RTEMS 6.1-rc2
pci.h File Reference
#include <stdint.h>
struct  pci_config_access_functions
struct  rtems_pci_config_t
#define PCI_VENDOR_ID   0x00 /* 16 bits */
#define PCI_DEVICE_ID   0x02 /* 16 bits */
#define PCI_INVALID_VENDORDEVICEID   0xffffffff
#define PCI_COMMAND   0x04 /* 16 bits */
#define PCI_COMMAND_IO   0x0001 /* Enable response in I/O space */
#define PCI_COMMAND_MEMORY   0x0002 /* Enable response in Memory space */
#define PCI_COMMAND_MASTER   0x0004 /* Enable bus mastering */
#define PCI_COMMAND_SPECIAL   0x0008 /* Enable response to special cycles */
#define PCI_COMMAND_INVALIDATE   0x0010 /* Use memory write and invalidate */
#define PCI_COMMAND_VGA_PALETTE   0x0020 /* Enable palette snooping */
#define PCI_COMMAND_PARITY   0x0040 /* Enable parity checking */
#define PCI_COMMAND_WAIT   0x0080 /* Enable address/data stepping */
#define PCI_COMMAND_SERR   0x0100 /* Enable SERR */
#define PCI_COMMAND_FAST_BACK   0x0200 /* Enable back-to-back writes */
#define PCI_COMMAND_INTX_DISABLE   0x0400 /* Disable INTx emulation */
#define PCI_STATUS   0x06 /* 16 bits */
#define PCI_STATUS_66MHZ   0x0020 /* Support 66 Mhz PCI 2.1 bus */
#define PCI_STATUS_UDF   0x0040 /* Support User Definable Features */
#define PCI_STATUS_FAST_BACK   0x0080 /* Accept fast-back to back */
#define PCI_STATUS_PARITY   0x0100 /* Detected parity error */
#define PCI_STATUS_DEVSEL_MASK   0x0600 /* DEVSEL timing */
#define PCI_STATUS_DEVSEL_FAST   0x0000
#define PCI_STATUS_DEVSEL_MEDIUM   0x0200
#define PCI_STATUS_DEVSEL_SLOW   0x0400
#define PCI_STATUS_SIG_TARGET_ABORT   0x0800 /* Set on target abort */
#define PCI_STATUS_REC_TARGET_ABORT   0x1000 /* Master ack of " */
#define PCI_STATUS_REC_MASTER_ABORT   0x2000 /* Set on master abort */
#define PCI_STATUS_SIG_SYSTEM_ERROR   0x4000 /* Set when we drive SERR */
#define PCI_STATUS_DETECTED_PARITY   0x8000 /* Set on parity error */
#define PCI_CLASS_REVISION   0x08 /* High 24 bits are class, low 8 revision */
#define PCI_REVISION_ID   0x08 /* Revision ID */
#define PCI_CLASS_PROG   0x09 /* Reg. Level Programming Interface */
#define PCI_CLASS_DEVICE   0x0a /* Device class */
#define PCI_CACHE_LINE_SIZE   0x0c /* 8 bits */
#define PCI_LATENCY_TIMER   0x0d /* 8 bits */
#define PCI_HEADER_TYPE   0x0e /* 8 bits */
#define PCI_HEADER_TYPE_NORMAL   0x00
#define PCI_HEADER_TYPE_BRIDGE   0x01
#define PCI_HEADER_TYPE_CARDBUS   0x02
#define PCI_HEADER_TYPE_MULTI_FUNCTION   0x80
#define PCI_BIST   0x0f /* 8 bits */
#define PCI_BIST_CODE_MASK   0x0f /* Return result */
#define PCI_BIST_START   0x40 /* 1 to start BIST, 2 secs or less */
#define PCI_BIST_CAPABLE   0x80 /* 1 if BIST capable */
#define PCI_BASE_ADDRESS_0   0x10 /* 32 bits */
#define PCI_BASE_ADDRESS_1   0x14 /* 32 bits [htype 0,1 only] */
#define PCI_BASE_ADDRESS_2   0x18 /* 32 bits [htype 0 only] */
#define PCI_BASE_ADDRESS_3   0x1c /* 32 bits */
#define PCI_BASE_ADDRESS_4   0x20 /* 32 bits */
#define PCI_BASE_ADDRESS_5   0x24 /* 32 bits */
#define PCI_BASE_ADDRESS_SPACE   0x01 /* 0 = memory, 1 = I/O */
#define PCI_BASE_ADDRESS_SPACE_IO   0x01
#define PCI_BASE_ADDRESS_SPACE_MEMORY   0x00
#define PCI_BASE_ADDRESS_MEM_TYPE_MASK   0x06
#define PCI_BASE_ADDRESS_MEM_TYPE_32   0x00 /* 32 bit address */
#define PCI_BASE_ADDRESS_MEM_TYPE_1M   0x02 /* Below 1M */
#define PCI_BASE_ADDRESS_MEM_TYPE_64   0x04 /* 64 bit address */
#define PCI_BASE_ADDRESS_MEM_PREFETCH   0x08 /* prefetchable? */
#define PCI_BASE_ADDRESS_MEM_MASK   (~0x0fUL)
#define PCI_BASE_ADDRESS_IO_MASK   (~0x03UL)
#define PCI_CARDBUS_CIS   0x28
#define PCI_SUBSYSTEM_VENDOR_ID   0x2c
#define PCI_SUBSYSTEM_ID   0x2e
#define PCI_ROM_ADDRESS   0x30 /* Bits 31..11 address, 10..1 reserved */
#define PCI_ROM_ADDRESS_ENABLE   0x01
#define PCI_ROM_ADDRESS_MASK   (~0x7ffUL)
#define PCI_CAPABILITY_LIST_POINTER   0x34
#define PCI_INTERRUPT_LINE   0x3c /* 8 bits */
#define PCI_INTERRUPT_PIN   0x3d /* 8 bits */
#define PCI_MIN_GNT   0x3e /* 8 bits */
#define PCI_MAX_LAT   0x3f /* 8 bits */
#define PCI_PRIMARY_BUS   0x18 /* Primary bus number */
#define PCI_SECONDARY_BUS   0x19 /* Secondary bus number */
#define PCI_SUBORDINATE_BUS   0x1a /* Highest bus number behind the bridge */
#define PCI_SEC_LATENCY_TIMER   0x1b /* Latency timer for secondary interface */
#define PCI_IO_BASE   0x1c /* I/O range behind the bridge */
#define PCI_IO_LIMIT   0x1d
#define PCI_IO_RANGE_TYPE_MASK   0x0f /* I/O bridging type */
#define PCI_IO_RANGE_TYPE_16   0x00
#define PCI_IO_RANGE_TYPE_32   0x01
#define PCI_IO_RANGE_MASK   ~0x0f
#define PCI_SEC_STATUS   0x1e /* Secondary status register, only bit 14 used */
#define PCI_MEMORY_BASE   0x20 /* Memory range behind */
#define PCI_MEMORY_LIMIT   0x22
#define PCI_MEMORY_RANGE_TYPE_MASK   0x0f
#define PCI_MEMORY_RANGE_MASK   ~0x0f
#define PCI_PREF_MEMORY_BASE   0x24 /* Prefetchable memory range behind */
#define PCI_PREF_MEMORY_LIMIT   0x26
#define PCI_PREF_RANGE_TYPE_MASK   0x0f
