RTEMS 6.1-rc2
cmsis_version.h
1/**************************************************************************/
7/*
8 * Copyright (c) 2009-2022 ARM Limited. All rights reserved.
9 *
10 * SPDX-License-Identifier: Apache-2.0
11 *
12 * Licensed under the Apache License, Version 2.0 (the License); you may
13 * not use this file except in compliance with the License.
14 * You may obtain a copy of the License at
15 *
16 * www.apache.org/licenses/LICENSE-2.0
17 *
18 * Unless required by applicable law or agreed to in writing, software
19 * distributed under the License is distributed on an AS IS BASIS, WITHOUT
20 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
21 * See the License for the specific language governing permissions and
22 * limitations under the License.
23 */
24
25#if defined ( __ICCARM__ )
26 #pragma system_include /* treat file as system include file for MISRA check */
27#elif defined (__clang__)
28 #pragma clang system_header /* treat file as system include file */
29#endif
30
31#ifndef __CMSIS_VERSION_H
32#define __CMSIS_VERSION_H
33
34/* CMSIS Version definitions */
35#define __CM_CMSIS_VERSION_MAIN ( 5U)
36#define __CM_CMSIS_VERSION_SUB ( 6U)
37#define __CM_CMSIS_VERSION ((__CM_CMSIS_VERSION_MAIN << 16U) | \
38 __CM_CMSIS_VERSION_SUB )
39#endif
