RTEMS 6.1-rc2
alt_sdr.h
1
7/*******************************************************************************
8* *
9* Copyright 2013 Altera Corporation. All Rights Reserved. *
10* *
11* Redistribution and use in source and binary forms, with or without *
12* modification, are permitted provided that the following conditions are met: *
13* *
14* 1. Redistributions of source code must retain the above copyright notice, *
15* this list of conditions and the following disclaimer. *
16* *
17* 2. Redistributions in binary form must reproduce the above copyright notice, *
18* this list of conditions and the following disclaimer in the documentation *
19* and/or other materials provided with the distribution. *
20* *
21* 3. The name of the author may not be used to endorse or promote products *
22* derived from this software without specific prior written permission. *
23* *
24* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34* *
35*******************************************************************************/
36
37/* Altera - ALT_SDR */
38
39#ifndef __ALTERA_ALT_SDR_H__
40#define __ALTERA_ALT_SDR_H__
41
42#ifdef __cplusplus
43extern "C"
44{
45#endif /* __cplusplus */
46
47/*
48 * Component : SDRAM Controller - ALT_SDR
49 * SDRAM Controller
50 *
51 * Address map for the SDRAM Interface registers
52 *
53 */
54/*
55 * Register Group : SDRAM Controller Module - ALT_SDR_CTL
56 * SDRAM Controller Module
57 *
58 * Address map for the SDRAM controller and multi-port front-end.
59 *
60 * All registers in this group reset to zero.
61 *
62 */
63/*
64 * Register : Controller Configuration Register - ctrlcfg
65 *
66 * The Controller Configuration Register determines the behavior of the controller.
67 *
68 * Register Layout
69 *
70 * Bits | Access | Reset | Description
71 * :--------|:-------|:--------|:---------------------------
72 * [2:0] | RW | Unknown | DRAM Memory Type
73 * [7:3] | RW | Unknown | DRAM Memory Burst Length
74 * [9:8] | RW | Unknown | Address Interleaving Order
75 * [10] | RW | Unknown | ECC Enable
76 * [11] | RW | Unknown | ECC Auto-Correction Enable
77 * [12] | RW | Unknown | TBD
78 * [13] | RW | Unknown | Generate Single Bit Errors
79 * [14] | RW | Unknown | Generate Double Bit Errors
80 * [15] | RW | Unknown | Command Reorder Enable
81 * [21:16] | RW | Unknown | Starvation Limit
82 * [22] | RW | Unknown | DQS Tracking Enable
83 * [23] | RW | Unknown | No DM Pins Present
84 * [24] | RW | Unknown | Burst Interrupt Enable
85 * [25] | RW | Unknown | Burst Terminate Enable
86 * [31:26] | ??? | Unknown | *UNDEFINED*
87 *
88 */
89/*
90 * Field : DRAM Memory Type - memtype
91 *
92 * Selects memory type. Program this field with one of the following binary values,
93 * "001" for DDR2 SDRAM, "010" for DDR3 SDRAM, "011"
94 * for LPDDR1 SDRAM or "100" for LPDDR2 SDRAM.
95 *
96 * Field Access Macros:
97 *
98 */
99/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field. */
100#define ALT_SDR_CTL_CTLCFG_MEMTYPE_LSB 0
101/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field. */
102#define ALT_SDR_CTL_CTLCFG_MEMTYPE_MSB 2
103/* The width in bits of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field. */
104#define ALT_SDR_CTL_CTLCFG_MEMTYPE_WIDTH 3
105/* The mask used to set the ALT_SDR_CTL_CTLCFG_MEMTYPE register field value. */
106#define ALT_SDR_CTL_CTLCFG_MEMTYPE_SET_MSK 0x00000007
107/* The mask used to clear the ALT_SDR_CTL_CTLCFG_MEMTYPE register field value. */
108#define ALT_SDR_CTL_CTLCFG_MEMTYPE_CLR_MSK 0xfffffff8
109/* The reset value of the ALT_SDR_CTL_CTLCFG_MEMTYPE register field is UNKNOWN. */
110#define ALT_SDR_CTL_CTLCFG_MEMTYPE_RESET 0x0
111/* Extracts the ALT_SDR_CTL_CTLCFG_MEMTYPE field value from a register. */
112#define ALT_SDR_CTL_CTLCFG_MEMTYPE_GET(value) (((value) & 0x00000007) >> 0)
113/* Produces a ALT_SDR_CTL_CTLCFG_MEMTYPE register field value suitable for setting the register. */
114#define ALT_SDR_CTL_CTLCFG_MEMTYPE_SET(value) (((value) << 0) & 0x00000007)
115
116/*
117 * Field : DRAM Memory Burst Length - membl
118 *
119 * Configures burst length as a static decimal value. Legal values are valid for
120 * JEDEC allowed DRAM values for the DRAM selected in cfg_type. For DDR3, this
121 * should be programmed with 8 (binary &quot;01000&quot;), for DDR2 it can be
122 * either 4 or 8 depending on the exact DRAM chip. LPDDR2 can be programmed with
123 * 4, 8, or 16 and LPDDR can be programmed with 2, 4, or 8. You must also program
124 * the membl field in the staticcfg register.
125 *
126 * Field Access Macros:
127 *
128 */
129/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_MEMBL register field. */
130#define ALT_SDR_CTL_CTLCFG_MEMBL_LSB 3
131/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_MEMBL register field. */
132#define ALT_SDR_CTL_CTLCFG_MEMBL_MSB 7
133/* The width in bits of the ALT_SDR_CTL_CTLCFG_MEMBL register field. */
134#define ALT_SDR_CTL_CTLCFG_MEMBL_WIDTH 5
135/* The mask used to set the ALT_SDR_CTL_CTLCFG_MEMBL register field value. */
136#define ALT_SDR_CTL_CTLCFG_MEMBL_SET_MSK 0x000000f8
137/* The mask used to clear the ALT_SDR_CTL_CTLCFG_MEMBL register field value. */
138#define ALT_SDR_CTL_CTLCFG_MEMBL_CLR_MSK 0xffffff07
139/* The reset value of the ALT_SDR_CTL_CTLCFG_MEMBL register field is UNKNOWN. */
140#define ALT_SDR_CTL_CTLCFG_MEMBL_RESET 0x0
141/* Extracts the ALT_SDR_CTL_CTLCFG_MEMBL field value from a register. */
142#define ALT_SDR_CTL_CTLCFG_MEMBL_GET(value) (((value) & 0x000000f8) >> 3)
143/* Produces a ALT_SDR_CTL_CTLCFG_MEMBL register field value suitable for setting the register. */
144#define ALT_SDR_CTL_CTLCFG_MEMBL_SET(value) (((value) << 3) & 0x000000f8)
145
146/*
147 * Field : Address Interleaving Order - addrorder
148 *
149 * Selects the order for address interleaving. Programming this field with
150 * different values gives different mappings between the AXI or Avalon-MM address
151 * and the SDRAM address. Program this field with the following binary values to
152 * select the ordering. &quot;00&quot; - chip, row, bank, column, &quot;01&quot; -
153 * chip, bank, row, column, &quot;10&quot;-row, chip, bank, column
154 *
155 * Field Access Macros:
156 *
157 */
158/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field. */
159#define ALT_SDR_CTL_CTLCFG_ADDRORDER_LSB 8
160/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field. */
161#define ALT_SDR_CTL_CTLCFG_ADDRORDER_MSB 9
162/* The width in bits of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field. */
163#define ALT_SDR_CTL_CTLCFG_ADDRORDER_WIDTH 2
164/* The mask used to set the ALT_SDR_CTL_CTLCFG_ADDRORDER register field value. */
165#define ALT_SDR_CTL_CTLCFG_ADDRORDER_SET_MSK 0x00000300
166/* The mask used to clear the ALT_SDR_CTL_CTLCFG_ADDRORDER register field value. */
167#define ALT_SDR_CTL_CTLCFG_ADDRORDER_CLR_MSK 0xfffffcff
168/* The reset value of the ALT_SDR_CTL_CTLCFG_ADDRORDER register field is UNKNOWN. */
169#define ALT_SDR_CTL_CTLCFG_ADDRORDER_RESET 0x0
170/* Extracts the ALT_SDR_CTL_CTLCFG_ADDRORDER field value from a register. */
171#define ALT_SDR_CTL_CTLCFG_ADDRORDER_GET(value) (((value) & 0x00000300) >> 8)
172/* Produces a ALT_SDR_CTL_CTLCFG_ADDRORDER register field value suitable for setting the register. */
173#define ALT_SDR_CTL_CTLCFG_ADDRORDER_SET(value) (((value) << 8) & 0x00000300)
174
175/*
176 * Field : ECC Enable - eccen
177 *
178 * Enable the generation and checking of ECC. This bit must only be set if the
179 * memory connected to the SDRAM interface is 24 or 40 bits wide. If you set this,
180 * you must clear the useeccasdata field in the staticcfg register.
181 *
182 * Field Access Macros:
183 *
184 */
185/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_ECCEN register field. */
186#define ALT_SDR_CTL_CTLCFG_ECCEN_LSB 10
187/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_ECCEN register field. */
188#define ALT_SDR_CTL_CTLCFG_ECCEN_MSB 10
189/* The width in bits of the ALT_SDR_CTL_CTLCFG_ECCEN register field. */
190#define ALT_SDR_CTL_CTLCFG_ECCEN_WIDTH 1
191/* The mask used to set the ALT_SDR_CTL_CTLCFG_ECCEN register field value. */
192#define ALT_SDR_CTL_CTLCFG_ECCEN_SET_MSK 0x00000400
193/* The mask used to clear the ALT_SDR_CTL_CTLCFG_ECCEN register field value. */
194#define ALT_SDR_CTL_CTLCFG_ECCEN_CLR_MSK 0xfffffbff
195/* The reset value of the ALT_SDR_CTL_CTLCFG_ECCEN register field is UNKNOWN. */
196#define ALT_SDR_CTL_CTLCFG_ECCEN_RESET 0x0
197/* Extracts the ALT_SDR_CTL_CTLCFG_ECCEN field value from a register. */
198#define ALT_SDR_CTL_CTLCFG_ECCEN_GET(value) (((value) & 0x00000400) >> 10)
199/* Produces a ALT_SDR_CTL_CTLCFG_ECCEN register field value suitable for setting the register. */
200#define ALT_SDR_CTL_CTLCFG_ECCEN_SET(value) (((value) << 10) & 0x00000400)
201
202/*
203 * Field : ECC Auto-Correction Enable - ecccorren
204 *
205 * Enable auto correction of the read data returned when single bit error is
206 * detected.
207 *
208 * Field Access Macros:
209 *
210 */
211/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field. */
212#define ALT_SDR_CTL_CTLCFG_ECCCORREN_LSB 11
213/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field. */
214#define ALT_SDR_CTL_CTLCFG_ECCCORREN_MSB 11
215/* The width in bits of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field. */
216#define ALT_SDR_CTL_CTLCFG_ECCCORREN_WIDTH 1
217/* The mask used to set the ALT_SDR_CTL_CTLCFG_ECCCORREN register field value. */
218#define ALT_SDR_CTL_CTLCFG_ECCCORREN_SET_MSK 0x00000800
219/* The mask used to clear the ALT_SDR_CTL_CTLCFG_ECCCORREN register field value. */
220#define ALT_SDR_CTL_CTLCFG_ECCCORREN_CLR_MSK 0xfffff7ff
221/* The reset value of the ALT_SDR_CTL_CTLCFG_ECCCORREN register field is UNKNOWN. */
222#define ALT_SDR_CTL_CTLCFG_ECCCORREN_RESET 0x0
223/* Extracts the ALT_SDR_CTL_CTLCFG_ECCCORREN field value from a register. */
224#define ALT_SDR_CTL_CTLCFG_ECCCORREN_GET(value) (((value) & 0x00000800) >> 11)
225/* Produces a ALT_SDR_CTL_CTLCFG_ECCCORREN register field value suitable for setting the register. */
226#define ALT_SDR_CTL_CTLCFG_ECCCORREN_SET(value) (((value) << 11) & 0x00000800)
227
228/*
229 * Field : TBD - cfg_enable_ecc_code_overwrites
230 *
231 * Set to a one to enable ECC overwrites. ECC overwrites occur when a correctable
232 * ECC error is seen and cause a new read/modify/write to be scheduled for that
233 * location to clear the ECC error.
234 *
235 * Field Access Macros:
236 *
237 */
238/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field. */
239#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_LSB 12
240/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field. */
241#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_MSB 12
242/* The width in bits of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field. */
243#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_WIDTH 1
244/* The mask used to set the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field value. */
245#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_SET_MSK 0x00001000
246/* The mask used to clear the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field value. */
247#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_CLR_MSK 0xffffefff
248/* The reset value of the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field is UNKNOWN. */
249#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_RESET 0x0
250/* Extracts the ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS field value from a register. */
251#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_GET(value) (((value) & 0x00001000) >> 12)
252/* Produces a ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS register field value suitable for setting the register. */
253#define ALT_SDR_CTL_CTLCFG_CFG_EN_ECC_CODE_OVERWRS_SET(value) (((value) << 12) & 0x00001000)
254
255/*
256 * Field : Generate Single Bit Errors - gensbe
257 *
258 * Enable the deliberate insertion of single bit errors in data written to memory.
259 * This should only be used for testing purposes.
260 *
261 * Field Access Macros:
262 *
263 */
264/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_GENSBE register field. */
265#define ALT_SDR_CTL_CTLCFG_GENSBE_LSB 13
266/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_GENSBE register field. */
267#define ALT_SDR_CTL_CTLCFG_GENSBE_MSB 13
268/* The width in bits of the ALT_SDR_CTL_CTLCFG_GENSBE register field. */
269#define ALT_SDR_CTL_CTLCFG_GENSBE_WIDTH 1
270/* The mask used to set the ALT_SDR_CTL_CTLCFG_GENSBE register field value. */
271#define ALT_SDR_CTL_CTLCFG_GENSBE_SET_MSK 0x00002000
272/* The mask used to clear the ALT_SDR_CTL_CTLCFG_GENSBE register field value. */
273#define ALT_SDR_CTL_CTLCFG_GENSBE_CLR_MSK 0xffffdfff
274/* The reset value of the ALT_SDR_CTL_CTLCFG_GENSBE register field is UNKNOWN. */
275#define ALT_SDR_CTL_CTLCFG_GENSBE_RESET 0x0
276/* Extracts the ALT_SDR_CTL_CTLCFG_GENSBE field value from a register. */
277#define ALT_SDR_CTL_CTLCFG_GENSBE_GET(value) (((value) & 0x00002000) >> 13)
278/* Produces a ALT_SDR_CTL_CTLCFG_GENSBE register field value suitable for setting the register. */
279#define ALT_SDR_CTL_CTLCFG_GENSBE_SET(value) (((value) << 13) & 0x00002000)
280
281/*
282 * Field : Generate Double Bit Errors - gendbe
283 *
284 * Enable the deliberate insertion of double bit errors in data written to memory.
