RTEMS 6.1-rc2
efierr.h
1/* $FreeBSD$ */
2#ifndef _EFI_ERR_H
3#define _EFI_ERR_H
4
5/*++
6
7Copyright (c) 1999 - 2002 Intel Corporation. All rights reserved
8This software and associated documentation (if any) is furnished
9under a license and may only be used or copied in accordance
10with the terms of the license. Except as permitted by such
11license, no part of this software or documentation may be
12reproduced, stored in a retrieval system, or transmitted in any
13form or by any means without the express written consent of
14Intel Corporation.
15
16Module Name:
17
18 efierr.h
19
20Abstract:
21
22 EFI error codes
23
24
25
26
27Revision History
28
29--*/
30
31
32#define EFIWARN(a) (a)
33#define EFI_ERROR(a) (((INTN) a) < 0)
34#define EFI_ERROR_CODE(a) (unsigned long)(a & ~EFI_ERROR_MASK)
35
36
37#define EFI_SUCCESS 0
38#define EFI_LOAD_ERROR EFIERR(1)
39#define EFI_INVALID_PARAMETER EFIERR(2)
40#define EFI_UNSUPPORTED EFIERR(3)
41#define EFI_BAD_BUFFER_SIZE EFIERR(4)
42#define EFI_BUFFER_TOO_SMALL EFIERR(5)
43#define EFI_NOT_READY EFIERR(6)
44#define EFI_DEVICE_ERROR EFIERR(7)
45#define EFI_WRITE_PROTECTED EFIERR(8)
46#define EFI_OUT_OF_RESOURCES EFIERR(9)
47#define EFI_VOLUME_CORRUPTED EFIERR(10)
48#define EFI_VOLUME_FULL EFIERR(11)
49#define EFI_NO_MEDIA EFIERR(12)
50#define EFI_MEDIA_CHANGED EFIERR(13)
51#define EFI_NOT_FOUND EFIERR(14)
52#define EFI_ACCESS_DENIED EFIERR(15)
53#define EFI_NO_RESPONSE EFIERR(16)
54#define EFI_NO_MAPPING EFIERR(17)
55#define EFI_TIMEOUT EFIERR(18)
56#define EFI_NOT_STARTED EFIERR(19)
57#define EFI_ALREADY_STARTED EFIERR(20)
58#define EFI_ABORTED EFIERR(21)
59#define EFI_ICMP_ERROR EFIERR(22)
60#define EFI_TFTP_ERROR EFIERR(23)
61#define EFI_PROTOCOL_ERROR EFIERR(24)
62
63#define EFI_WARN_UNKNOWN_GLYPH EFIWARN(1)
64#define EFI_WARN_DELETE_FAILURE EFIWARN(2)
65#define EFI_WARN_WRITE_FAILURE EFIWARN(3)
66#define EFI_WARN_BUFFER_TOO_SMALL EFIWARN(4)
67
68#endif
