RTEMS 6.1-rc2
atsam-spi.h
2
3/*
4 * Copyright (c) 2016 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef LIBBSP_ARM_ATSAM_ATSAM_SPI_H
29#define LIBBSP_ARM_ATSAM_ATSAM_SPI_H
30
31#include <libchip/chip.h>
32
33#ifdef __cplusplus
34extern "C" {
35#endif /* __cplusplus */
36
37typedef struct {
38 uint8_t spi_peripheral_id;
39 const Pin *pins;
40 Spi *spi_regs;
41 size_t pin_count;
42 bool chip_select_decode;
43
44 /* Delay before SCLK in ns */
45 uint32_t dlybs_in_ns[4];
46
47 /* Delay before consecutive word transfers in ns */
48 uint32_t dlybct_in_ns[4];
50
51int spi_bus_register_atsam(
52 const char *bus_path,
54);
55
56#ifdef __cplusplus
57}
58#endif /* __cplusplus */
59
60#endif /* LIBBSP_ARM_ATSAM_ATSAM_SPI_H */
Spi hardware registers.
Definition: component_spi.h:41
Definition: pio.h:172
Definition: atsam-spi.h:37
Definition: deflate.c:114
