RTEMS 6.1-rc2
au1x00.h File Reference
struct  au1x00_macdma_rx_t
struct  au1x00_macdma_tx_t
struct  au1x00_uart_t
#define bit(x)   (1 << (x))
#define CP0_Index   $0
#define CP0_Random   $1
#define CP0_EntryLo0   $2
#define CP0_EntryLo1   $3
#define CP0_Context   $4
#define CP0_PageMask   $5
#define CP0_Wired   $6
#define CP0_BadVAddr   $8
#define CP0_Count   $9
#define CP0_EntryHi   $10
#define CP0_Compare   $11
#define CP0_Status   $12
#define CP0_Cause   $13
#define CP0_EPC   $14
#define CP0_PRId   $15
#define CP0_Config   $16
#define CP0_Config0   $16
#define CP0_Config1   $16,1
#define CP0_LLAddr   $17
#define CP0_WatchLo   $18
#define CP0_IWatchLo   $18,1
#define CP0_WatchHi   $19
#define CP0_IWatchHi   $19,1
#define CP0_Scratch   $22
#define CP0_Debug   $23
#define CP0_DEPC   $24
#define CP0_PerfCnt   $25
#define CP0_PerfCtrl   $25,1
#define CP0_DTag   $28
#define CP0_DData   $28,1
#define CP0_ITag   $29
#define CP0_IData   $29,1
#define CP0_ErrorEPC   $30
#define CP0_DESave   $31
#define AU1X00_MEM_ADDR   0xB4000000
#define AU1X00_AC97_ADDR   0xB0000000
#define AU1X00_USBH_ADDR   0xB0100000
#define AU1X00_USBD_ADDR   0xB0200000
#define AU1X00_MACDMA0_ADDR   0xB4004000
#define AU1X00_MACDMA1_ADDR   0xB4004200
#define AU1X00_UART0_ADDR   0xB1100000
#define AU1X00_UART3_ADDR   0xB1400000
#define AU1X00_SYS_ADDR   0xB1900000
#define AU1X00_GPIO2_ADDR   0xB1700000
#define AU1X00_IC0_ADDR   0xB0400000
#define AU1X00_IC1_ADDR   0xB1800000
#define AU1100_MAC0_ADDR   0xB0500000
#define AU1100_MACEN_ADDR   0xB0520000
#define AU1500_MAC0_ADDR   0xB1500000
#define AU1500_MAC1_ADDR   0xB1510000
#define AU1500_MACEN_ADDR   0xB1520000
#define AU1500_PCI_ADDR   0xB4005000
#define gpio2_dir   0x0000
#define gpio2_output   0x0008
#define gpio2_pinstate   0x000c
#define gpio2_inten   0x0010
#define gpio2_enable   0x0014
#define mem_sdmode0   0x0000
#define mem_sdmode1   0x0004
#define mem_sdmode2   0x0008
#define mem_sdaddr0   0x000C
#define mem_sdaddr1   0x0010
#define mem_sdaddr2   0x0014
#define mem_sdrefcfg   0x0018
#define mem_sdprecmd   0x001C
#define mem_sdautoref   0x0020
#define mem_sdwrmd0   0x0024
#define mem_sdwrmd1   0x0028
#define mem_sdwrmd2   0x002C
#define mem_sdsleep   0x0030
#define mem_sdsmcke   0x0034
#define mem_stcfg0   0x1000
#define mem_sttime0   0x1004
#define mem_staddr0   0x1008
#define mem_stcfg1   0x1010
#define mem_sttime1   0x1014
#define mem_staddr1   0x1018
#define mem_stcfg2   0x1020
#define mem_sttime2   0x1024
#define mem_staddr2   0x1028
#define mem_stcfg3   0x1030
#define mem_sttime3   0x1034
#define mem_staddr3   0x1038
#define ac97_enable   0x0010
#define usbh_enable   0x0007FFFC
#define usbd_enable   0x0058
#define irda_enable   0x0040
#define macen_mac0   0x0000
#define macen_mac1   0x0004
