RTEMS 6.1-rc2
eficon.h
1/* $FreeBSD$ */
2#ifndef _EFI_CON_H
3#define _EFI_CON_H
4
5/*++
6
7Copyright (c) 1999 - 2002 Intel Corporation. All rights reserved
8This software and associated documentation (if any) is furnished
9under a license and may only be used or copied in accordance
10with the terms of the license. Except as permitted by such
11license, no part of this software or documentation may be
12reproduced, stored in a retrieval system, or transmitted in any
13form or by any means without the express written consent of
14Intel Corporation.
15
16Module Name:
17
18 eficon.h
19
20Abstract:
21
22 EFI console protocols
23
24
25
26Revision History
27
28--*/
29
30//
31// Text output protocol
32//
33
34#define SIMPLE_TEXT_OUTPUT_PROTOCOL \
35 { 0x387477c2, 0x69c7, 0x11d2, {0x8e, 0x39, 0x0, 0xa0, 0xc9, 0x69, 0x72, 0x3b} }
36
37INTERFACE_DECL(_SIMPLE_TEXT_OUTPUT_INTERFACE);
38
39typedef
40EFI_STATUS
41(EFIAPI *EFI_TEXT_RESET) (
42 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
43 IN BOOLEAN ExtendedVerification
44 );
45
46typedef
47EFI_STATUS
48(EFIAPI *EFI_TEXT_OUTPUT_STRING) (
49 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
50 IN CHAR16 *String
51 );
52
53typedef
54EFI_STATUS
55(EFIAPI *EFI_TEXT_TEST_STRING) (
56 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
57 IN CHAR16 *String
58 );
59
60typedef
61EFI_STATUS
62(EFIAPI *EFI_TEXT_QUERY_MODE) (
63 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
64 IN UINTN ModeNumber,
65 OUT UINTN *Columns,
66 OUT UINTN *Rows
67 );
68
69typedef
70EFI_STATUS
71(EFIAPI *EFI_TEXT_SET_MODE) (
72 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
73 IN UINTN ModeNumber
74 );
75
76typedef
77EFI_STATUS
78(EFIAPI *EFI_TEXT_SET_ATTRIBUTE) (
79 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
80 IN UINTN Attribute
81 );
82
83#define EFI_BLACK 0x00
84#define EFI_BLUE 0x01
85#define EFI_GREEN 0x02
86#define EFI_CYAN (EFI_BLUE | EFI_GREEN)
87#define EFI_RED 0x04
88#define EFI_MAGENTA (EFI_BLUE | EFI_RED)
89#define EFI_BROWN (EFI_GREEN | EFI_RED)
90#define EFI_LIGHTGRAY (EFI_BLUE | EFI_GREEN | EFI_RED)
91#define EFI_BRIGHT 0x08
92#define EFI_DARKGRAY (EFI_BRIGHT)
93#define EFI_LIGHTBLUE (EFI_BLUE | EFI_BRIGHT)
94#define EFI_LIGHTGREEN (EFI_GREEN | EFI_BRIGHT)
95#define EFI_LIGHTCYAN (EFI_CYAN | EFI_BRIGHT)
96#define EFI_LIGHTRED (EFI_RED | EFI_BRIGHT)
97#define EFI_LIGHTMAGENTA (EFI_MAGENTA | EFI_BRIGHT)
98#define EFI_YELLOW (EFI_BROWN | EFI_BRIGHT)
99#define EFI_WHITE (EFI_BLUE | EFI_GREEN | EFI_RED | EFI_BRIGHT)
100
101#define EFI_TEXT_ATTR(f,b) ((f) | ((b) << 4))
102
103#define EFI_BACKGROUND_BLACK 0x00
104#define EFI_BACKGROUND_BLUE 0x10
