RTEMS 6.1-rc2
exec_elf.h
1/* $NetBSD: exec_elf.h,v 1.168 2020/10/19 19:33:02 christos Exp $ */
2
3/*-
4 * Copyright (c) 1994 The NetBSD Foundation, Inc.
5 * All rights reserved.
6 *
7 * This code is derived from software contributed to The NetBSD Foundation
8 * by Christos Zoulas.
9 *
10 * Redistribution and use in source and binary forms, with or without
11 * modification, are permitted provided that the following conditions
12 * are met:
13 * 1. Redistributions of source code must retain the above copyright
14 * notice, this list of conditions and the following disclaimer.
15 * 2. Redistributions in binary form must reproduce the above copyright
16 * notice, this list of conditions and the following disclaimer in the
17 * documentation and/or other materials provided with the distribution.
18 *
19 * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
20 * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
21 * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
22 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
23 * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
24 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
25 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
26 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
27 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
28 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
29 * POSSIBILITY OF SUCH DAMAGE.
30 */
31
32#ifndef _SYS_EXEC_ELF_H_
33#define _SYS_EXEC_ELF_H_
34
35/*
36 * The current ELF ABI specification is available at:
37 * http://www.sco.com/developers/gabi/
38 *
39 * Current header definitions are in:
40 * http://www.sco.com/developers/gabi/latest/ch4.eheader.html
41 */
42
43#if defined(_KERNEL) || defined(_STANDALONE)
44#include <sys/types.h>
45#else
46#include <inttypes.h>
47#include <stddef.h>
48#endif /* _KERNEL || _STANDALONE */
49
50#if defined(ELFSIZE)
51#define CONCAT(x,y) __CONCAT(x,y)
52#define ELFNAME(x) CONCAT(elf,CONCAT(ELFSIZE,CONCAT(_,x)))
53#define ELFNAME2(x,y) CONCAT(x,CONCAT(_elf,CONCAT(ELFSIZE,CONCAT(_,y))))
54#define ELFNAMEEND(x) CONCAT(x,CONCAT(_elf,ELFSIZE))
55#define ELFDEFNNAME(x) CONCAT(ELF,CONCAT(ELFSIZE,CONCAT(_,x)))
56#endif
57
58#if HAVE_NBTOOL_CONFIG_H
59#include <nbinclude/machine/elf_machdep.h>
60#else
61#include <machine/elf_machdep.h>
62#endif
63
64typedef uint8_t Elf_Byte;
65
66typedef uint32_t Elf32_Addr;
67#define ELF32_FSZ_ADDR 4
68typedef uint32_t Elf32_Off;
69typedef int32_t Elf32_SOff;
70#define ELF32_FSZ_OFF 4
71typedef int32_t Elf32_Sword;
72#define ELF32_FSZ_SWORD 4
73typedef uint32_t Elf32_Word;
74#define ELF32_FSZ_WORD 4
75typedef uint16_t Elf32_Half;
76#define ELF32_FSZ_HALF 2
77typedef uint64_t Elf32_Lword;
78#define ELF32_FSZ_LWORD 8
79
80typedef uint64_t Elf64_Addr;
81#define ELF64_FSZ_ADDR 8
82typedef uint64_t Elf64_Off;
83typedef int64_t Elf64_SOff;
84#define ELF64_FSZ_OFF 8
85
86typedef int32_t Elf64_Sword;
87#define ELF64_FSZ_SWORD 4
88typedef uint32_t Elf64_Word;
89#define ELF64_FSZ_WORD 4
90
91typedef int64_t Elf64_Sxword;
92#define ELF64_FSZ_SXWORD 8
93typedef uint64_t Elf64_Xword;
94#define ELF64_FSZ_XWORD 8
95typedef uint64_t Elf64_Lword;
96#define ELF64_FSZ_LWORD 8
97typedef uint16_t Elf64_Half;
98#define ELF64_FSZ_HALF 2
99
100/*
101 * ELF Header
102 */
103#define ELF_NIDENT 16
104
105typedef struct {
106 unsigned char e_ident[ELF_NIDENT]; /* Id bytes */
107 Elf32_Half e_type; /* file type */
108 Elf32_Half e_machine; /* machine type */
109 Elf32_Word e_version; /* version number */
110 Elf32_Addr e_entry; /* entry point */
111 Elf32_Off e_phoff; /* Program hdr offset */
112 Elf32_Off e_shoff; /* Section hdr offset */
113 Elf32_Word e_flags; /* Processor flags */
114 Elf32_Half e_ehsize; /* sizeof ehdr */
115 Elf32_Half e_phentsize; /* Program header entry size */
116 Elf32_Half e_phnum; /* Number of program headers */
117 Elf32_Half e_shentsize; /* Section header entry size */
118 Elf32_Half e_shnum; /* Number of section headers */
119 Elf32_Half e_shstrndx; /* String table index */
120} Elf32_Ehdr;
121
122typedef struct {
123 unsigned char e_ident[ELF_NIDENT]; /* Id bytes */
124 Elf64_Half e_type; /* file type */
125 Elf64_Half e_machine; /* machine type */
126 Elf64_Word e_version; /* version number */
127 Elf64_Addr e_entry; /* entry point */
128 Elf64_Off e_phoff; /* Program hdr offset */
129 Elf64_Off e_shoff; /* Section hdr offset */
130 Elf64_Word e_flags; /* Processor flags */
131 Elf64_Half e_ehsize; /* sizeof ehdr */
132 Elf64_Half e_phentsize; /* Program header entry size */
133 Elf64_Half e_phnum; /* Number of program headers */
134 Elf64_Half e_shentsize; /* Section header entry size */
135 Elf64_Half e_shnum; /* Number of section headers */
136 Elf64_Half e_shstrndx; /* String table index */
137} Elf64_Ehdr;
138
139/* e_ident offsets */
140#define EI_MAG0 0 /* '\177' */
141#define EI_MAG1 1 /* 'E' */
142#define EI_MAG2 2 /* 'L' */
143#define EI_MAG3 3 /* 'F' */
144#define EI_CLASS 4 /* File class */
145#define EI_DATA 5 /* Data encoding */
146#define EI_VERSION 6 /* File version */
147#define EI_OSABI 7 /* Operating system/ABI identification */
148#define EI_ABIVERSION 8 /* ABI version */
149#define EI_PAD 9 /* Start of padding bytes up to EI_NIDENT*/
150#define EI_NIDENT 16 /* First non-ident header byte */
151
152/* e_ident[EI_MAG0,EI_MAG3] */
153#define ELFMAG0 0x7f
154#define ELFMAG1 'E'
155#define ELFMAG2 'L'
156#define ELFMAG3 'F'
157#define ELFMAG "\177ELF"
158#define SELFMAG 4
159
160/* e_ident[EI_CLASS] */
161#define ELFCLASSNONE 0 /* Invalid class */
162#define ELFCLASS32 1 /* 32-bit objects */
163#define ELFCLASS64 2 /* 64-bit objects */
164#define ELFCLASSNUM 3
165
166/* e_ident[EI_DATA] */
167#define ELFDATANONE 0 /* Invalid data encoding */
168#define ELFDATA2LSB 1 /* 2's complement values, LSB first */
169#define ELFDATA2MSB 2 /* 2's complement values, MSB first */
170
171/* e_ident[EI_VERSION] */
172#define EV_NONE 0 /* Invalid version */
173#define EV_CURRENT 1 /* Current version */
174#define EV_NUM 2
175
176/* e_ident[EI_OSABI] */
177#define ELFOSABI_SYSV 0 /* UNIX System V ABI */
178#define ELFOSABI_HPUX 1 /* HP-UX operating system */
179#define ELFOSABI_NETBSD 2 /* NetBSD */
180#define ELFOSABI_GNU 3 /* GNU/Linux */
181#define ELFOSABI_HURD 4 /* GNU/Hurd - historical */
182#define ELFOSABI_86OPEN 5 /* 86Open - historical */
183#define ELFOSABI_SOLARIS 6 /* Solaris */
184#define ELFOSABI_AIX 7 /* AIX */
185#define ELFOSABI_IRIX 8 /* IRIX */
186#define ELFOSABI_FREEBSD 9 /* FreeBSD */
187#define ELFOSABI_TRU64 10 /* TRU64 UNIX */
188#define ELFOSABI_MODESTO 11 /* Novell Modesto */
189#define ELFOSABI_OPENBSD 12 /* OpenBSD */
190#define ELFOSABI_OPENVMS 13 /* OpenVMS */
191#define ELFOSABI_NSK 14 /* HP Non-Stop Kernel */
192#define ELFOSABI_AROS 15 /* Amiga Research OS */
193#define ELFOSABI_FENIXOS 16 /* The FenixOS highly scalable multi-core OS */
194#define ELFOSABI_CLOUDABI 17 /* Nuxi CloudABI */
195#define ELFOSABI_OPENVOS 18 /* Stratus Technologies OpenVOS */
196/* Unofficial OSABIs follow */
197#define ELFOSABI_ARM 97 /* ARM */
198#define ELFOSABI_STANDALONE 255 /* Standalone (embedded) application */
199
200#define ELFOSABI_NONE ELFOSABI_SYSV
201
202/* Historical aliases. */
203#define ELFOSABI_LINUX ELFOSABI_GNU
204#define ELFOSABI_MONTEREY ELFOSABI_AIX
205
206/* e_type */
207#define ET_NONE 0 /* No file type */
208#define ET_REL 1 /* Relocatable file */
209#define ET_EXEC 2 /* Executable file */
210#define ET_DYN 3 /* Shared object file */
211#define ET_CORE 4 /* Core file */
212#define ET_NUM 5
213
214#define ET_LOOS 0xfe00 /* Operating system specific range */
215#define ET_HIOS 0xfeff
216#define ET_LOPROC 0xff00 /* Processor-specific range */
217#define ET_HIPROC 0xffff
218
219/* e_machine */
220#define EM_NONE 0 /* No machine */
221#define EM_M32 1 /* AT&T WE 32100 */
222#define EM_SPARC 2 /* SPARC */