#define i2s_enable   0x0008
#define uart_enable   0x0100
#define ssi_enable   0x0100
#define sys_scratch0   0x0018
#define sys_scratch1   0x001c
#define sys_cntctrl   0x0014
#define sys_freqctrl0   0x0020
#define sys_freqctrl1   0x0024
#define sys_clksrc   0x0028
#define sys_pinfunc   0x002C
#define sys_powerctrl   0x003C
#define sys_endian   0x0038
#define sys_wakesrc   0x005C
#define sys_cpupll   0x0060
#define sys_auxpll   0x0064
#define sys_pininputen   0x0110
#define pci_cmem   0x0000
#define pci_config   0x0004
#define pci_b2bmask_cch   0x0008
#define pci_b2bbase0_venid   0x000C
#define pci_b2bbase1_id   0x0010
#define pci_mwmask_dev   0x0014
#define pci_mwbase_rev_ccl   0x0018
#define pci_err_addr   0x001C
#define pci_spec_intack   0x0020
#define pci_id   0x0100
#define pci_statcmd   0x0104
#define pci_classrev   0x0108
#define pci_hdrtype   0x010C
#define pci_mbar   0x0110
#define SYS_CPUPLL   33
#define SYS_POWERCTRL   1
#define SYS_AUXPLL   8
#define SYS_CNTCTRL   256
#define MEM_STCFG0   0x00000203
#define MEM_STTIME0   0x22080b20
#define MEM_STADDR0   0x11f03fc0
#define MEM_STCFG1   0x00000203
#define MEM_STTIME1   0x22080b20
#define MEM_STADDR1   0x11e03fc0
#define MEM_STCFG2   0x00000244
#define MEM_STTIME2   0x22080a20
#define MEM_STADDR2   0x11803f00
#define MEM_STCFG3   0x00000201
#define MEM_STTIME3   0x22080b20
#define MEM_STADDR3   0x11003f00
#define MEM_SDMODE0   0x00552229
#define MEM_SDMODE1   0x00552229
#define MEM_SDMODE2   0x00552229
#define MEM_SDADDR0   0x001003F8
#define MEM_SDADDR1   0x001023F8
#define MEM_SDADDR2   0x001043F8
#define MEM_SDREFCFG_D   0x74000c30 /* disable */
#define MEM_SDREFCFG_E   0x76000c30 /* enable */
#define MEM_SDWRMD0   0x00000023
#define MEM_SDWRMD1   0x00000023
#define MEM_SDWRMD2   0x00000023
#define MEM_1MS   ((396000000/1000000) * 1000)
#define AU1X00_IC_CFG0RD(x)   (*(volatile uint32_t*)(x + 0x40))
#define AU1X00_IC_CFG0SET(x)   (*(volatile uint32_t*)(x + 0x40))
#define AU1X00_IC_CFG0CLR(x)   (*(volatile uint32_t*)(x + 0x44))
#define AU1X00_IC_CFG1RD(x)   (*(volatile uint32_t*)(x + 0x48))
#define AU1X00_IC_CFG1SET(x)   (*(volatile uint32_t*)(x + 0x48))
#define AU1X00_IC_CFG1CLR(x)   (*(volatile uint32_t*)(x + 0x4c))
#define AU1X00_IC_CFG2RD(x)   (*(volatile uint32_t*)(x + 0x50))
#define AU1X00_IC_CFG2SET(x)   (*(volatile uint32_t*)(x + 0x50))
#define AU1X00_IC_CFG2CLR(x)   (*(volatile uint32_t*)(x + 0x54))
#define AU1X00_IC_REQ0INT(x)   (*(volatile uint32_t*)(x + 0x54))
#define AU1X00_IC_SRCRD(x)   (*(volatile uint32_t*)(x + 0x58))
#define AU1X00_IC_SRCSET(x)   (*(volatile uint32_t*)(x + 0x58))
#define AU1X00_IC_SRCCLR(x)   (*(volatile uint32_t*)(x + 0x5c))
#define AU1X00_IC_REQ1INT(x)   (*(volatile uint32_t*)(x + 0x5c))
#define AU1X00_IC_ASSIGNRD(x)   (*(volatile uint32_t*)(x + 0x60))