105#define EFI_BACKGROUND_GREEN 0x20
106#define EFI_BACKGROUND_CYAN (EFI_BACKGROUND_BLUE | EFI_BACKGROUND_GREEN)
107#define EFI_BACKGROUND_RED 0x40
108#define EFI_BACKGROUND_MAGENTA (EFI_BACKGROUND_BLUE | EFI_BACKGROUND_RED)
109#define EFI_BACKGROUND_BROWN (EFI_BACKGROUND_GREEN | EFI_BACKGROUND_RED)
110#define EFI_BACKGROUND_LIGHTGRAY (EFI_BACKGROUND_BLUE | EFI_BACKGROUND_GREEN | EFI_BACKGROUND_RED)
111
112
113typedef
114EFI_STATUS
115(EFIAPI *EFI_TEXT_CLEAR_SCREEN) (
116 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This
117 );
118
119typedef
120EFI_STATUS
121(EFIAPI *EFI_TEXT_SET_CURSOR_POSITION) (
122 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
123 IN UINTN Column,
124 IN UINTN Row
125 );
126
127typedef
128EFI_STATUS
129(EFIAPI *EFI_TEXT_ENABLE_CURSOR) (
130 IN struct _SIMPLE_TEXT_OUTPUT_INTERFACE *This,
131 IN BOOLEAN Enable
132 );
133
134typedef struct {
135 INT32 MaxMode;
136 // current settings
137 INT32 Mode;
138 INT32 Attribute;
139 INT32 CursorColumn;
140 INT32 CursorRow;
141 BOOLEAN CursorVisible;
143
145 EFI_TEXT_RESET Reset;
146
147 EFI_TEXT_OUTPUT_STRING OutputString;
148 EFI_TEXT_TEST_STRING TestString;
149
150 EFI_TEXT_QUERY_MODE QueryMode;
151 EFI_TEXT_SET_MODE SetMode;
152 EFI_TEXT_SET_ATTRIBUTE SetAttribute;
153
154 EFI_TEXT_CLEAR_SCREEN ClearScreen;
155 EFI_TEXT_SET_CURSOR_POSITION SetCursorPosition;
156 EFI_TEXT_ENABLE_CURSOR EnableCursor;
157
158 // Current mode
161
162//
163// Define's for required EFI Unicode Box Draw character
164//
165
166#define BOXDRAW_HORIZONTAL 0x2500
167#define BOXDRAW_VERTICAL 0x2502
168#define BOXDRAW_DOWN_RIGHT 0x250c
169#define BOXDRAW_DOWN_LEFT 0x2510
170#define BOXDRAW_UP_RIGHT 0x2514
171#define BOXDRAW_UP_LEFT 0x2518
172#define BOXDRAW_VERTICAL_RIGHT 0x251c
173#define BOXDRAW_VERTICAL_LEFT 0x2524
174#define BOXDRAW_DOWN_HORIZONTAL 0x252c
175#define BOXDRAW_UP_HORIZONTAL 0x2534
176#define BOXDRAW_VERTICAL_HORIZONTAL 0x253c
177
178#define BOXDRAW_DOUBLE_HORIZONTAL 0x2550
179#define BOXDRAW_DOUBLE_VERTICAL 0x2551
180#define BOXDRAW_DOWN_RIGHT_DOUBLE 0x2552
181#define BOXDRAW_DOWN_DOUBLE_RIGHT 0x2553
182#define BOXDRAW_DOUBLE_DOWN_RIGHT 0x2554
183
184#define BOXDRAW_DOWN_LEFT_DOUBLE 0x2555
185#define BOXDRAW_DOWN_DOUBLE_LEFT 0x2556
186#define BOXDRAW_DOUBLE_DOWN_LEFT 0x2557
187
188#define BOXDRAW_UP_RIGHT_DOUBLE 0x2558
189#define BOXDRAW_UP_DOUBLE_RIGHT 0x2559
190#define BOXDRAW_DOUBLE_UP_RIGHT 0x255a
191
192#define BOXDRAW_UP_LEFT_DOUBLE 0x255b
193#define BOXDRAW_UP_DOUBLE_LEFT 0x255c
194#define BOXDRAW_DOUBLE_UP_LEFT 0x255d
195
196#define BOXDRAW_VERTICAL_RIGHT_DOUBLE 0x255e
197#define BOXDRAW_VERTICAL_DOUBLE_RIGHT 0x255f