223#define EM_386 3 /* Intel 80386 */
224#define EM_68K 4 /* Motorola 68000 */
225#define EM_88K 5 /* Motorola 88000 */
226#define EM_486 6 /* Intel 80486 [old] */
227#define EM_IAMCU 6 /* Intel MCU. */
228#define EM_860 7 /* Intel 80860 */
229#define EM_MIPS 8 /* MIPS I Architecture */
230#define EM_S370 9 /* Amdahl UTS on System/370 */
231#define EM_MIPS_RS3_LE 10 /* MIPS RS3000 Little-endian */
232 /* 11-14 - Reserved */
233#define EM_RS6000 11 /* IBM RS/6000 XXX reserved */
234#define EM_PARISC 15 /* Hewlett-Packard PA-RISC */
235#define EM_NCUBE 16 /* NCube XXX reserved */
236#define EM_VPP500 17 /* Fujitsu VPP500 */
237#define EM_SPARC32PLUS 18 /* Enhanced instruction set SPARC */
238#define EM_960 19 /* Intel 80960 */
239#define EM_PPC 20 /* PowerPC */
240#define EM_PPC64 21 /* 64-bit PowerPC */
241#define EM_S390 22 /* IBM System/390 Processor */
242#define EM_SPU 23 /* IBM SPU/SPC */
243 /* 24-35 - Reserved */
244#define EM_V800 36 /* NEC V800 */
245#define EM_FR20 37 /* Fujitsu FR20 */
246#define EM_RH32 38 /* TRW RH-32 */
247#define EM_RCE 39 /* Motorola RCE */
248#define EM_ARM 40 /* Advanced RISC Machines ARM */
249#define EM_OLD_ALPHA 41 /* DIGITAL Alpha (obsolete) */
250#define EM_SH 42 /* Hitachi Super-H */
251#define EM_SPARCV9 43 /* SPARC Version 9 */
252#define EM_TRICORE 44 /* Siemens Tricore */
253#define EM_ARC 45 /* Argonaut RISC Core */
254#define EM_H8_300 46 /* Hitachi H8/300 */
255#define EM_H8_300H 47 /* Hitachi H8/300H */
256#define EM_H8S 48 /* Hitachi H8S */
257#define EM_H8_500 49 /* Hitachi H8/500 */
258#define EM_IA_64 50 /* Intel Merced Processor */
259#define EM_MIPS_X 51 /* Stanford MIPS-X */
260#define EM_COLDFIRE 52 /* Motorola Coldfire */
261#define EM_68HC12 53 /* Motorola MC68HC12 */
262#define EM_MMA 54 /* Fujitsu MMA Multimedia Accelerator */
263#define EM_PCP 55 /* Siemens PCP */
264#define EM_NCPU 56 /* Sony nCPU embedded RISC processor */
265#define EM_NDR1 57 /* Denso NDR1 microprocessor */
266#define EM_STARCORE 58 /* Motorola Star*Core processor */
267#define EM_ME16 59 /* Toyota ME16 processor */
268#define EM_ST100 60 /* STMicroelectronics ST100 processor */
269#define EM_TINYJ 61 /* Advanced Logic Corp. TinyJ embedded family processor */
270#define EM_X86_64 62 /* AMD x86-64 architecture */
271#define EM_PDSP 63 /* Sony DSP Processor */
272#define EM_PDP10 64 /* Digital Equipment Corp. PDP-10 */
273#define EM_PDP11 65 /* Digital Equipment Corp. PDP-11 */
274#define EM_FX66 66 /* Siemens FX66 microcontroller */
275#define EM_ST9PLUS 67 /* STMicroelectronics ST9+ 8/16 bit microcontroller */
276#define EM_ST7 68 /* STMicroelectronics ST7 8-bit microcontroller */
277#define EM_68HC16 69 /* Motorola MC68HC16 Microcontroller */
278#define EM_68HC11 70 /* Motorola MC68HC11 Microcontroller */
279#define EM_68HC08 71 /* Motorola MC68HC08 Microcontroller */
280#define EM_68HC05 72 /* Motorola MC68HC05 Microcontroller */
281#define EM_SVX 73 /* Silicon Graphics SVx */
282#define EM_ST19 74 /* STMicroelectronics ST19 8-bit CPU */
283#define EM_VAX 75 /* Digital VAX */
284#define EM_CRIS 76 /* Axis Communications 32-bit embedded processor */
285#define EM_JAVELIN 77 /* Infineon Technologies 32-bit embedded CPU */
286#define EM_FIREPATH 78 /* Element 14 64-bit DSP processor */
287#define EM_ZSP 79 /* LSI Logic's 16-bit DSP processor */
288#define EM_MMIX 80 /* Donald Knuth's educational 64-bit processor */
289#define EM_HUANY 81 /* Harvard's machine-independent format */
290#define EM_PRISM 82 /* SiTera Prism */
291#define EM_AVR 83 /* Atmel AVR 8-bit microcontroller */
292#define EM_FR30 84 /* Fujitsu FR30 */
293#define EM_D10V 85 /* Mitsubishi D10V */
294#define EM_D30V 86 /* Mitsubishi D30V */
295#define EM_V850 87 /* NEC v850 */
296#define EM_M32R 88 /* Mitsubishi M32R */
297#define EM_MN10300 89 /* Matsushita MN10300 */
298#define EM_MN10200 90 /* Matsushita MN10200 */
299#define EM_PJ 91 /* picoJava */
300#define EM_OR1K 92 /* OpenRISC 32-bit embedded processor */
301#define EM_OPENRISC EM_OR1K
302#define EM_ARC_A5 93 /* ARC Cores Tangent-A5 */
303#define EM_XTENSA 94 /* Tensilica Xtensa Architecture */
304#define EM_VIDEOCORE 95 /* Alphamosaic VideoCore processor */
305#define EM_TMM_GPP 96 /* Thompson Multimedia General Purpose Processor */
306#define EM_NS32K 97 /* National Semiconductor 32000 series */
307#define EM_TPC 98 /* Tenor Network TPC processor */
308#define EM_SNP1K 99 /* Trebia SNP 1000 processor */
309#define EM_ST200 100 /* STMicroelectronics ST200 microcontroller */
310#define EM_IP2K 101 /* Ubicom IP2xxx microcontroller family */
311#define EM_MAX 102 /* MAX processor */
312#define EM_CR 103 /* National Semiconductor CompactRISC micorprocessor */
313#define EM_F2MC16 104 /* Fujitsu F2MC16 */
314#define EM_MSP430 105 /* Texas Instruments MSP430 */
315#define EM_BLACKFIN 106 /* Analog Devices Blackfin DSP */
316#define EM_SE_C33 107 /* Seiko Epson S1C33 family */
317#define EM_SEP 108 /* Sharp embedded microprocessor */
318#define EM_ARCA 109 /* Arca RISC microprocessor */
319#define EM_UNICORE 110 /* UNICORE from PKU-Unity Ltd. and MPRC Peking University */
320#define EM_EXCESS 111 /* eXcess: 16/32/64-bit configurable embedded CPU */
321#define EM_DXP 112 /* Icera Semiconductor Inc. Deep Execution Processor */
322#define EM_ALTERA_NIOS2 113 /* Altera Nios II soft-core processor */
323#define EM_CRX 114 /* National Semiconductor CompactRISC CRX microprocessor */
324#define EM_XGATE 115 /* Motorola XGATE embedded processor */
325#define EM_C166 116 /* Infineon C16x/XC16x processor */
326#define EM_M16C 117 /* Renesas M16C series microprocessors */
327#define EM_DSPIC30F 118 /* Microchip Technology dsPIC30F Digital Signal Controller */
328#define EM_CE 119 /* Freescale Communication Engine RISC core */
329#define EM_M32C 120 /* Renesas M32C series microprocessors */
330 /* 121-130 - Reserved */
331#define EM_TSK3000 131 /* Altium TSK3000 core */
332#define EM_RS08 132 /* Freescale RS08 embedded processor */
333#define EM_SHARC 133 /* Analog Devices SHARC family of 32-bit DSP processors */
334#define EM_ECOG2 134 /* Cyan Technology eCOG2 microprocessor */
335#define EM_SCORE7 135 /* Sunplus S+core7 RISC processor */
336#define EM_DSP24 136 /* New Japan Radio (NJR) 24-bit DSP Processor */
337#define EM_VIDEOCORE3 137 /* Broadcom VideoCore III processor */
338#define EM_LATTICEMICO32 138 /* RISC processor for Lattice FPGA architecture */
339#define EM_SE_C17 139 /* Seiko Epson C17 family */
340#define EM_TI_C6000 140 /* The Texas Instruments TMS320C6000 DSP family */
341#define EM_TI_C2000 141 /* The Texas Instruments TMS320C2000 DSP family */
342#define EM_TI_C5500 142 /* The Texas Instruments TMS320C55x DSP family */
343#define EM_TI_ARP32 143 /* Texas Instruments Application Specific RISC Processor, 32bit fetch */
344#define EM_TI_PRU 144 /* Texas Instruments Programmable Realtime Unit */
345 /* 145-159 - Reserved */
346#define EM_MMDSP_PLUS 160 /* STMicroelectronics 64bit VLIW Data Signal Processor */
347#define EM_CYPRESS_M8C 161 /* Cypress M8C microprocessor */
348#define EM_R32C 162 /* Renesas R32C series microprocessors */
349#define EM_TRIMEDIA 163 /* NXP Semiconductors TriMedia architecture family */
350#define EM_QDSP6 164 /* QUALCOMM DSP6 Processor */
351#define EM_8051 165 /* Intel 8051 and variants */
352#define EM_STXP7X 166 /* STMicroelectronics STxP7x family of configurable and extensible RISC processors */
353#define EM_NDS32 167 /* Andes Technology compact code size embedded RISC processor family */
354#define EM_ECOG1 168 /* Cyan Technology eCOG1X family */
355#define EM_ECOG1X 168 /* Cyan Technology eCOG1X family */
356#define EM_MAXQ30 169 /* Dallas Semiconductor MAXQ30 Core Micro-controllers */
357#define EM_XIMO16 170 /* New Japan Radio (NJR) 16-bit DSP Processor */
358#define EM_MANIK 171 /* M2000 Reconfigurable RISC Microprocessor */
