RTEMS 6.1-rc2
bsd.h
2
11/*
12 * Copyright (c) 2015 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_BSD_H
37#define _RTEMS_BSD_H
38
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
57static inline void rtems_bsd_bintime( struct bintime *bt )
58{
59 _Timecounter_Bintime( bt );
60}
61
65static inline void rtems_bsd_nanotime( struct timespec *ts )
66{
67 _Timecounter_Nanotime( ts );
68}
69
73static inline void rtems_bsd_microtime( struct timeval *tv )
74{
75 _Timecounter_Microtime( tv );
76}
77
81static inline void rtems_bsd_binuptime( struct bintime *bt )
82{
83 _Timecounter_Binuptime( bt );
84}
85
89static inline void rtems_bsd_nanouptime( struct timespec *ts )
90{
91 _Timecounter_Nanouptime( ts );
92}
93
97static inline void rtems_bsd_microuptime( struct timeval *tv )
98{
99 _Timecounter_Microuptime( tv );
100}
101
105static inline void rtems_bsd_getbintime( struct bintime *bt )
106{
107 _Timecounter_Getbintime( bt );
108}
109
113static inline void rtems_bsd_getnanotime( struct timespec *ts )
114{
115 _Timecounter_Getnanotime( ts );
116}
117
121static inline void rtems_bsd_getmicrotime( struct timeval *tv )
122{
123 _Timecounter_Getmicrotime( tv );
124}
125
129static inline void rtems_bsd_getbinuptime( struct bintime *bt )
130{
131 _Timecounter_Getbinuptime( bt );
132}
133
137static inline void rtems_bsd_getnanouptime( struct timespec *ts )
138{
139 _Timecounter_Getnanouptime( ts );
140}
141
145static inline void rtems_bsd_getmicrouptime( struct timeval *tv )
146{
147 _Timecounter_Getmicrouptime( tv );
148}
149
152#ifdef __cplusplus
153}
154#endif /* __cplusplus */
155
156#endif /* _RTEMS_BSD_H */
This header file provides basic definitions used by the API and the implementation.
This header file provides interfaces of the Timecounter Handler which are used by the implementation ...