198#define BOXDRAW_DOUBLE_VERTICAL_RIGHT 0x2560
199
200#define BOXDRAW_VERTICAL_LEFT_DOUBLE 0x2561
201#define BOXDRAW_VERTICAL_DOUBLE_LEFT 0x2562
202#define BOXDRAW_DOUBLE_VERTICAL_LEFT 0x2563
203
204#define BOXDRAW_DOWN_HORIZONTAL_DOUBLE 0x2564
205#define BOXDRAW_DOWN_DOUBLE_HORIZONTAL 0x2565
206#define BOXDRAW_DOUBLE_DOWN_HORIZONTAL 0x2566
207
208#define BOXDRAW_UP_HORIZONTAL_DOUBLE 0x2567
209#define BOXDRAW_UP_DOUBLE_HORIZONTAL 0x2568
210#define BOXDRAW_DOUBLE_UP_HORIZONTAL 0x2569
211
212#define BOXDRAW_VERTICAL_HORIZONTAL_DOUBLE 0x256a
213#define BOXDRAW_VERTICAL_DOUBLE_HORIZONTAL 0x256b
214#define BOXDRAW_DOUBLE_VERTICAL_HORIZONTAL 0x256c
215
216//
217// EFI Required Block Elements Code Chart
218//
219
220#define BLOCKELEMENT_FULL_BLOCK 0x2588
221#define BLOCKELEMENT_LIGHT_SHADE 0x2591
222//
223// EFI Required Geometric Shapes Code Chart
224//
225
226#define GEOMETRICSHAPE_UP_TRIANGLE 0x25b2
227#define GEOMETRICSHAPE_RIGHT_TRIANGLE 0x25ba
228#define GEOMETRICSHAPE_DOWN_TRIANGLE 0x25bc
229#define GEOMETRICSHAPE_LEFT_TRIANGLE 0x25c4
230
231//
232// EFI Required Arrow shapes
233//
234
235#define ARROW_UP 0x2191
236#define ARROW_DOWN 0x2193
237
238//
239// Text input protocol
240//
241
242#define SIMPLE_TEXT_INPUT_PROTOCOL \
243 { 0x387477c1, 0x69c7, 0x11d2, {0x8e, 0x39, 0x0, 0xa0, 0xc9, 0x69, 0x72, 0x3b} }
244
245INTERFACE_DECL(_SIMPLE_INPUT_INTERFACE);
246
247typedef struct {
248 UINT16 ScanCode;
249 CHAR16 UnicodeChar;
251
252//
253// Baseline unicode control chars
254//
255
256#define CHAR_NULL 0x0000
257#define CHAR_BACKSPACE 0x0008
258#define CHAR_TAB 0x0009
259#define CHAR_LINEFEED 0x000A
260#define CHAR_CARRIAGE_RETURN 0x000D
261
262//
263// Scan codes for base line keys
264//
265
266#define SCAN_NULL 0x0000
267#define SCAN_UP 0x0001
268#define SCAN_DOWN 0x0002
269#define SCAN_RIGHT 0x0003
270#define SCAN_LEFT 0x0004
271#define SCAN_HOME 0x0005
272#define SCAN_END 0x0006
273#define SCAN_INSERT 0x0007
274#define SCAN_DELETE 0x0008
275#define SCAN_PAGE_UP 0x0009
276#define SCAN_PAGE_DOWN 0x000A
277#define SCAN_F1 0x000B
278#define SCAN_F2 0x000C
279#define SCAN_F3 0x000D
280#define SCAN_F4 0x000E
281#define SCAN_F5 0x000F
282#define SCAN_F6 0x0010
283#define SCAN_F7 0x0011
284#define SCAN_F8 0x0012
285#define SCAN_F9 0x0013
286#define SCAN_F10 0x0014
287#define SCAN_ESC 0x0017
288
289//
290// EFI Scan code Ex
291//
292#define SCAN_F11 0x0015
293#define SCAN_F12 0x0016
294#define SCAN_F13 0x0068
295#define SCAN_F14 0x0069
296#define SCAN_F15 0x006A
297#define SCAN_F16 0x006B
298#define SCAN_F17 0x006C
299#define SCAN_F18 0x006D
300#define SCAN_F19 0x006E
301#define SCAN_F20 0x006F
302#define SCAN_F21 0x0070