359#define EM_CRAYNV2 172 /* Cray Inc. NV2 vector architecture */
360#define EM_RX 173 /* Renesas RX family */
361#define EM_METAG 174 /* Imagination Technologies META processor architecture */
362#define EM_MCST_ELBRUS 175 /* MCST Elbrus general purpose hardware architecture */
363#define EM_ECOG16 176 /* Cyan Technology eCOG16 family */
364#define EM_CR16 177 /* National Semiconductor CompactRISC CR16 16-bit microprocessor */
365#define EM_ETPU 178 /* Freescale Extended Time Processing Unit */
366#define EM_SLE9X 179 /* Infineon Technologies SLE9X core */
367#define EM_L10M 180 /* Intel L10M */
368#define EM_K10M 181 /* Intel K10M */
369 /* 182 - Reserved */
370#define EM_AARCH64 183 /* AArch64 64-bit ARM microprocessor */
371 /* 184 - Reserved */
372//#define EM_AVR32 185 /* Atmel Corporation 32-bit microprocessor family*/
373#define EM_TILE64 187 /* Tilera TILE64 multicore architecture family */
374#define EM_TILEPRO 188 /* Tilera TILEPro multicore architecture family */
375#define EM_MICROBLAZE 189 /* Xilinx MicroBlaze 32-bit RISC soft processor core */
376#define EM_CUDA 190 /* NVIDIA CUDA architecture */
377#define EM_TILEGX 191 /* Tilera TILE-GX multicore architecture family */
378#define EM_CLOUDSHIELD 192 /* CloudShield architecture family */
379#define EM_COREA_1ST 193 /* KIPO-KAIST Core-A 1st generation processor family */
380#define EM_COREA_2ND 194 /* KIPO-KAIST Core-A 2nd generation processor family */
381#define EM_ARC_COMPACT2 195 /* Synopsys ARCompact V2 */
382#define EM_OPEN8 196 /* Open8 8-bit RISC soft processor core */
383#define EM_RL78 197 /* Renesas RL78 family */
384#define EM_VIDEOCORE5 198 /* Broadcom VideoCore V processor */
385#define EM_78KOR 199 /* Renesas 78KOR family */
386#define EM_56800EX 200 /* Freescale 56800EX Digital Signal Controller (DSC) */
387#define EM_BA1 201 /* Beyond BA1 CPU architecture */
388#define EM_BA2 202 /* Beyond BA2 CPU architecture */
389#define EM_XCORE 203 /* XMOS xCORE processor family */
390#define EM_MCHP_PIC 204 /* Microchip 8-bit PIC(r) family */
391#define EM_INTEL205 205 /* Reserved by Intel */
392#define EM_INTEL206 206 /* Reserved by Intel */
393#define EM_INTEL207 207 /* Reserved by Intel */
394#define EM_INTEL208 208 /* Reserved by Intel */
395#define EM_INTEL209 209 /* Reserved by Intel */
396#define EM_KM32 210 /* KM211 KM32 32-bit processor */
397#define EM_KMX32 211 /* KM211 KMX32 32-bit processor */
398#define EM_KMX16 212 /* KM211 KMX16 16-bit processor */
399#define EM_KMX8 213 /* KM211 KMX8 8-bit processor */
400#define EM_KVARC 214 /* KM211 KVARC processor */
401#define EM_CDP 215 /* Paneve CDP architecture family */
402#define EM_COGE 216 /* Cognitive Smart Memory Processor */
403#define EM_COOL 217 /* Bluechip Systems CoolEngine */
404#define EM_NORC 218 /* Nanoradio Optimized RISC */
405#define EM_CSR_KALIMBA 219 /* CSR Kalimba architecture family */
406#define EM_Z80 220 /* Zilog Z80 */
407#define EM_VISIUM 221 /* Controls and Data Services VISIUMcore processor */
408#define EM_FT32 222 /* FTDI Chip FT32 high performance 32-bit RISC architecture */
409#define EM_MOXIE 223 /* Moxie processor family */
410#define EM_AMDGPU 224 /* AMD GPU architecture */
411 /* 225-242 - Reserved */
412#define EM_RISCV 243 /* RISC-V */
413
414/* Unofficial machine types follow */
415#define EM_AVR32 6317 /* used by NetBSD/avr32 */
416#define EM_ALPHA_EXP 36902 /* used by NetBSD/alpha; obsolete */
417#define EM_NUM 36903
418
419/*
420 * Program Header
421 */
422typedef struct {
423 Elf32_Word p_type; /* entry type */
424 Elf32_Off p_offset; /* offset */
425 Elf32_Addr p_vaddr; /* virtual address */
426 Elf32_Addr p_paddr; /* physical address */
427 Elf32_Word p_filesz; /* file size */
428 Elf32_Word p_memsz; /* memory size */
429 Elf32_Word p_flags; /* flags */
430 Elf32_Word p_align; /* memory & file alignment */
431} Elf32_Phdr;
432
433typedef struct {
434 Elf64_Word p_type; /* entry type */
435 Elf64_Word p_flags; /* flags */
436 Elf64_Off p_offset; /* offset */
437 Elf64_Addr p_vaddr; /* virtual address */
438 Elf64_Addr p_paddr; /* physical address */
439 Elf64_Xword p_filesz; /* file size */
440 Elf64_Xword p_memsz; /* memory size */
441 Elf64_Xword p_align; /* memory & file alignment */
442} Elf64_Phdr;
443
444/* p_type */
445#define PT_NULL 0 /* Program header table entry unused */
446#define PT_LOAD 1 /* Loadable program segment */
447#define PT_DYNAMIC 2 /* Dynamic linking information */
448#define PT_INTERP 3 /* Program interpreter */
449#define PT_NOTE 4 /* Auxiliary information */
450#define PT_SHLIB 5 /* Reserved, unspecified semantics */
451#define PT_PHDR 6 /* Entry for header table itself */
452#define PT_TLS 7 /* TLS initialisation image */
453#define PT_NUM 8
454
455#define PT_LOOS 0x60000000 /* OS-specific range */
456
457/* GNU-specific */
458#define PT_GNU_EH_FRAME 0x6474e550 /* EH frame segment */
459#define PT_GNU_STACK 0x6474e551 /* Indicate executable stack */
460#define PT_GNU_RELRO 0x6474e552 /* Make read-only after relocation */
461
462#define PT_HIOS 0x6fffffff
463#define PT_LOPROC 0x70000000 /* Processor-specific range */
464#define PT_HIPROC 0x7fffffff
465
466#define PT_MIPS_REGINFO 0x70000000
467#define PT_MIPS_ABIFLAGS 0x70000003
468
469/* p_flags */
470#define PF_R 0x4 /* Segment is readable */
471#define PF_W 0x2 /* Segment is writable */
472#define PF_X 0x1 /* Segment is executable */
473
474#define PF_MASKOS 0x0ff00000 /* Operating system specific values */
475#define PF_MASKPROC 0xf0000000 /* Processor-specific values */
476
477/* Extended program header index. */
478#define PN_XNUM 0xffff
479
480/*
481 * Section Headers
482 */
483typedef struct {
484 Elf32_Word sh_name; /* section name (.shstrtab index) */
485 Elf32_Word sh_type; /* section type */
486 Elf32_Word sh_flags; /* section flags */
487 Elf32_Addr sh_addr; /* virtual address */
488 Elf32_Off sh_offset; /* file offset */
489 Elf32_Word sh_size; /* section size */
490 Elf32_Word sh_link; /* link to another */
491 Elf32_Word sh_info; /* misc info */
492 Elf32_Word sh_addralign; /* memory alignment */
493 Elf32_Word sh_entsize; /* table entry size */
494} Elf32_Shdr;
495
496typedef struct {
497 Elf64_Word sh_name; /* section name (.shstrtab index) */
498 Elf64_Word sh_type; /* section type */
499 Elf64_Xword sh_flags; /* section flags */
500 Elf64_Addr sh_addr; /* virtual address */
501 Elf64_Off sh_offset; /* file offset */
502 Elf64_Xword sh_size; /* section size */
503 Elf64_Word sh_link; /* link to another */
504 Elf64_Word sh_info; /* misc info */
505 Elf64_Xword sh_addralign; /* memory alignment */
506 Elf64_Xword sh_entsize; /* table entry size */
507} Elf64_Shdr;
508
509/* sh_type */
510#define SHT_NULL 0 /* Section header table entry unused */
511#define SHT_PROGBITS 1 /* Program information */
512#define SHT_SYMTAB 2 /* Symbol table */
513#define SHT_STRTAB 3 /* String table */
514#define SHT_RELA 4 /* Relocation information w/ addend */
515#define SHT_HASH 5 /* Symbol hash table */
516#define SHT_DYNAMIC 6 /* Dynamic linking information */
517#define SHT_NOTE 7 /* Auxiliary information */
518#define SHT_NOBITS 8 /* No space allocated in file image */
519#define SHT_REL 9 /* Relocation information w/o addend */
520#define SHT_SHLIB 10 /* Reserved, unspecified semantics */
521#define SHT_DYNSYM 11 /* Symbol table for dynamic linker */
522#define SHT_INIT_ARRAY 14 /* Initialization function pointers */
523#define SHT_FINI_ARRAY 15 /* Termination function pointers */
524#define SHT_PREINIT_ARRAY 16 /* Pre-initialization function ptrs */
525#define SHT_GROUP 17 /* Section group */
526#define SHT_SYMTAB_SHNDX 18 /* Section indexes (see SHN_XINDEX) */
527#define SHT_NUM 19
528
529#define SHT_LOOS 0x60000000 /* Operating system specific range */
530#define SHT_GNU_INCREMENTAL_INPUTS 0x6fff4700 /* GNU incremental build data */
531#define SHT_LOSUNW 0x6ffffff4