#define PCI_PREF_RANGE_TYPE_32   0x00
#define PCI_PREF_RANGE_TYPE_64   0x01
#define PCI_PREF_RANGE_MASK   ~0x0f
#define PCI_PREF_BASE_UPPER32   0x28 /* Upper half of prefetchable memory */
#define PCI_PREF_LIMIT_UPPER32   0x2c
#define PCI_IO_BASE_UPPER16   0x30 /* Upper half of I/O addresses */
#define PCI_IO_LIMIT_UPPER16   0x32
#define PCI_ROM_ADDRESS1   0x38 /* Same as PCI_ROM_ADDRESS, but for htype 1 */
#define PCI_BRIDGE_CONTROL   0x3e
#define PCI_BRIDGE_CTL_PARITY   0x01 /* Enable parity detection on secondary interface */
#define PCI_BRIDGE_CTL_SERR   0x02 /* The same for SERR forwarding */
#define PCI_BRIDGE_CTL_NO_ISA   0x04 /* Disable bridging of ISA ports */
#define PCI_BRIDGE_CTL_VGA   0x08 /* Forward VGA addresses */
#define PCI_BRIDGE_CTL_MASTER_ABORT   0x20 /* Report master aborts */
#define PCI_BRIDGE_CTL_BUS_RESET   0x40 /* Secondary bus reset */
#define PCI_BRIDGE_CTL_FAST_BACK   0x80 /* Fast Back2Back enabled */
#define PCI_CB_SEC_STATUS   0x16 /* Secondary status */
#define PCI_CB_PRIMARY_BUS   0x18 /* PCI bus number */
#define PCI_CB_CARD_BUS   0x19 /* CardBus bus number */
#define PCI_CB_SUBORDINATE_BUS   0x1a /* Subordinate bus number */
#define PCI_CB_LATENCY_TIMER   0x1b /* CardBus latency timer */
#define PCI_CB_MEMORY_BASE_0   0x1c
#define PCI_CB_MEMORY_LIMIT_0   0x20
#define PCI_CB_MEMORY_BASE_1   0x24
#define PCI_CB_MEMORY_LIMIT_1   0x28
#define PCI_CB_IO_BASE_0   0x2c
#define PCI_CB_IO_BASE_0_HI   0x2e
#define PCI_CB_IO_LIMIT_0   0x30
#define PCI_CB_IO_LIMIT_0_HI   0x32
#define PCI_CB_IO_BASE_1   0x34
#define PCI_CB_IO_BASE_1_HI   0x36
#define PCI_CB_IO_LIMIT_1   0x38
#define PCI_CB_IO_LIMIT_1_HI   0x3a
#define PCI_CB_IO_RANGE_MASK   ~0x03
#define PCI_CB_BRIDGE_CONTROL   0x3e
#define PCI_CB_BRIDGE_CTL_PARITY   0x01 /* Similar to standard bridge */
#define PCI_CB_BRIDGE_CTL_SERR   0x02
#define PCI_CB_BRIDGE_CTL_ISA   0x04
#define PCI_CB_BRIDGE_CTL_VGA   0x08
#define PCI_CB_BRIDGE_CTL_MASTER_ABORT   0x20
#define PCI_CB_BRIDGE_CTL_CB_RESET   0x40 /* CardBus reset */
#define PCI_CB_BRIDGE_CTL_16BIT_INT   0x80 /* Enable interrupt for */
#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM0   0x100 /* Prefetch enable for */
#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM1   0x200
#define PCI_CB_BRIDGE_CTL_POST_WRITES   0x400
#define PCI_CB_SUBSYSTEM_VENDOR_ID   0x40
#define PCI_CB_SUBSYSTEM_ID   0x42
#define PCI_CB_LEGACY_MODE_BASE   0x44
#define PCI_CLASS_NOT_DEFINED   0x0000
#define PCI_CLASS_NOT_DEFINED_VGA   0x0001
#define PCI_BASE_CLASS_STORAGE   0x01
#define PCI_CLASS_STORAGE_SCSI   0x0100
#define PCI_CLASS_STORAGE_IDE   0x0101
#define PCI_CLASS_STORAGE_FLOPPY   0x0102
#define PCI_CLASS_STORAGE_IPI   0x0103
#define PCI_CLASS_STORAGE_RAID   0x0104
#define PCI_CLASS_STORAGE_OTHER   0x0180
#define PCI_BASE_CLASS_NETWORK   0x02
#define PCI_CLASS_NETWORK_ETHERNET   0x0200
#define PCI_CLASS_NETWORK_TOKEN_RING   0x0201
#define PCI_CLASS_NETWORK_FDDI   0x0202
#define PCI_CLASS_NETWORK_ATM   0x0203
#define PCI_CLASS_NETWORK_OTHER   0x0280
#define PCI_BASE_CLASS_DISPLAY   0x03
#define PCI_CLASS_DISPLAY_VGA   0x0300
#define PCI_CLASS_DISPLAY_XGA   0x0301
#define PCI_CLASS_DISPLAY_OTHER   0x0380
#define PCI_BASE_CLASS_MULTIMEDIA   0x04
#define PCI_CLASS_MULTIMEDIA_VIDEO   0x0400
#define PCI_CLASS_MULTIMEDIA_AUDIO   0x0401
#define PCI_CLASS_MULTIMEDIA_OTHER   0x0480
#define PCI_BASE_CLASS_MEMORY   0x05
#define PCI_CLASS_MEMORY_RAM   0x0500
#define PCI_CLASS_MEMORY_FLASH   0x0501
#define PCI_CLASS_MEMORY_OTHER   0x0580
#define PCI_BASE_CLASS_BRIDGE   0x06
#define PCI_CLASS_BRIDGE_HOST   0x0600
#define PCI_CLASS_BRIDGE_ISA   0x0601
#define PCI_CLASS_BRIDGE_EISA   0x0602
#define PCI_CLASS_BRIDGE_MC   0x0603
#define PCI_CLASS_BRIDGE_PCI   0x0604
#define PCI_CLASS_BRIDGE_PCMCIA   0x0605
#define PCI_CLASS_BRIDGE_NUBUS   0x0606
#define PCI_CLASS_BRIDGE_CARDBUS   0x0607
#define PCI_CLASS_BRIDGE_OTHER   0x0680
#define PCI_BASE_CLASS_COMMUNICATION   0x07
#define PCI_CLASS_COMMUNICATION_SERIAL   0x0700
#define PCI_CLASS_COMMUNICATION_PARALLEL   0x0701
#define PCI_CLASS_COMMUNICATION_OTHER   0x0780
#define PCI_BASE_CLASS_SYSTEM   0x08
#define PCI_CLASS_SYSTEM_PIC   0x0800
#define PCI_CLASS_SYSTEM_DMA   0x0801
#define PCI_CLASS_SYSTEM_TIMER   0x0802
#define PCI_CLASS_SYSTEM_RTC   0x0803
#define PCI_CLASS_SYSTEM_OTHER   0x0880
#define PCI_BASE_CLASS_INPUT   0x09
#define PCI_CLASS_INPUT_KEYBOARD   0x0900
#define PCI_CLASS_INPUT_PEN   0x0901
#define PCI_CLASS_INPUT_MOUSE   0x0902
#define PCI_CLASS_INPUT_OTHER   0x0980
#define PCI_BASE_CLASS_DOCKING   0x0a
#define PCI_CLASS_DOCKING_GENERIC   0x0a00
#define PCI_CLASS_DOCKING_OTHER   0x0a01
#define PCI_BASE_CLASS_PROCESSOR   0x0b
#define PCI_CLASS_PROCESSOR_386   0x0b00
#define PCI_CLASS_PROCESSOR_486   0x0b01
#define PCI_CLASS_PROCESSOR_PENTIUM   0x0b02
#define PCI_CLASS_PROCESSOR_ALPHA   0x0b10
#define PCI_CLASS_PROCESSOR_POWERPC   0x0b20
#define PCI_CLASS_PROCESSOR_CO   0x0b40