303#define SCAN_F22 0x0071
304#define SCAN_F23 0x0072
305#define SCAN_F24 0x0073
306#define SCAN_MUTE 0x007F
307#define SCAN_VOLUME_UP 0x0080
308#define SCAN_VOLUME_DOWN 0x0081
309#define SCAN_BRIGHTNESS_UP 0x0100
310#define SCAN_BRIGHTNESS_DOWN 0x0101
311#define SCAN_SUSPEND 0x0102
312#define SCAN_HIBERNATE 0x0103
313#define SCAN_TOGGLE_DISPLAY 0x0104
314#define SCAN_RECOVERY 0x0105
315#define SCAN_EJECT 0x0106
316
317typedef
318EFI_STATUS
319(EFIAPI *EFI_INPUT_RESET) (
320 IN struct _SIMPLE_INPUT_INTERFACE *This,
321 IN BOOLEAN ExtendedVerification
322 );
323
324typedef
325EFI_STATUS
326(EFIAPI *EFI_INPUT_READ_KEY) (
327 IN struct _SIMPLE_INPUT_INTERFACE *This,
328 OUT EFI_INPUT_KEY *Key
329 );
330
332 EFI_INPUT_RESET Reset;
333 EFI_INPUT_READ_KEY ReadKeyStroke;
334 EFI_EVENT WaitForKey;
336
337#define EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL_GUID \
338 {0xdd9e7534, 0x7762, 0x4698, {0x8c, 0x14, 0xf5, 0x85, \
339 0x17, 0xa6, 0x25, 0xaa} }
340
342
343typedef UINT8 EFI_KEY_TOGGLE_STATE;
344//
345// Any Shift or Toggle State that is valid should have
346// high order bit set.
347//
348typedef struct EFI_KEY_STATE {
349 UINT32 KeyShiftState;
350 EFI_KEY_TOGGLE_STATE KeyToggleState;
352
353typedef struct {
354 EFI_INPUT_KEY Key;
355 EFI_KEY_STATE KeyState;
357
358//
359// Shift state
360//
361#define EFI_SHIFT_STATE_VALID 0x80000000
362#define EFI_RIGHT_SHIFT_PRESSED 0x00000001
363#define EFI_LEFT_SHIFT_PRESSED 0x00000002
364#define EFI_RIGHT_CONTROL_PRESSED 0x00000004
365#define EFI_LEFT_CONTROL_PRESSED 0x00000008
366#define EFI_RIGHT_ALT_PRESSED 0x00000010
367#define EFI_LEFT_ALT_PRESSED 0x00000020
368#define EFI_RIGHT_LOGO_PRESSED 0x00000040
369#define EFI_LEFT_LOGO_PRESSED 0x00000080
370#define EFI_MENU_KEY_PRESSED 0x00000100
371#define EFI_SYS_REQ_PRESSED 0x00000200
372
373//
374// Toggle state
375//
376#define EFI_TOGGLE_STATE_VALID 0x80
377#define EFI_KEY_STATE_EXPOSED 0x40
378#define EFI_SCROLL_LOCK_ACTIVE 0x01
379#define EFI_NUM_LOCK_ACTIVE 0x02
380#define EFI_CAPS_LOCK_ACTIVE 0x04
381
382//
383// EFI Key Notfication Function
384//
385typedef
386EFI_STATUS
387(EFIAPI *EFI_KEY_NOTIFY_FUNCTION) (
388 IN EFI_KEY_DATA *KeyData
389 );
390
391typedef
392EFI_STATUS
393(EFIAPI *EFI_INPUT_RESET_EX) (
395 IN BOOLEAN ExtendedVerification
396 )
397/*++
398
399 Routine Description:
400 Reset the input device and optionaly run diagnostics
401
402 Arguments:
403 This - Protocol instance pointer.
404 ExtendedVerification - Driver may perform diagnostics on reset.
405
406 Returns:
407 EFI_SUCCESS - The device was reset.
408 EFI_DEVICE_ERROR - The device is not functioning properly and could
409 not be reset.