532#define SHT_SUNW_dof 0x6ffffff4
533#define SHT_GNU_ATTRIBUTES 0x6ffffff5 /* GNU object attributes */
534#define SHT_SUNW_cap 0x6ffffff5
535#define SHT_SUNW_SIGNATURE 0x6ffffff6
536#define SHT_GNU_HASH 0x6ffffff6 /* GNU style symbol hash table */
537#define SHT_GNU_LIBLIST 0x6ffffff7 /* GNU list of prelink dependencies */
538#define SHT_SUNW_move 0x6ffffffa
539#define SHT_SUNW_COMDAT 0x6ffffffb
540#define SHT_SUNW_syminfo 0x6ffffffc
541#define SHT_SUNW_verdef 0x6ffffffd /* Versions defined by file */
542#define SHT_GNU_verdef SHT_SUNW_verdef
543#define SHT_SUNW_verneed 0x6ffffffe /* Versions needed by file */
544#define SHT_GNU_verneed SHT_SUNW_verneed
545#define SHT_SUNW_versym 0x6fffffff /* Symbol versions */
546#define SHT_GNU_versym SHT_SUNW_versym
547#define SHT_HISUNW 0x6fffffff
548#define SHT_HIOS 0x6fffffff
549#define SHT_LOPROC 0x70000000 /* Processor-specific range */
550#define SHT_AMD64_UNWIND 0x70000001 /* unwind information */
551#define SHT_ARM_EXIDX 0x70000001 /* exception index table */
552#define SHT_ARM_PREEMPTMAP 0x70000002 /* BPABI DLL dynamic linking
553 * pre-emption map */
554#define SHT_ARM_ATTRIBUTES 0x70000003 /* Object file compatibility
555 * attributes */
556#define SHT_ARM_DEBUGOVERLAY 0x70000004 /* See DBGOVL for details */
557#define SHT_ARM_OVERLAYSECTION 0x70000005
558#define SHT_MIPS_REGINFO 0x70000006
559#define SHT_MIPS_OPTIONS 0x7000000d
560#define SHT_MIPS_DWARF 0x7000001e /* MIPS gcc uses MIPS_DWARF */
561#define SHT_MIPS_XHASH 0x7000002b /* MIPS version of GNU_HASH */
562#define SHT_HIPROC 0x7fffffff
563#define SHT_LOUSER 0x80000000 /* Application-specific range */
564#define SHT_HIUSER 0xffffffff
565
566/* sh_flags */
567#define SHF_WRITE 0x00000001 /* Contains writable data */
568#define SHF_ALLOC 0x00000002 /* Occupies memory */
569#define SHF_EXECINSTR 0x00000004 /* Contains executable insns */
570#define SHF_MERGE 0x00000010 /* Might be merged */
571#define SHF_STRINGS 0x00000020 /* Contains nul terminated strings */
572#define SHF_INFO_LINK 0x00000040 /* "sh_info" contains SHT index */
573#define SHF_LINK_ORDER 0x00000080 /* Preserve order after combining */
574#define SHF_OS_NONCONFORMING 0x00000100 /* OS specific handling required */
575#define SHF_GROUP 0x00000200 /* Is member of a group */
576#define SHF_TLS 0x00000400 /* Holds thread-local data */
577#define SHF_MASKOS 0x0ff00000 /* Operating system specific values */
578#define SHF_MASKPROC 0xf0000000 /* Processor-specific values */
579#define SHF_ORDERED 0x40000000 /* Ordering requirement (Solaris) */
580#define SHF_EXCLUDE 0x80000000 /* Excluded unless unles ref/alloc
581 (Solaris).*/
583 * Symbol Table
584 */
585typedef struct {
586 Elf32_Word st_name; /* Symbol name (.strtab index) */
587 Elf32_Word st_value; /* value of symbol */
588 Elf32_Word st_size; /* size of symbol */
589 Elf_Byte st_info; /* type / binding attrs */
590 Elf_Byte st_other; /* unused */
591 Elf32_Half st_shndx; /* section index of symbol */
592} Elf32_Sym;
593
594typedef struct {
595 Elf64_Word st_name; /* Symbol name (.strtab index) */
596 Elf_Byte st_info; /* type / binding attrs */
597 Elf_Byte st_other; /* unused */
598 Elf64_Half st_shndx; /* section index of symbol */
599 Elf64_Addr st_value; /* value of symbol */
600 Elf64_Xword st_size; /* size of symbol */
601} Elf64_Sym;
602
603/* Symbol Table index of the undefined symbol */
604#define ELF_SYM_UNDEFINED 0
605
606#define STN_UNDEF 0 /* undefined index */
607
608/* st_info: Symbol Bindings */
609#define STB_LOCAL 0 /* local symbol */
610#define STB_GLOBAL 1 /* global symbol */
611#define STB_WEAK 2 /* weakly defined global symbol */
612#define STB_NUM 3
613
614#define STB_LOOS 10 /* Operating system specific range */
615#define STB_HIOS 12
616#define STB_LOPROC 13 /* Processor-specific range */
617#define STB_HIPROC 15
618
619/* st_info: Symbol Types */
620#define STT_NOTYPE 0 /* Type not specified */
621#define STT_OBJECT 1 /* Associated with a data object */
622#define STT_FUNC 2 /* Associated with a function */
623#define STT_SECTION 3 /* Associated with a section */
624#define STT_FILE 4 /* Associated with a file name */
625#define STT_COMMON 5 /* Uninitialised common block */
626#define STT_TLS 6 /* Thread local data object */
627#define STT_NUM 7
628
629#define STT_LOOS 10 /* Operating system specific range */
630#define STT_GNU_IFUNC 10 /* GNU extension: indirect function */
631#define STT_HIOS 12
632#define STT_LOPROC 13 /* Processor-specific range */
633#define STT_HIPROC 15
634
635/* st_other: Visibility Types */
636#define STV_DEFAULT 0 /* use binding type */
637#define STV_INTERNAL 1 /* not referenced from outside */
638#define STV_HIDDEN 2 /* not visible, may be used via ptr */
639#define STV_PROTECTED 3 /* visible, not preemptible */
640#define STV_EXPORTED 4
641#define STV_SINGLETON 5
642#define STV_ELIMINATE 6
643
644/* st_info/st_other utility macros */
645#define ELF_ST_BIND(info) ((uint32_t)(info) >> 4)
646#define ELF_ST_TYPE(info) ((uint32_t)(info) & 0xf)
647#define ELF_ST_INFO(bind,type) ((Elf_Byte)(((bind) << 4) | \
648 ((type) & 0xf)))
649#define ELF_ST_VISIBILITY(other) ((uint32_t)(other) & 3)
650
651/*
652 * Special section indexes
653 */
654#define SHN_UNDEF 0 /* Undefined section */
655
656#define SHN_LORESERVE 0xff00 /* Reserved range */
657#define SHN_ABS 0xfff1 /* Absolute symbols */
658#define SHN_COMMON 0xfff2 /* Common symbols */
659#define SHN_XINDEX 0xffff /* Escape -- index stored elsewhere */
660#define SHN_HIRESERVE 0xffff
661
662#define SHN_LOPROC 0xff00 /* Processor-specific range */
663#define SHN_HIPROC 0xff1f
664#define SHN_LOOS 0xff20 /* Operating system specific range */
665#define SHN_HIOS 0xff3f
666
667#define SHN_MIPS_ACOMMON 0xff00
668#define SHN_MIPS_TEXT 0xff01
669#define SHN_MIPS_DATA 0xff02
670#define SHN_MIPS_SCOMMON 0xff03
671
673 * Relocation Entries
674 */
675typedef struct {
676 Elf32_Word r_offset; /* where to do it */
677 Elf32_Word r_info; /* index & type of relocation */
678} Elf32_Rel;
679
680typedef struct {
681 Elf32_Word r_offset; /* where to do it */
682 Elf32_Word r_info; /* index & type of relocation */
683 Elf32_Sword r_addend; /* adjustment value */
684} Elf32_Rela;
685
686/* r_info utility macros */
687#define ELF32_R_SYM(info) ((info) >> 8)
688#define ELF32_R_TYPE(info) ((info) & 0xff)
689#define ELF32_R_INFO(sym, type) (((sym) << 8) + (unsigned char)(type))
690
691typedef struct {
692 Elf64_Addr r_offset; /* where to do it */
693 Elf64_Xword r_info; /* index & type of relocation */
694} Elf64_Rel;
695
696typedef struct {
697 Elf64_Addr r_offset; /* where to do it */
698 Elf64_Xword r_info; /* index & type of relocation */
699 Elf64_Sxword r_addend; /* adjustment value */
700} Elf64_Rela;
701
702/* r_info utility macros */
703#define ELF64_R_SYM(info) ((info) >> 32)
704#define ELF64_R_TYPE(info) ((info) & 0xffffffff)
705#define ELF64_R_INFO(sym,type) (((sym) << 32) + (type))
706
708 * Move entries
709 */
710typedef struct {
711 Elf32_Lword m_value; /* symbol value */
712 Elf32_Word m_info; /* size + index */
713 Elf32_Word m_poffset; /* symbol offset */
714 Elf32_Half m_repeat; /* repeat count */
715 Elf32_Half m_stride; /* stride info */
716} Elf32_Move;
717
718#define ELF32_M_SYM(info) ((info) >> 8)
719#define ELF32_M_SIZE(info) (info) & 0xff)
720#define ELF32_M_INFO(sym, size) (((sym) << 8) + (unsigned char)(size))
721
722typedef struct {
723 Elf64_Lword m_value; /* symbol value */
724 Elf64_Xword m_info; /* size + index */
725 Elf64_Xword m_poffset; /* symbol offset */
726 Elf64_Word m_repeat; /* repeat count */
727 Elf64_Word m_stride; /* stride info */
728} Elf64_Move;
729
730#define ELF64_M_SYM(info) ((info) >> 8)
731#define ELF64_M_SIZE(info) (info) & 0xff)
732#define ELF64_M_INFO(sym, size) (((sym) << 8) + (unsigned char)(size))
733
735 * Hardware/software capabilities entry
736 */