#define PCI_BASE_CLASS_SERIAL   0x0c
#define PCI_CLASS_SERIAL_FIREWIRE   0x0c00
#define PCI_CLASS_SERIAL_ACCESS   0x0c01
#define PCI_CLASS_SERIAL_SSA   0x0c02
#define PCI_CLASS_SERIAL_USB   0x0c03
#define PCI_CLASS_SERIAL_FIBER   0x0c04
#define PCI_CLASS_OTHERS   0xff
#define PCI_VENDOR_ID_COMPAQ   0x0e11
#define PCI_DEVICE_ID_COMPAQ_1280   0x3033
#define PCI_DEVICE_ID_COMPAQ_TRIFLEX   0x4000
#define PCI_DEVICE_ID_COMPAQ_SMART2P   0xae10
#define PCI_DEVICE_ID_COMPAQ_NETEL100   0xae32
#define PCI_DEVICE_ID_COMPAQ_NETEL10   0xae34
#define PCI_DEVICE_ID_COMPAQ_NETFLEX3I   0xae35
#define PCI_DEVICE_ID_COMPAQ_NETEL100D   0xae40
#define PCI_DEVICE_ID_COMPAQ_NETEL100PI   0xae43
#define PCI_DEVICE_ID_COMPAQ_NETEL100I   0xb011
#define PCI_DEVICE_ID_COMPAQ_THUNDER   0xf130
#define PCI_DEVICE_ID_COMPAQ_NETFLEX3B   0xf150
#define PCI_VENDOR_ID_NCR   0x1000
#define PCI_DEVICE_ID_NCR_53C810   0x0001
#define PCI_DEVICE_ID_NCR_53C820   0x0002
#define PCI_DEVICE_ID_NCR_53C825   0x0003
#define PCI_DEVICE_ID_NCR_53C815   0x0004
#define PCI_DEVICE_ID_NCR_53C860   0x0006
#define PCI_DEVICE_ID_NCR_53C896   0x000b
#define PCI_DEVICE_ID_NCR_53C895   0x000c
#define PCI_DEVICE_ID_NCR_53C885   0x000d
#define PCI_DEVICE_ID_NCR_53C875   0x000f
#define PCI_DEVICE_ID_NCR_53C875J   0x008f
#define PCI_VENDOR_ID_ATI   0x1002
#define PCI_DEVICE_ID_ATI_68800   0x4158
#define PCI_DEVICE_ID_ATI_215CT222   0x4354
#define PCI_DEVICE_ID_ATI_210888CX   0x4358
#define PCI_DEVICE_ID_ATI_215GB   0x4742
#define PCI_DEVICE_ID_ATI_215GD   0x4744
#define PCI_DEVICE_ID_ATI_215GI   0x4749
#define PCI_DEVICE_ID_ATI_215GP   0x4750
#define PCI_DEVICE_ID_ATI_215GQ   0x4751
#define PCI_DEVICE_ID_ATI_215GT   0x4754
#define PCI_DEVICE_ID_ATI_215GTB   0x4755
#define PCI_DEVICE_ID_ATI_210888GX   0x4758
#define PCI_DEVICE_ID_ATI_215LG   0x4c47
#define PCI_DEVICE_ID_ATI_264LT   0x4c54
#define PCI_DEVICE_ID_ATI_264VT   0x5654
#define PCI_VENDOR_ID_VLSI   0x1004
#define PCI_DEVICE_ID_VLSI_82C592   0x0005
#define PCI_DEVICE_ID_VLSI_82C593   0x0006
#define PCI_DEVICE_ID_VLSI_82C594   0x0007
#define PCI_DEVICE_ID_VLSI_82C597   0x0009
#define PCI_DEVICE_ID_VLSI_82C541   0x000c
#define PCI_DEVICE_ID_VLSI_82C543   0x000d
#define PCI_DEVICE_ID_VLSI_82C532   0x0101
#define PCI_DEVICE_ID_VLSI_82C534   0x0102
#define PCI_DEVICE_ID_VLSI_82C535   0x0104
#define PCI_DEVICE_ID_VLSI_82C147   0x0105
#define PCI_DEVICE_ID_VLSI_VAS96011   0x0702
#define PCI_VENDOR_ID_ADL   0x1005
#define PCI_DEVICE_ID_ADL_2301   0x2301
#define PCI_VENDOR_ID_NS   0x100b
#define PCI_DEVICE_ID_NS_87415   0x0002
#define PCI_DEVICE_ID_NS_87410   0xd001
#define PCI_VENDOR_ID_TSENG   0x100c
#define PCI_DEVICE_ID_TSENG_W32P_2   0x3202
#define PCI_DEVICE_ID_TSENG_W32P_b   0x3205
#define PCI_DEVICE_ID_TSENG_W32P_c   0x3206
#define PCI_DEVICE_ID_TSENG_W32P_d   0x3207
#define PCI_DEVICE_ID_TSENG_ET6000   0x3208
#define PCI_VENDOR_ID_WEITEK   0x100e
#define PCI_DEVICE_ID_WEITEK_P9000   0x9001
#define PCI_DEVICE_ID_WEITEK_P9100   0x9100
#define PCI_VENDOR_ID_DEC   0x1011
#define PCI_DEVICE_ID_DEC_BRD   0x0001
#define PCI_DEVICE_ID_DEC_TULIP   0x0002
#define PCI_DEVICE_ID_DEC_TGA   0x0004
#define PCI_DEVICE_ID_DEC_TULIP_FAST   0x0009
#define PCI_DEVICE_ID_DEC_TGA2   0x000D
#define PCI_DEVICE_ID_DEC_FDDI   0x000F
#define PCI_DEVICE_ID_DEC_TULIP_PLUS   0x0014
#define PCI_DEVICE_ID_DEC_21142   0x0019
#define PCI_DEVICE_ID_DEC_21143   0x0019
#define PCI_DEVICE_ID_DEC_21052   0x0021
#define PCI_DEVICE_ID_DEC_21150   0x0022
#define PCI_DEVICE_ID_DEC_21152   0x0024
#define PCI_VENDOR_ID_CIRRUS   0x1013
#define PCI_DEVICE_ID_CIRRUS_7548   0x0038
#define PCI_DEVICE_ID_CIRRUS_5430   0x00a0
#define PCI_DEVICE_ID_CIRRUS_5434_4   0x00a4
#define PCI_DEVICE_ID_CIRRUS_5434_8   0x00a8
#define PCI_DEVICE_ID_CIRRUS_5436   0x00ac
#define PCI_DEVICE_ID_CIRRUS_5446   0x00b8
#define PCI_DEVICE_ID_CIRRUS_5480   0x00bc
#define PCI_DEVICE_ID_CIRRUS_5464   0x00d4
#define PCI_DEVICE_ID_CIRRUS_5465   0x00d6
#define PCI_DEVICE_ID_CIRRUS_6729   0x1100
#define PCI_DEVICE_ID_CIRRUS_6832   0x1110
#define PCI_DEVICE_ID_CIRRUS_7542   0x1200
#define PCI_DEVICE_ID_CIRRUS_7543   0x1202
#define PCI_DEVICE_ID_CIRRUS_7541   0x1204
#define PCI_VENDOR_ID_IBM   0x1014
#define PCI_DEVICE_ID_IBM_FIRE_CORAL   0x000a
#define PCI_DEVICE_ID_IBM_TR   0x0018
#define PCI_DEVICE_ID_IBM_82G2675   0x001d
#define PCI_DEVICE_ID_IBM_MCA   0x0020
#define PCI_DEVICE_ID_IBM_82351   0x0022
#define PCI_DEVICE_ID_IBM_SERVERAID   0x002e
#define PCI_DEVICE_ID_IBM_TR_WAKE   0x003e
#define PCI_DEVICE_ID_IBM_MPIC   0x0046
#define PCI_DEVICE_ID_IBM_3780IDSP   0x007d
#define PCI_DEVICE_ID_IBM_MPIC_2   0xffff
#define PCI_VENDOR_ID_WD   0x101c
#define PCI_DEVICE_ID_WD_7197   0x3296
#define PCI_VENDOR_ID_AMD   0x1022
#define PCI_DEVICE_ID_AMD_LANCE   0x2000
#define PCI_DEVICE_ID_AMD_SCSI   0x2020
#define PCI_VENDOR_ID_TRIDENT   0x1023
#define PCI_DEVICE_ID_TRIDENT_9397   0x9397
#define PCI_DEVICE_ID_TRIDENT_9420   0x9420
