RTEMS 6.1-rc2
ambapp_bus.h
2
3/* General part of a AMBA Plug & Play bus driver.
4 *
5 * COPYRIGHT (c) 2008.
6 * Cobham Gaisler AB.
7 *
8 * This is the general part of the different AMBA Plug & Play
9 * drivers. The drivers are wrappers around this driver, making
10 * the code size smaller for systems with multiple AMBA Plug &
11 * Play buses.
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#ifndef __AMBAPP_BUS_H__
36#define __AMBAPP_BUS_H__
37
38#include <drvmgr/drvmgr.h>
39#include "ambapp.h"
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
45/* GRLIB AMBA Plug&Play Driver ID generation */
46#define DRIVER_AMBAPP_ID(vendor, device) \
47 DRIVER_ID(DRVMGR_BUS_TYPE_AMBAPP, ((((vendor) & 0xff) << 16) | ((device) & 0xfff)))
48
49/*** Gaisler Hardware Device Driver IDs ***/
50#define DRIVER_AMBAPP_GAISLER_AHBSTAT_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_AHBSTAT)
51#define DRIVER_AMBAPP_GAISLER_APBUART_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_APBUART)
52#define DRIVER_AMBAPP_GAISLER_B1553BRM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_B1553BRM)
53#define DRIVER_AMBAPP_GAISLER_B1553RT_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_B1553RT)
54#define DRIVER_AMBAPP_GAISLER_GPTIMER_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GPTIMER)
55#define DRIVER_AMBAPP_GAISLER_GR1553B_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GR1553B)
56#define DRIVER_AMBAPP_GAISLER_GRADCDAC_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRADCDAC)
57#define DRIVER_AMBAPP_GAISLER_GRAES_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRAESDMA)
58#define DRIVER_AMBAPP_GAISLER_GRCAN_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRCAN)
59#define DRIVER_AMBAPP_GAISLER_GRCTM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRCTM)
60#define DRIVER_AMBAPP_GAISLER_GRETH_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_ETHMAC)
61#define DRIVER_AMBAPP_GAISLER_GRGPIO_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GPIO)
62#define DRIVER_AMBAPP_GAISLER_GRPCI2_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRPCI2)
63#define DRIVER_AMBAPP_GAISLER_GRIOMMU_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRIOMMU)
64#define DRIVER_AMBAPP_GAISLER_GRPCI_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PCIFBRG)
65#define DRIVER_AMBAPP_GAISLER_GRPWM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRPWM)
66#define DRIVER_AMBAPP_GAISLER_GRPWRX_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PW2APB)
67#define DRIVER_AMBAPP_GAISLER_GRSPW_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW)
68#define DRIVER_AMBAPP_GAISLER_GRSPW2_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW2)
69#define DRIVER_AMBAPP_GAISLER_GRTC_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRTC)
70#define DRIVER_AMBAPP_GAISLER_GRTM_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_GRTM)
71#define DRIVER_AMBAPP_GAISLER_I2CMST_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_I2CMST)
72#define DRIVER_AMBAPP_GAISLER_OCCAN_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_CANAHB)
73#define DRIVER_AMBAPP_GAISLER_PCIF_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PCIF)
74#define DRIVER_AMBAPP_GAISLER_PCITRACE_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_PCITRACE)
75#define DRIVER_AMBAPP_GAISLER_SPICTRL_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPICTRL)
76#define DRIVER_AMBAPP_GAISLER_SPWCUC_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPWCUC)
77#define DRIVER_AMBAPP_GAISLER_SPW_ROUTER_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPW_ROUTER)