737typedef struct {
738 Elf32_Word c_tag; /* entry tag value */
739 union {
740 Elf32_Addr c_ptr;
741 Elf32_Word c_val;
742 } c_un;
743} Elf32_Cap;
744
745typedef struct {
746 Elf64_Xword c_tag; /* entry tag value */
747 union {
748 Elf64_Addr c_ptr;
749 Elf64_Xword c_val;
750 } c_un;
751} Elf64_Cap;
752
754 * Dynamic Section structure array
755 */
756typedef struct {
757 Elf32_Word d_tag; /* entry tag value */
758 union {
759 Elf32_Addr d_ptr;
760 Elf32_Word d_val;
761 } d_un;
762} Elf32_Dyn;
763
764typedef struct {
765 Elf64_Xword d_tag; /* entry tag value */
766 union {
767 Elf64_Addr d_ptr;
768 Elf64_Xword d_val;
769 } d_un;
770} Elf64_Dyn;
771
772/* d_tag */
773#define DT_NULL 0 /* Marks end of dynamic array */
774#define DT_NEEDED 1 /* Name of needed library (DT_STRTAB offset) */
775#define DT_PLTRELSZ 2 /* Size, in bytes, of relocations in PLT */
776#define DT_PLTGOT 3 /* Address of PLT and/or GOT */
777#define DT_HASH 4 /* Address of symbol hash table */
778#define DT_STRTAB 5 /* Address of string table */
779#define DT_SYMTAB 6 /* Address of symbol table */
780#define DT_RELA 7 /* Address of Rela relocation table */
781#define DT_RELASZ 8 /* Size, in bytes, of DT_RELA table */
782#define DT_RELAENT 9 /* Size, in bytes, of one DT_RELA entry */
783#define DT_STRSZ 10 /* Size, in bytes, of DT_STRTAB table */
784#define DT_SYMENT 11 /* Size, in bytes, of one DT_SYMTAB entry */
785#define DT_INIT 12 /* Address of initialization function */
786#define DT_FINI 13 /* Address of termination function */
787#define DT_SONAME 14 /* Shared object name (DT_STRTAB offset) */
788#define DT_RPATH 15 /* Library search path (DT_STRTAB offset) */
789#define DT_SYMBOLIC 16 /* Start symbol search within local object */
790#define DT_REL 17 /* Address of Rel relocation table */
791#define DT_RELSZ 18 /* Size, in bytes, of DT_REL table */
792#define DT_RELENT 19 /* Size, in bytes, of one DT_REL entry */
793#define DT_PLTREL 20 /* Type of PLT relocation entries */
794#define DT_DEBUG 21 /* Used for debugging; unspecified */
795#define DT_TEXTREL 22 /* Relocations might modify non-writable seg */
796#define DT_JMPREL 23 /* Address of relocations associated with PLT */
797#define DT_BIND_NOW 24 /* Process all relocations at load-time */
798#define DT_INIT_ARRAY 25 /* Address of initialization function array */
799#define DT_FINI_ARRAY 26 /* Size, in bytes, of DT_INIT_ARRAY array */
800#define DT_INIT_ARRAYSZ 27 /* Address of termination function array */
801#define DT_FINI_ARRAYSZ 28 /* Size, in bytes, of DT_FINI_ARRAY array*/
802#define DT_RUNPATH 29 /* overrides DT_RPATH */
803#define DT_FLAGS 30 /* Encodes ORIGIN, SYMBOLIC, TEXTREL, BIND_NOW, STATIC_TLS */
804#define DT_ENCODING 31 /* ??? */
805#define DT_PREINIT_ARRAY 32 /* Address of pre-init function array */
806#define DT_PREINIT_ARRAYSZ 33 /* Size, in bytes, of DT_PREINIT_ARRAY array */
807#define DT_NUM 34
808
809#define DT_LOOS 0x60000000 /* Operating system specific range */
810#define DT_GNU_HASH 0x6ffffef5 /* GNU-style hash table */
811#define DT_VERSYM 0x6ffffff0 /* Symbol versions */
812#define DT_FLAGS_1 0x6ffffffb /* ELF dynamic flags */
813#define DT_VERDEF 0x6ffffffc /* Versions defined by file */
814#define DT_VERDEFNUM 0x6ffffffd /* Number of versions defined by file */
815#define DT_VERNEED 0x6ffffffe /* Versions needed by file */
816#define DT_VERNEEDNUM 0x6fffffff /* Number of versions needed by file */
817#define DT_HIOS 0x6fffffff
818#define DT_LOPROC 0x70000000 /* Processor-specific range */
819#define DT_MIPS_XHASH 0x70000036 /* MIPS version of GNU_HASH */
820#define DT_HIPROC 0x7fffffff
821
822/* Flag values for DT_FLAGS */
823#define DF_ORIGIN 0x00000001 /* uses $ORIGIN */
824#define DF_SYMBOLIC 0x00000002 /* */
825#define DF_TEXTREL 0x00000004 /* */
826#define DF_BIND_NOW 0x00000008 /* */
827#define DF_STATIC_TLS 0x00000010 /* */
828
829/* Flag values for DT_FLAGS_1 */
830#define DF_1_NOW 0x00000001 /* Same as DF_BIND_NOW */
831#define DF_1_GLOBAL 0x00000002 /* Unused */
832#define DF_1_GROUP 0x00000004 /* Is member of group */
833#define DF_1_NODELETE 0x00000008 /* Cannot be deleted from process */
834#define DF_1_LOADFLTR 0x00000010 /* Immediate loading of filters */
835#define DF_1_INITFIRST 0x00000020 /* init/fini takes priority */
836#define DF_1_NOOPEN 0x00000040 /* Do not allow loading on dlopen() */
837#define DF_1_ORIGIN 0x00000080 /* Require $ORIGIN processing */
838#define DF_1_DIRECT 0x00000100 /* Enable direct bindings */
839#define DF_1_INTERPOSE 0x00000400 /* Is an interposer */
840#define DF_1_NODEFLIB 0x00000800 /* Ignore default library search path */
841#define DF_1_NODUMP 0x00001000 /* Cannot be dumped with dldump(3C) */
842#define DF_1_CONFALT 0x00002000 /* Configuration alternative */
843#define DF_1_ENDFILTEE 0x00004000 /* Filtee ends filter's search */
844#define DF_1_DISPRELDNE 0x00008000 /* Did displacement relocation */
845#define DF_1_DISPRELPND 0x00010000 /* Pending displacement relocation */
846#define DF_1_NODIRECT 0x00020000 /* Has non-direct bindings */
847#define DF_1_IGNMULDEF 0x00040000 /* Used internally */
848#define DF_1_NOKSYMS 0x00080000 /* Used internally */
849#define DF_1_NOHDR 0x00100000 /* Used internally */
850#define DF_1_EDITED 0x00200000 /* Has been modified since build */
851#define DF_1_NORELOC 0x00400000 /* Used internally */
852#define DF_1_SYMINTPOSE 0x00800000 /* Has individual symbol interposers */
853#define DF_1_GLOBAUDIT 0x01000000 /* Require global auditing */
854#define DF_1_SINGLETON 0x02000000 /* Has singleton symbols */
855#define DF_1_STUB 0x04000000 /* Stub */
856#define DF_1_PIE 0x08000000 /* Position Independent Executable */
857
859 * Auxiliary Vectors
860 */
861typedef struct {
862 Elf32_Word a_type; /* 32-bit id */
863 Elf32_Word a_v; /* 32-bit id */
864} Aux32Info;
865
866typedef struct {
867 Elf64_Word a_type; /* 32-bit id */
868 Elf64_Xword a_v; /* 64-bit id */
869} Aux64Info;
870
871/* a_type */
872#define AT_NULL 0 /* Marks end of array */
873#define AT_IGNORE 1 /* No meaning, a_un is undefined */
874#define AT_EXECFD 2 /* Open file descriptor of object file */
875#define AT_PHDR 3 /* &phdr[0] */
876#define AT_PHENT 4 /* sizeof(phdr[0]) */
877#define AT_PHNUM 5 /* # phdr entries */
878#define AT_PAGESZ 6 /* PAGESIZE */
879#define AT_BASE 7 /* Interpreter base addr */
880#define AT_FLAGS 8 /* Processor flags */
881#define AT_ENTRY 9 /* Entry address of executable */
882#define AT_DCACHEBSIZE 10 /* Data cache block size */
883#define AT_ICACHEBSIZE 11 /* Instruction cache block size */
884#define AT_UCACHEBSIZE 12 /* Unified cache block size */
885#define AT_STACKBASE 13 /* Base address of the main thread */
886
887 /* Vendor specific */
888#define AT_MIPS_NOTELF 10 /* XXX a_val != 0 -> MIPS XCOFF executable */
889
890#define AT_EUID 2000 /* euid (solaris compatible numbers) */
891#define AT_RUID 2001 /* ruid (solaris compatible numbers) */
892#define AT_EGID 2002 /* egid (solaris compatible numbers) */
893#define AT_RGID 2003 /* rgid (solaris compatible numbers) */
894
895 /* Solaris kernel specific */
896#define AT_SUN_LDELF 2004 /* dynamic linker's ELF header */
897#define AT_SUN_LDSHDR 2005 /* dynamic linker's section header */
898#define AT_SUN_LDNAME 2006 /* dynamic linker's name */
899#define AT_SUN_LPGSIZE 2007 /* large pagesize */
900
901 /* Other information */
902#define AT_SUN_PLATFORM 2008 /* sysinfo(SI_PLATFORM) */
903#define AT_SUN_HWCAP 2009 /* process hardware capabilities */
904#define AT_SUN_IFLUSH 2010 /* do we need to flush the instruction cache? */
905#define AT_SUN_CPU 2011 /* CPU name */
906 /* ibcs2 emulation band aid */
907#define AT_SUN_EMUL_ENTRY 2012 /* coff entry point */
908#define AT_SUN_EMUL_EXECFD 2013 /* coff file descriptor */
909 /* Executable's fully resolved name */
910#define AT_SUN_EXECNAME 2014
911
913 * The header for GNU-style hash sections.
