RTEMS 6.1-rc2
Generic Flash API. More...
struct | rtems_flashdev_region |
General definition for on flash device. More... | |
struct | rtems_flashdev_region_table |
Struct holding region definitions. More... | |
struct | rtems_flashdev_ioctl_page_info |
Page information returned from IOCTL calls. More... | |
struct | rtems_flashdev |
Flash device. More... | |
#define | RTEMS_FLASHDEV_IOCTL_OBTAIN 0 |
Obtains the flash device. | |
#define | RTEMS_FLASHDEV_IOCTL_RELEASE 1 |
Releases the flash device. | |
#define | RTEMS_FLASHDEV_IOCTL_JEDEC_ID 2 |
Returns the JEDEC ID of the flash device. This IOCTL call is informational only. | |
#define | RTEMS_FLASHDEV_IOCTL_ERASE 3 |
Erases flash device. | |
#define | RTEMS_FLASHDEV_IOCTL_REGION_SET 4 |
Set a region that limits read, write and erase calls to within it. Regions are file descriptor specific and limited to a single region per file descriptor and 32 regions total per flash device. Regions can be changed or updated by calling this IOCTL again. | |
#define | RTEMS_FLASHDEV_IOCTL_REGION_UNSET 5 |
Removes the set region on the file descriptor. | |
#define | RTEMS_FLASHDEV_IOCTL_TYPE 6 |
Returns the type of flash device (e.g. NOR or NAND). | |
#define | RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET 7 |
Get the size and address of flash page at given offset. | |
#define | RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX 8 |
Get the size and address of nth flash page where n is index passed in. | |
#define | RTEMS_FLASHDEV_IOCTL_PAGE_COUNT 9 |
Get the number of pages in flash device. | |
#define | RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE 10 |
Get the minimum write size supported by the driver. | |
#define | RTEMS_FLASHDEV_MAX_REGIONS 32 |
The maximum number of region limited file descriptors allowed to be open at once. | |
Typedefs | |
typedef struct rtems_flashdev | rtems_flashdev |
typedef enum rtems_flashdev_flash_type | rtems_flashdev_flash_type |
Enum for flash type returned from IOCTL call. | |
typedef struct rtems_flashdev_region | rtems_flashdev_region |
General definition for on flash device. | |
typedef struct rtems_flashdev_region_table | rtems_flashdev_region_table |
Struct holding region definitions. | |
typedef struct rtems_flashdev_ioctl_page_info | rtems_flashdev_ioctl_page_info |
Page information returned from IOCTL calls. | |
Enumerations | |
enum | rtems_flashdev_flash_type { RTEMS_FLASHDEV_NOR , RTEMS_FLASHDEV_NAND } |
Enum for flash type returned from IOCTL call. More... | |
rtems_flashdev * | rtems_flashdev_alloc_and_init (size_t size) |
Allocate and initialize the flash device. | |
int | rtems_flashdev_init (rtems_flashdev *flash) |
Initialize the flash device. | |
int | rtems_flashdev_register (rtems_flashdev *flash, const char *flash_path) |
Register the flash device. | |
void | rtems_flashdev_destroy (rtems_flashdev *flash) |
Destroys the flash device. | |
void | rtems_flashdev_destroy_and_free (rtems_flashdev *flash) |
Destroys the flash device and frees its memory. | |
Generic Flash API.
