RTEMS 6.1-rc2
extern-cp.h
1/* $NetBSD: extern.h,v 1.12 2005/10/15 18:22:18 christos Exp $ */
2
3/*-
4 * Copyright (c) 1991, 1993, 1994
5 * The Regents of the University of California. All rights reserved.
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 * 3. Neither the name of the University nor the names of its contributors
16 * may be used to endorse or promote products derived from this software
17 * without specific prior written permission.
18 *
19 * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22 * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29 * SUCH DAMAGE.
30 *
31 * @(#)extern.h 8.2 (Berkeley) 4/1/94
32 */
33
34#ifndef _EXTERN_CP_H_
35#define _EXTERN_CP_H_
36
37#define PATH_T RTEMS_SHELL_CP_PATH_T
38
39typedef struct {
40 char *p_end; /* pointer to NULL at end of path */
41 char *target_end; /* pointer to end of target base */
42 char p_path[MAXPATHLEN + 1]; /* pointer to the start of a path */
43} PATH_T;
44
45#include <setjmp.h>
46#include <rtems.h>
47
48typedef struct {
49 PATH_T to;
50 int info;
51 uid_t myuid;
52 int fflag, iflag, lflag, nflag, pflag, vflag;
53 mode_t myumask;
54 jmp_buf exit_jmp;
56
57#define to cp_globals->to
58#define info cp_globals->info
59#define myuid cp_globals->myuid
60#define fflag cp_globals->fflag
61#define iflag cp_globals->iflag
62#define lflag cp_globals->lflag
63#define nflag cp_globals->nflag
64#define pflag cp_globals->pflag
65#define vflag cp_globals->vflag
66#define myumask cp_globals->myumask
67#define exit_jump &(cp_globals->exit_jmp)
68
69#define copy_fifo rtems_shell_cp_copy_fifo
70#define copy_file rtems_shell_cp_copy_file
71#define copy_link rtems_shell_cp_copy_link
72#define copy_special rtems_shell_cp_copy_special
73#define set_utimes rtems_shell_cp_set_utimes
74#define setfile rtems_shell_cp_setfile
75#define usage rtems_shell_cp_usage
76
77#include <sys/cdefs.h>
78
79__BEGIN_DECLS
80int copy_fifo(rtems_shell_cp_globals* cp_globals, struct stat *, int);
81int copy_file(rtems_shell_cp_globals* cp_globals, FTSENT *, int);
82int copy_link(rtems_shell_cp_globals* cp_globals, FTSENT *, int);
83int copy_special(rtems_shell_cp_globals* cp_globals, struct stat *, int);
84int set_utimes(const char *, struct stat *);
85int setfile(rtems_shell_cp_globals* cp_globals, struct stat *, int);
86int preserve_dir_acls(struct stat *, char *, char *);
87int preserve_fd_acls(int, int);
88void usage(rtems_shell_cp_globals* cp_globals);
89
90__END_DECLS
91
92#endif /* !_EXTERN_H_ */
Definition: extern-cp.h:39
Definition: fts.h:74
Definition: extern-cp.h:48
