RTEMS 6.1-rc2
eeprom.h
2
11/*
12 * Copyright (c) 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _DEV_I2C_EEPROM_H
37#define _DEV_I2C_EEPROM_H
38
39#include <dev/i2c/i2c.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
55int i2c_dev_register_eeprom(
56 const char *bus_path,
57 const char *dev_path,
58 uint16_t i2c_address,
59 uint16_t address_bytes,
60 uint16_t page_size_in_bytes,
61 uint32_t size_in_bytes,
62 uint32_t program_timeout_in_ms
63);
64
67#ifdef __cplusplus
68}
69#endif /* __cplusplus */
70
71#endif /* _DEV_I2C_EEPROM_H */
Inter-Integrated Circuit (I2C) Driver API.