#define PCI_DEVICE_ID_TRIDENT_9440   0x9440
#define PCI_DEVICE_ID_TRIDENT_9660   0x9660
#define PCI_DEVICE_ID_TRIDENT_9750   0x9750
#define PCI_VENDOR_ID_AI   0x1025
#define PCI_DEVICE_ID_AI_M1435   0x1435
#define PCI_VENDOR_ID_MATROX   0x102B
#define PCI_DEVICE_ID_MATROX_MGA_2   0x0518
#define PCI_DEVICE_ID_MATROX_MIL   0x0519
#define PCI_DEVICE_ID_MATROX_MYS   0x051A
#define PCI_DEVICE_ID_MATROX_MIL_2   0x051b
#define PCI_DEVICE_ID_MATROX_MIL_2_AGP   0x051f
#define PCI_DEVICE_ID_MATROX_MGA_IMP   0x0d10
#define PCI_VENDOR_ID_CT   0x102c
#define PCI_DEVICE_ID_CT_65545   0x00d8
#define PCI_DEVICE_ID_CT_65548   0x00dc
#define PCI_DEVICE_ID_CT_65550   0x00e0
#define PCI_DEVICE_ID_CT_65554   0x00e4
#define PCI_DEVICE_ID_CT_65555   0x00e5
#define PCI_VENDOR_ID_MIRO   0x1031
#define PCI_DEVICE_ID_MIRO_36050   0x5601
#define PCI_VENDOR_ID_NEC   0x1033
#define PCI_DEVICE_ID_NEC_PCX2   0x0046
#define PCI_VENDOR_ID_FD   0x1036
#define PCI_DEVICE_ID_FD_36C70   0x0000
#define PCI_VENDOR_ID_SI   0x1039
#define PCI_DEVICE_ID_SI_5591_AGP   0x0001
#define PCI_DEVICE_ID_SI_6202   0x0002
#define PCI_DEVICE_ID_SI_503   0x0008
#define PCI_DEVICE_ID_SI_ACPI   0x0009
#define PCI_DEVICE_ID_SI_5597_VGA   0x0200
#define PCI_DEVICE_ID_SI_6205   0x0205
#define PCI_DEVICE_ID_SI_501   0x0406
#define PCI_DEVICE_ID_SI_496   0x0496
#define PCI_DEVICE_ID_SI_601   0x0601
#define PCI_DEVICE_ID_SI_5107   0x5107
#define PCI_DEVICE_ID_SI_5511   0x5511
#define PCI_DEVICE_ID_SI_5513   0x5513
#define PCI_DEVICE_ID_SI_5571   0x5571
#define PCI_DEVICE_ID_SI_5591   0x5591
#define PCI_DEVICE_ID_SI_5597   0x5597
#define PCI_DEVICE_ID_SI_7001   0x7001
#define PCI_VENDOR_ID_HP   0x103c
#define PCI_DEVICE_ID_HP_J2585A   0x1030
#define PCI_DEVICE_ID_HP_J2585B   0x1031
#define PCI_VENDOR_ID_PCTECH   0x1042
#define PCI_DEVICE_ID_PCTECH_RZ1000   0x1000
#define PCI_DEVICE_ID_PCTECH_RZ1001   0x1001
#define PCI_DEVICE_ID_PCTECH_SAMURAI_0   0x3000
#define PCI_DEVICE_ID_PCTECH_SAMURAI_1   0x3010
#define PCI_DEVICE_ID_PCTECH_SAMURAI_IDE   0x3020
#define PCI_VENDOR_ID_DPT   0x1044
#define PCI_DEVICE_ID_DPT   0xa400
#define PCI_VENDOR_ID_OPTI   0x1045
#define PCI_DEVICE_ID_OPTI_92C178   0xc178
#define PCI_DEVICE_ID_OPTI_82C557   0xc557
#define PCI_DEVICE_ID_OPTI_82C558   0xc558
#define PCI_DEVICE_ID_OPTI_82C621   0xc621
#define PCI_DEVICE_ID_OPTI_82C700   0xc700
#define PCI_DEVICE_ID_OPTI_82C701   0xc701
#define PCI_DEVICE_ID_OPTI_82C814   0xc814
#define PCI_DEVICE_ID_OPTI_82C822   0xc822
#define PCI_DEVICE_ID_OPTI_82C825   0xd568
#define PCI_VENDOR_ID_SGS   0x104a
#define PCI_DEVICE_ID_SGS_2000   0x0008
#define PCI_DEVICE_ID_SGS_1764   0x0009
#define PCI_VENDOR_ID_BUSLOGIC   0x104B
#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER_NC   0x0140
#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER   0x1040
#define PCI_DEVICE_ID_BUSLOGIC_FLASHPOINT   0x8130
#define PCI_VENDOR_ID_TI   0x104c
#define PCI_DEVICE_ID_TI_TVP4010   0x3d04
#define PCI_DEVICE_ID_TI_TVP4020   0x3d07
#define PCI_DEVICE_ID_TI_PCI1130   0xac12
#define PCI_DEVICE_ID_TI_PCI1031   0xac13
#define PCI_DEVICE_ID_TI_PCI1131   0xac15
#define PCI_DEVICE_ID_TI_PCI1250   0xac16
#define PCI_DEVICE_ID_TI_PCI1220   0xac17
#define PCI_VENDOR_ID_OAK   0x104e
#define PCI_DEVICE_ID_OAK_OTI107   0x0107
#define PCI_VENDOR_ID_WINBOND2   0x1050
#define PCI_DEVICE_ID_WINBOND2_89C940   0x0940
#define PCI_VENDOR_ID_MOTOROLA   0x1057
#define PCI_DEVICE_ID_MOTOROLA_MPC105   0x0001
#define PCI_DEVICE_ID_MOTOROLA_MPC106   0x0002
#define PCI_DEVICE_ID_MOTOROLA_RAVEN   0x4801
#define PCI_DEVICE_ID_MOTOROLA_HAWK   0x4803
#define PCI_VENDOR_ID_PROMISE   0x105a
#define PCI_DEVICE_ID_PROMISE_20246   0x4d33
#define PCI_DEVICE_ID_PROMISE_5300   0x5300
#define PCI_VENDOR_ID_N9   0x105d
#define PCI_DEVICE_ID_N9_I128   0x2309
#define PCI_DEVICE_ID_N9_I128_2   0x2339
#define PCI_DEVICE_ID_N9_I128_T2R   0x493d
#define PCI_VENDOR_ID_UMC   0x1060
#define PCI_DEVICE_ID_UMC_UM8673F   0x0101
#define PCI_DEVICE_ID_UMC_UM8891A   0x0891
#define PCI_DEVICE_ID_UMC_UM8886BF   0x673a
#define PCI_DEVICE_ID_UMC_UM8886A   0x886a
#define PCI_DEVICE_ID_UMC_UM8881F   0x8881
#define PCI_DEVICE_ID_UMC_UM8886F   0x8886
#define PCI_DEVICE_ID_UMC_UM9017F   0x9017
#define PCI_DEVICE_ID_UMC_UM8886N   0xe886
#define PCI_DEVICE_ID_UMC_UM8891N   0xe891
#define PCI_VENDOR_ID_X   0x1061
#define PCI_DEVICE_ID_X_AGX016   0x0001
#define PCI_VENDOR_ID_PICOP   0x1066
#define PCI_DEVICE_ID_PICOP_PT86C52X   0x0001
#define PCI_DEVICE_ID_PICOP_PT80C524   0x8002
#define PCI_VENDOR_ID_APPLE   0x106b
#define PCI_DEVICE_ID_APPLE_BANDIT   0x0001
#define PCI_DEVICE_ID_APPLE_GC   0x0002
#define PCI_DEVICE_ID_APPLE_HYDRA   0x000e
#define PCI_VENDOR_ID_NEXGEN   0x1074
#define PCI_DEVICE_ID_NEXGEN_82C501   0x4e78
#define PCI_VENDOR_ID_QLOGIC   0x1077
#define PCI_DEVICE_ID_QLOGIC_ISP1020   0x1020
#define PCI_DEVICE_ID_QLOGIC_ISP1022   0x1022
#define PCI_VENDOR_ID_CYRIX   0x1078
