RTEMS
6.1-rc2
bsps
arm
atsam
contrib
libraries
libboard
include
cs2100.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
37
#ifndef CS2100_H
38
#define CS2100_H
39
40
#include "
board.h
41
42
43
* Definitions
44
45
46
#define CS2100_SLAVE_ADDRESS 0x4E
47
49
#define CS2100_REG_ID 0x01
50
52
#define CS2100_REG_CTRL 0x02
53
55
#define CS2100_REG_DEV_CFG1 0x03
56
58
#define CS2100_REG_CFG 0x05
59
61
#define CS2100_REG_32_BIT_RATIO_1 0x06
63
#define CS2100_REG_32_BIT_RATIO_2 0x07
65
#define CS2100_REG_32_BIT_RATIO_3 0x08
67
#define CS2100_REG_32_BIT_RATIO_4 0x09
69
#define CS2100_REG_FUNC_CFG1 0x16
71
#define CS2100_REG_FUNC_CFG2 0x17
73
#define CS2100_REG_FUNC_CFG3 0x1E
74
75
76
* Exported functions
77
78
79
extern
uint16_t CS2100_Read(
80
Twid
*pTwid,
81
uint32_t device,
82
uint32_t regAddr);
83
84
extern
void
CS2100_Write(
85
Twid
*pTwid,
86
uint32_t device,
87
uint32_t regAddr,
88
uint16_t data);
89
90
extern
uint8_t CS2100_Init(
Twid
*pTwid, uint32_t device, uint32_t PCK);
91
#endif
// CS2100_H
92
93
board.h
_Twid
TWI driver structure. Holds the internal state of the driver.
Definition:
twid.h:72
