RTEMS 6.1-rc2
barrier.h
2
11/*
12 * Copyright (C) 2020, 2021 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/barrier/if/header */
55
56#ifndef _RTEMS_RTEMS_BARRIER_H
57#define _RTEMS_RTEMS_BARRIER_H
58
59#include <stdint.h>
60#include <rtems/rtems/attr.h>
61#include <rtems/rtems/status.h>
62#include <rtems/rtems/types.h>
63
64#ifdef __cplusplus
65extern "C" {
66#endif
67
68/* Generated from spec:/rtems/barrier/if/group */
69
79/* Generated from spec:/rtems/barrier/if/create */
80
168 rtems_name name,
169 rtems_attribute attribute_set,
170 uint32_t maximum_waiters,
171 rtems_id *id
172);
173
174/* Generated from spec:/rtems/barrier/if/ident */
175
222
223/* Generated from spec:/rtems/barrier/if/delete */
224
264
265/* Generated from spec:/rtems/barrier/if/wait */
266
313
314/* Generated from spec:/rtems/barrier/if/release */
315
350rtems_status_code rtems_barrier_release( rtems_id id, uint32_t *released );
351
352#ifdef __cplusplus
353}
354#endif
355
356#endif /* _RTEMS_RTEMS_BARRIER_H */
This header file provides Classic API directive attributes.
This header file provides types used by the Classic API.
uint32_t rtems_attribute
This type represents Classic API attributes.
Definition: attr.h:96
rtems_status_code rtems_barrier_wait(rtems_id id, rtems_interval timeout)
Waits at the barrier.
Definition: barrierwait.c:51
rtems_status_code rtems_barrier_delete(rtems_id id)
Deletes the barrier.
Definition: barrierdelete.c:44
rtems_status_code rtems_barrier_create(rtems_name name, rtems_attribute attribute_set, uint32_t maximum_waiters, rtems_id *id)
Creates a barrier.
Definition: barriercreate.c:49
rtems_status_code rtems_barrier_release(rtems_id id, uint32_t *released)
Releases the barrier.
Definition: barrierrelease.c:44
rtems_status_code rtems_barrier_ident(rtems_name name, rtems_id *id)
Identifies a barrier by the object name.
Definition: barrierident.c:45
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition: types.h:114
This header file provides the status codes of Classic API directives and support functions.