285 * This should only be used for testing purposes.
286 *
287 * Field Access Macros:
288 *
289 */
290/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_GENDBE register field. */
291#define ALT_SDR_CTL_CTLCFG_GENDBE_LSB 14
292/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_GENDBE register field. */
293#define ALT_SDR_CTL_CTLCFG_GENDBE_MSB 14
294/* The width in bits of the ALT_SDR_CTL_CTLCFG_GENDBE register field. */
295#define ALT_SDR_CTL_CTLCFG_GENDBE_WIDTH 1
296/* The mask used to set the ALT_SDR_CTL_CTLCFG_GENDBE register field value. */
297#define ALT_SDR_CTL_CTLCFG_GENDBE_SET_MSK 0x00004000
298/* The mask used to clear the ALT_SDR_CTL_CTLCFG_GENDBE register field value. */
299#define ALT_SDR_CTL_CTLCFG_GENDBE_CLR_MSK 0xffffbfff
300/* The reset value of the ALT_SDR_CTL_CTLCFG_GENDBE register field is UNKNOWN. */
301#define ALT_SDR_CTL_CTLCFG_GENDBE_RESET 0x0
302/* Extracts the ALT_SDR_CTL_CTLCFG_GENDBE field value from a register. */
303#define ALT_SDR_CTL_CTLCFG_GENDBE_GET(value) (((value) & 0x00004000) >> 14)
304/* Produces a ALT_SDR_CTL_CTLCFG_GENDBE register field value suitable for setting the register. */
305#define ALT_SDR_CTL_CTLCFG_GENDBE_SET(value) (((value) << 14) & 0x00004000)
306
307/*
308 * Field : Command Reorder Enable - reorderen
309 *
310 * This bit controls whether the controller can re-order operations to optimize
311 * SDRAM bandwidth. It should generally be set to a one.
312 *
313 * Field Access Macros:
314 *
315 */
316/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_REORDEREN register field. */
317#define ALT_SDR_CTL_CTLCFG_REORDEREN_LSB 15
318/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_REORDEREN register field. */
319#define ALT_SDR_CTL_CTLCFG_REORDEREN_MSB 15
320/* The width in bits of the ALT_SDR_CTL_CTLCFG_REORDEREN register field. */
321#define ALT_SDR_CTL_CTLCFG_REORDEREN_WIDTH 1
322/* The mask used to set the ALT_SDR_CTL_CTLCFG_REORDEREN register field value. */
323#define ALT_SDR_CTL_CTLCFG_REORDEREN_SET_MSK 0x00008000
324/* The mask used to clear the ALT_SDR_CTL_CTLCFG_REORDEREN register field value. */
325#define ALT_SDR_CTL_CTLCFG_REORDEREN_CLR_MSK 0xffff7fff
326/* The reset value of the ALT_SDR_CTL_CTLCFG_REORDEREN register field is UNKNOWN. */
327#define ALT_SDR_CTL_CTLCFG_REORDEREN_RESET 0x0
328/* Extracts the ALT_SDR_CTL_CTLCFG_REORDEREN field value from a register. */
329#define ALT_SDR_CTL_CTLCFG_REORDEREN_GET(value) (((value) & 0x00008000) >> 15)
330/* Produces a ALT_SDR_CTL_CTLCFG_REORDEREN register field value suitable for setting the register. */
331#define ALT_SDR_CTL_CTLCFG_REORDEREN_SET(value) (((value) << 15) & 0x00008000)
332
333/*
334 * Field : Starvation Limit - starvelimit
335 *
336 * Specifies the number of DRAM burst transactions an individual transaction will
337 * allow to reorder ahead of it before its priority is raised in the memory
338 * controller.
339 *
340 * Field Access Macros:
341 *
342 */
343/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field. */
344#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_LSB 16
345/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field. */
346#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_MSB 21
347/* The width in bits of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field. */
348#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_WIDTH 6
349/* The mask used to set the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field value. */
350#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_SET_MSK 0x003f0000
351/* The mask used to clear the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field value. */
352#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_CLR_MSK 0xffc0ffff
353/* The reset value of the ALT_SDR_CTL_CTLCFG_STARVELIMIT register field is UNKNOWN. */
354#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_RESET 0x0
355/* Extracts the ALT_SDR_CTL_CTLCFG_STARVELIMIT field value from a register. */
356#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_GET(value) (((value) & 0x003f0000) >> 16)
357/* Produces a ALT_SDR_CTL_CTLCFG_STARVELIMIT register field value suitable for setting the register. */
358#define ALT_SDR_CTL_CTLCFG_STARVELIMIT_SET(value) (((value) << 16) & 0x003f0000)
359
360/*
361 * Field : DQS Tracking Enable - dqstrken
362 *
363 * Enables DQS tracking in the PHY.
364 *
365 * Field Access Macros:
366 *
367 */
368/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field. */
369#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_LSB 22
370/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field. */
371#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_MSB 22
372/* The width in bits of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field. */
373#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_WIDTH 1
374/* The mask used to set the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field value. */
375#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_SET_MSK 0x00400000
376/* The mask used to clear the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field value. */
377#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_CLR_MSK 0xffbfffff
378/* The reset value of the ALT_SDR_CTL_CTLCFG_DQSTRKEN register field is UNKNOWN. */
379#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_RESET 0x0
380/* Extracts the ALT_SDR_CTL_CTLCFG_DQSTRKEN field value from a register. */
381#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_GET(value) (((value) & 0x00400000) >> 22)
382/* Produces a ALT_SDR_CTL_CTLCFG_DQSTRKEN register field value suitable for setting the register. */
383#define ALT_SDR_CTL_CTLCFG_DQSTRKEN_SET(value) (((value) << 22) & 0x00400000)
384
385/*
386 * Field : No DM Pins Present - nodmpins
387 *
388 * Set to a one to enable DRAM operation if no DM pins are connected.
389 *
390 * Field Access Macros:
391 *
392 */
393/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_NODMPINS register field. */
394#define ALT_SDR_CTL_CTLCFG_NODMPINS_LSB 23
395/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_NODMPINS register field. */
396#define ALT_SDR_CTL_CTLCFG_NODMPINS_MSB 23
397/* The width in bits of the ALT_SDR_CTL_CTLCFG_NODMPINS register field. */
398#define ALT_SDR_CTL_CTLCFG_NODMPINS_WIDTH 1
399/* The mask used to set the ALT_SDR_CTL_CTLCFG_NODMPINS register field value. */
400#define ALT_SDR_CTL_CTLCFG_NODMPINS_SET_MSK 0x00800000
401/* The mask used to clear the ALT_SDR_CTL_CTLCFG_NODMPINS register field value. */
402#define ALT_SDR_CTL_CTLCFG_NODMPINS_CLR_MSK 0xff7fffff
403/* The reset value of the ALT_SDR_CTL_CTLCFG_NODMPINS register field is UNKNOWN. */
404#define ALT_SDR_CTL_CTLCFG_NODMPINS_RESET 0x0
405/* Extracts the ALT_SDR_CTL_CTLCFG_NODMPINS field value from a register. */
406#define ALT_SDR_CTL_CTLCFG_NODMPINS_GET(value) (((value) & 0x00800000) >> 23)
407/* Produces a ALT_SDR_CTL_CTLCFG_NODMPINS register field value suitable for setting the register. */
408#define ALT_SDR_CTL_CTLCFG_NODMPINS_SET(value) (((value) << 23) & 0x00800000)
409
410/*
411 * Field : Burst Interrupt Enable - burstintren
412 *
413 * Set to a one to enable the controller to issue burst interrupt commands. This
414 * must only be set when the DRAM memory type is LPDDR2.
415 *
416 * Field Access Macros:
417 *
418 */
419/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field. */
420#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_LSB 24
421/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field. */
422#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_MSB 24
423/* The width in bits of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field. */
424#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_WIDTH 1
425/* The mask used to set the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field value. */
426#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_SET_MSK 0x01000000
427/* The mask used to clear the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field value. */
428#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_CLR_MSK 0xfeffffff
429/* The reset value of the ALT_SDR_CTL_CTLCFG_BURSTINTREN register field is UNKNOWN. */
430#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_RESET 0x0
431/* Extracts the ALT_SDR_CTL_CTLCFG_BURSTINTREN field value from a register. */
432#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_GET(value) (((value) & 0x01000000) >> 24)
433/* Produces a ALT_SDR_CTL_CTLCFG_BURSTINTREN register field value suitable for setting the register. */
434#define ALT_SDR_CTL_CTLCFG_BURSTINTREN_SET(value) (((value) << 24) & 0x01000000)
435
436/*
437 * Field : Burst Terminate Enable - bursttermen
438 *
439 * Set to a one to enable the controller to issue burst terminate commands. This
440 * must only be set when the DRAM memory type is LPDDR2.
441 *
442 * Field Access Macros:
443 *
444 */
445/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field. */
446#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_LSB 25
447/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field. */
448#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_MSB 25
449/* The width in bits of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field. */
450#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_WIDTH 1
451/* The mask used to set the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field value. */
452#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_SET_MSK 0x02000000
453/* The mask used to clear the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field value. */
454#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_CLR_MSK 0xfdffffff
455/* The reset value of the ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field is UNKNOWN. */
456#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_RESET 0x0
457/* Extracts the ALT_SDR_CTL_CTLCFG_BURSTTERMEN field value from a register. */
458#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_GET(value) (((value) & 0x02000000) >> 25)
459/* Produces a ALT_SDR_CTL_CTLCFG_BURSTTERMEN register field value suitable for setting the register. */
460#define ALT_SDR_CTL_CTLCFG_BURSTTERMEN_SET(value) (((value) << 25) & 0x02000000)
461
462#ifndef __ASSEMBLY__
463/*
464 * WARNING: The C register and register group struct declarations are provided for
465 * convenience and illustrative purposes. They should, however, be used with
466 * caution as the C language standard provides no guarantees about the alignment or
467 * atomicity of device memory accesses. The recommended practice for writing
468 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
469 * alt_write_word() functions.
470 *
471 * The struct declaration for register ALT_SDR_CTL_CTLCFG.
472 */
474{
475 uint32_t memtype : 3; /* DRAM Memory Type */
476 uint32_t membl : 5; /* DRAM Memory Burst Length */
477 uint32_t addrorder : 2; /* Address Interleaving Order */
478 uint32_t eccen : 1; /* ECC Enable */
479 uint32_t ecccorren : 1; /* ECC Auto-Correction Enable */
480 uint32_t cfg_enable_ecc_code_overwrites : 1; /* TBD */
481 uint32_t gensbe : 1; /* Generate Single Bit Errors */
482 uint32_t gendbe : 1; /* Generate Double Bit Errors */
483 uint32_t reorderen : 1; /* Command Reorder Enable */
484 uint32_t starvelimit : 6; /* Starvation Limit */
485 uint32_t dqstrken : 1; /* DQS Tracking Enable */
486 uint32_t nodmpins : 1; /* No DM Pins Present */
487 uint32_t burstintren : 1; /* Burst Interrupt Enable */
488 uint32_t bursttermen : 1; /* Burst Terminate Enable */
489 uint32_t : 6; /* *UNDEFINED* */
490};
491
492/* The typedef declaration for register ALT_SDR_CTL_CTLCFG. */
493typedef volatile struct ALT_SDR_CTL_CTLCFG_s ALT_SDR_CTL_CTLCFG_t;
494#endif /* __ASSEMBLY__ */
495
496/* The byte offset of the ALT_SDR_CTL_CTLCFG register from the beginning of the component. */
497#define ALT_SDR_CTL_CTLCFG_OFST 0x0
498
499/*
500 * Register : DRAM Timings 1 Register - dramtiming1
501 *
502 * This register implements JEDEC standardized timing parameters. It should be
503 * programmed in clock cycles, for the value specified by the memory vendor.
504 *
505 * Register Layout
506 *
507 * Bits | Access | Reset | Description
508 * :--------|:-------|:--------|:---------------------------
509 * [3:0] | RW | Unknown | CAS Write Latency
510 * [8:4] | RW | Unknown | Additive Latency
511 * [13:9] | RW | Unknown | CAS Read Latency
512 * [17:14] | RW | Unknown | Activate to Activate Delay
513 * [23:18] | RW | Unknown | Four Activate Window Time
514 * [31:24] | RW | Unknown | Refresh Cycle Time
515 *
516 */
517/*
518 * Field : CAS Write Latency - tcwl
519 *
520 * Memory write latency.
521 *
522 * Field Access Macros:
523 *
524 */
525/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field. */
526#define ALT_SDR_CTL_DRAMTIMING1_TCWL_LSB 0
527/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field. */
528#define ALT_SDR_CTL_DRAMTIMING1_TCWL_MSB 3
529/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field. */
530#define ALT_SDR_CTL_DRAMTIMING1_TCWL_WIDTH 4
531/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TCWL register field value. */
532#define ALT_SDR_CTL_DRAMTIMING1_TCWL_SET_MSK 0x0000000f
533/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TCWL register field value. */
534#define ALT_SDR_CTL_DRAMTIMING1_TCWL_CLR_MSK 0xfffffff0
535/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TCWL register field is UNKNOWN. */
536#define ALT_SDR_CTL_DRAMTIMING1_TCWL_RESET 0x0
537/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TCWL field value from a register. */
538#define ALT_SDR_CTL_DRAMTIMING1_TCWL_GET(value) (((value) & 0x0000000f) >> 0)
539/* Produces a ALT_SDR_CTL_DRAMTIMING1_TCWL register field value suitable for setting the register. */
540#define ALT_SDR_CTL_DRAMTIMING1_TCWL_SET(value) (((value) << 0) & 0x0000000f)
541
542/*
543 * Field : Additive Latency - tal
544 *
545 * Memory additive latency.