#define PCI_DEVICE_ID_CYRIX_5510   0x0000
#define PCI_DEVICE_ID_CYRIX_PCI_MASTER   0x0001
#define PCI_DEVICE_ID_CYRIX_5520   0x0002
#define PCI_DEVICE_ID_CYRIX_5530_LEGACY   0x0100
#define PCI_DEVICE_ID_CYRIX_5530_SMI   0x0101
#define PCI_DEVICE_ID_CYRIX_5530_IDE   0x0102
#define PCI_DEVICE_ID_CYRIX_5530_AUDIO   0x0103
#define PCI_DEVICE_ID_CYRIX_5530_VIDEO   0x0104
#define PCI_VENDOR_ID_LEADTEK   0x107d
#define PCI_DEVICE_ID_LEADTEK_805   0x0000
#define PCI_VENDOR_ID_CONTAQ   0x1080
#define PCI_DEVICE_ID_CONTAQ_82C599   0x0600
#define PCI_DEVICE_ID_CONTAQ_82C693   0xc693
#define PCI_VENDOR_ID_FOREX   0x1083
#define PCI_VENDOR_ID_OLICOM   0x108d
#define PCI_DEVICE_ID_OLICOM_OC3136   0x0001
#define PCI_DEVICE_ID_OLICOM_OC2315   0x0011
#define PCI_DEVICE_ID_OLICOM_OC2325   0x0012
#define PCI_DEVICE_ID_OLICOM_OC2183   0x0013
#define PCI_DEVICE_ID_OLICOM_OC2326   0x0014
#define PCI_DEVICE_ID_OLICOM_OC6151   0x0021
#define PCI_VENDOR_ID_SUN   0x108e
#define PCI_DEVICE_ID_SUN_EBUS   0x1000
#define PCI_DEVICE_ID_SUN_HAPPYMEAL   0x1001
#define PCI_DEVICE_ID_SUN_SIMBA   0x5000
#define PCI_DEVICE_ID_SUN_PBM   0x8000
#define PCI_DEVICE_ID_SUN_SABRE   0xa000
#define PCI_VENDOR_ID_CMD   0x1095
#define PCI_DEVICE_ID_CMD_640   0x0640
#define PCI_DEVICE_ID_CMD_643   0x0643
#define PCI_DEVICE_ID_CMD_646   0x0646
#define PCI_DEVICE_ID_CMD_647   0x0647
#define PCI_DEVICE_ID_CMD_670   0x0670
#define PCI_VENDOR_ID_VISION   0x1098
#define PCI_DEVICE_ID_VISION_QD8500   0x0001
#define PCI_DEVICE_ID_VISION_QD8580   0x0002
#define PCI_VENDOR_ID_BROOKTREE   0x109e
#define PCI_DEVICE_ID_BROOKTREE_848   0x0350
#define PCI_DEVICE_ID_BROOKTREE_849A   0x0351
#define PCI_DEVICE_ID_BROOKTREE_8474   0x8474
#define PCI_VENDOR_ID_SIERRA   0x10a8
#define PCI_DEVICE_ID_SIERRA_STB   0x0000
#define PCI_VENDOR_ID_ACC   0x10aa
#define PCI_DEVICE_ID_ACC_2056   0x0000
#define PCI_VENDOR_ID_WINBOND   0x10ad
#define PCI_DEVICE_ID_WINBOND_83769   0x0001
#define PCI_DEVICE_ID_WINBOND_82C105   0x0105
#define PCI_DEVICE_ID_WINBOND_83C553   0x0565
#define PCI_VENDOR_ID_DATABOOK   0x10b3
#define PCI_DEVICE_ID_DATABOOK_87144   0xb106
#define PCI_VENDOR_ID_PLX   0x10b5
#define PCI_DEVICE_ID_PLX_9050   0x9050
#define PCI_DEVICE_ID_PLX_9060   0x9060
#define PCI_DEVICE_ID_PLX_9060ES   0x906E
#define PCI_DEVICE_ID_PLX_9060SD   0x906D
#define PCI_DEVICE_ID_PLX_9080   0x9080
#define PCI_VENDOR_ID_PLX2   0x3388
#define PCI_DEVICE_ID_PLX2_PCI6154_HB2   0x0026
#define PCI_VENDOR_ID_MADGE   0x10b6
#define PCI_DEVICE_ID_MADGE_MK2   0x0002
#define PCI_DEVICE_ID_MADGE_C155S   0x1001
#define PCI_VENDOR_ID_3COM   0x10b7
#define PCI_DEVICE_ID_3COM_3C339   0x3390
#define PCI_DEVICE_ID_3COM_3C590   0x5900
#define PCI_DEVICE_ID_3COM_3C595TX   0x5950
#define PCI_DEVICE_ID_3COM_3C595T4   0x5951
#define PCI_DEVICE_ID_3COM_3C595MII   0x5952
#define PCI_DEVICE_ID_3COM_3C900TPO   0x9000
#define PCI_DEVICE_ID_3COM_3C900COMBO   0x9001
#define PCI_DEVICE_ID_3COM_3C905TX   0x9050
#define PCI_DEVICE_ID_3COM_3C905T4   0x9051
#define PCI_DEVICE_ID_3COM_3C905B_TX   0x9055
#define PCI_VENDOR_ID_SMC   0x10b8
#define PCI_DEVICE_ID_SMC_EPIC100   0x0005
#define PCI_VENDOR_ID_AL   0x10b9
#define PCI_DEVICE_ID_AL_M1445   0x1445
#define PCI_DEVICE_ID_AL_M1449   0x1449
#define PCI_DEVICE_ID_AL_M1451   0x1451
#define PCI_DEVICE_ID_AL_M1461   0x1461
#define PCI_DEVICE_ID_AL_M1489   0x1489
#define PCI_DEVICE_ID_AL_M1511   0x1511
#define PCI_DEVICE_ID_AL_M1513   0x1513
#define PCI_DEVICE_ID_AL_M1521   0x1521
#define PCI_DEVICE_ID_AL_M1523   0x1523
#define PCI_DEVICE_ID_AL_M1531   0x1531
#define PCI_DEVICE_ID_AL_M1533   0x1533
#define PCI_DEVICE_ID_AL_M3307   0x3307
#define PCI_DEVICE_ID_AL_M4803   0x5215
#define PCI_DEVICE_ID_AL_M5219   0x5219
#define PCI_DEVICE_ID_AL_M5229   0x5229
#define PCI_DEVICE_ID_AL_M5237   0x5237
#define PCI_DEVICE_ID_AL_M7101   0x7101
#define PCI_VENDOR_ID_MITSUBISHI   0x10ba
#define PCI_VENDOR_ID_SURECOM   0x10bd
#define PCI_DEVICE_ID_SURECOM_NE34   0x0e34
#define PCI_VENDOR_ID_NEOMAGIC   0x10c8
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2070   0x0001
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128V   0x0002
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128ZV   0x0003
#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2160   0x0004
#define PCI_VENDOR_ID_ASP   0x10cd
#define PCI_DEVICE_ID_ASP_ABP940   0x1200
#define PCI_DEVICE_ID_ASP_ABP940U   0x1300
#define PCI_DEVICE_ID_ASP_ABP940UW   0x2300
#define PCI_VENDOR_ID_MACRONIX   0x10d9
#define PCI_DEVICE_ID_MACRONIX_MX98713   0x0512
#define PCI_DEVICE_ID_MACRONIX_MX987x5   0x0531
#define PCI_VENDOR_ID_CERN   0x10dc
#define PCI_DEVICE_ID_CERN_SPSB_PMC   0x0001
#define PCI_DEVICE_ID_CERN_SPSB_PCI   0x0002
#define PCI_DEVICE_ID_CERN_HIPPI_DST   0x0021
#define PCI_DEVICE_ID_CERN_HIPPI_SRC   0x0022
#define PCI_VENDOR_ID_NVIDIA   0x10de
#define PCI_VENDOR_ID_IMS   0x10e0
#define PCI_DEVICE_ID_IMS_8849   0x8849
#define PCI_VENDOR_ID_TEKRAM2   0x10e1