#define AU1X00_IC_ASSIGNSET(x)   (*(volatile uint32_t*)(x + 0x60))
#define AU1X00_IC_ASSIGNCLR(x)   (*(volatile uint32_t*)(x + 0x64))
#define AU1X00_IC_WAKERD(x)   (*(volatile uint32_t*)(x + 0x68))
#define AU1X00_IC_WAKESET(x)   (*(volatile uint32_t*)(x + 0x68))
#define AU1X00_IC_WAKECLR(x)   (*(volatile uint32_t*)(x + 0x6c))
#define AU1X00_IC_MASKRD(x)   (*(volatile uint32_t*)(x + 0x70))
#define AU1X00_IC_MASKSET(x)   (*(volatile uint32_t*)(x + 0x70))
#define AU1X00_IC_MASKCLR(x)   (*(volatile uint32_t*)(x + 0x74))
#define AU1X00_IC_RISINGRD(x)   (*(volatile uint32_t*)(x + 0x78))
#define AU1X00_IC_RISINGCLR(x)   (*(volatile uint32_t*)(x + 0x78))
#define AU1X00_IC_FALLINGRD(x)   (*(volatile uint32_t*)(x + 0x7c))
#define AU1X00_IC_FALLINGCLR(x)   (*(volatile uint32_t*)(x + 0x7c))
#define AU1X00_IC_TESTBIT(x)   (*(volatile uint32_t*)(x + 0x80))
#define AU1X00_IC_IRQ_MAC0   (bit(28))
#define AU1X00_IC_IRQ_MAC1   (bit(29))
#define AU1X00_IC_IRQ_TOY_MATCH0   (bit(15))
#define AU1X00_IC_IRQ_TOY_MATCH1   (bit(16))
#define AU1X00_IC_IRQ_TOY_MATCH2   (bit(17))
#define AU1X00_SYS_TOYTRIM(x)   (*(volatile uint32_t*)(x + 0x00))
#define AU1X00_SYS_TOYWRITE(x)   (*(volatile uint32_t*)(x + 0x04))
#define AU1X00_SYS_TOYMATCH0(x)   (*(volatile uint32_t*)(x + 0x08))
#define AU1X00_SYS_TOYMATCH1(x)   (*(volatile uint32_t*)(x + 0x0c))
#define AU1X00_SYS_TOYMATCH2(x)   (*(volatile uint32_t*)(x + 0x10))
#define AU1X00_SYS_CNTCTRL(x)   (*(volatile uint32_t*)(x + 0x14))
#define AU1X00_SYS_SCRATCH0(x)   (*(volatile uint32_t*)(x + 0x18))
#define AU1X00_SYS_SCRATCH1(x)   (*(volatile uint32_t*)(x + 0x1c))
#define AU1X00_SYS_WAKEMSK(x)   (*(volatile uint32_t*)(x + 0x34))
#define AU1X00_SYS_ENDIAN(x)   (*(volatile uint32_t*)(x + 0x38))
#define AU1X00_SYS_POWERCTRL(x)   (*(volatile uint32_t*)(x + 0x3c))
#define AU1X00_SYS_TOYREAD(x)   (*(volatile uint32_t*)(x + 0x40))
#define AU1X00_SYS_RTCTRIM(x)   (*(volatile uint32_t*)(x + 0x44))
#define AU1X00_SYS_RTCWRITE(x)   (*(volatile uint32_t*)(x + 0x48))
#define AU1X00_SYS_RTCMATCH0(x)   (*(volatile uint32_t*)(x + 0x4c))
#define AU1X00_SYS_RTCMATCH1(x)   (*(volatile uint32_t*)(x + 0x50))
#define AU1X00_SYS_RTCMATCH2(x)   (*(volatile uint32_t*)(x + 0x54))
#define AU1X00_SYS_RTCREAD(x)   (*(volatile uint32_t*)(x + 0x58))
#define AU1X00_SYS_WAKESRC(x)   (*(volatile uint32_t*)(x + 0x5c))
#define AU1X00_SYS_SLPPWR(x)   (*(volatile uint32_t*)(x + 0x78))
#define AU1X00_SYS_SLEEP(x)   (*(volatile uint32_t*)(x + 0x7c))
#define AU1X00_SYS_CNTCTRL_ERS   (bit(23))
#define AU1X00_SYS_CNTCTRL_RTS   (bit(20))
#define AU1X00_SYS_CNTCTRL_RM2   (bit(19))
#define AU1X00_SYS_CNTCTRL_RM1   (bit(18))
#define AU1X00_SYS_CNTCTRL_RM0   (bit(17))
#define AU1X00_SYS_CNTCTRL_RS   (bit(16))