914 */
915typedef struct {
916 uint32_t gh_nbuckets; /* Number of hash buckets. */
917 uint32_t gh_symndx; /* First visible symbol in .dynsym. */
918 uint32_t gh_maskwords; /* #maskwords used in bloom filter. */
919 uint32_t gh_shift2; /* Bloom filter shift count. */
921
923 * Note Headers
924 */
925typedef struct {
926 Elf32_Word n_namesz;
927 Elf32_Word n_descsz;
928 Elf32_Word n_type;
929} Elf32_Nhdr;
930
931typedef struct {
932 Elf64_Word n_namesz;
933 Elf64_Word n_descsz;
934 Elf64_Word n_type;
935} Elf64_Nhdr;
936
937#define ELF_NOTE_GNU_NAMESZ 4
938#define ELF_NOTE_GNU_NAME "GNU\0"
939
940/*
941 * GNU-specific note type: ABI tag
942 * name: GNU\0
943 * namesz: 4
944 * desc:
945 * word[0]: OS tag
946 * word[1]: major version
947 * word[2]: minor version
948 * word[3]: teeny version
949 * descsz: 16
950 */
951/* GNU-specific note name and description sizes */
952#define ELF_NOTE_TYPE_ABI_TAG 1
953#define ELF_NOTE_ABI_NAME ELF_NOTE_GNU_NAME
954#define ELF_NOTE_ABI_NAMESZ ELF_NOTE_GNU_NAMESZ
955#define ELF_NOTE_ABI_DESCSZ 16
956/* GNU-specific OS/version value stuff */
957#define ELF_NOTE_ABI_OS_LINUX 0
958#define ELF_NOTE_ABI_OS_HURD 1
959#define ELF_NOTE_ABI_OS_SOLARIS 2
960#define ELF_NOTE_ABI_OS_KFREEBSD 3
961#define ELF_NOTE_ABI_OS_KNETBSD 4
962
963/* Old gcc style, under the ABI tag */
964#define ELF_NOTE_OGCC_NAMESZ 8
965#define ELF_NOTE_OGCC_NAME "01.01\0\0\0\0"
966#define ELF_NOTE_OGCC_DESCSZ 0
967
968/*
969 * GNU-specific note type: Hardware capabilities
970 * name: GNU\0
971 * namesz: 4
972 * desc:
973 * word[0]: Number of entries
974 * word[1]: Bitmask of enabled entries
975 * Followed by a byte id, and a NUL terminated string per entry
976 * descsz: variable
977 */
978#define ELF_NOTE_TYPE_GNU_HWCAP 2
979
980/*
981 * GNU-specific note type: Build ID generated by ld
982 * name: GNU\0
983 * desc:
984 * word[0..4] SHA1 [default]
985 * or
986 * word[0..3] md5 or uuid
987 * descsz: 16 or 20
988 */
989#define ELF_NOTE_TYPE_GNU_BUILD_ID 3
990
991/* SuSE-specific note type: ABI
992 * name: SuSE\0
993 * namesz: 5
994 * desc:
995 * half[0] = MMmm
996 *
997 * M = product major version
998 * m = product minor version
999 * descsz: 2
1000 */
1001#define ELF_NOTE_TYPE_SUSE_TAG 1
1002/* SuSE-specific note name and description sizes */
1003#define ELF_NOTE_SUSE_NAMESZ 5
1004#define ELF_NOTE_SUSE_DESCSZ 2
1005/* SuSE-specific note name */
1006#define ELF_NOTE_SUSE_NAME "SuSE\0"
1007
1008/* SuSE-specific note type: version
1009 * name: SuSE\0\0\0\0
1010 * namesz: 8
1011 * desc:
1012 * word[0] = VVTTMMmm
1013 *
1014 * V = version of following data
1015 * T = product type: [box, sles, nld, whatever]
1016 * M = product major version
1017 * m = product minor version
1018 * descsz: 8
1019 */
1020#define ELF_NOTE_TYPE_SUSE_VERSION_TAG 0x45537553 /* SuSE in LE */
1021/* SuSE-specific note name and description sizes */
1022#define ELF_NOTE_SUSE_VERSION_NAMESZ 8
1023#define ELF_NOTE_SUSE_VERSION_DESCSZ 8
1024/* SuSE-specific note name */
1025#define ELF_NOTE_SUSE_VERSION_NAME "SuSE\0\0\0\0"
1026
1027/* Go-specific note type: buildid
1028 * name: Go\0\0
1029 * namesz: 4
1030 * desc:
1031 * words[10]
1032 * descsz: 40
1033 */
1034#define ELF_NOTE_TYPE_GO_BUILDID_TAG 4
1035#define ELF_NOTE_GO_BUILDID_NAMESZ 4
1036#define ELF_NOTE_GO_BUILDID_DESCSZ 40
1037#define ELF_NOTE_GO_BUILDID_NAME "Go\0\0"
1038
1039/* NetBSD-specific note type: NetBSD ABI version.
1040 * name: NetBSD\0\0
1041 * namesz: 8
1042 * desc:
1043 * word[0]: MMmmrrpp00
1044 *
1045 * M = major version
1046 * m = minor version
1047 * r = release ["",A-Z,Z[A-Z] but numeric]
1048 * p = patchlevel
1049 * descsz: 4
1050 */
1051#define ELF_NOTE_TYPE_NETBSD_TAG 1
1052/* NetBSD-specific note name and description sizes */
1053#define ELF_NOTE_NETBSD_NAMESZ 7
1054#define ELF_NOTE_NETBSD_DESCSZ 4
1055/* NetBSD-specific note name */
1056#define ELF_NOTE_NETBSD_NAME "NetBSD\0\0"
1057
1058/* NetBSD-specific note type: Emulation (obsolete; last used early 2000)
1059 * name: NetBSD\0\0
1060 * namesz: 8
1061 * desc:
1062 * "netbsd\0"
1063 *
1064 * descsz: 8
1065 */
1066#define ELF_NOTE_TYPE_NETBSD_EMUL_TAG 2
1067#define ELF_NOTE_NETBSD_EMUL_NAMESZ 7
1068#define ELF_NOTE_NETBSD_EMUL_DESCSZ 7
1069/* NetBSD-specific note name */
1070#define ELF_NOTE_NETBSD_EMUL_NAME "NetBSD\0\0"
1071
1072/*
1073 * NetBSD-specific note type: PaX.
1074 * There should be 1 NOTE per executable.
1075 * name: PaX\0
1076 * namesz: 4
1077 * desc:
1078 * word[0]: capability bitmask
1079 * descsz: 4
1080 */
1081#define ELF_NOTE_TYPE_PAX_TAG 3
1082#define ELF_NOTE_PAX_MPROTECT 0x01 /* Force enable Mprotect */
1083#define ELF_NOTE_PAX_NOMPROTECT 0x02 /* Force disable Mprotect */
1084#define ELF_NOTE_PAX_GUARD 0x04 /* Force enable Segvguard */
1085#define ELF_NOTE_PAX_NOGUARD 0x08 /* Force disable Servguard */
1086#define ELF_NOTE_PAX_ASLR 0x10 /* Force enable ASLR */
1087#define ELF_NOTE_PAX_NOASLR 0x20 /* Force disable ASLR */
1088#define ELF_NOTE_PAX_NAMESZ 4
1089#define ELF_NOTE_PAX_NAME "PaX\0"
1090#define ELF_NOTE_PAX_DESCSZ 4
1091
1092/*
1093 * NetBSD-specific core file information.