546 *
547 * Field Access Macros:
548 *
549 */
550/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TAL register field. */
551#define ALT_SDR_CTL_DRAMTIMING1_TAL_LSB 4
552/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TAL register field. */
553#define ALT_SDR_CTL_DRAMTIMING1_TAL_MSB 8
554/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TAL register field. */
555#define ALT_SDR_CTL_DRAMTIMING1_TAL_WIDTH 5
556/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TAL register field value. */
557#define ALT_SDR_CTL_DRAMTIMING1_TAL_SET_MSK 0x000001f0
558/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TAL register field value. */
559#define ALT_SDR_CTL_DRAMTIMING1_TAL_CLR_MSK 0xfffffe0f
560/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TAL register field is UNKNOWN. */
561#define ALT_SDR_CTL_DRAMTIMING1_TAL_RESET 0x0
562/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TAL field value from a register. */
563#define ALT_SDR_CTL_DRAMTIMING1_TAL_GET(value) (((value) & 0x000001f0) >> 4)
564/* Produces a ALT_SDR_CTL_DRAMTIMING1_TAL register field value suitable for setting the register. */
565#define ALT_SDR_CTL_DRAMTIMING1_TAL_SET(value) (((value) << 4) & 0x000001f0)
566
567/*
568 * Field : CAS Read Latency - tcl
569 *
570 * Memory read latency.
571 *
572 * Field Access Macros:
573 *
574 */
575/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCL register field. */
576#define ALT_SDR_CTL_DRAMTIMING1_TCL_LSB 9
577/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TCL register field. */
578#define ALT_SDR_CTL_DRAMTIMING1_TCL_MSB 13
579/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TCL register field. */
580#define ALT_SDR_CTL_DRAMTIMING1_TCL_WIDTH 5
581/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TCL register field value. */
582#define ALT_SDR_CTL_DRAMTIMING1_TCL_SET_MSK 0x00003e00
583/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TCL register field value. */
584#define ALT_SDR_CTL_DRAMTIMING1_TCL_CLR_MSK 0xffffc1ff
585/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TCL register field is UNKNOWN. */
586#define ALT_SDR_CTL_DRAMTIMING1_TCL_RESET 0x0
587/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TCL field value from a register. */
588#define ALT_SDR_CTL_DRAMTIMING1_TCL_GET(value) (((value) & 0x00003e00) >> 9)
589/* Produces a ALT_SDR_CTL_DRAMTIMING1_TCL register field value suitable for setting the register. */
590#define ALT_SDR_CTL_DRAMTIMING1_TCL_SET(value) (((value) << 9) & 0x00003e00)
591
592/*
593 * Field : Activate to Activate Delay - trrd
594 *
595 * The activate to activate, different banks timing parameter.
596 *
597 * Field Access Macros:
598 *
599 */
600/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field. */
601#define ALT_SDR_CTL_DRAMTIMING1_TRRD_LSB 14
602/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field. */
603#define ALT_SDR_CTL_DRAMTIMING1_TRRD_MSB 17
604/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field. */
605#define ALT_SDR_CTL_DRAMTIMING1_TRRD_WIDTH 4
606/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TRRD register field value. */
607#define ALT_SDR_CTL_DRAMTIMING1_TRRD_SET_MSK 0x0003c000
608/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TRRD register field value. */
609#define ALT_SDR_CTL_DRAMTIMING1_TRRD_CLR_MSK 0xfffc3fff
610/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TRRD register field is UNKNOWN. */
611#define ALT_SDR_CTL_DRAMTIMING1_TRRD_RESET 0x0
612/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TRRD field value from a register. */
613#define ALT_SDR_CTL_DRAMTIMING1_TRRD_GET(value) (((value) & 0x0003c000) >> 14)
614/* Produces a ALT_SDR_CTL_DRAMTIMING1_TRRD register field value suitable for setting the register. */
615#define ALT_SDR_CTL_DRAMTIMING1_TRRD_SET(value) (((value) << 14) & 0x0003c000)
616
617/*
618 * Field : Four Activate Window Time - tfaw
619 *
620 * The four-activate window timing parameter.
621 *
622 * Field Access Macros:
623 *
624 */
625/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field. */
626#define ALT_SDR_CTL_DRAMTIMING1_TFAW_LSB 18
627/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field. */
628#define ALT_SDR_CTL_DRAMTIMING1_TFAW_MSB 23
629/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field. */
630#define ALT_SDR_CTL_DRAMTIMING1_TFAW_WIDTH 6
631/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TFAW register field value. */
632#define ALT_SDR_CTL_DRAMTIMING1_TFAW_SET_MSK 0x00fc0000
633/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TFAW register field value. */
634#define ALT_SDR_CTL_DRAMTIMING1_TFAW_CLR_MSK 0xff03ffff
635/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TFAW register field is UNKNOWN. */
636#define ALT_SDR_CTL_DRAMTIMING1_TFAW_RESET 0x0
637/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TFAW field value from a register. */
638#define ALT_SDR_CTL_DRAMTIMING1_TFAW_GET(value) (((value) & 0x00fc0000) >> 18)
639/* Produces a ALT_SDR_CTL_DRAMTIMING1_TFAW register field value suitable for setting the register. */
640#define ALT_SDR_CTL_DRAMTIMING1_TFAW_SET(value) (((value) << 18) & 0x00fc0000)
641
642/*
643 * Field : Refresh Cycle Time - trfc
644 *
645 * The refresh cycle timing parameter.
646 *
647 * Field Access Macros:
648 *
649 */
650/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field. */
651#define ALT_SDR_CTL_DRAMTIMING1_TRFC_LSB 24
652/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field. */
653#define ALT_SDR_CTL_DRAMTIMING1_TRFC_MSB 31
654/* The width in bits of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field. */
655#define ALT_SDR_CTL_DRAMTIMING1_TRFC_WIDTH 8
656/* The mask used to set the ALT_SDR_CTL_DRAMTIMING1_TRFC register field value. */
657#define ALT_SDR_CTL_DRAMTIMING1_TRFC_SET_MSK 0xff000000
658/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING1_TRFC register field value. */
659#define ALT_SDR_CTL_DRAMTIMING1_TRFC_CLR_MSK 0x00ffffff
660/* The reset value of the ALT_SDR_CTL_DRAMTIMING1_TRFC register field is UNKNOWN. */
661#define ALT_SDR_CTL_DRAMTIMING1_TRFC_RESET 0x0
662/* Extracts the ALT_SDR_CTL_DRAMTIMING1_TRFC field value from a register. */
663#define ALT_SDR_CTL_DRAMTIMING1_TRFC_GET(value) (((value) & 0xff000000) >> 24)
664/* Produces a ALT_SDR_CTL_DRAMTIMING1_TRFC register field value suitable for setting the register. */
665#define ALT_SDR_CTL_DRAMTIMING1_TRFC_SET(value) (((value) << 24) & 0xff000000)
666
667#ifndef __ASSEMBLY__
668/*
669 * WARNING: The C register and register group struct declarations are provided for
670 * convenience and illustrative purposes. They should, however, be used with
671 * caution as the C language standard provides no guarantees about the alignment or
672 * atomicity of device memory accesses. The recommended practice for writing
673 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
674 * alt_write_word() functions.
675 *
676 * The struct declaration for register ALT_SDR_CTL_DRAMTIMING1.
677 */
679{
680 uint32_t tcwl : 4; /* CAS Write Latency */
681 uint32_t tal : 5; /* Additive Latency */
682 uint32_t tcl : 5; /* CAS Read Latency */
683 uint32_t trrd : 4; /* Activate to Activate Delay */
684 uint32_t tfaw : 6; /* Four Activate Window Time */
685 uint32_t trfc : 8; /* Refresh Cycle Time */
686};
687
688/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING1. */
690#endif /* __ASSEMBLY__ */
691
692/* The byte offset of the ALT_SDR_CTL_DRAMTIMING1 register from the beginning of the component. */
693#define ALT_SDR_CTL_DRAMTIMING1_OFST 0x4
694
695/*
696 * Register : DRAM Timings 2 Register - dramtiming2
697 *
698 * This register implements JEDEC standardized timing parameters. It should be
699 * programmed in clock cycles, for the value specified by the memory vendor.
700 *
701 * Register Layout
702 *
703 * Bits | Access | Reset | Description
704 * :--------|:-------|:--------|:--------------------------------
705 * [12:0] | RW | Unknown | Refresh Interval
706 * [16:13] | RW | Unknown | Activate to Read or Write Delay
707 * [20:17] | RW | Unknown | Row Precharge Time
708 * [24:21] | RW | Unknown | Write Recovery Time
709 * [28:25] | RW | Unknown | Write to Read Time
710 * [31:29] | ??? | 0x0 | *UNDEFINED*
711 *
712 */
713/*
714 * Field : Refresh Interval - trefi
715 *
716 * The refresh interval timing parameter.
717 *
718 * Field Access Macros:
719 *
720 */
721/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field. */
722#define ALT_SDR_CTL_DRAMTIMING2_TREFI_LSB 0
723/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field. */
724#define ALT_SDR_CTL_DRAMTIMING2_TREFI_MSB 12
725/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field. */
726#define ALT_SDR_CTL_DRAMTIMING2_TREFI_WIDTH 13
727/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TREFI register field value. */
728#define ALT_SDR_CTL_DRAMTIMING2_TREFI_SET_MSK 0x00001fff
729/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TREFI register field value. */
730#define ALT_SDR_CTL_DRAMTIMING2_TREFI_CLR_MSK 0xffffe000
731/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TREFI register field is UNKNOWN. */
732#define ALT_SDR_CTL_DRAMTIMING2_TREFI_RESET 0x0
733/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TREFI field value from a register. */
734#define ALT_SDR_CTL_DRAMTIMING2_TREFI_GET(value) (((value) & 0x00001fff) >> 0)
735/* Produces a ALT_SDR_CTL_DRAMTIMING2_TREFI register field value suitable for setting the register. */
736#define ALT_SDR_CTL_DRAMTIMING2_TREFI_SET(value) (((value) << 0) & 0x00001fff)
737
738/*
739 * Field : Activate to Read or Write Delay - trcd
740 *
741 * The activate to read/write timing parameter.
742 *
743 * Field Access Macros:
744 *
745 */
746/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field. */
747#define ALT_SDR_CTL_DRAMTIMING2_TRCD_LSB 13
748/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field. */
749#define ALT_SDR_CTL_DRAMTIMING2_TRCD_MSB 16
750/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field. */
751#define ALT_SDR_CTL_DRAMTIMING2_TRCD_WIDTH 4
752/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TRCD register field value. */
753#define ALT_SDR_CTL_DRAMTIMING2_TRCD_SET_MSK 0x0001e000
754/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TRCD register field value. */
755#define ALT_SDR_CTL_DRAMTIMING2_TRCD_CLR_MSK 0xfffe1fff
756/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TRCD register field is UNKNOWN. */
757#define ALT_SDR_CTL_DRAMTIMING2_TRCD_RESET 0x0
758/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TRCD field value from a register. */
759#define ALT_SDR_CTL_DRAMTIMING2_TRCD_GET(value) (((value) & 0x0001e000) >> 13)
760/* Produces a ALT_SDR_CTL_DRAMTIMING2_TRCD register field value suitable for setting the register. */
761#define ALT_SDR_CTL_DRAMTIMING2_TRCD_SET(value) (((value) << 13) & 0x0001e000)
762
763/*
764 * Field : Row Precharge Time - trp
765 *
766 * The precharge to activate timing parameter.
767 *
768 * Field Access Macros:
769 *
770 */
771/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRP register field. */
772#define ALT_SDR_CTL_DRAMTIMING2_TRP_LSB 17
773/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TRP register field. */
774#define ALT_SDR_CTL_DRAMTIMING2_TRP_MSB 20
775/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TRP register field. */
776#define ALT_SDR_CTL_DRAMTIMING2_TRP_WIDTH 4
777/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TRP register field value. */
778#define ALT_SDR_CTL_DRAMTIMING2_TRP_SET_MSK 0x001e0000
779/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TRP register field value. */
780#define ALT_SDR_CTL_DRAMTIMING2_TRP_CLR_MSK 0xffe1ffff
781/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TRP register field is UNKNOWN. */
782#define ALT_SDR_CTL_DRAMTIMING2_TRP_RESET 0x0
783/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TRP field value from a register. */
784#define ALT_SDR_CTL_DRAMTIMING2_TRP_GET(value) (((value) & 0x001e0000) >> 17)
785/* Produces a ALT_SDR_CTL_DRAMTIMING2_TRP register field value suitable for setting the register. */
786#define ALT_SDR_CTL_DRAMTIMING2_TRP_SET(value) (((value) << 17) & 0x001e0000)
787
788/*
789 * Field : Write Recovery Time - twr
790 *
791 * The write recovery timing.
792 *
793 * Field Access Macros:
794 *
795 */
796/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWR register field. */
797#define ALT_SDR_CTL_DRAMTIMING2_TWR_LSB 21
798/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWR register field. */
799#define ALT_SDR_CTL_DRAMTIMING2_TWR_MSB 24
800/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TWR register field. */
801#define ALT_SDR_CTL_DRAMTIMING2_TWR_WIDTH 4
802/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TWR register field value. */
803#define ALT_SDR_CTL_DRAMTIMING2_TWR_SET_MSK 0x01e00000
804/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TWR register field value. */
805#define ALT_SDR_CTL_DRAMTIMING2_TWR_CLR_MSK 0xfe1fffff
806/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TWR register field is UNKNOWN. */
807#define ALT_SDR_CTL_DRAMTIMING2_TWR_RESET 0x0
808/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TWR field value from a register. */
809#define ALT_SDR_CTL_DRAMTIMING2_TWR_GET(value) (((value) & 0x01e00000) >> 21)
810/* Produces a ALT_SDR_CTL_DRAMTIMING2_TWR register field value suitable for setting the register. */
811#define ALT_SDR_CTL_DRAMTIMING2_TWR_SET(value) (((value) << 21) & 0x01e00000)
812
813/*
814 * Field : Write to Read Time - twtr
815 *
816 * The write to read timing parameter.