#define AU1X00_SYS_CNTCTRL_BP   (bit(14))
#define AU1X00_SYS_CNTCTRL_REN   (bit(13))
#define AU1X00_SYS_CNTCTRL_BRT   (bit(12))
#define AU1X00_SYS_CNTCTRL_TEN   (bit(11))
#define AU1X00_SYS_CNTCTRL_BTT   (bit(10))
#define AU1X00_SYS_CNTCTRL_E0   (bit(8))
#define AU1X00_SYS_CNTCTRL_ETS   (bit(7))
#define AU1X00_SYS_CNTCTRL_32S   (bit(5))
#define AU1X00_SYS_CNTCTRL_TTS   (bit(4))
#define AU1X00_SYS_CNTCTRL_TM2   (bit(3))
#define AU1X00_SYS_CNTCTRL_TM1   (bit(2))
#define AU1X00_SYS_CNTCTRL_TM0   (bit(1))
#define AU1X00_SYS_CNTCTRL_TS   (bit(0))
#define AU1X00_SYS_WAKEMSK_M20   (bit(8))
#define AU1X00_MAC_CONTROL(x)   (*(volatile uint32_t*)(x + 0x00))
#define AU1X00_MAC_ADDRHIGH(x)   (*(volatile uint32_t*)(x + 0x04))
#define AU1X00_MAC_ADDRLOW(x)   (*(volatile uint32_t*)(x + 0x08))
#define AU1X00_MAC_HASHHIGH(x)   (*(volatile uint32_t*)(x + 0x0c))
#define AU1X00_MAC_HASHLOW(x)   (*(volatile uint32_t*)(x + 0x10))
#define AU1X00_MAC_MIICTRL(x)   (*(volatile uint32_t*)(x + 0x14))
#define AU1X00_MAC_MIIDATA(x)   (*(volatile uint32_t*)(x + 0x18))
#define AU1X00_MAC_FLOWCTRL(x)   (*(volatile uint32_t*)(x + 0x1c))
#define AU1X00_MAC_VLAN1(x)   (*(volatile uint32_t*)(x + 0x20))
#define AU1X00_MAC_VLAN2(x)   (*(volatile uint32_t*)(x + 0x24))
#define AU1X00_MAC_EN0   (*(volatile uint32_t*)(AU1X00_MACEN_ADDR + 0x0))
#define AU1X00_MAC_EN1   (*(volatile uint32_t*)(AU1X00_MACEN_ADDR + 0x4))
#define AU1X00_MAC_DMA_TX0_ADDR(x)   (*(volatile uint32_t*)(x + 0x000))
#define AU1X00_MAC_DMA_TX1_ADDR(x)   (*(volatile uint32_t*)(x + 0x010))
#define AU1X00_MAC_DMA_TX2_ADDR(x)   (*(volatile uint32_t*)(x + 0x020))
#define AU1X00_MAC_DMA_TX3_ADDR(x)   (*(volatile uint32_t*)(x + 0x030))
#define AU1X00_MAC_DMA_RX0_ADDR(x)   (*(volatile uint32_t*)(x + 0x100))
#define AU1X00_MAC_DMA_RX1_ADDR(x)   (*(volatile uint32_t*)(x + 0x110))
#define AU1X00_MAC_DMA_RX2_ADDR(x)   (*(volatile uint32_t*)(x + 0x120))
#define AU1X00_MAC_DMA_RX3_ADDR(x)   (*(volatile uint32_t*)(x + 0x130))
#define AU1X00_MAC_CTRL_RA   (bit(31))
#define AU1X00_MAC_CTRL_EM   (bit(30))
#define AU1X00_MAC_CTRL_DO   (bit(23))
#define AU1X00_MAC_CTRL_LM(x)   ((x) << 21)
#define AU1X00_MAC_CTRL_LM_NORMAL   ((0) << 21)
#define AU1X00_MAC_CTRL_LM_INTERNAL   ((1) << 21)
#define AU1X00_MAC_CTRL_LM_EXTERNAL   ((2) << 21)
#define AU1X00_MAC_CTRL_F   (bit(20))
#define AU1X00_MAC_CTRL_PM   (bit(19))
#define AU1X00_MAC_CTRL_PR   (bit(18))
#define AU1X00_MAC_CTRL_IF   (bit(17))
#define AU1X00_MAC_CTRL_PB   (bit(16))
#define AU1X00_MAC_CTRL_HO   (bit(15))
#define AU1X00_MAC_CTRL_HP   (bit(13))
#define AU1X00_MAC_CTRL_LC   (bit(12))
#define AU1X00_MAC_CTRL_DB   (bit(11))
#define AU1X00_MAC_CTRL_DR   (bit(10))
#define AU1X00_MAC_CTRL_AP   (bit(8))
#define AU1X00_MAC_CTRL_BL(x)   ((x) << 6)
#define AU1X00_MAC_CTRL_DC   (bit(5))