410
411--*/
412;
413
414typedef
415EFI_STATUS
416(EFIAPI *EFI_INPUT_READ_KEY_EX) (
418 OUT EFI_KEY_DATA *KeyData
419 )
420/*++
421
422 Routine Description:
423 Reads the next keystroke from the input device. The WaitForKey Event can
424 be used to test for existence of a keystroke via WaitForEvent () call.
425
426 Arguments:
427 This - Protocol instance pointer.
428 KeyData - A pointer to a buffer that is filled in with the keystroke
429 state data for the key that was pressed.
430
431 Returns:
432 EFI_SUCCESS - The keystroke information was returned.
433 EFI_NOT_READY - There was no keystroke data availiable.
434 EFI_DEVICE_ERROR - The keystroke information was not returned due to
435 hardware errors.
436 EFI_INVALID_PARAMETER - KeyData is NULL.
437--*/
438;
439
440typedef
441EFI_STATUS
442(EFIAPI *EFI_SET_STATE) (
444 IN EFI_KEY_TOGGLE_STATE *KeyToggleState
445 )
446/*++
447
448 Routine Description:
449 Set certain state for the input device.
450
451 Arguments:
452 This - Protocol instance pointer.
453 KeyToggleState - A pointer to the EFI_KEY_TOGGLE_STATE to set the
454 state for the input device.
455
456 Returns:
457 EFI_SUCCESS - The device state was set successfully.
458 EFI_DEVICE_ERROR - The device is not functioning correctly and could
459 not have the setting adjusted.
460 EFI_UNSUPPORTED - The device does not have the ability to set its state.
461 EFI_INVALID_PARAMETER - KeyToggleState is NULL.
462
463--*/
464;
465
466typedef
467EFI_STATUS
468(EFIAPI *EFI_REGISTER_KEYSTROKE_NOTIFY) (
470 IN EFI_KEY_DATA *KeyData,
471 IN EFI_KEY_NOTIFY_FUNCTION KeyNotificationFunction,
472 OUT EFI_HANDLE *NotifyHandle
473 )
474/*++
475
476 Routine Description:
477 Register a notification function for a particular keystroke for the input device.
478
479 Arguments:
480 This - Protocol instance pointer.
481 KeyData - A pointer to a buffer that is filled in with the keystroke
482 information data for the key that was pressed.
483 KeyNotificationFunction - Points to the function to be called when the key
484 sequence is typed specified by KeyData.
485 NotifyHandle - Points to the unique handle assigned to the registered notification.
486
487 Returns:
488 EFI_SUCCESS - The notification function was registered successfully.
489 EFI_OUT_OF_RESOURCES - Unable to allocate resources for necesssary data structures.
490 EFI_INVALID_PARAMETER - KeyData or NotifyHandle is NULL.
491
492--*/
493;
494
495typedef
496EFI_STATUS
497(EFIAPI *EFI_UNREGISTER_KEYSTROKE_NOTIFY) (
499 IN EFI_HANDLE NotificationHandle
500 )
501/*++
502
503 Routine Description:
504 Remove a registered notification function from a particular keystroke.
505
506 Arguments:
507 This - Protocol instance pointer.
508 NotificationHandle - The handle of the notification function being unregistered.
509
510 Returns:
511 EFI_SUCCESS - The notification function was unregistered successfully.
512 EFI_INVALID_PARAMETER - The NotificationHandle is invalid.
513 EFI_NOT_FOUND - Can not find the matching entry in database.
514
515--*/
516;
517
519 EFI_INPUT_RESET_EX Reset;
520 EFI_INPUT_READ_KEY_EX ReadKeyStrokeEx;
521 EFI_EVENT WaitForKeyEx;
522 EFI_SET_STATE SetState;
523 EFI_REGISTER_KEYSTROKE_NOTIFY RegisterKeyNotify;
524 EFI_UNREGISTER_KEYSTROKE_NOTIFY UnregisterKeyNotify;
526
527#endif
Definition: eficon.h:247
Definition: eficon.h:353
Definition: eficon.h:348
Definition: eficon.h:134
Definition: eficon.h:518
Definition: eficon.h:331
Definition: eficon.h:144