817 *
818 * Field Access Macros:
819 *
820 */
821/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field. */
822#define ALT_SDR_CTL_DRAMTIMING2_TWTR_LSB 25
823/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field. */
824#define ALT_SDR_CTL_DRAMTIMING2_TWTR_MSB 28
825/* The width in bits of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field. */
826#define ALT_SDR_CTL_DRAMTIMING2_TWTR_WIDTH 4
827/* The mask used to set the ALT_SDR_CTL_DRAMTIMING2_TWTR register field value. */
828#define ALT_SDR_CTL_DRAMTIMING2_TWTR_SET_MSK 0x1e000000
829/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING2_TWTR register field value. */
830#define ALT_SDR_CTL_DRAMTIMING2_TWTR_CLR_MSK 0xe1ffffff
831/* The reset value of the ALT_SDR_CTL_DRAMTIMING2_TWTR register field is UNKNOWN. */
832#define ALT_SDR_CTL_DRAMTIMING2_TWTR_RESET 0x0
833/* Extracts the ALT_SDR_CTL_DRAMTIMING2_TWTR field value from a register. */
834#define ALT_SDR_CTL_DRAMTIMING2_TWTR_GET(value) (((value) & 0x1e000000) >> 25)
835/* Produces a ALT_SDR_CTL_DRAMTIMING2_TWTR register field value suitable for setting the register. */
836#define ALT_SDR_CTL_DRAMTIMING2_TWTR_SET(value) (((value) << 25) & 0x1e000000)
837
838#ifndef __ASSEMBLY__
839/*
840 * WARNING: The C register and register group struct declarations are provided for
841 * convenience and illustrative purposes. They should, however, be used with
842 * caution as the C language standard provides no guarantees about the alignment or
843 * atomicity of device memory accesses. The recommended practice for writing
844 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
845 * alt_write_word() functions.
846 *
847 * The struct declaration for register ALT_SDR_CTL_DRAMTIMING2.
848 */
850{
851 uint32_t trefi : 13; /* Refresh Interval */
852 uint32_t trcd : 4; /* Activate to Read or Write Delay */
853 uint32_t trp : 4; /* Row Precharge Time */
854 uint32_t twr : 4; /* Write Recovery Time */
855 uint32_t twtr : 4; /* Write to Read Time */
856 uint32_t : 3; /* *UNDEFINED* */
857};
858
859/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING2. */
861#endif /* __ASSEMBLY__ */
862
863/* The byte offset of the ALT_SDR_CTL_DRAMTIMING2 register from the beginning of the component. */
864#define ALT_SDR_CTL_DRAMTIMING2_OFST 0x8
865
866/*
867 * Register : DRAM Timings 3 Register - dramtiming3
868 *
869 * This register implements JEDEC standardized timing parameters. It should be
870 * programmed in clock cycles, for the value specified by the memory vendor.
871 *
872 * Register Layout
873 *
874 * Bits | Access | Reset | Description
875 * :--------|:-------|:--------|:--------------------------------
876 * [3:0] | RW | Unknown | Read to Precharge Time
877 * [8:4] | RW | Unknown | Activate to Precharge Time
878 * [14:9] | RW | Unknown | Row Cycle Time
879 * [18:15] | RW | Unknown | Mode Register Programming Delay
880 * [22:19] | RW | Unknown | CAS to CAS Delay
881 * [31:23] | ??? | 0x0 | *UNDEFINED*
882 *
883 */
884/*
885 * Field : Read to Precharge Time - trtp
886 *
887 * The read to precharge timing parameter.
888 *
889 * Field Access Macros:
890 *
891 */
892/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field. */
893#define ALT_SDR_CTL_DRAMTIMING3_TRTP_LSB 0
894/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field. */
895#define ALT_SDR_CTL_DRAMTIMING3_TRTP_MSB 3
896/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field. */
897#define ALT_SDR_CTL_DRAMTIMING3_TRTP_WIDTH 4
898/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TRTP register field value. */
899#define ALT_SDR_CTL_DRAMTIMING3_TRTP_SET_MSK 0x0000000f
900/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TRTP register field value. */
901#define ALT_SDR_CTL_DRAMTIMING3_TRTP_CLR_MSK 0xfffffff0
902/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TRTP register field is UNKNOWN. */
903#define ALT_SDR_CTL_DRAMTIMING3_TRTP_RESET 0x0
904/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TRTP field value from a register. */
905#define ALT_SDR_CTL_DRAMTIMING3_TRTP_GET(value) (((value) & 0x0000000f) >> 0)
906/* Produces a ALT_SDR_CTL_DRAMTIMING3_TRTP register field value suitable for setting the register. */
907#define ALT_SDR_CTL_DRAMTIMING3_TRTP_SET(value) (((value) << 0) & 0x0000000f)
908
909/*
910 * Field : Activate to Precharge Time - tras
911 *
912 * The activate to precharge timing parameter.
913 *
914 * Field Access Macros:
915 *
916 */
917/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field. */
918#define ALT_SDR_CTL_DRAMTIMING3_TRAS_LSB 4
919/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field. */
920#define ALT_SDR_CTL_DRAMTIMING3_TRAS_MSB 8
921/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field. */
922#define ALT_SDR_CTL_DRAMTIMING3_TRAS_WIDTH 5
923/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TRAS register field value. */
924#define ALT_SDR_CTL_DRAMTIMING3_TRAS_SET_MSK 0x000001f0
925/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TRAS register field value. */
926#define ALT_SDR_CTL_DRAMTIMING3_TRAS_CLR_MSK 0xfffffe0f
927/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TRAS register field is UNKNOWN. */
928#define ALT_SDR_CTL_DRAMTIMING3_TRAS_RESET 0x0
929/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TRAS field value from a register. */
930#define ALT_SDR_CTL_DRAMTIMING3_TRAS_GET(value) (((value) & 0x000001f0) >> 4)
931/* Produces a ALT_SDR_CTL_DRAMTIMING3_TRAS register field value suitable for setting the register. */
932#define ALT_SDR_CTL_DRAMTIMING3_TRAS_SET(value) (((value) << 4) & 0x000001f0)
933
934/*
935 * Field : Row Cycle Time - trc
936 *
937 * The activate to activate timing parameter.
938 *
939 * Field Access Macros:
940 *
941 */
942/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRC register field. */
943#define ALT_SDR_CTL_DRAMTIMING3_TRC_LSB 9
944/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TRC register field. */
945#define ALT_SDR_CTL_DRAMTIMING3_TRC_MSB 14
946/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TRC register field. */
947#define ALT_SDR_CTL_DRAMTIMING3_TRC_WIDTH 6
948/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TRC register field value. */
949#define ALT_SDR_CTL_DRAMTIMING3_TRC_SET_MSK 0x00007e00
950/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TRC register field value. */
951#define ALT_SDR_CTL_DRAMTIMING3_TRC_CLR_MSK 0xffff81ff
952/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TRC register field is UNKNOWN. */
953#define ALT_SDR_CTL_DRAMTIMING3_TRC_RESET 0x0
954/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TRC field value from a register. */
955#define ALT_SDR_CTL_DRAMTIMING3_TRC_GET(value) (((value) & 0x00007e00) >> 9)
956/* Produces a ALT_SDR_CTL_DRAMTIMING3_TRC register field value suitable for setting the register. */
957#define ALT_SDR_CTL_DRAMTIMING3_TRC_SET(value) (((value) << 9) & 0x00007e00)
958
959/*
960 * Field : Mode Register Programming Delay - tmrd
961 *
962 * Mode register timing parameter.
963 *
964 * Field Access Macros:
965 *
966 */
967/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field. */
968#define ALT_SDR_CTL_DRAMTIMING3_TMRD_LSB 15
969/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field. */
970#define ALT_SDR_CTL_DRAMTIMING3_TMRD_MSB 18
971/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field. */
972#define ALT_SDR_CTL_DRAMTIMING3_TMRD_WIDTH 4
973/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TMRD register field value. */
974#define ALT_SDR_CTL_DRAMTIMING3_TMRD_SET_MSK 0x00078000
975/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TMRD register field value. */
976#define ALT_SDR_CTL_DRAMTIMING3_TMRD_CLR_MSK 0xfff87fff
977/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TMRD register field is UNKNOWN. */
978#define ALT_SDR_CTL_DRAMTIMING3_TMRD_RESET 0x0
979/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TMRD field value from a register. */
980#define ALT_SDR_CTL_DRAMTIMING3_TMRD_GET(value) (((value) & 0x00078000) >> 15)
981/* Produces a ALT_SDR_CTL_DRAMTIMING3_TMRD register field value suitable for setting the register. */
982#define ALT_SDR_CTL_DRAMTIMING3_TMRD_SET(value) (((value) << 15) & 0x00078000)
983
984/*
985 * Field : CAS to CAS Delay - tccd
986 *
987 * The CAS to CAS delay time.
988 *
989 * Field Access Macros:
990 *
991 */
992/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field. */
993#define ALT_SDR_CTL_DRAMTIMING3_TCCD_LSB 19
994/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field. */
995#define ALT_SDR_CTL_DRAMTIMING3_TCCD_MSB 22
996/* The width in bits of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field. */
997#define ALT_SDR_CTL_DRAMTIMING3_TCCD_WIDTH 4
998/* The mask used to set the ALT_SDR_CTL_DRAMTIMING3_TCCD register field value. */
999#define ALT_SDR_CTL_DRAMTIMING3_TCCD_SET_MSK 0x00780000
1000/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING3_TCCD register field value. */
1001#define ALT_SDR_CTL_DRAMTIMING3_TCCD_CLR_MSK 0xff87ffff
1002/* The reset value of the ALT_SDR_CTL_DRAMTIMING3_TCCD register field is UNKNOWN. */
1003#define ALT_SDR_CTL_DRAMTIMING3_TCCD_RESET 0x0
1004/* Extracts the ALT_SDR_CTL_DRAMTIMING3_TCCD field value from a register. */
1005#define ALT_SDR_CTL_DRAMTIMING3_TCCD_GET(value) (((value) & 0x00780000) >> 19)
1006/* Produces a ALT_SDR_CTL_DRAMTIMING3_TCCD register field value suitable for setting the register. */
1007#define ALT_SDR_CTL_DRAMTIMING3_TCCD_SET(value) (((value) << 19) & 0x00780000)
1008
1009#ifndef __ASSEMBLY__
1010/*
1011 * WARNING: The C register and register group struct declarations are provided for
1012 * convenience and illustrative purposes. They should, however, be used with
1013 * caution as the C language standard provides no guarantees about the alignment or
1014 * atomicity of device memory accesses. The recommended practice for writing
1015 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1016 * alt_write_word() functions.
1017 *
1018 * The struct declaration for register ALT_SDR_CTL_DRAMTIMING3.
1019 */
1021{
1022 uint32_t trtp : 4; /* Read to Precharge Time */
1023 uint32_t tras : 5; /* Activate to Precharge Time */
1024 uint32_t trc : 6; /* Row Cycle Time */
1025 uint32_t tmrd : 4; /* Mode Register Programming Delay */
1026 uint32_t tccd : 4; /* CAS to CAS Delay */
1027 uint32_t : 9; /* *UNDEFINED* */
1028};
1029
1030/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING3. */
1032#endif /* __ASSEMBLY__ */
1033
1034/* The byte offset of the ALT_SDR_CTL_DRAMTIMING3 register from the beginning of the component. */
1035#define ALT_SDR_CTL_DRAMTIMING3_OFST 0xc
1036
1037/*
1038 * Register : DRAM Timings 4 Register - dramtiming4
1039 *
1040 * This register implements JEDEC standardized timing parameters. It should be
1041 * programmed in clock cycles, for the value specified by the memory vendor.
1042 *
1043 * Register Layout
1044 *
1045 * Bits | Access | Reset | Description
1046 * :--------|:-------|:--------|:-------------------------------
1047 * [9:0] | RW | Unknown | Self-refresh Exit
1048 * [19:10] | RW | Unknown | Power Down Exit
1049 * [23:20] | RW | Unknown | Minimum Low Power State Cycles
1050 * [31:24] | ??? | 0x0 | *UNDEFINED*
1051 *
1052 */
1053/*
1054 * Field : Self-refresh Exit - selfrfshexit
1055 *
1056 * The self refresh exit cycles, tXS.
1057 *
1058 * Field Access Macros:
1059 *
1060 */
1061/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field. */
1062#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_LSB 0
1063/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field. */
1064#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_MSB 9
1065/* The width in bits of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field. */
1066#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_WIDTH 10
1067/* The mask used to set the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field value. */
1068#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_SET_MSK 0x000003ff
1069/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field value. */
1070#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_CLR_MSK 0xfffffc00
1071/* The reset value of the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field is UNKNOWN. */
1072#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_RESET 0x0
1073/* Extracts the ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT field value from a register. */
1074#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_GET(value) (((value) & 0x000003ff) >> 0)
1075/* Produces a ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT register field value suitable for setting the register. */
1076#define ALT_SDR_CTL_DRAMTIMING4_SELFRFSHEXIT_SET(value) (((value) << 0) & 0x000003ff)
1077
1078/*
1079 * Field : Power Down Exit - pwrdownexit
1080 *
1081 * The power down exit cycles, tXPDLL.
1082 *
1083 * Field Access Macros:
1084 *
1085 */
1086/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field. */
1087#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_LSB 10
1088/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field. */
1089#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_MSB 19
1090/* The width in bits of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field. */
1091#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_WIDTH 10
1092/* The mask used to set the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field value. */
1093#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_SET_MSK 0x000ffc00
1094/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field value. */
1095#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_CLR_MSK 0xfff003ff
1096/* The reset value of the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field is UNKNOWN. */
1097#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_RESET 0x0
1098/* Extracts the ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT field value from a register. */
1099#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_GET(value) (((value) & 0x000ffc00) >> 10)
1100/* Produces a ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT register field value suitable for setting the register. */
1101#define ALT_SDR_CTL_DRAMTIMING4_PWRDOWNEXIT_SET(value) (((value) << 10) & 0x000ffc00)
1102
1103/*
1104 * Field : Minimum Low Power State Cycles - minpwrsavecycles
1105 *
1106 * The minimum number of cycles to stay in a low power state. This applies to both
1107 * power down and self-refresh and should be set to the greater of tPD and tCKESR.
1108 *
1109 * Field Access Macros:
1110 *
1111 */
1112/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field. */
1113#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_LSB 20
1114/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field. */
1115#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_MSB 23
1116/* The width in bits of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field. */
1117#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_WIDTH 4
1118/* The mask used to set the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field value. */
1119#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_SET_MSK 0x00f00000
1120/* The mask used to clear the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field value. */
1121#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_CLR_MSK 0xff0fffff
1122/* The reset value of the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field is UNKNOWN. */
1123#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_RESET 0x0
1124/* Extracts the ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES field value from a register. */
1125#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_GET(value) (((value) & 0x00f00000) >> 20)
1126/* Produces a ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES register field value suitable for setting the register. */
1127#define ALT_SDR_CTL_DRAMTIMING4_MINPWRSAVECYCLES_SET(value) (((value) << 20) & 0x00f00000)
1128
1129#ifndef __ASSEMBLY__
1130/*
1131 * WARNING: The C register and register group struct declarations are provided for
1132 * convenience and illustrative purposes. They should, however, be used with
1133 * caution as the C language standard provides no guarantees about the alignment or
1134 * atomicity of device memory accesses. The recommended practice for writing
1135 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1136 * alt_write_word() functions.
