSRC_M7RequestReset
Definition: fsl_soc_src.h:115
@ kSRC_CSUReset
Definition: fsl_soc_src.h:117
@ kSRC_M4LockUpReset
Definition: fsl_soc_src.h:112
@ kSRC_Wdog3Reset
Definition: fsl_soc_src.h:110
@ kSRC_OverVoltageReset
Definition: fsl_soc_src.h:119
@ kSRC_M7LockUpReset
Definition: fsl_soc_src.h:113
@ kSRC_Cpu0StopModeAssertReset
Definition: fsl_soc_src.h:195
@ kSRC_Cpu1StopModeAssertReset
Definition: fsl_soc_src.h:199
@ kSRC_Cpu1RunModeAssertReset
Definition: fsl_soc_src.h:197
@ kSRC_Cpu1SuspendModeAssertReset
Definition: fsl_soc_src.h:200
@ kSRC_Cpu0SuspendModeAssertReset
Definition: fsl_soc_src.h:196
@ kSRC_Cpu1WaitModeAssertReset
Definition: fsl_soc_src.h:198
@ kSRC_Cpu0RunModeAssertReset
Definition: fsl_soc_src.h:193
@ kSRC_Cpu0WaitModeAssertReset
Definition: fsl_soc_src.h:194
@ kSRC_DoNotResetSystem
Definition: fsl_soc_src.h:168
@ kSRC_ResetSystem
Definition: fsl_soc_src.h:167
@ kSRC_GeneralPurposeRegister18
Definition: fsl_soc_src.h:248
@ kSRC_GeneralPurposeRegister15
Definition: fsl_soc_src.h:245
@ kSRC_GeneralPurposeRegister6
Definition: fsl_soc_src.h:236
@ kSRC_GeneralPurposeRegister16
Definition: fsl_soc_src.h:246
@ kSRC_GeneralPurposeRegister13
Definition: fsl_soc_src.h:243
@ kSRC_GeneralPurposeRegister12
Definition: fsl_soc_src.h:242
@ kSRC_GeneralPurposeRegister4
Definition: fsl_soc_src.h:234
@ kSRC_GeneralPurposeRegister5
Definition: fsl_soc_src.h:235
Definition: fsl_soc_src.h:231
@ kSRC_GeneralPurposeRegister2
Definition: fsl_soc_src.h:232
@ kSRC_GeneralPurposeRegister17
Definition: fsl_soc_src.h:247
@ kSRC_GeneralPurposeRegister10
Definition: fsl_soc_src.h:240
@ kSRC_GeneralPurposeRegister19
Definition: fsl_soc_src.h:249
@ kSRC_GeneralPurposeRegister20
Definition: fsl_soc_src.h:250
@ kSRC_GeneralPurposeRegister7
Definition: fsl_soc_src.h:237
@ kSRC_GeneralPurposeRegister3
Definition: fsl_soc_src.h:233
@ kSRC_GeneralPurposeRegister9
Definition: fsl_soc_src.h:239
@ kSRC_GeneralPurposeRegister14
Definition: fsl_soc_src.h:244
@ kSRC_GeneralPurposeRegister8
Definition: fsl_soc_src.h:238
@ kSRC_GeneralPurposeRegister11
Definition: fsl_soc_src.h:241
Definition: MIMXRT1052.h:42848
Definition: fsl_soc_src.h:274
bool enableDomainModeTransferReset
Definition: fsl_soc_src.h:275
uint32_t assignList
Definition: fsl_soc_src.h:279
bool lockAssignList
Definition: fsl_soc_src.h:281
Definition: fsl_soc_src.h:257
uint32_t whiteList
Definition: fsl_soc_src.h:262
bool lockWhiteList
Definition: fsl_soc_src.h:264
bool lockSetting
Definition: fsl_soc_src.h:265
bool allowNonSecureModeAccess
Definition: fsl_soc_src.h:266
bool allowUserModeAccess
Definition: fsl_soc_src.h:267
bool enableSetpointTranferReset
Definition: fsl_soc_src.h:258