#define AU1X00_MAC_CTRL_TE   (bit(3))
#define AU1X00_MAC_CTRL_RE   (bit(2))
#define AU1X00_MAC_EN_JP   (bit(6))
#define AU1X00_MAC_EN_E2   (bit(5))
#define AU1X00_MAC_EN_E1   (bit(4))
#define AU1X00_MAC_EN_C   (bit(3))
#define AU1X00_MAC_EN_TS   (bit(2))
#define AU1X00_MAC_EN_E0   (bit(1))
#define AU1X00_MAC_EN_CE   (bit(0))
#define AU1X00_MAC_ADDRHIGH_MASK   (0xffff)_
#define AU1X00_MAC_MIICTRL_PHYADDR(x)   ((x & 0x1f) << 11)
#define AU1X00_MAC_MIICTRL_MIIREG(x)   ((x & 0x1f) << 6)
#define AU1X00_MAC_MIICTRL_MW   (bit(1))
#define AU1X00_MAC_MIICTRL_MB   (bit(0))
#define AU1X00_MAC_MIIDATA_MASK   (0xffff)
#define AU1X00_MAC_FLOWCTRL_PT(x)   (((x) & 0xffff) << 16)
#define AU1X00_MAC_FLOWCTRL_PC   (bit(2))
#define AU1X00_MAC_FLOWCTRL_FE   (bit(1))
#define AU1X00_MAC_FLOWCTRL_FB   (bit(0))
#define AU1X00_MAC_DMA_RXSTAT_MI   (bit(31))
#define AU1X00_MAC_DMA_RXSTAT_PF   (bit(30))
#define AU1X00_MAC_DMA_RXSTAT_FF   (bit(29))
#define AU1X00_MAC_DMA_RXSTAT_BF   (bit(28))
#define AU1X00_MAC_DMA_RXSTAT_MF   (bit(27))
#define AU1X00_MAC_DMA_RXSTAT_UC   (bit(26))
#define AU1X00_MAC_DMA_RXSTAT_CF   (bit(25))
#define AU1X00_MAC_DMA_RXSTAT_LE   (bit(24))
#define AU1X00_MAC_DMA_RXSTAT_V2   (bit(23))
#define AU1X00_MAC_DMA_RXSTAT_V1   (bit(22))
#define AU1X00_MAC_DMA_RXSTAT_CR   (bit(21))
#define AU1X00_MAC_DMA_RXSTAT_DB   (bit(20))
#define AU1X00_MAC_DMA_RXSTAT_ME   (bit(19))
#define AU1X00_MAC_DMA_RXSTAT_FT   (bit(18))
#define AU1X00_MAC_DMA_RXSTAT_CS   (bit(17))
#define AU1X00_MAC_DMA_RXSTAT_FL   (bit(16))
#define AU1X00_MAC_DMA_RXSTAT_RF   (bit(15))
#define AU1X00_MAC_DMA_RXSTAT_WT   (bit(14))
#define AU1X00_MAC_DMA_RXSTAT_LEN(x)   ((x) & 0x3fff)
#define AU1X00_MAC_DMA_RXADDR_ADDR(x)   ((x) & ~0x1f)
#define AU1X00_MAC_DMA_RXADDR_CB_MASK   (0x3 << 0x2)
#define AU1X00_MAC_DMA_RXADDR_DN   (bit(1))
#define AU1X00_MAC_DMA_RXADDR_EN   (bit(0))
#define AU1X00_MAC_DMA_TXSTAT_PR   (bit(31))
#define AU1X00_MAC_DMA_TXSTAT_CC_MASK   (0xf << 10)
#define AU1X00_MAC_DMA_TXSTAT_LO   (bit(9))
#define AU1X00_MAC_DMA_TXSTAT_DF   (bit(8))
#define AU1X00_MAC_DMA_TXSTAT_UR   (bit(7))
#define AU1X00_MAC_DMA_TXSTAT_EC   (bit(6))
#define AU1X00_MAC_DMA_TXSTAT_LC   (bit(5))
#define AU1X00_MAC_DMA_TXSTAT_ED   (bit(4))
#define AU1X00_MAC_DMA_TXSTAT_LS   (bit(3))
#define AU1X00_MAC_DMA_TXSTAT_NC   (bit(2))
#define AU1X00_MAC_DMA_TXSTAT_JT   (bit(1))
#define AU1X00_MAC_DMA_TXSTAT_FA   (bit(0))
#define AU1X00_MAC_DMA_TXADDR_ADDR(x)   ((x) & ~0x1f)
#define AU1X00_MAC_DMA_TXADDR_CB_MASK   (0x3 << 0x2)
#define AU1X00_MAC_DMA_TXADDR_DN   (bit(1))
#define AU1X00_MAC_DMA_TXADDR_EN   (bit(0))
void mips_default_isr (int vector)
int assert_sw_irq (uint32_t irqnum)
int negate_sw_irq (uint32_t irqnum)
au1x00_uart_tuart0
au1x00_uart_tuart3
AMD AU1X00 specific information
