RTEMS 6.1-rc2
fsl_cdog.h File Reference
#include "fsl_common.h"
struct  cdog_config_t
CDOG Functional Operation
status_t CDOG_Init (CDOG_Type *base, cdog_config_t *conf)
 Initialize CDOG.
void CDOG_Deinit (CDOG_Type *base)
 Deinitialize CDOG.
void CDOG_GetDefaultConfig (cdog_config_t *conf)
 Sets the default configuration of CDOG.
void CDOG_Stop (CDOG_Type *base, uint32_t stop)
 Stops secure counter and instruction timer.
void CDOG_Start (CDOG_Type *base, uint32_t reload, uint32_t start)
 Sets secure counter and instruction timer values.
void CDOG_Check (CDOG_Type *base, uint32_t check)
 Checks secure counter.
void CDOG_Set (CDOG_Type *base, uint32_t stop, uint32_t reload, uint32_t start)
void CDOG_Add (CDOG_Type *base, uint32_t add)
 Add value to secure counter.
void CDOG_Add1 (CDOG_Type *base)
 Add 1 to secure counter.
void CDOG_Add16 (CDOG_Type *base)
 Add 16 to secure counter.
void CDOG_Add256 (CDOG_Type *base)
 Add 256 to secure counter.
void CDOG_Sub (CDOG_Type *base, uint32_t sub)
void CDOG_Sub1 (CDOG_Type *base)
 Substract 1 from secure counter.
void CDOG_Sub16 (CDOG_Type *base)
 Substract 16 from secure counter.
void CDOG_Sub256 (CDOG_Type *base)
 Substract 256 from secure counter.
void CDOG_WritePersistent (CDOG_Type *base, uint32_t value)
 Set the CDOG persistent word.
uint32_t CDOG_ReadPersistent (CDOG_Type *base)
 Get the CDOG persistent word.
Driver version
#define FSL_CDOG_DRIVER_VERSION   (MAKE_VERSION(2, 1, 1))
 Defines CDOG driver version 2.1.1.
#define SC_ADD(add)
#define SC_ADD1
#define SC_ADD16
#define SC_ADD256
#define SC_SUB(sub)
#define SC_SUB1
#define SC_SUB16
#define SC_SUB256
#define SC_CHECK(val)
enum  __cdog_debug_Action_ctrl_enum { kCDOG_DebugHaltCtrl_Run = 0x1 , kCDOG_DebugHaltCtrl_Pause = 0x2 }
enum  __cdog_irq_pause_ctrl_enum { kCDOG_IrqPauseCtrl_Run = 0x1 , kCDOG_IrqPauseCtrl_Pause = 0x2 }
enum  __cdog_fault_ctrl_enum { kCDOG_FaultCtrl_EnableReset = 0x1U , kCDOG_FaultCtrl_EnableInterrupt = 0x2U , kCDOG_FaultCtrl_NoAction = 0x4U }
enum  __code_lock_ctrl_enum { kCDOG_LockCtrl_Lock = 0x1 , kCDOG_LockCtrl_Unlock = 0x2 }
typedef uint32_t secure_counter_t
void CDOG_DriverIRQHandler (void)