1137 *
1138 * The struct declaration for register ALT_SDR_CTL_DRAMTIMING4.
1139 */
1141{
1142 uint32_t selfrfshexit : 10; /* Self-refresh Exit */
1143 uint32_t pwrdownexit : 10; /* Power Down Exit */
1144 uint32_t minpwrsavecycles : 4; /* Minimum Low Power State Cycles */
1145 uint32_t : 8; /* *UNDEFINED* */
1146};
1147
1148/* The typedef declaration for register ALT_SDR_CTL_DRAMTIMING4. */
1150#endif /* __ASSEMBLY__ */
1151
1152/* The byte offset of the ALT_SDR_CTL_DRAMTIMING4 register from the beginning of the component. */
1153#define ALT_SDR_CTL_DRAMTIMING4_OFST 0x10
1154
1155/*
1156 * Register : Lower Power Timing Register - lowpwrtiming
1157 *
1158 * This register controls the behavior of the low power logic in the controller.
1159 *
1160 * Register Layout
1161 *
1162 * Bits | Access | Reset | Description
1163 * :--------|:-------|:--------|:---------------------------
1164 * [15:0] | RW | Unknown | Auto-power Down Cycles
1165 * [19:16] | RW | Unknown | Clock Disable Delay Cycles
1166 * [31:20] | ??? | 0x0 | *UNDEFINED*
1167 *
1168 */
1169/*
1170 * Field : Auto-power Down Cycles - autopdcycles
1171 *
1172 * The number of idle clock cycles after which the controller should place the
1173 * memory into power-down mode.
1174 *
1175 * Field Access Macros:
1176 *
1177 */
1178/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field. */
1179#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_LSB 0
1180/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field. */
1181#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_MSB 15
1182/* The width in bits of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field. */
1183#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_WIDTH 16
1184/* The mask used to set the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field value. */
1185#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_SET_MSK 0x0000ffff
1186/* The mask used to clear the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field value. */
1187#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_CLR_MSK 0xffff0000
1188/* The reset value of the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field is UNKNOWN. */
1189#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_RESET 0x0
1190/* Extracts the ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES field value from a register. */
1191#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_GET(value) (((value) & 0x0000ffff) >> 0)
1192/* Produces a ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES register field value suitable for setting the register. */
1193#define ALT_SDR_CTL_LOWPWRTIMING_AUTOPDCYCLES_SET(value) (((value) << 0) & 0x0000ffff)
1194
1195/*
1196 * Field : Clock Disable Delay Cycles - clkdisablecycles
1197 *
1198 * Set to a the number of clocks after the execution of an self-refresh to stop the
1199 * clock. This register is generally set based on PHY design latency and should
1200 * generally not be changed.
1201 *
1202 * Field Access Macros:
1203 *
1204 */
1205/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field. */
1206#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_LSB 16
1207/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field. */
1208#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_MSB 19
1209/* The width in bits of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field. */
1210#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_WIDTH 4
1211/* The mask used to set the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field value. */
1212#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_SET_MSK 0x000f0000
1213/* The mask used to clear the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field value. */
1214#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_CLR_MSK 0xfff0ffff
1215/* The reset value of the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field is UNKNOWN. */
1216#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_RESET 0x0
1217/* Extracts the ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES field value from a register. */
1218#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_GET(value) (((value) & 0x000f0000) >> 16)
1219/* Produces a ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES register field value suitable for setting the register. */
1220#define ALT_SDR_CTL_LOWPWRTIMING_CLKDISCYCLES_SET(value) (((value) << 16) & 0x000f0000)
1221
1222#ifndef __ASSEMBLY__
1223/*
1224 * WARNING: The C register and register group struct declarations are provided for
1225 * convenience and illustrative purposes. They should, however, be used with
1226 * caution as the C language standard provides no guarantees about the alignment or
1227 * atomicity of device memory accesses. The recommended practice for writing
1228 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1229 * alt_write_word() functions.
1230 *
1231 * The struct declaration for register ALT_SDR_CTL_LOWPWRTIMING.
1232 */
1234{
1235 uint32_t autopdcycles : 16; /* Auto-power Down Cycles */
1236 uint32_t clkdisablecycles : 4; /* Clock Disable Delay Cycles */
1237 uint32_t : 12; /* *UNDEFINED* */
1238};
1239
1240/* The typedef declaration for register ALT_SDR_CTL_LOWPWRTIMING. */
1242#endif /* __ASSEMBLY__ */
1243
1244/* The byte offset of the ALT_SDR_CTL_LOWPWRTIMING register from the beginning of the component. */
1245#define ALT_SDR_CTL_LOWPWRTIMING_OFST 0x14
1246
1247/*
1248 * Register : ODT Control Register - dramodt
1249 *
1250 * This register controls which ODT pin is asserted during reads or writes. Bits
1251 * [1:0] control which ODT pin is asserted during to accesses to chip select 0,
1252 * bits [3:2] which ODT pin is asserted during accesses to chip select 1. For
1253 * example, a value of &quot;1001&quot; will cause ODT[0] to be asserted for
1254 * accesses to CS[0], and ODT[1] to be asserted for access to CS[1] pin. Set this
1255 * to &quot;0001&quot; if there is only one chip select available.
1256 *
1257 * Register Layout
1258 *
1259 * Bits | Access | Reset | Description
1260 * :-------|:-------|:--------|:------------------
1261 * [3:0] | RW | Unknown | Write ODT Control
1262 * [7:4] | RW | Unknown | Read ODT Control
1263 * [31:8] | ??? | 0x0 | *UNDEFINED*
1264 *
1265 */
1266/*
1267 * Field : Write ODT Control - cfg_write_odt_chip
1268 *
1269 * This register controls which ODT pin is asserted during writes.
1270 *
1271 * Field Access Macros:
1272 *
1273 */
1274/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field. */
1275#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_LSB 0
1276/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field. */
1277#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_MSB 3
1278/* The width in bits of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field. */
1279#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_WIDTH 4
1280/* The mask used to set the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field value. */
1281#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_SET_MSK 0x0000000f
1282/* The mask used to clear the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field value. */
1283#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_CLR_MSK 0xfffffff0
1284/* The reset value of the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field is UNKNOWN. */
1285#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_RESET 0x0
1286/* Extracts the ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP field value from a register. */
1287#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_GET(value) (((value) & 0x0000000f) >> 0)
1288/* Produces a ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP register field value suitable for setting the register. */
1289#define ALT_SDR_CTL_DRAMODT_CFG_WR_ODT_CHIP_SET(value) (((value) << 0) & 0x0000000f)
1290
1291/*
1292 * Field : Read ODT Control - cfg_read_odt_chip
1293 *
1294 * This register controls which ODT pin is asserted during reads.
1295 *
1296 * Field Access Macros:
1297 *
1298 */
1299/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field. */
1300#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_LSB 4
1301/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field. */
1302#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_MSB 7
1303/* The width in bits of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field. */
1304#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_WIDTH 4
1305/* The mask used to set the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field value. */
1306#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_SET_MSK 0x000000f0
1307/* The mask used to clear the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field value. */
1308#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_CLR_MSK 0xffffff0f
1309/* The reset value of the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field is UNKNOWN. */
1310#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_RESET 0x0
1311/* Extracts the ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP field value from a register. */
1312#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_GET(value) (((value) & 0x000000f0) >> 4)
1313/* Produces a ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP register field value suitable for setting the register. */
1314#define ALT_SDR_CTL_DRAMODT_CFG_RD_ODT_CHIP_SET(value) (((value) << 4) & 0x000000f0)
1315
1316#ifndef __ASSEMBLY__
1317/*
1318 * WARNING: The C register and register group struct declarations are provided for
1319 * convenience and illustrative purposes. They should, however, be used with
1320 * caution as the C language standard provides no guarantees about the alignment or
1321 * atomicity of device memory accesses. The recommended practice for writing
1322 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1323 * alt_write_word() functions.
1324 *
1325 * The struct declaration for register ALT_SDR_CTL_DRAMODT.
1326 */
1328{
1329 uint32_t cfg_write_odt_chip : 4; /* Write ODT Control */
1330 uint32_t cfg_read_odt_chip : 4; /* Read ODT Control */
1331 uint32_t : 24; /* *UNDEFINED* */
1332};
1333
1334/* The typedef declaration for register ALT_SDR_CTL_DRAMODT. */
1335typedef volatile struct ALT_SDR_CTL_DRAMODT_s ALT_SDR_CTL_DRAMODT_t;
1336#endif /* __ASSEMBLY__ */
1337
1338/* The byte offset of the ALT_SDR_CTL_DRAMODT register from the beginning of the component. */
1339#define ALT_SDR_CTL_DRAMODT_OFST 0x18
1340
1341/*
1342 * Register : DRAM Address Widths Register - dramaddrw
1343 *
1344 * This register configures the width of the various address fields of the DRAM.
1345 * The values specified in this register must match the memory devices being used.
1346 *
1347 * Register Layout
1348 *
1349 * Bits | Access | Reset | Description
1350 * :--------|:-------|:--------|:-------------------------
1351 * [4:0] | RW | Unknown | DRAM Column Address Bits
1352 * [9:5] | RW | Unknown | DRAM Row Address Bits
1353 * [12:10] | RW | Unknown | DRAM Bank Address Bits
1354 * [15:13] | RW | Unknown | DRAM Chip Address Bits
1355 * [31:16] | ??? | 0x0 | *UNDEFINED*
1356 *
1357 */
1358/*
1359 * Field : DRAM Column Address Bits - colbits
1360 *
1361 * The number of column address bits for the memory devices in your memory
1362 * interface.
1363 *
1364 * Field Access Macros:
1365 *
1366 */
1367/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field. */
1368#define ALT_SDR_CTL_DRAMADDRW_COLBITS_LSB 0
1369/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field. */
1370#define ALT_SDR_CTL_DRAMADDRW_COLBITS_MSB 4
1371/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field. */
1372#define ALT_SDR_CTL_DRAMADDRW_COLBITS_WIDTH 5
1373/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_COLBITS register field value. */
1374#define ALT_SDR_CTL_DRAMADDRW_COLBITS_SET_MSK 0x0000001f
1375/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_COLBITS register field value. */
1376#define ALT_SDR_CTL_DRAMADDRW_COLBITS_CLR_MSK 0xffffffe0
1377/* The reset value of the ALT_SDR_CTL_DRAMADDRW_COLBITS register field is UNKNOWN. */
1378#define ALT_SDR_CTL_DRAMADDRW_COLBITS_RESET 0x0
1379/* Extracts the ALT_SDR_CTL_DRAMADDRW_COLBITS field value from a register. */
1380#define ALT_SDR_CTL_DRAMADDRW_COLBITS_GET(value) (((value) & 0x0000001f) >> 0)
1381/* Produces a ALT_SDR_CTL_DRAMADDRW_COLBITS register field value suitable for setting the register. */
1382#define ALT_SDR_CTL_DRAMADDRW_COLBITS_SET(value) (((value) << 0) & 0x0000001f)
1383
1384/*
1385 * Field : DRAM Row Address Bits - rowbits
1386 *
1387 * The number of row address bits for the memory devices in your memory interface.
1388 *
1389 * Field Access Macros:
1390 *
1391 */
1392/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field. */
1393#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_LSB 5
1394/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field. */
1395#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_MSB 9
1396/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field. */
1397#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_WIDTH 5
1398/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field value. */
1399#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_SET_MSK 0x000003e0
1400/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field value. */
1401#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_CLR_MSK 0xfffffc1f
1402/* The reset value of the ALT_SDR_CTL_DRAMADDRW_ROWBITS register field is UNKNOWN. */
1403#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_RESET 0x0
1404/* Extracts the ALT_SDR_CTL_DRAMADDRW_ROWBITS field value from a register. */
1405#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_GET(value) (((value) & 0x000003e0) >> 5)
1406/* Produces a ALT_SDR_CTL_DRAMADDRW_ROWBITS register field value suitable for setting the register. */
1407#define ALT_SDR_CTL_DRAMADDRW_ROWBITS_SET(value) (((value) << 5) & 0x000003e0)
1408
1409/*
1410 * Field : DRAM Bank Address Bits - bankbits
1411 *
1412 * The number of bank address bits for the memory devices in your memory interface.
1413 *
1414 * Field Access Macros:
1415 *
1416 */
1417/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field. */
1418#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_LSB 10
1419/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field. */
1420#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_MSB 12
1421/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field. */
1422#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_WIDTH 3
1423/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field value. */
1424#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_SET_MSK 0x00001c00
1425/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field value. */
1426#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_CLR_MSK 0xffffe3ff
1427/* The reset value of the ALT_SDR_CTL_DRAMADDRW_BANKBITS register field is UNKNOWN. */
1428#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_RESET 0x0
1429/* Extracts the ALT_SDR_CTL_DRAMADDRW_BANKBITS field value from a register. */
1430#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_GET(value) (((value) & 0x00001c00) >> 10)
1431/* Produces a ALT_SDR_CTL_DRAMADDRW_BANKBITS register field value suitable for setting the register. */
1432#define ALT_SDR_CTL_DRAMADDRW_BANKBITS_SET(value) (((value) << 10) & 0x00001c00)
1433
1434/*
1435 * Field : DRAM Chip Address Bits - csbits
1436 *
1437 * The number of chip select address bits for the memory devices in your memory
1438 * interface.
1439 *
1440 * Field Access Macros:
1441 *
1442 */
1443/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field. */
1444#define ALT_SDR_CTL_DRAMADDRW_CSBITS_LSB 13
1445/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field. */
1446#define ALT_SDR_CTL_DRAMADDRW_CSBITS_MSB 15
1447/* The width in bits of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field. */
1448#define ALT_SDR_CTL_DRAMADDRW_CSBITS_WIDTH 3
1449/* The mask used to set the ALT_SDR_CTL_DRAMADDRW_CSBITS register field value. */
1450#define ALT_SDR_CTL_DRAMADDRW_CSBITS_SET_MSK 0x0000e000
1451/* The mask used to clear the ALT_SDR_CTL_DRAMADDRW_CSBITS register field value. */
1452#define ALT_SDR_CTL_DRAMADDRW_CSBITS_CLR_MSK 0xffff1fff
1453/* The reset value of the ALT_SDR_CTL_DRAMADDRW_CSBITS register field is UNKNOWN. */
1454#define ALT_SDR_CTL_DRAMADDRW_CSBITS_RESET 0x0
1455/* Extracts the ALT_SDR_CTL_DRAMADDRW_CSBITS field value from a register. */
1456#define ALT_SDR_CTL_DRAMADDRW_CSBITS_GET(value) (((value) & 0x0000e000) >> 13)
1457/* Produces a ALT_SDR_CTL_DRAMADDRW_CSBITS register field value suitable for setting the register. */
1458#define ALT_SDR_CTL_DRAMADDRW_CSBITS_SET(value) (((value) << 13) & 0x0000e000)
1459
1460#ifndef __ASSEMBLY__
1461/*
1462 * WARNING: The C register and register group struct declarations are provided for
1463 * convenience and illustrative purposes. They should, however, be used with
1464 * caution as the C language standard provides no guarantees about the alignment or
1465 * atomicity of device memory accesses. The recommended practice for writing
1466 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1467 * alt_write_word() functions.
