RTEMS
6.1-rc2
bsps
arm
include
bsp
arm-pl111-fb.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (c) 2013 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_SHARED_ARM_PL111_FB_H
37
#define LIBBSP_ARM_SHARED_ARM_PL111_FB_H
38
39
bsp/arm-pl111-regs.h
40
41
typedef
struct
pl111_fb_config
42
volatile
pl111
*regs;
43
uint32_t timing0;
44
uint32_t timing1;
45
uint32_t timing2;
46
uint32_t timing3;
47
uint32_t
control
48
uint32_t power_delay_in_us;
49
void (*set_up)(
const
struct
pl111_fb_config
*cfg);
50
void (*pins_set_up)(
const
struct
pl111_fb_config
*cfg);
51
void (*pins_tear_down)(
const
struct
pl111_fb_config
*cfg);
52
void (*tear_down)(
const
struct
pl111_fb_config
*cfg);
53
pl111_fb_config
54
55
const
pl111_fb_config
*arm_pl111_fb_get_config(
void
56
57
#endif
/* LIBBSP_ARM_SHARED_ARM_PL111_FB_H */
arm-pl111-regs.h
ARM PL111 Register definitions.
control
Definition:
intercom.c:87
pl111_fb_config
Definition:
arm-pl111-fb.h:41
pl111
Definition:
arm-pl111-regs.h:191