#define PCI_DEVICE_ID_TEKRAM2_690c   0x690c
#define PCI_VENDOR_ID_TUNDRA   0x10e3
#define PCI_DEVICE_ID_TUNDRA_CA91C042   0x0000
#define PCI_VENDOR_ID_AMCC   0x10e8
#define PCI_DEVICE_ID_AMCC_MYRINET   0x8043
#define PCI_DEVICE_ID_AMCC_PARASTATION   0x8062
#define PCI_DEVICE_ID_AMCC_S5933   0x807d
#define PCI_DEVICE_ID_AMCC_S5933_HEPC3   0x809c
#define PCI_VENDOR_ID_INTERG   0x10ea
#define PCI_DEVICE_ID_INTERG_1680   0x1680
#define PCI_DEVICE_ID_INTERG_1682   0x1682
#define PCI_VENDOR_ID_REALTEK   0x10ec
#define PCI_DEVICE_ID_REALTEK_8029   0x8029
#define PCI_DEVICE_ID_REALTEK_8129   0x8129
#define PCI_DEVICE_ID_REALTEK_8139   0x8139
#define PCI_VENDOR_ID_TRUEVISION   0x10fa
#define PCI_DEVICE_ID_TRUEVISION_T1000   0x000c
#define PCI_VENDOR_ID_INIT   0x1101
#define PCI_DEVICE_ID_INIT_320P   0x9100
#define PCI_DEVICE_ID_INIT_360P   0x9500
#define PCI_VENDOR_ID_TTI   0x1103
#define PCI_DEVICE_ID_TTI_HPT343   0x0003
#define PCI_VENDOR_ID_VIA   0x1106
#define PCI_DEVICE_ID_VIA_82C505   0x0505
#define PCI_DEVICE_ID_VIA_82C561   0x0561
#define PCI_DEVICE_ID_VIA_82C586_1   0x0571
#define PCI_DEVICE_ID_VIA_82C576   0x0576
#define PCI_DEVICE_ID_VIA_82C585   0x0585
#define PCI_DEVICE_ID_VIA_82C586_0   0x0586
#define PCI_DEVICE_ID_VIA_82C595   0x0595
#define PCI_DEVICE_ID_VIA_82C597_0   0x0597
#define PCI_DEVICE_ID_VIA_82C926   0x0926
#define PCI_DEVICE_ID_VIA_82C416   0x1571
#define PCI_DEVICE_ID_VIA_82C595_97   0x1595
#define PCI_DEVICE_ID_VIA_82C586_2   0x3038
#define PCI_DEVICE_ID_VIA_82C586_3   0x3040
#define PCI_DEVICE_ID_VIA_86C100A   0x6100
#define PCI_DEVICE_ID_VIA_82C597_1   0x8597
#define PCI_VENDOR_ID_VORTEX   0x1119
#define PCI_DEVICE_ID_VORTEX_GDT60x0   0x0000
#define PCI_DEVICE_ID_VORTEX_GDT6000B   0x0001
#define PCI_DEVICE_ID_VORTEX_GDT6x10   0x0002
#define PCI_DEVICE_ID_VORTEX_GDT6x20   0x0003
#define PCI_DEVICE_ID_VORTEX_GDT6530   0x0004
#define PCI_DEVICE_ID_VORTEX_GDT6550   0x0005
#define PCI_DEVICE_ID_VORTEX_GDT6x17   0x0006
#define PCI_DEVICE_ID_VORTEX_GDT6x27   0x0007
#define PCI_DEVICE_ID_VORTEX_GDT6537   0x0008
#define PCI_DEVICE_ID_VORTEX_GDT6557   0x0009
#define PCI_DEVICE_ID_VORTEX_GDT6x15   0x000a
#define PCI_DEVICE_ID_VORTEX_GDT6x25   0x000b
#define PCI_DEVICE_ID_VORTEX_GDT6535   0x000c
#define PCI_DEVICE_ID_VORTEX_GDT6555   0x000d
#define PCI_DEVICE_ID_VORTEX_GDT6x17RP   0x0100
#define PCI_DEVICE_ID_VORTEX_GDT6x27RP   0x0101
#define PCI_DEVICE_ID_VORTEX_GDT6537RP   0x0102
#define PCI_DEVICE_ID_VORTEX_GDT6557RP   0x0103
#define PCI_DEVICE_ID_VORTEX_GDT6x11RP   0x0104
#define PCI_DEVICE_ID_VORTEX_GDT6x21RP   0x0105
#define PCI_DEVICE_ID_VORTEX_GDT6x17RP1   0x0110
#define PCI_DEVICE_ID_VORTEX_GDT6x27RP1   0x0111
#define PCI_DEVICE_ID_VORTEX_GDT6537RP1   0x0112
#define PCI_DEVICE_ID_VORTEX_GDT6557RP1   0x0113
#define PCI_DEVICE_ID_VORTEX_GDT6x11RP1   0x0114
#define PCI_DEVICE_ID_VORTEX_GDT6x21RP1   0x0115
#define PCI_DEVICE_ID_VORTEX_GDT6x17RP2   0x0120
#define PCI_DEVICE_ID_VORTEX_GDT6x27RP2   0x0121
#define PCI_DEVICE_ID_VORTEX_GDT6537RP2   0x0122
#define PCI_DEVICE_ID_VORTEX_GDT6557RP2   0x0123
#define PCI_DEVICE_ID_VORTEX_GDT6x11RP2   0x0124
#define PCI_DEVICE_ID_VORTEX_GDT6x21RP2   0x0125
#define PCI_VENDOR_ID_EF   0x111a
#define PCI_DEVICE_ID_EF_ATM_FPGA   0x0000
#define PCI_DEVICE_ID_EF_ATM_ASIC   0x0002
#define PCI_VENDOR_ID_FORE   0x1127
#define PCI_DEVICE_ID_FORE_PCA200PC   0x0210
#define PCI_DEVICE_ID_FORE_PCA200E   0x0300
#define PCI_VENDOR_ID_IMAGINGTECH   0x112f
#define PCI_DEVICE_ID_IMAGINGTECH_ICPCI   0x0000
#define PCI_VENDOR_ID_PHILIPS   0x1131
#define PCI_DEVICE_ID_PHILIPS_SAA7145   0x7145
#define PCI_DEVICE_ID_PHILIPS_SAA7146   0x7146
#define PCI_VENDOR_ID_CYCLONE   0x113c
#define PCI_DEVICE_ID_CYCLONE_SDK   0x0001
#define PCI_VENDOR_ID_ALLIANCE   0x1142
#define PCI_DEVICE_ID_ALLIANCE_PROMOTIO   0x3210
#define PCI_DEVICE_ID_ALLIANCE_PROVIDEO   0x6422
#define PCI_DEVICE_ID_ALLIANCE_AT24   0x6424
#define PCI_DEVICE_ID_ALLIANCE_AT3D   0x643d
#define PCI_VENDOR_ID_SK   0x1148
#define PCI_DEVICE_ID_SK_FP   0x4000
#define PCI_DEVICE_ID_SK_TR   0x4200
#define PCI_DEVICE_ID_SK_GE   0x4300
#define PCI_VENDOR_ID_VMIC   0x114a
#define PCI_DEVICE_ID_VMIC_VME   0x7587
#define PCI_VENDOR_ID_DIGI   0x114f
#define PCI_DEVICE_ID_DIGI_EPC   0x0002
#define PCI_DEVICE_ID_DIGI_RIGHTSWITCH   0x0003
#define PCI_DEVICE_ID_DIGI_XEM   0x0004
#define PCI_DEVICE_ID_DIGI_XR   0x0005
#define PCI_DEVICE_ID_DIGI_CX   0x0006
#define PCI_DEVICE_ID_DIGI_XRJ   0x0009
#define PCI_DEVICE_ID_DIGI_EPCJ   0x000a
#define PCI_DEVICE_ID_DIGI_XR_920   0x0027
#define PCI_VENDOR_ID_MUTECH   0x1159
#define PCI_DEVICE_ID_MUTECH_MV1000   0x0001
#define PCI_VENDOR_ID_RENDITION   0x1163
#define PCI_DEVICE_ID_RENDITION_VERITE   0x0001
#define PCI_DEVICE_ID_RENDITION_VERITE2100   0x2000
#define PCI_VENDOR_ID_TOSHIBA   0x1179
#define PCI_DEVICE_ID_TOSHIBA_601   0x0601
#define PCI_DEVICE_ID_TOSHIBA_TOPIC95   0x060a
#define PCI_DEVICE_ID_TOSHIBA_TOPIC97   0x060f