1468 *
1469 * The struct declaration for register ALT_SDR_CTL_DRAMADDRW.
1470 */
1472{
1473 uint32_t colbits : 5; /* DRAM Column Address Bits */
1474 uint32_t rowbits : 5; /* DRAM Row Address Bits */
1475 uint32_t bankbits : 3; /* DRAM Bank Address Bits */
1476 uint32_t csbits : 3; /* DRAM Chip Address Bits */
1477 uint32_t : 16; /* *UNDEFINED* */
1478};
1479
1480/* The typedef declaration for register ALT_SDR_CTL_DRAMADDRW. */
1481typedef volatile struct ALT_SDR_CTL_DRAMADDRW_s ALT_SDR_CTL_DRAMADDRW_t;
1482#endif /* __ASSEMBLY__ */
1483
1484/* The byte offset of the ALT_SDR_CTL_DRAMADDRW register from the beginning of the component. */
1485#define ALT_SDR_CTL_DRAMADDRW_OFST 0x2c
1486
1487/*
1488 * Register : DRAM Interface Data Width Register - dramifwidth
1489 *
1490 *
1491 * Register Layout
1492 *
1493 * Bits | Access | Reset | Description
1494 * :-------|:-------|:--------|:--------------------------
1495 * [7:0] | RW | Unknown | DRAM Interface Data Width
1496 * [31:8] | ??? | 0x0 | *UNDEFINED*
1497 *
1498 */
1499/*
1500 * Field : DRAM Interface Data Width - ifwidth
1501 *
1502 * This register controls the interface width of the SDRAM interface, including any
1503 * bits used for ECC. For example, for a 32-bit interface with ECC, program this
1504 * register with 0x28. You must also program the ctrlwidth register.
1505 *
1506 * Field Access Macros:
1507 *
1508 */
1509/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field. */
1510#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_LSB 0
1511/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field. */
1512#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_MSB 7
1513/* The width in bits of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field. */
1514#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_WIDTH 8
1515/* The mask used to set the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field value. */
1516#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_SET_MSK 0x000000ff
1517/* The mask used to clear the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field value. */
1518#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_CLR_MSK 0xffffff00
1519/* The reset value of the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field is UNKNOWN. */
1520#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_RESET 0x0
1521/* Extracts the ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH field value from a register. */
1522#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_GET(value) (((value) & 0x000000ff) >> 0)
1523/* Produces a ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH register field value suitable for setting the register. */
1524#define ALT_SDR_CTL_DRAMIFWIDTH_IFWIDTH_SET(value) (((value) << 0) & 0x000000ff)
1525
1526#ifndef __ASSEMBLY__
1527/*
1528 * WARNING: The C register and register group struct declarations are provided for
1529 * convenience and illustrative purposes. They should, however, be used with
1530 * caution as the C language standard provides no guarantees about the alignment or
1531 * atomicity of device memory accesses. The recommended practice for writing
1532 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1533 * alt_write_word() functions.
1534 *
1535 * The struct declaration for register ALT_SDR_CTL_DRAMIFWIDTH.
1536 */
1538{
1539 uint32_t ifwidth : 8; /* DRAM Interface Data Width */
1540 uint32_t : 24; /* *UNDEFINED* */
1541};
1542
1543/* The typedef declaration for register ALT_SDR_CTL_DRAMIFWIDTH. */
1545#endif /* __ASSEMBLY__ */
1546
1547/* The byte offset of the ALT_SDR_CTL_DRAMIFWIDTH register from the beginning of the component. */
1548#define ALT_SDR_CTL_DRAMIFWIDTH_OFST 0x30
1549
1550/*
1551 * Register : DRAM Devices Data Width Register - dramdevwidth
1552 *
1553 *
1554 * Register Layout
1555 *
1556 * Bits | Access | Reset | Description
1557 * :-------|:-------|:--------|:------------------------
1558 * [3:0] | RW | Unknown | DRAM Devices Data Width
1559 * [31:4] | ??? | 0x0 | *UNDEFINED*
1560 *
1561 */
1562/*
1563 * Field : DRAM Devices Data Width - devwidth
1564 *
1565 * This register specifies the width of the physical DRAM chips, for example 8 or
1566 * 16.
1567 *
1568 * Field Access Macros:
1569 *
1570 */
1571/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field. */
1572#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_LSB 0
1573/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field. */
1574#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_MSB 3
1575/* The width in bits of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field. */
1576#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_WIDTH 4
1577/* The mask used to set the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field value. */
1578#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_SET_MSK 0x0000000f
1579/* The mask used to clear the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field value. */
1580#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_CLR_MSK 0xfffffff0
1581/* The reset value of the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field is UNKNOWN. */
1582#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_RESET 0x0
1583/* Extracts the ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH field value from a register. */
1584#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_GET(value) (((value) & 0x0000000f) >> 0)
1585/* Produces a ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH register field value suitable for setting the register. */
1586#define ALT_SDR_CTL_DRAMDEVWIDTH_DEVWIDTH_SET(value) (((value) << 0) & 0x0000000f)
1587
1588#ifndef __ASSEMBLY__
1589/*
1590 * WARNING: The C register and register group struct declarations are provided for
1591 * convenience and illustrative purposes. They should, however, be used with
1592 * caution as the C language standard provides no guarantees about the alignment or
1593 * atomicity of device memory accesses. The recommended practice for writing
1594 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1595 * alt_write_word() functions.
1596 *
1597 * The struct declaration for register ALT_SDR_CTL_DRAMDEVWIDTH.
1598 */
1600{
1601 uint32_t devwidth : 4; /* DRAM Devices Data Width */
1602 uint32_t : 28; /* *UNDEFINED* */
1603};
1604
1605/* The typedef declaration for register ALT_SDR_CTL_DRAMDEVWIDTH. */
1607#endif /* __ASSEMBLY__ */
1608
1609/* The byte offset of the ALT_SDR_CTL_DRAMDEVWIDTH register from the beginning of the component. */
1610#define ALT_SDR_CTL_DRAMDEVWIDTH_OFST 0x34
1611
1612/*
1613 * Register : DRAM Status Register - dramsts
1614 *
1615 * This register provides the status of the calibration and ECC logic.
1616 *
1617 * Register Layout
1618 *
1619 * Bits | Access | Reset | Description
1620 * :-------|:-------|:--------|:----------------------------
1621 * [0] | RW | Unknown | PHY Calibration Successful
1622 * [1] | RW | Unknown | PHY Calibration Failed
1623 * [2] | RW | Unknown | Single Bit Error Seen
1624 * [3] | RW | Unknown | Double Bit Error Seen
1625 * [4] | RW | Unknown | ECC Auto-Correction Dropped
1626 * [31:5] | ??? | 0x0 | *UNDEFINED*
1627 *
1628 */
1629/*
1630 * Field : PHY Calibration Successful - calsuccess
1631 *
1632 * This bit will be set to 1 if the PHY was able to successfully calibrate.
1633 *
1634 * Field Access Macros:
1635 *
1636 */
1637/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field. */
1638#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_LSB 0
1639/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field. */
1640#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_MSB 0
1641/* The width in bits of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field. */
1642#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_WIDTH 1
1643/* The mask used to set the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field value. */
1644#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_SET_MSK 0x00000001
1645/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field value. */
1646#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_CLR_MSK 0xfffffffe
1647/* The reset value of the ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field is UNKNOWN. */
1648#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_RESET 0x0
1649/* Extracts the ALT_SDR_CTL_DRAMSTS_CALSUCCESS field value from a register. */
1650#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_GET(value) (((value) & 0x00000001) >> 0)
1651/* Produces a ALT_SDR_CTL_DRAMSTS_CALSUCCESS register field value suitable for setting the register. */
1652#define ALT_SDR_CTL_DRAMSTS_CALSUCCESS_SET(value) (((value) << 0) & 0x00000001)
1653
1654/*
1655 * Field : PHY Calibration Failed - calfail
1656 *
1657 * This bit will be set to 1 if the PHY was unable to calibrate.
1658 *
1659 * Field Access Macros:
1660 *
1661 */
1662/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field. */
1663#define ALT_SDR_CTL_DRAMSTS_CALFAIL_LSB 1
1664/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field. */
1665#define ALT_SDR_CTL_DRAMSTS_CALFAIL_MSB 1
1666/* The width in bits of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field. */
1667#define ALT_SDR_CTL_DRAMSTS_CALFAIL_WIDTH 1
1668/* The mask used to set the ALT_SDR_CTL_DRAMSTS_CALFAIL register field value. */
1669#define ALT_SDR_CTL_DRAMSTS_CALFAIL_SET_MSK 0x00000002
1670/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_CALFAIL register field value. */
1671#define ALT_SDR_CTL_DRAMSTS_CALFAIL_CLR_MSK 0xfffffffd
1672/* The reset value of the ALT_SDR_CTL_DRAMSTS_CALFAIL register field is UNKNOWN. */
1673#define ALT_SDR_CTL_DRAMSTS_CALFAIL_RESET 0x0
1674/* Extracts the ALT_SDR_CTL_DRAMSTS_CALFAIL field value from a register. */
1675#define ALT_SDR_CTL_DRAMSTS_CALFAIL_GET(value) (((value) & 0x00000002) >> 1)
1676/* Produces a ALT_SDR_CTL_DRAMSTS_CALFAIL register field value suitable for setting the register. */
1677#define ALT_SDR_CTL_DRAMSTS_CALFAIL_SET(value) (((value) << 1) & 0x00000002)
1678
1679/*
1680 * Field : Single Bit Error Seen - sbeerr
1681 *
1682 * This bit will be set to 1 if there have been any ECC single bit errors detected.
1683 *
1684 * Field Access Macros:
1685 *
1686 */
1687/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_SBEERR register field. */
1688#define ALT_SDR_CTL_DRAMSTS_SBEERR_LSB 2
1689/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_SBEERR register field. */
1690#define ALT_SDR_CTL_DRAMSTS_SBEERR_MSB 2
1691/* The width in bits of the ALT_SDR_CTL_DRAMSTS_SBEERR register field. */
1692#define ALT_SDR_CTL_DRAMSTS_SBEERR_WIDTH 1
1693/* The mask used to set the ALT_SDR_CTL_DRAMSTS_SBEERR register field value. */
1694#define ALT_SDR_CTL_DRAMSTS_SBEERR_SET_MSK 0x00000004
1695/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_SBEERR register field value. */
1696#define ALT_SDR_CTL_DRAMSTS_SBEERR_CLR_MSK 0xfffffffb
1697/* The reset value of the ALT_SDR_CTL_DRAMSTS_SBEERR register field is UNKNOWN. */
1698#define ALT_SDR_CTL_DRAMSTS_SBEERR_RESET 0x0
1699/* Extracts the ALT_SDR_CTL_DRAMSTS_SBEERR field value from a register. */
1700#define ALT_SDR_CTL_DRAMSTS_SBEERR_GET(value) (((value) & 0x00000004) >> 2)
1701/* Produces a ALT_SDR_CTL_DRAMSTS_SBEERR register field value suitable for setting the register. */
1702#define ALT_SDR_CTL_DRAMSTS_SBEERR_SET(value) (((value) << 2) & 0x00000004)
1703
1704/*
1705 * Field : Double Bit Error Seen - dbeerr
1706 *
1707 * This bit will be set to 1 if there have been any ECC double bit errors detected.
1708 *
1709 * Field Access Macros:
1710 *
1711 */
1712/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_DBEERR register field. */
1713#define ALT_SDR_CTL_DRAMSTS_DBEERR_LSB 3
1714/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_DBEERR register field. */
1715#define ALT_SDR_CTL_DRAMSTS_DBEERR_MSB 3
1716/* The width in bits of the ALT_SDR_CTL_DRAMSTS_DBEERR register field. */
1717#define ALT_SDR_CTL_DRAMSTS_DBEERR_WIDTH 1
1718/* The mask used to set the ALT_SDR_CTL_DRAMSTS_DBEERR register field value. */
1719#define ALT_SDR_CTL_DRAMSTS_DBEERR_SET_MSK 0x00000008
1720/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_DBEERR register field value. */
1721#define ALT_SDR_CTL_DRAMSTS_DBEERR_CLR_MSK 0xfffffff7
1722/* The reset value of the ALT_SDR_CTL_DRAMSTS_DBEERR register field is UNKNOWN. */
1723#define ALT_SDR_CTL_DRAMSTS_DBEERR_RESET 0x0
1724/* Extracts the ALT_SDR_CTL_DRAMSTS_DBEERR field value from a register. */
1725#define ALT_SDR_CTL_DRAMSTS_DBEERR_GET(value) (((value) & 0x00000008) >> 3)
1726/* Produces a ALT_SDR_CTL_DRAMSTS_DBEERR register field value suitable for setting the register. */
1727#define ALT_SDR_CTL_DRAMSTS_DBEERR_SET(value) (((value) << 3) & 0x00000008)
1728
1729/*
1730 * Field : ECC Auto-Correction Dropped - corrdrop
1731 *
1732 * This bit will be set to 1 if there any auto-corrections have been dropped.