1094 *
1095 * NetBSD ELF core files use notes to provide information about
1096 * the process's state. The note name is "NetBSD-CORE" for
1097 * information that is global to the process, and "NetBSD-CORE@nn",
1098 * where "nn" is the lwpid of the LWP that the information belongs
1099 * to (such as register state).
1100 *
1101 * We use the following note identifiers:
1102 *
1103 * ELF_NOTE_NETBSD_CORE_PROCINFO
1104 * Note is a "netbsd_elfcore_procinfo" structure.
1105 * ELF_NOTE_NETBSD_CORE_AUXV
1106 * Note is an array of AuxInfo structures.
1107 *
1108 * We also use ptrace(2) request numbers (the ones that exist in
1109 * machine-dependent space) to identify register info notes. The
1110 * info in such notes is in the same format that ptrace(2) would
1111 * export that information.
1112 *
1113 * Please try to keep the members of this structure nicely aligned,
1114 * and if you add elements, add them to the end and bump the version.
1115 */
1116
1117#define ELF_NOTE_NETBSD_CORE_NAME "NetBSD-CORE"
1118
1119#define ELF_NOTE_NETBSD_CORE_PROCINFO 1
1120#define ELF_NOTE_NETBSD_CORE_AUXV 2
1122#define NETBSD_ELFCORE_PROCINFO_VERSION 1
1123
1125 /* Version 1 fields start here. */
1126 uint32_t cpi_version; /* netbsd_elfcore_procinfo version */
1127 uint32_t cpi_cpisize; /* sizeof(netbsd_elfcore_procinfo) */
1128 uint32_t cpi_signo; /* killing signal */
1129 uint32_t cpi_sigcode; /* signal code */
1130 uint32_t cpi_sigpend[4]; /* pending signals */
1131 uint32_t cpi_sigmask[4]; /* blocked signals */
1132 uint32_t cpi_sigignore[4];/* ignored signals */
1133 uint32_t cpi_sigcatch[4];/* caught signals */
1134 int32_t cpi_pid; /* process ID */
1135 int32_t cpi_ppid; /* parent process ID */
1136 int32_t cpi_pgrp; /* process group ID */
1137 int32_t cpi_sid; /* session ID */
1138 uint32_t cpi_ruid; /* real user ID */
1139 uint32_t cpi_euid; /* effective user ID */
1140 uint32_t cpi_svuid; /* saved user ID */
1141 uint32_t cpi_rgid; /* real group ID */
1142 uint32_t cpi_egid; /* effective group ID */
1143 uint32_t cpi_svgid; /* saved group ID */
1144 uint32_t cpi_nlwps; /* number of LWPs */
1145 int8_t cpi_name[32]; /* copy of p->p_comm */
1146 /* Add version 2 fields below here. */
1147 int32_t cpi_siglwp; /* LWP target of killing signal */
1148};
1149
1150/*
1151 * NetBSD-specific note type: MACHINE_ARCH.
1152 * There should be 1 NOTE per executable.
1153 * name: NetBSD\0
1154 * namesz: 7
1155 * desc: string
1156 * descsz: variable
1157 */
1158#define ELF_NOTE_TYPE_MARCH_TAG 5
1159/* NetBSD-specific note name and description sizes */
1160#define ELF_NOTE_MARCH_NAMESZ ELF_NOTE_NETBSD_NAMESZ
1161/* NetBSD-specific note name */
1162#define ELF_NOTE_MARCH_NAME ELF_NOTE_NETBSD_NAME
1163
1164/*
1165 * NetBSD-specific note type: MCMODEL
1166 * There should be 1 NOTE per executable.
1167 * name: NetBSD\0
1168 * namesz: 7
1169 * code model: string
1170 */
1171
1172#define ELF_NOTE_TYPE_MCMODEL_TAG 6
1173/* NetBSD-specific note name and description sizes */
1174#define ELF_NOTE_MCMODEL_NAMESZ ELF_NOTE_NETBSD_NAMESZ
1175/* NetBSD-specific note name */
1176#define ELF_NOTE_MCMODEL_NAME ELF_NOTE_NETBSD_NAME
1177
1178
1179#if !defined(ELFSIZE)
1180# if defined(_RUMPKERNEL) || !defined(_KERNEL)
1181# define ELFSIZE ARCH_ELFSIZE
1182# else
1183# define ELFSIZE KERN_ELFSIZE
1184# endif
1185#endif
1186
1187#if defined(ELFSIZE)
1188#define CONCAT(x,y) __CONCAT(x,y)
1189#define ELFNAME(x) CONCAT(elf,CONCAT(ELFSIZE,CONCAT(_,x)))
1190#define ELFNAME2(x,y) CONCAT(x,CONCAT(_elf,CONCAT(ELFSIZE,CONCAT(_,y))))
1191#define ELFNAMEEND(x) CONCAT(x,CONCAT(_elf,ELFSIZE))
1192#define ELFDEFNNAME(x) CONCAT(ELF,CONCAT(ELFSIZE,CONCAT(_,x)))
1193#define ElfW(x) CONCAT(Elf,CONCAT(ELFSIZE,CONCAT(_,x)))
1194#endif
1195
1196#if defined(ELFSIZE) && (ELFSIZE == 32)
1197#define Elf_Ehdr Elf32_Ehdr
1198#define Elf_Phdr Elf32_Phdr
1199#define Elf_Shdr Elf32_Shdr
1200#define Elf_Sym Elf32_Sym
1201#define Elf_Rel Elf32_Rel
1202#define Elf_Rela Elf32_Rela
1203#define Elf_Dyn Elf32_Dyn
1204#define Elf_Word Elf32_Word
1205#define Elf_Sword Elf32_Sword
1206#define Elf_Half Elf32_Half
1207#define Elf_Addr Elf32_Addr
1208#define Elf_Off Elf32_Off
1209#define Elf_SOff Elf32_SOff
1210#define Elf_Nhdr Elf32_Nhdr
1211#define Elf_Verdef Elf32_Verdef
1212#define Elf_Verdaux Elf32_Verdaux
1213#define Elf_Verneed Elf32_Verneed
1214#define Elf_Vernaux Elf32_Vernaux
1215#define Elf_Versym Elf32_Versym
1216
1217#define ELF_R_SYM ELF32_R_SYM
1218#define ELF_R_TYPE ELF32_R_TYPE
1219#define ELFCLASS ELFCLASS32
1220
1221#define AuxInfo Aux32Info
1222#elif defined(ELFSIZE) && (ELFSIZE == 64)
1223#define Elf_Ehdr Elf64_Ehdr
1224#define Elf_Phdr Elf64_Phdr
1225#define Elf_Shdr Elf64_Shdr
1226#define Elf_Sym Elf64_Sym
1227#define Elf_Rel Elf64_Rel
1228#define Elf_Rela Elf64_Rela
1229#define Elf_Dyn Elf64_Dyn
1230#define Elf_Word Elf64_Word
1231#define Elf_Sword Elf64_Sword
1232#define Elf_Half Elf64_Half
1233#define Elf_Addr Elf64_Addr
1234#define Elf_Off Elf64_Off
1235#define Elf_SOff Elf64_SOff
1236#define Elf_Nhdr Elf64_Nhdr
1237#define Elf_Verdef Elf64_Verdef
1238#define Elf_Verdaux Elf64_Verdaux
1239#define Elf_Verneed Elf64_Verneed
1240#define Elf_Vernaux Elf64_Vernaux
1241#define Elf_Versym Elf64_Versym
1242
1243#define ELF_R_SYM ELF64_R_SYM
1244#define ELF_R_TYPE ELF64_R_TYPE
1245#define ELFCLASS ELFCLASS64
1246
1247#define AuxInfo Aux64Info
1248#endif
1249
1250#ifndef Elf_Symindx
1251#define Elf_Symindx uint32_t
1252#endif
1253
1254#define ELF32_ST_BIND(info) ELF_ST_BIND(info)
1255#define ELF32_ST_TYPE(info) ELF_ST_TYPE(info)
1256#define ELF32_ST_INFO(bind,type) ELF_ST_INFO(bind,type)
1257#define ELF32_ST_VISIBILITY(other) ELF_ST_VISIBILITY(other)
1258
1259#define ELF64_ST_BIND(info) ELF_ST_BIND(info)
1260#define ELF64_ST_TYPE(info) ELF_ST_TYPE(info)
1261#define ELF64_ST_INFO(bind,type) ELF_ST_INFO(bind,type)
1262#define ELF64_ST_VISIBILITY(other) ELF_ST_VISIBILITY(other)
1263
1264typedef struct {
1265 Elf32_Half si_boundto; /* direct bindings - symbol bound to */
1266 Elf32_Half si_flags; /* per symbol flags */
1268
1269typedef struct {
1270 Elf64_Word si_boundto; /* direct bindings - symbol bound to */
1271 Elf64_Word si_flags; /* per symbol flags */
1273
1274#define SYMINFO_FLG_DIRECT 0x0001 /* symbol ref has direct association
1275 to object containing definition */
1276#define SYMINFO_FLG_PASSTHRU 0x0002 /* ignored - see SYMINFO_FLG_FILTER */
1277#define SYMINFO_FLG_COPY 0x0004 /* symbol is a copy-reloc */
1278#define SYMINFO_FLG_LAZYLOAD 0x0008 /* object containing defn should be
1279 lazily-loaded */
1280#define SYMINFO_FLG_DIRECTBIND 0x0010 /* ref should be bound directly to
1281 object containing definition */
1282#define SYMINFO_FLG_NOEXTDIRECT 0x0020 /* don't let an external reference
1283 directly bind to this symbol */
1284#define SYMINFO_FLG_FILTER 0x0002 /* symbol ref is associated to a */
1285#define SYMINFO_FLG_AUXILIARY 0x0040 /* standard or auxiliary filter */
1286
1287#define SYMINFO_BT_SELF 0xffff /* symbol bound to self */
1288#define SYMINFO_BT_PARENT 0xfffe /* symbol bound to parent */
1289#define SYMINFO_BT_NONE 0xfffd /* no special symbol binding */
1290#define SYMINFO_BT_EXTERN 0xfffc /* symbol defined as external */
1291#define SYMINFO_BT_LOWRESERVE 0xff00 /* beginning of reserved entries */
1292
1293#define SYMINFO_NONE 0 /* Syminfo version */
1294#define SYMINFO_CURRENT 1
1295#define SYMINFO_NUM 2
1296
1297/*
1298 * These constants are used for Elf32_Verdef struct's version number.