#define PCI_VENDOR_ID_RICOH   0x1180
#define PCI_DEVICE_ID_RICOH_RL5C465   0x0465
#define PCI_DEVICE_ID_RICOH_RL5C466   0x0466
#define PCI_DEVICE_ID_RICOH_RL5C475   0x0475
#define PCI_DEVICE_ID_RICOH_RL5C478   0x0478
#define PCI_VENDOR_ID_ARTOP   0x1191
#define PCI_DEVICE_ID_ARTOP_ATP8400   0x0004
#define PCI_DEVICE_ID_ARTOP_ATP850UF   0x0005
#define PCI_VENDOR_ID_ZEITNET   0x1193
#define PCI_DEVICE_ID_ZEITNET_1221   0x0001
#define PCI_DEVICE_ID_ZEITNET_1225   0x0002
#define PCI_VENDOR_ID_OMEGA   0x119b
#define PCI_DEVICE_ID_OMEGA_82C092G   0x1221
#define PCI_VENDOR_ID_MARVELL   0x11ab
#define PCI_DEVICE_ID_MARVELL_GT6426xAB   0x6430
#define PCI_VENDOR_ID_LITEON   0x11ad
#define PCI_DEVICE_ID_LITEON_LNE100TX   0x0002
#define PCI_VENDOR_ID_NP   0x11bc
#define PCI_DEVICE_ID_NP_PCI_FDDI   0x0001
#define PCI_VENDOR_ID_ATT   0x11c1
#define PCI_DEVICE_ID_ATT_L56XMF   0x0440
#define PCI_VENDOR_ID_SPECIALIX   0x11cb
#define PCI_DEVICE_ID_SPECIALIX_IO8   0x2000
#define PCI_DEVICE_ID_SPECIALIX_XIO   0x4000
#define PCI_DEVICE_ID_SPECIALIX_RIO   0x8000
#define PCI_VENDOR_ID_AURAVISION   0x11d1
#define PCI_DEVICE_ID_AURAVISION_VXP524   0x01f7
#define PCI_VENDOR_ID_IKON   0x11d5
#define PCI_DEVICE_ID_IKON_10115   0x0115
#define PCI_DEVICE_ID_IKON_10117   0x0117
#define PCI_VENDOR_ID_ZORAN   0x11de
#define PCI_DEVICE_ID_ZORAN_36057   0x6057
#define PCI_DEVICE_ID_ZORAN_36120   0x6120
#define PCI_VENDOR_ID_KINETIC   0x11f4
#define PCI_DEVICE_ID_KINETIC_2915   0x2915
#define PCI_VENDOR_ID_COMPEX   0x11f6
#define PCI_DEVICE_ID_COMPEX_ENET100VG4   0x0112
#define PCI_DEVICE_ID_COMPEX_RL2000   0x1401
#define PCI_VENDOR_ID_RP   0x11fe
#define PCI_DEVICE_ID_RP32INTF   0x0001
#define PCI_DEVICE_ID_RP8INTF   0x0002
#define PCI_DEVICE_ID_RP16INTF   0x0003
#define PCI_DEVICE_ID_RP4QUAD   0x0004
#define PCI_DEVICE_ID_RP8OCTA   0x0005
#define PCI_DEVICE_ID_RP8J   0x0006
#define PCI_DEVICE_ID_RPP4   0x000A
#define PCI_DEVICE_ID_RPP8   0x000B
#define PCI_DEVICE_ID_RP8M   0x000C
#define PCI_VENDOR_ID_CYCLADES   0x120e
#define PCI_DEVICE_ID_CYCLOM_Y_Lo   0x0100
#define PCI_DEVICE_ID_CYCLOM_Y_Hi   0x0101
#define PCI_DEVICE_ID_CYCLOM_Z_Lo   0x0200
#define PCI_DEVICE_ID_CYCLOM_Z_Hi   0x0201
#define PCI_VENDOR_ID_ESSENTIAL   0x120f
#define PCI_DEVICE_ID_ESSENTIAL_ROADRUNNER   0x0001
#define PCI_VENDOR_ID_O2   0x1217
#define PCI_DEVICE_ID_O2_6729   0x6729
#define PCI_DEVICE_ID_O2_6730   0x673a
#define PCI_DEVICE_ID_O2_6832   0x6832
#define PCI_DEVICE_ID_O2_6836   0x6836
#define PCI_VENDOR_ID_3DFX   0x121a
#define PCI_DEVICE_ID_3DFX_VOODOO   0x0001
#define PCI_DEVICE_ID_3DFX_VOODOO2   0x0002
#define PCI_VENDOR_ID_SIGMADES   0x1236
#define PCI_DEVICE_ID_SIGMADES_6425   0x6401
#define PCI_VENDOR_ID_CCUBE   0x123f
#define PCI_VENDOR_ID_DIPIX   0x1246
#define PCI_VENDOR_ID_STALLION   0x124d
#define PCI_DEVICE_ID_STALLION_ECHPCI832   0x0000
#define PCI_DEVICE_ID_STALLION_ECHPCI864   0x0002
#define PCI_DEVICE_ID_STALLION_EIOPCI   0x0003
#define PCI_VENDOR_ID_OPTIBASE   0x1255
#define PCI_DEVICE_ID_OPTIBASE_FORGE   0x1110
#define PCI_DEVICE_ID_OPTIBASE_FUSION   0x1210
#define PCI_DEVICE_ID_OPTIBASE_VPLEX   0x2110
#define PCI_DEVICE_ID_OPTIBASE_VPLEXCC   0x2120
#define PCI_DEVICE_ID_OPTIBASE_VQUEST   0x2130
#define PCI_VENDOR_ID_SATSAGEM   0x1267
#define PCI_DEVICE_ID_SATSAGEM_PCR2101   0x5352
#define PCI_DEVICE_ID_SATSAGEM_TELSATTURBO   0x5a4b
#define PCI_VENDOR_ID_HUGHES   0x1273
#define PCI_DEVICE_ID_HUGHES_DIRECPC   0x0002
#define PCI_VENDOR_ID_ENSONIQ   0x1274
#define PCI_DEVICE_ID_ENSONIQ_AUDIOPCI   0x5000
#define PCI_VENDOR_ID_ALTEON   0x12ae
#define PCI_DEVICE_ID_ALTEON_ACENIC   0x0001
#define PCI_VENDOR_ID_PICTUREL   0x12c5
#define PCI_DEVICE_ID_PICTUREL_PCIVST   0x0081
#define PCI_VENDOR_ID_NVIDIA_SGS   0x12d2
#define PCI_DEVICE_ID_NVIDIA_SGS_RIVA128   0x0018
#define PCI_VENDOR_ID_CBOARDS   0x1307
#define PCI_DEVICE_ID_CBOARDS_DAS1602_16   0x0001
#define PCI_VENDOR_ID_SYMPHONY   0x1c1c
#define PCI_DEVICE_ID_SYMPHONY_101   0x0001
#define PCI_VENDOR_ID_TEKRAM   0x1de1
#define PCI_DEVICE_ID_TEKRAM_DC290   0xdc29
#define PCI_VENDOR_ID_3DLABS   0x3d3d
#define PCI_DEVICE_ID_3DLABS_300SX   0x0001
#define PCI_DEVICE_ID_3DLABS_500TX   0x0002
#define PCI_DEVICE_ID_3DLABS_DELTA   0x0003
#define PCI_DEVICE_ID_3DLABS_PERMEDIA   0x0004
#define PCI_DEVICE_ID_3DLABS_MX   0x0006
#define PCI_VENDOR_ID_AVANCE   0x4005
#define PCI_DEVICE_ID_AVANCE_ALG2064   0x2064
#define PCI_DEVICE_ID_AVANCE_2302   0x2302
#define PCI_VENDOR_ID_NETVIN   0x4a14
#define PCI_DEVICE_ID_NETVIN_NV5000SC   0x5000
#define PCI_VENDOR_ID_S3   0x5333
#define PCI_DEVICE_ID_S3_PLATO_PXS   0x0551
#define PCI_DEVICE_ID_S3_ViRGE   0x5631
#define PCI_DEVICE_ID_S3_TRIO   0x8811
#define PCI_DEVICE_ID_S3_AURORA64VP   0x8812
#define PCI_DEVICE_ID_S3_TRIO64UVP   0x8814
#define PCI_DEVICE_ID_S3_ViRGE_VX   0x883d
#define PCI_DEVICE_ID_S3_868   0x8880
#define PCI_DEVICE_ID_S3_928   0x88b0
#define PCI_DEVICE_ID_S3_864_1   0x88c0