78#define DRIVER_AMBAPP_GAISLER_L2CACHE_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_L2CACHE)
79#define DRIVER_AMBAPP_GAISLER_MEMSCRUB_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_MEMSCRUB)
80#define DRIVER_AMBAPP_GAISLER_L4STAT_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_L4STAT)
81#define DRIVER_AMBAPP_GAISLER_SPWTDP_ID DRIVER_AMBAPP_ID(VENDOR_GAISLER, GAISLER_SPWTDP)
82
83/*** ESA Hardware Device Driver IDs ***/
84#define DRIVER_AMBAPP_ESA_MCTRL_ID DRIVER_AMBAPP_ID(VENDOR_ESA, ESA_MCTRL)
85#define DRIVER_AMBAPP_MCTRL_ID DRIVER_AMBAPP_ESA_MCTRL_ID
86
88 unsigned short vendor;
89 unsigned short device;
90 /* Version ? */
91};
92
94 struct drvmgr_drv general; /* General bus info */
95 /* AMBA specific bus information */
96 struct amba_dev_id *ids; /* Supported hardware */
97};
98
100 struct amba_dev_id id;
101 struct ambapp_core info;
102};
103
105 int (*int_register)
106 (struct drvmgr_dev *dev, int index, const char *info, drvmgr_isr isr, void *arg);
107 int (*int_unregister)
108 (struct drvmgr_dev *dev, int index, drvmgr_isr isr, void *arg);
109 int (*int_clear)(struct drvmgr_dev *dev, int index);
110 int (*int_mask)(struct drvmgr_dev *dev, int index);
111 int (*int_unmask)(struct drvmgr_dev *dev, int index);
112#ifdef RTEMS_SMP
113 int (*int_set_affinity)(struct drvmgr_dev *dev, int index,
114 const Processor_mask *cpus);
115#endif
116 int (*get_params)
117 (struct drvmgr_dev *, struct drvmgr_bus_params *);
118};
119
121 struct ambapp_bus *abus; /* Prescanned AMBA PnP bus */
122 struct ambapp_ops *ops; /* AMBA bus operations */
123 struct drvmgr_map_entry *maps_up; /* Bus memory map up-stream towards CPU */
124 struct drvmgr_map_entry *maps_down; /* Bus memory map down-stream towards HW */
125 struct drvmgr_bus_res *resources; /* Driver Resources */
126 int bus_type; /* Set DRVMGR_BUS_TYPE_AMBAPP_DIST if distributed AMBA Bus */
127 struct drvmgr_func *funcs; /* Custom functions */
128};
129
130/*** Bus operations with READ/WRITE access operations ***
131 *
132 * The functions are implemented using the standard drvmgr RW interface
133 */
134#define AMBAPP_R8 DRVMGR_RWFUNC(RW_SIZE_1|RW_READ|RW_REG)
135#define AMBAPP_R16 DRVMGR_RWFUNC(RW_SIZE_2|RW_READ|RW_REG)
136#define AMBAPP_R32 DRVMGR_RWFUNC(RW_SIZE_4|RW_READ|RW_REG)
137#define AMBAPP_R64 DRVMGR_RWFUNC(RW_SIZE_8|RW_READ|RW_REG)
138#define AMBAPP_W8 DRVMGR_RWFUNC(RW_SIZE_1|RW_WRITE|RW_REG)
139#define AMBAPP_W16 DRVMGR_RWFUNC(RW_SIZE_2|RW_WRITE|RW_REG)
140#define AMBAPP_W32 DRVMGR_RWFUNC(RW_SIZE_4|RW_WRITE|RW_REG)
141#define AMBAPP_W64 DRVMGR_RWFUNC(RW_SIZE_8|RW_WRITE|RW_REG)
142#define AMBAPP_RMEM DRVMGR_RWFUNC(RW_SIZE_ANY|RW_READ|RW_MEM)
143#define AMBAPP_WMEM DRVMGR_RWFUNC(RW_SIZE_ANY|RW_WRITE|RW_MEM)
144#define AMBAPP_MEMSET DRVMGR_RWFUNC(RW_SIZE_ANY|RW_SET|RW_MEM)
145#define AMBAPP_RW_ARG DRVMGR_RWFUNC(RW_ARG)
146
147/* Register an ambapp bus on-top of a device */
148extern int ambapp_bus_register(
149 struct drvmgr_dev *dev,
150 struct ambapp_config *config
151 );
152
153extern void ambapp_bus_freq_register(
154 struct drvmgr_dev *dev,
155 int amba_interface,
156 unsigned int freq_hz);
157
158#ifdef __cplusplus
159}
160#endif
161
162#endif
Driver Manager Interface.
Definition: ambapp_bus.h:87
Definition: ambapp_bus.h:99
Definition: ambapp_bus.h:93
Definition: ambapp.h:133
Definition: ambapp_bus.h:120
Definition: ambapp.h:109
Definition: ambapp_bus.h:104
Definition: deflate.c:114
Definition: drvmgr.h:145
Definition: drvmgr.h:238
Definition: drvmgr.h:297
Definition: drvmgr.h:327
Definition: drvmgr.h:182
Definition: drvmgr.h:249