1299 */
1300#define VER_DEF_NONE 0
1301#define VER_DEF_CURRENT 1
1302
1303/*
1304 * These constants are used for Elf32_Verdef struct's vd_ndx.
1305 */
1306#define VER_DEF_IDX(x) VER_NDX(x)
1307
1308/*
1309 * These constants are used for Elf32_Verdef struct's vd_flags.
1310 */
1311#define VER_FLG_BASE 0x1
1312#define VER_FLG_WEAK 0x2
1313
1314/*
1315 * These are used in an Elf32_Versym field.
1316 */
1317#define VER_NDX_LOCAL 0
1318#define VER_NDX_GLOBAL 1
1319#define VER_NDX_GIVEN 2
1320
1321/*
1322 * These constants are used for Elf32_Verneed struct's version number.
1323 */
1324#define VER_NEED_NONE 0
1325#define VER_NEED_CURRENT 1
1326
1327/*
1328 * These constants are used for Elf32_Vernaux struct's vna_other.
1329 */
1330#define VER_NEED_HIDDEN VER_NDX_HIDDEN
1331#define VER_NEED_IDX(x) VER_NDX(x)
1332
1333/* index */
1334#define VER_NDX_HIDDEN 0x8000
1335#define VER_NDX(x) ((x) & ~VER_NDX_HIDDEN)
1336
1337/*
1338 * GNU Extension hidding symbol
1339 */
1340#define VERSYM_HIDDEN 0x8000
1341#define VERSYM_VERSION 0x7fff
1343#define ELF_VER_CHR '@'
1344
1345/*
1346 * These are current size independent.
1347 */
1348
1349typedef struct {
1350 Elf32_Half vd_version; /* version number of structure */
1351 Elf32_Half vd_flags; /* flags (VER_FLG_*) */
1352 Elf32_Half vd_ndx; /* version index */
1353 Elf32_Half vd_cnt; /* number of verdaux entries */
1354 Elf32_Word vd_hash; /* hash of name */
1355 Elf32_Word vd_aux; /* offset to verdaux entries */
1356 Elf32_Word vd_next; /* offset to next verdef */
1357} Elf32_Verdef;
1360typedef struct {
1361 Elf32_Word vda_name; /* string table offset of name */
1362 Elf32_Word vda_next; /* offset to verdaux */
1365
1366typedef struct {
1367 Elf32_Half vn_version; /* version number of structure */
1368 Elf32_Half vn_cnt; /* number of vernaux entries */
1369 Elf32_Word vn_file; /* string table offset of library name*/
1370 Elf32_Word vn_aux; /* offset to vernaux entries */
1371 Elf32_Word vn_next; /* offset to next verneed */
1374
1375typedef struct {
1376 Elf32_Word vna_hash; /* Hash of dependency name */
1377 Elf32_Half vna_flags; /* flags (VER_FLG_*) */
1378 Elf32_Half vna_other; /* unused */
1379 Elf32_Word vna_name; /* string table offset to version name*/
1380 Elf32_Word vna_next; /* offset to next vernaux */
1383
1384typedef struct {
1385 Elf32_Half vs_vers;
1386} Elf32_Versym;
1388
1389#ifdef _KERNEL
1390
1391/*
1392 * Arbitrary limits to avoid DoS for excessive memory allocation.
1393 */
1394#define ELF_MAXPHNUM 128
1395#define ELF_MAXSHNUM 32768
1396#define ELF_MAXNOTESIZE 1024
1397
1398#define ELF_AUX_ENTRIES 15 /* Max size of aux array passed to loader */
1399#define ELF32_NO_ADDR (~(Elf32_Addr)0) /* Indicates addr. not yet filled in */
1400#define ELF32_LINK_ADDR ((Elf32_Addr)-2) /* advises to use link address */
1401#define ELF64_NO_ADDR (~(Elf64_Addr)0) /* Indicates addr. not yet filled in */
1402#define ELF64_LINK_ADDR ((Elf64_Addr)-2) /* advises to use link address */
1403
1404#if defined(ELFSIZE) && (ELFSIZE == 64)
1405#define ELF_NO_ADDR ELF64_NO_ADDR
1406#define ELF_LINK_ADDR ELF64_LINK_ADDR
1407#elif defined(ELFSIZE) && (ELFSIZE == 32)
1408#define ELF_NO_ADDR ELF32_NO_ADDR
1409#define ELF_LINK_ADDR ELF32_LINK_ADDR
1410#endif
1411
1412#ifndef ELF32_EHDR_FLAGS_OK
1413#define ELF32_EHDR_FLAGS_OK(eh) 1
1414#endif
1415
1416#ifndef ELF64_EHDR_FLAGS_OK
1417#define ELF64_EHDR_FLAGS_OK(eh) 1
1418#endif
1419
1420#if defined(ELFSIZE) && (ELFSIZE == 64)
1421#define ELF_EHDR_FLAGS_OK(eh) ELF64_EHDR_FLAGS_OK(eh)
1422#else
1423#define ELF_EHDR_FLAGS_OK(eh) ELF32_EHDR_FLAGS_OK(eh)
1424#endif
1425
1426#if defined(ELFSIZE)
1427struct elf_args {
1428 Elf_Addr arg_entry; /* program entry point */
1429 Elf_Addr arg_interp; /* Interpreter load address */
1430 Elf_Addr arg_phaddr; /* program header address */
1431 Elf_Addr arg_phentsize; /* Size of program header */
1432 Elf_Addr arg_phnum; /* Number of program headers */
1433};
1434#endif
1435
1436#ifdef _KERNEL_OPT
1437#include "opt_execfmt.h"
1438#endif
1439
1440struct ps_strings;
1441struct coredump_iostate;
1442struct note_state;
1443struct exec_package;
1444
1445#ifdef EXEC_ELF32
1446int exec_elf32_makecmds(struct lwp *, struct exec_package *);
1447int elf32_populate_auxv(struct lwp *, struct exec_package *, char **);
1448int elf32_copyargs(struct lwp *, struct exec_package *,
1449 struct ps_strings *, char **, void *);
1450
1451int elf32_check_header(Elf32_Ehdr *);
1452#endif
1453
1454int real_coredump_elf32(struct lwp *, struct coredump_iostate *);
1455int coredump_elf32(struct lwp *, struct coredump_iostate *);
1456void coredump_savenote_elf32(struct note_state *, unsigned int,
1457 const char *, void *, size_t);
1458
1459
1460#ifdef EXEC_ELF64
1461int exec_elf64_makecmds(struct lwp *, struct exec_package *);
1462int elf64_populate_auxv(struct lwp *, struct exec_package *, char **);
1463int elf64_copyargs(struct lwp *, struct exec_package *,
1464 struct ps_strings *, char **, void *);
1465
1466int elf64_check_header(Elf64_Ehdr *);
1467#endif
1468
1469int real_coredump_elf64(struct lwp *, struct coredump_iostate *);
1470int coredump_elf64(struct lwp *, struct coredump_iostate *);
1471void coredump_savenote_elf64(struct note_state *, unsigned int,
1472 const char *, void *, size_t);
1473
1474
1475#endif /* _KERNEL */
1476
1477#endif /* !_SYS_EXEC_ELF_H_ */
Provide printf() PRIxxx Constante Beyond Standards.
Definition: exec_elf.h:858
Definition: exec_elf.h:863
Definition: exec_elf.h:734
Definition: exec_elf.h:753
Definition: exec_elf.h:105
Definition: exec_elf.h:707
Definition: exec_elf.h:922
Definition: exec_elf.h:422
Definition: exec_elf.h:672
Definition: exec_elf.h:677
Definition: exec_elf.h:483
Definition: exec_elf.h:582
Definition: exec_elf.h:1261
Definition: exec_elf.h:1353
Definition: exec_elf.h:1342
Definition: exec_elf.h:1368
Definition: exec_elf.h:1359
Definition: exec_elf.h:1377
Definition: exec_elf.h:742
Definition: exec_elf.h:761
Definition: exec_elf.h:122
Definition: exec_elf.h:719
Definition: exec_elf.h:928
Definition: exec_elf.h:433
Definition: exec_elf.h:688
Definition: exec_elf.h:693
Definition: exec_elf.h:496
Definition: exec_elf.h:591
Definition: exec_elf.h:1266
Definition: exec_elf.h:912
Definition: exec_elf.h:1121