#define PCI_DEVICE_ID_S3_864_2   0x88c1
#define PCI_DEVICE_ID_S3_964_1   0x88d0
#define PCI_DEVICE_ID_S3_964_2   0x88d1
#define PCI_DEVICE_ID_S3_968   0x88f0
#define PCI_DEVICE_ID_S3_TRIO64V2   0x8901
#define PCI_DEVICE_ID_S3_PLATO_PXG   0x8902
#define PCI_DEVICE_ID_S3_ViRGE_DXGX   0x8a01
#define PCI_DEVICE_ID_S3_ViRGE_GX2   0x8a10
#define PCI_DEVICE_ID_S3_ViRGE_MX   0x8c01
#define PCI_DEVICE_ID_S3_ViRGE_MXP   0x8c02
#define PCI_DEVICE_ID_S3_ViRGE_MXPMV   0x8c03
#define PCI_DEVICE_ID_S3_SONICVIBES   0xca00
#define PCI_VENDOR_ID_INTEL   0x8086
#define PCI_DEVICE_ID_INTEL_82375   0x0482
#define PCI_DEVICE_ID_INTEL_82424   0x0483
#define PCI_DEVICE_ID_INTEL_82378   0x0484
#define PCI_DEVICE_ID_INTEL_82430   0x0486
#define PCI_DEVICE_ID_INTEL_82434   0x04a3
#define PCI_DEVICE_ID_INTEL_82544EI_COPPER   0x1008
#define PCI_DEVICE_ID_INTEL_82092AA_0   0x1221
#define PCI_DEVICE_ID_INTEL_82092AA_1   0x1222
#define PCI_DEVICE_ID_INTEL_7116   0x1223
#define PCI_DEVICE_ID_INTEL_82596   0x1226
#define PCI_DEVICE_ID_INTEL_82865   0x1227
#define PCI_DEVICE_ID_INTEL_82557   0x1229
#define PCI_DEVICE_ID_INTEL_82437   0x122d
#define PCI_DEVICE_ID_INTEL_82371FB_0   0x122e
#define PCI_DEVICE_ID_INTEL_82371FB_1   0x1230
#define PCI_DEVICE_ID_INTEL_82371MX   0x1234
#define PCI_DEVICE_ID_INTEL_82437MX   0x1235
#define PCI_DEVICE_ID_INTEL_82441   0x1237
#define PCI_DEVICE_ID_INTEL_82380FB   0x124b
#define PCI_DEVICE_ID_INTEL_82439   0x1250
#define PCI_DEVICE_ID_INTEL_82371SB_0   0x7000
#define PCI_DEVICE_ID_INTEL_82371SB_1   0x7010
#define PCI_DEVICE_ID_INTEL_82371SB_2   0x7020
#define PCI_DEVICE_ID_INTEL_82437VX   0x7030
#define PCI_DEVICE_ID_INTEL_82439TX   0x7100
#define PCI_DEVICE_ID_INTEL_82371AB_0   0x7110
#define PCI_DEVICE_ID_INTEL_82371AB   0x7111
#define PCI_DEVICE_ID_INTEL_82371AB_2   0x7112
#define PCI_DEVICE_ID_INTEL_82371AB_3   0x7113
#define PCI_DEVICE_ID_INTEL_82443LX_0   0x7180
#define PCI_DEVICE_ID_INTEL_82443LX_1   0x7181
#define PCI_DEVICE_ID_INTEL_82443BX_0   0x7190
#define PCI_DEVICE_ID_INTEL_82443BX_1   0x7191
#define PCI_DEVICE_ID_INTEL_82443BX_2   0x7192
#define PCI_DEVICE_ID_INTEL_P6   0x84c4
#define PCI_DEVICE_ID_INTEL_82450GX   0x84c5
#define PCI_VENDOR_ID_KTI   0x8e2e
#define PCI_DEVICE_ID_KTI_ET32P2   0x3000
#define PCI_VENDOR_ID_ADAPTEC   0x9004
#define PCI_DEVICE_ID_ADAPTEC_7810   0x1078
#define PCI_DEVICE_ID_ADAPTEC_7850   0x5078
#define PCI_DEVICE_ID_ADAPTEC_7855   0x5578
#define PCI_DEVICE_ID_ADAPTEC_5800   0x5800
#define PCI_DEVICE_ID_ADAPTEC_1480A   0x6075
#define PCI_DEVICE_ID_ADAPTEC_7860   0x6078
#define PCI_DEVICE_ID_ADAPTEC_7861   0x6178
#define PCI_DEVICE_ID_ADAPTEC_7870   0x7078
#define PCI_DEVICE_ID_ADAPTEC_7871   0x7178
#define PCI_DEVICE_ID_ADAPTEC_7872   0x7278
#define PCI_DEVICE_ID_ADAPTEC_7873   0x7378
#define PCI_DEVICE_ID_ADAPTEC_7874   0x7478
#define PCI_DEVICE_ID_ADAPTEC_7895   0x7895
#define PCI_DEVICE_ID_ADAPTEC_7880   0x8078
#define PCI_DEVICE_ID_ADAPTEC_7881   0x8178
#define PCI_DEVICE_ID_ADAPTEC_7882   0x8278
#define PCI_DEVICE_ID_ADAPTEC_7883   0x8378
#define PCI_DEVICE_ID_ADAPTEC_7884   0x8478
#define PCI_DEVICE_ID_ADAPTEC_1030   0x8b78
#define PCI_VENDOR_ID_ADAPTEC2   0x9005
#define PCI_DEVICE_ID_ADAPTEC2_2940U2   0x0010
#define PCI_DEVICE_ID_ADAPTEC2_7890   0x001f
#define PCI_DEVICE_ID_ADAPTEC2_3940U2   0x0050
#define PCI_DEVICE_ID_ADAPTEC2_7896   0x005f
#define PCI_VENDOR_ID_ATRONICS   0x907f
#define PCI_DEVICE_ID_ATRONICS_2015   0x2015
#define PCI_VENDOR_ID_HOLTEK   0x9412
#define PCI_DEVICE_ID_HOLTEK_6565   0x6565
#define PCI_VENDOR_ID_TIGERJET   0xe159
#define PCI_DEVICE_ID_TIGERJET_300   0x0001
#define PCI_VENDOR_ID_ARK   0xedd8
#define PCI_DEVICE_ID_ARK_STING   0xa091
#define PCI_DEVICE_ID_ARK_STINGARK   0xa099
#define PCI_DEVICE_ID_ARK_2000MT   0xa0a1
#define PCI_DEVFN(_slot, _func)   ((((_slot) & 0x1f) << 3) | ((_func) & 0x07))
#define PCI_SLOT(_devfn)   (((_devfn) >> 3) & 0x1f)
#define PCI_FUNC(_devfn)   ((_devfn) & 0x07)
#define PCIBIOS_SUCCESSFUL   0x00
#define PCIBIOS_FUNC_NOT_SUPPORTED   0x81
#define PCIBIOS_BAD_VENDOR_ID   0x83
#define PCIBIOS_DEVICE_NOT_FOUND   0x86
#define PCIBIOS_BAD_REGISTER_NUMBER   0x87
#define PCIBIOS_SET_FAILED   0x88
#define PCIBIOS_BUFFER_TOO_SMALL   0x89
#define PCI_MAX_DEVICES   32
#define PCI_MAX_FUNCTIONS   8
#define PCIB_ERR_SUCCESS   (0)
#define PCIB_ERR_UNINITIALIZED   (-1) /* PCI BIOS is not initilized */
#define PCIB_ERR_NOTPRESENT   (-2) /* PCI BIOS not present */
#define PCIB_ERR_NOFUNC   (-3) /* Function not supported */
#define PCIB_ERR_BADVENDOR   (-4) /* Bad Vendor ID */
#define PCIB_ERR_DEVNOTFOUND   (-5) /* Device not found */
#define PCIB_ERR_BADREG   (-6) /* Bad register number */
int pci_initialize (void)
int pci_find_device (unsigned short vendorid, unsigned short deviceid, int instance, int *pbus, int *pdev, int *pfun)
unsigned char pci_bus_count (void)
rtems_pci_config_t BSP_pci_configuration
PCI defines and function prototypes