1733 *
1734 * Field Access Macros:
1735 *
1736 */
1737/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field. */
1738#define ALT_SDR_CTL_DRAMSTS_CORRDROP_LSB 4
1739/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field. */
1740#define ALT_SDR_CTL_DRAMSTS_CORRDROP_MSB 4
1741/* The width in bits of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field. */
1742#define ALT_SDR_CTL_DRAMSTS_CORRDROP_WIDTH 1
1743/* The mask used to set the ALT_SDR_CTL_DRAMSTS_CORRDROP register field value. */
1744#define ALT_SDR_CTL_DRAMSTS_CORRDROP_SET_MSK 0x00000010
1745/* The mask used to clear the ALT_SDR_CTL_DRAMSTS_CORRDROP register field value. */
1746#define ALT_SDR_CTL_DRAMSTS_CORRDROP_CLR_MSK 0xffffffef
1747/* The reset value of the ALT_SDR_CTL_DRAMSTS_CORRDROP register field is UNKNOWN. */
1748#define ALT_SDR_CTL_DRAMSTS_CORRDROP_RESET 0x0
1749/* Extracts the ALT_SDR_CTL_DRAMSTS_CORRDROP field value from a register. */
1750#define ALT_SDR_CTL_DRAMSTS_CORRDROP_GET(value) (((value) & 0x00000010) >> 4)
1751/* Produces a ALT_SDR_CTL_DRAMSTS_CORRDROP register field value suitable for setting the register. */
1752#define ALT_SDR_CTL_DRAMSTS_CORRDROP_SET(value) (((value) << 4) & 0x00000010)
1753
1754#ifndef __ASSEMBLY__
1755/*
1756 * WARNING: The C register and register group struct declarations are provided for
1757 * convenience and illustrative purposes. They should, however, be used with
1758 * caution as the C language standard provides no guarantees about the alignment or
1759 * atomicity of device memory accesses. The recommended practice for writing
1760 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1761 * alt_write_word() functions.
1762 *
1763 * The struct declaration for register ALT_SDR_CTL_DRAMSTS.
1764 */
1766{
1767 uint32_t calsuccess : 1; /* PHY Calibration Successful */
1768 uint32_t calfail : 1; /* PHY Calibration Failed */
1769 uint32_t sbeerr : 1; /* Single Bit Error Seen */
1770 uint32_t dbeerr : 1; /* Double Bit Error Seen */
1771 uint32_t corrdrop : 1; /* ECC Auto-Correction Dropped */
1772 uint32_t : 27; /* *UNDEFINED* */
1773};
1774
1775/* The typedef declaration for register ALT_SDR_CTL_DRAMSTS. */
1776typedef volatile struct ALT_SDR_CTL_DRAMSTS_s ALT_SDR_CTL_DRAMSTS_t;
1777#endif /* __ASSEMBLY__ */
1778
1779/* The byte offset of the ALT_SDR_CTL_DRAMSTS register from the beginning of the component. */
1780#define ALT_SDR_CTL_DRAMSTS_OFST 0x38
1781
1782/*
1783 * Register : ECC Interrupt Register - dramintr
1784 *
1785 *
1786 * Register Layout
1787 *
1788 * Bits | Access | Reset | Description
1789 * :-------|:-------|:--------|:---------------------------------------
1790 * [0] | RW | Unknown | Interrupt Enable
1791 * [1] | RW | Unknown | Mask Single Bit Error Interrupt
1792 * [2] | RW | Unknown | Mask Double Bit Error Interrupt
1793 * [3] | RW | Unknown | Mask Dropped Auto-correction Interrupt
1794 * [4] | RW | Unknown | Clear Interrupt Signal
1795 * [31:5] | ??? | 0x0 | *UNDEFINED*
1796 *
1797 */
1798/*
1799 * Field : Interrupt Enable - intren
1800 *
1801 * Enable the interrupt output.
1802 *
1803 * Field Access Macros:
1804 *
1805 */
1806/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_INTREN register field. */
1807#define ALT_SDR_CTL_DRAMINTR_INTREN_LSB 0
1808/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_INTREN register field. */
1809#define ALT_SDR_CTL_DRAMINTR_INTREN_MSB 0
1810/* The width in bits of the ALT_SDR_CTL_DRAMINTR_INTREN register field. */
1811#define ALT_SDR_CTL_DRAMINTR_INTREN_WIDTH 1
1812/* The mask used to set the ALT_SDR_CTL_DRAMINTR_INTREN register field value. */
1813#define ALT_SDR_CTL_DRAMINTR_INTREN_SET_MSK 0x00000001
1814/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_INTREN register field value. */
1815#define ALT_SDR_CTL_DRAMINTR_INTREN_CLR_MSK 0xfffffffe
1816/* The reset value of the ALT_SDR_CTL_DRAMINTR_INTREN register field is UNKNOWN. */
1817#define ALT_SDR_CTL_DRAMINTR_INTREN_RESET 0x0
1818/* Extracts the ALT_SDR_CTL_DRAMINTR_INTREN field value from a register. */
1819#define ALT_SDR_CTL_DRAMINTR_INTREN_GET(value) (((value) & 0x00000001) >> 0)
1820/* Produces a ALT_SDR_CTL_DRAMINTR_INTREN register field value suitable for setting the register. */
1821#define ALT_SDR_CTL_DRAMINTR_INTREN_SET(value) (((value) << 0) & 0x00000001)
1822
1823/*
1824 * Field : Mask Single Bit Error Interrupt - sbemask
1825 *
1826 * Mask the single bit error interrupt.
1827 *
1828 * Field Access Macros:
1829 *
1830 */
1831/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field. */
1832#define ALT_SDR_CTL_DRAMINTR_SBEMSK_LSB 1
1833/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field. */
1834#define ALT_SDR_CTL_DRAMINTR_SBEMSK_MSB 1
1835/* The width in bits of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field. */
1836#define ALT_SDR_CTL_DRAMINTR_SBEMSK_WIDTH 1
1837/* The mask used to set the ALT_SDR_CTL_DRAMINTR_SBEMSK register field value. */
1838#define ALT_SDR_CTL_DRAMINTR_SBEMSK_SET_MSK 0x00000002
1839/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_SBEMSK register field value. */
1840#define ALT_SDR_CTL_DRAMINTR_SBEMSK_CLR_MSK 0xfffffffd
1841/* The reset value of the ALT_SDR_CTL_DRAMINTR_SBEMSK register field is UNKNOWN. */
1842#define ALT_SDR_CTL_DRAMINTR_SBEMSK_RESET 0x0
1843/* Extracts the ALT_SDR_CTL_DRAMINTR_SBEMSK field value from a register. */
1844#define ALT_SDR_CTL_DRAMINTR_SBEMSK_GET(value) (((value) & 0x00000002) >> 1)
1845/* Produces a ALT_SDR_CTL_DRAMINTR_SBEMSK register field value suitable for setting the register. */
1846#define ALT_SDR_CTL_DRAMINTR_SBEMSK_SET(value) (((value) << 1) & 0x00000002)
1847
1848/*
1849 * Field : Mask Double Bit Error Interrupt - dbemask
1850 *
1851 * Mask the double bit error interrupt.
1852 *
1853 * Field Access Macros:
1854 *
1855 */
1856/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field. */
1857#define ALT_SDR_CTL_DRAMINTR_DBEMSK_LSB 2
1858/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field. */
1859#define ALT_SDR_CTL_DRAMINTR_DBEMSK_MSB 2
1860/* The width in bits of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field. */
1861#define ALT_SDR_CTL_DRAMINTR_DBEMSK_WIDTH 1
1862/* The mask used to set the ALT_SDR_CTL_DRAMINTR_DBEMSK register field value. */
1863#define ALT_SDR_CTL_DRAMINTR_DBEMSK_SET_MSK 0x00000004
1864/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_DBEMSK register field value. */
1865#define ALT_SDR_CTL_DRAMINTR_DBEMSK_CLR_MSK 0xfffffffb
1866/* The reset value of the ALT_SDR_CTL_DRAMINTR_DBEMSK register field is UNKNOWN. */
1867#define ALT_SDR_CTL_DRAMINTR_DBEMSK_RESET 0x0
1868/* Extracts the ALT_SDR_CTL_DRAMINTR_DBEMSK field value from a register. */
1869#define ALT_SDR_CTL_DRAMINTR_DBEMSK_GET(value) (((value) & 0x00000004) >> 2)
1870/* Produces a ALT_SDR_CTL_DRAMINTR_DBEMSK register field value suitable for setting the register. */
1871#define ALT_SDR_CTL_DRAMINTR_DBEMSK_SET(value) (((value) << 2) & 0x00000004)
1872
1873/*
1874 * Field : Mask Dropped Auto-correction Interrupt - corrdropmask
1875 *
1876 * Set this bit to a one to mask interrupts for an ECC correction write back
1877 * needing to be dropped. This indicates a burst of memory errors in a short
1878 * period of time.
1879 *
1880 * Field Access Macros:
1881 *
1882 */
1883/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field. */
1884#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_LSB 3
1885/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field. */
1886#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_MSB 3
1887/* The width in bits of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field. */
1888#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_WIDTH 1
1889/* The mask used to set the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field value. */
1890#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_SET_MSK 0x00000008
1891/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field value. */
1892#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_CLR_MSK 0xfffffff7
1893/* The reset value of the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field is UNKNOWN. */
1894#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_RESET 0x0
1895/* Extracts the ALT_SDR_CTL_DRAMINTR_CORRDROPMSK field value from a register. */
1896#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_GET(value) (((value) & 0x00000008) >> 3)
1897/* Produces a ALT_SDR_CTL_DRAMINTR_CORRDROPMSK register field value suitable for setting the register. */
1898#define ALT_SDR_CTL_DRAMINTR_CORRDROPMSK_SET(value) (((value) << 3) & 0x00000008)
1899
1900/*
1901 * Field : Clear Interrupt Signal - intrclr
1902 *
1903 * Writing to this self-clearing bit clears the interrupt signal. Writing to this
1904 * bit also clears the error count and error address registers.
1905 *
1906 * Field Access Macros:
1907 *
1908 */
1909/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field. */
1910#define ALT_SDR_CTL_DRAMINTR_INTRCLR_LSB 4
1911/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field. */
1912#define ALT_SDR_CTL_DRAMINTR_INTRCLR_MSB 4
1913/* The width in bits of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field. */
1914#define ALT_SDR_CTL_DRAMINTR_INTRCLR_WIDTH 1
1915/* The mask used to set the ALT_SDR_CTL_DRAMINTR_INTRCLR register field value. */
1916#define ALT_SDR_CTL_DRAMINTR_INTRCLR_SET_MSK 0x00000010
1917/* The mask used to clear the ALT_SDR_CTL_DRAMINTR_INTRCLR register field value. */
1918#define ALT_SDR_CTL_DRAMINTR_INTRCLR_CLR_MSK 0xffffffef
1919/* The reset value of the ALT_SDR_CTL_DRAMINTR_INTRCLR register field is UNKNOWN. */
1920#define ALT_SDR_CTL_DRAMINTR_INTRCLR_RESET 0x0
1921/* Extracts the ALT_SDR_CTL_DRAMINTR_INTRCLR field value from a register. */
1922#define ALT_SDR_CTL_DRAMINTR_INTRCLR_GET(value) (((value) & 0x00000010) >> 4)
1923/* Produces a ALT_SDR_CTL_DRAMINTR_INTRCLR register field value suitable for setting the register. */
1924#define ALT_SDR_CTL_DRAMINTR_INTRCLR_SET(value) (((value) << 4) & 0x00000010)
1925
1926#ifndef __ASSEMBLY__
1927/*
1928 * WARNING: The C register and register group struct declarations are provided for
1929 * convenience and illustrative purposes. They should, however, be used with
1930 * caution as the C language standard provides no guarantees about the alignment or
1931 * atomicity of device memory accesses. The recommended practice for writing
1932 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1933 * alt_write_word() functions.
1934 *
1935 * The struct declaration for register ALT_SDR_CTL_DRAMINTR.
1936 */
1938{
1939 uint32_t intren : 1; /* Interrupt Enable */
1940 uint32_t sbemask : 1; /* Mask Single Bit Error Interrupt */
1941 uint32_t dbemask : 1; /* Mask Double Bit Error Interrupt */
1942 uint32_t corrdropmask : 1; /* Mask Dropped Auto-correction Interrupt */
1943 uint32_t intrclr : 1; /* Clear Interrupt Signal */
1944 uint32_t : 27; /* *UNDEFINED* */
1945};
1946
1947/* The typedef declaration for register ALT_SDR_CTL_DRAMINTR. */
1948typedef volatile struct ALT_SDR_CTL_DRAMINTR_s ALT_SDR_CTL_DRAMINTR_t;
1949#endif /* __ASSEMBLY__ */
1950
1951/* The byte offset of the ALT_SDR_CTL_DRAMINTR register from the beginning of the component. */
1952#define ALT_SDR_CTL_DRAMINTR_OFST 0x3c
1953
1954/*
1955 * Register : ECC Single Bit Error Count Register - sbecount
1956 *
1957 *
1958 * Register Layout
1959 *
1960 * Bits | Access | Reset | Description
1961 * :-------|:-------|:--------|:-----------------------
1962 * [7:0] | RW | Unknown | Single Bit Error Count
1963 * [31:8] | ??? | 0x0 | *UNDEFINED*
1964 *
1965 */
1966/*
1967 * Field : Single Bit Error Count - count
1968 *
1969 * Reports the number of single bit errors that have occurred since the status
1970 * register counters were last cleared.
1971 *
1972 * Field Access Macros:
1973 *
1974 */
1975/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_SBECOUNT_COUNT register field. */
1976#define ALT_SDR_CTL_SBECOUNT_COUNT_LSB 0
1977/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_SBECOUNT_COUNT register field. */
1978#define ALT_SDR_CTL_SBECOUNT_COUNT_MSB 7
1979/* The width in bits of the ALT_SDR_CTL_SBECOUNT_COUNT register field. */
1980#define ALT_SDR_CTL_SBECOUNT_COUNT_WIDTH 8
1981/* The mask used to set the ALT_SDR_CTL_SBECOUNT_COUNT register field value. */
1982#define ALT_SDR_CTL_SBECOUNT_COUNT_SET_MSK 0x000000ff
1983/* The mask used to clear the ALT_SDR_CTL_SBECOUNT_COUNT register field value. */
1984#define ALT_SDR_CTL_SBECOUNT_COUNT_CLR_MSK 0xffffff00
1985/* The reset value of the ALT_SDR_CTL_SBECOUNT_COUNT register field is UNKNOWN. */
1986#define ALT_SDR_CTL_SBECOUNT_COUNT_RESET 0x0
1987/* Extracts the ALT_SDR_CTL_SBECOUNT_COUNT field value from a register. */
1988#define ALT_SDR_CTL_SBECOUNT_COUNT_GET(value) (((value) & 0x000000ff) >> 0)
1989/* Produces a ALT_SDR_CTL_SBECOUNT_COUNT register field value suitable for setting the register. */
1990#define ALT_SDR_CTL_SBECOUNT_COUNT_SET(value) (((value) << 0) & 0x000000ff)
1991
1992#ifndef __ASSEMBLY__
1993/*
1994 * WARNING: The C register and register group struct declarations are provided for
1995 * convenience and illustrative purposes. They should, however, be used with
1996 * caution as the C language standard provides no guarantees about the alignment or
1997 * atomicity of device memory accesses. The recommended practice for writing
1998 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1999 * alt_write_word() functions.
2000 *
2001 * The struct declaration for register ALT_SDR_CTL_SBECOUNT.
2002 */
2004{
2005 uint32_t count : 8; /* Single Bit Error Count */
2006 uint32_t : 24; /* *UNDEFINED* */
2007};
2008
2009/* The typedef declaration for register ALT_SDR_CTL_SBECOUNT. */
2010typedef volatile struct ALT_SDR_CTL_SBECOUNT_s ALT_SDR_CTL_SBECOUNT_t;
2011#endif /* __ASSEMBLY__ */
2012
2013/* The byte offset of the ALT_SDR_CTL_SBECOUNT register from the beginning of the component. */
2014#define ALT_SDR_CTL_SBECOUNT_OFST 0x40
2015
2016/*
2017 * Register : ECC Double Bit Error Count Register - dbecount
2018 *
2019 *
2020 * Register Layout
2021 *
2022 * Bits | Access | Reset | Description
2023 * :-------|:-------|:--------|:-----------------------
2024 * [7:0] | RW | Unknown | Double Bit Error Count
2025 * [31:8] | ??? | 0x0 | *UNDEFINED*
2026 *
2027 */
2028/*
2029 * Field : Double Bit Error Count - count
2030 *
2031 * Reports the number of double bit errors that have occurred since the status
2032 * register counters were last cleared.
2033 *
2034 * Field Access Macros:
2035 *
2036 */
2037/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DBECOUNT_COUNT register field. */
2038#define ALT_SDR_CTL_DBECOUNT_COUNT_LSB 0
2039/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DBECOUNT_COUNT register field. */
2040#define ALT_SDR_CTL_DBECOUNT_COUNT_MSB 7
2041/* The width in bits of the ALT_SDR_CTL_DBECOUNT_COUNT register field. */
2042#define ALT_SDR_CTL_DBECOUNT_COUNT_WIDTH 8
2043/* The mask used to set the ALT_SDR_CTL_DBECOUNT_COUNT register field value. */
2044#define ALT_SDR_CTL_DBECOUNT_COUNT_SET_MSK 0x000000ff
2045/* The mask used to clear the ALT_SDR_CTL_DBECOUNT_COUNT register field value. */
2046#define ALT_SDR_CTL_DBECOUNT_COUNT_CLR_MSK 0xffffff00
2047/* The reset value of the ALT_SDR_CTL_DBECOUNT_COUNT register field is UNKNOWN. */
2048#define ALT_SDR_CTL_DBECOUNT_COUNT_RESET 0x0
2049/* Extracts the ALT_SDR_CTL_DBECOUNT_COUNT field value from a register. */
2050#define ALT_SDR_CTL_DBECOUNT_COUNT_GET(value) (((value) & 0x000000ff) >> 0)
2051/* Produces a ALT_SDR_CTL_DBECOUNT_COUNT register field value suitable for setting the register. */
2052#define ALT_SDR_CTL_DBECOUNT_COUNT_SET(value) (((value) << 0) & 0x000000ff)
2053
2054#ifndef __ASSEMBLY__
2055/*
2056 * WARNING: The C register and register group struct declarations are provided for
2057 * convenience and illustrative purposes. They should, however, be used with
2058 * caution as the C language standard provides no guarantees about the alignment or
2059 * atomicity of device memory accesses. The recommended practice for writing
2060 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2061 * alt_write_word() functions.
2062 *
2063 * The struct declaration for register ALT_SDR_CTL_DBECOUNT.
2064 */
2066{
2067 uint32_t count : 8; /* Double Bit Error Count */
2068 uint32_t : 24; /* *UNDEFINED* */
2069};
2070
2071/* The typedef declaration for register ALT_SDR_CTL_DBECOUNT. */
2072typedef volatile struct ALT_SDR_CTL_DBECOUNT_s ALT_SDR_CTL_DBECOUNT_t;
2073#endif /* __ASSEMBLY__ */
2074
2075/* The byte offset of the ALT_SDR_CTL_DBECOUNT register from the beginning of the component. */
2076#define ALT_SDR_CTL_DBECOUNT_OFST 0x44
2077
2078/*
2079 * Register : ECC Error Address Register - erraddr
2080 *
2081 *
2082 * Register Layout
2083 *
2084 * Bits | Access | Reset | Description
2085 * :-------|:-------|:--------|:------------------
2086 * [31:0] | RW | Unknown | ECC Error Address
2087 *
2088 */
2089/*
2090 * Field : ECC Error Address - addr
2091 *
2092 * The address of the most recent ECC error.
2093 *
2094 * Field Access Macros:
2095 *
2096 */
2097/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_ERRADDR_ADDR register field. */
2098#define ALT_SDR_CTL_ERRADDR_ADDR_LSB 0
2099/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_ERRADDR_ADDR register field. */
2100#define ALT_SDR_CTL_ERRADDR_ADDR_MSB 31
2101/* The width in bits of the ALT_SDR_CTL_ERRADDR_ADDR register field. */
2102#define ALT_SDR_CTL_ERRADDR_ADDR_WIDTH 32
2103/* The mask used to set the ALT_SDR_CTL_ERRADDR_ADDR register field value. */
2104#define ALT_SDR_CTL_ERRADDR_ADDR_SET_MSK 0xffffffff
2105/* The mask used to clear the ALT_SDR_CTL_ERRADDR_ADDR register field value. */
2106#define ALT_SDR_CTL_ERRADDR_ADDR_CLR_MSK 0x00000000
2107/* The reset value of the ALT_SDR_CTL_ERRADDR_ADDR register field is UNKNOWN. */
2108#define ALT_SDR_CTL_ERRADDR_ADDR_RESET 0x0
2109/* Extracts the ALT_SDR_CTL_ERRADDR_ADDR field value from a register. */
2110#define ALT_SDR_CTL_ERRADDR_ADDR_GET(value) (((value) & 0xffffffff) >> 0)
2111/* Produces a ALT_SDR_CTL_ERRADDR_ADDR register field value suitable for setting the register. */
2112#define ALT_SDR_CTL_ERRADDR_ADDR_SET(value) (((value) << 0) & 0xffffffff)
2113
2114#ifndef __ASSEMBLY__
2115/*
2116 * WARNING: The C register and register group struct declarations are provided for
2117 * convenience and illustrative purposes. They should, however, be used with
2118 * caution as the C language standard provides no guarantees about the alignment or
2119 * atomicity of device memory accesses. The recommended practice for writing
2120 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2121 * alt_write_word() functions.
2122 *
2123 * The struct declaration for register ALT_SDR_CTL_ERRADDR.
2124 */
2126{
2127 uint32_t addr : 32; /* ECC Error Address */
2128};
2129
2130/* The typedef declaration for register ALT_SDR_CTL_ERRADDR. */
2131typedef volatile struct ALT_SDR_CTL_ERRADDR_s ALT_SDR_CTL_ERRADDR_t;
2132#endif /* __ASSEMBLY__ */
2133
2134/* The byte offset of the ALT_SDR_CTL_ERRADDR register from the beginning of the component. */
2135#define ALT_SDR_CTL_ERRADDR_OFST 0x48
2136
2137/*
2138 * Register : ECC Auto-correction Dropped Count Register - dropcount
2139 *
2140 *
2141 * Register Layout
2142 *
2143 * Bits | Access | Reset | Description
2144 * :-------|:-------|:--------|:------------------------------
2145 * [7:0] | RW | Unknown | Dropped Auto-correction Count
2146 * [31:8] | ??? | 0x0 | *UNDEFINED*
2147 *
2148 */
2149/*
2150 * Field : Dropped Auto-correction Count - corrdropcount
2151 *
2152 * This gives the count of the number of ECC write back transactions dropped due to
2153 * the internal FIFO overflowing.
2154 *
2155 * Field Access Macros:
2156 *
2157 */
2158/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field. */
2159#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_LSB 0
2160/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field. */
2161#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_MSB 7
2162/* The width in bits of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field. */
2163#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_WIDTH 8
2164/* The mask used to set the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field value. */
2165#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_SET_MSK 0x000000ff
2166/* The mask used to clear the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field value. */
2167#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_CLR_MSK 0xffffff00
2168/* The reset value of the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field is UNKNOWN. */
2169#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_RESET 0x0
2170/* Extracts the ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT field value from a register. */
2171#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_GET(value) (((value) & 0x000000ff) >> 0)
2172/* Produces a ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT register field value suitable for setting the register. */
2173#define ALT_SDR_CTL_DROPCOUNT_CORRDROPCOUNT_SET(value) (((value) << 0) & 0x000000ff)
2174
2175#ifndef __ASSEMBLY__
2176/*
2177 * WARNING: The C register and register group struct declarations are provided for
2178 * convenience and illustrative purposes. They should, however, be used with
2179 * caution as the C language standard provides no guarantees about the alignment or
2180 * atomicity of device memory accesses. The recommended practice for writing
2181 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2182 * alt_write_word() functions.
2183 *
2184 * The struct declaration for register ALT_SDR_CTL_DROPCOUNT.
2185 */
2187{
2188 uint32_t corrdropcount : 8; /* Dropped Auto-correction Count */
2189 uint32_t : 24; /* *UNDEFINED* */
2190};
2191
2192/* The typedef declaration for register ALT_SDR_CTL_DROPCOUNT. */
2193typedef volatile struct ALT_SDR_CTL_DROPCOUNT_s ALT_SDR_CTL_DROPCOUNT_t;
2194#endif /* __ASSEMBLY__ */
2195
2196/* The byte offset of the ALT_SDR_CTL_DROPCOUNT register from the beginning of the component. */
2197#define ALT_SDR_CTL_DROPCOUNT_OFST 0x4c
2198
2199/*
2200 * Register : ECC Auto-correction Dropped Address Register - dropaddr
2201 *
2202 *
2203 * Register Layout
2204 *
2205 * Bits | Access | Reset | Description
2206 * :-------|:-------|:--------|:--------------------------------
2207 * [31:0] | RW | Unknown | Dropped Auto-correction Address
2208 *
2209 */
2210/*
2211 * Field : Dropped Auto-correction Address - corrdropaddr
2212 *
2213 * This register gives the last address which was dropped.
2214 *
2215 * Field Access Macros:
2216 *
2217 */
2218/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field. */
2219#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_LSB 0
2220/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field. */
2221#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_MSB 31
2222/* The width in bits of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field. */
2223#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_WIDTH 32
2224/* The mask used to set the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field value. */
2225#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_SET_MSK 0xffffffff
2226/* The mask used to clear the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field value. */
2227#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_CLR_MSK 0x00000000
2228/* The reset value of the ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field is UNKNOWN. */
2229#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_RESET 0x0
2230/* Extracts the ALT_SDR_CTL_DROPADDR_CORRDROPADDR field value from a register. */
2231#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_GET(value) (((value) & 0xffffffff) >> 0)
2232/* Produces a ALT_SDR_CTL_DROPADDR_CORRDROPADDR register field value suitable for setting the register. */
2233#define ALT_SDR_CTL_DROPADDR_CORRDROPADDR_SET(value) (((value) << 0) & 0xffffffff)
2234
2235#ifndef __ASSEMBLY__
2236/*
2237 * WARNING: The C register and register group struct declarations are provided for
2238 * convenience and illustrative purposes. They should, however, be used with
2239 * caution as the C language standard provides no guarantees about the alignment or
2240 * atomicity of device memory accesses. The recommended practice for writing
2241 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2242 * alt_write_word() functions.
2243 *
2244 * The struct declaration for register ALT_SDR_CTL_DROPADDR.
2245 */
2247{
2248 uint32_t corrdropaddr : 32; /* Dropped Auto-correction Address */
2249};
2250
2251/* The typedef declaration for register ALT_SDR_CTL_DROPADDR. */
2252typedef volatile struct ALT_SDR_CTL_DROPADDR_s ALT_SDR_CTL_DROPADDR_t;
2253#endif /* __ASSEMBLY__ */
2254
2255/* The byte offset of the ALT_SDR_CTL_DROPADDR register from the beginning of the component. */
2256#define ALT_SDR_CTL_DROPADDR_OFST 0x50
2257
2258/*
2259 * Register : Low Power Control Register - lowpwreq
2260 *
2261 * This register instructs the controller to put the DRAM into a power down state.
2262 * Note that some commands are only valid for certain memory types.
2263 *
2264 * Register Layout
2265 *
2266 * Bits | Access | Reset | Description
2267 * :-------|:-------|:--------|:---------------------------------
2268 * [0] | RW | Unknown | Deep Power Down Request
2269 * [2:1] | RW | Unknown | Deep Power Down Chip Select Mask
2270 * [3] | RW | Unknown | Self-refresh Request
2271 * [5:4] | RW | Unknown | Self-refresh Chip Select Mask
2272 * [31:6] | ??? | 0x0 | *UNDEFINED*
2273 *
2274 */
2275/*
2276 * Field : Deep Power Down Request - deeppwrdnreq
2277 *
2278 * Write a one to this bit to request a deep power down. This bit should only be
2279 * written with LPDDR2 DRAMs, DDR3 DRAMs do not support deep power down.
2280 *
2281 * Field Access Macros:
2282 *
2283 */
2284/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field. */
2285#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_LSB 0
2286/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field. */
2287#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_MSB 0
2288/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field. */
2289#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_WIDTH 1
2290/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field value. */
2291#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_SET_MSK 0x00000001
2292/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field value. */
2293#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_CLR_MSK 0xfffffffe
2294/* The reset value of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field is UNKNOWN. */
2295#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_RESET 0x0
2296/* Extracts the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ field value from a register. */
2297#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_GET(value) (((value) & 0x00000001) >> 0)
2298/* Produces a ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ register field value suitable for setting the register. */
2299#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNREQ_SET(value) (((value) << 0) & 0x00000001)
2300
2301/*
2302 * Field : Deep Power Down Chip Select Mask - deeppwrdnmask
2303 *
2304 * Write ones to this register to select which DRAM chip selects will be powered
2305 * down. Typical usage is to set both of these bits when deeppwrdnreq is set but
2306 * the controller does support putting a single chip into deep power down and
2307 * keeping the other chip running.
2308 *
2309 * Field Access Macros:
2310 *
2311 */
2312/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field. */
2313#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_LSB 1
2314/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field. */
2315#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_MSB 2
2316/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field. */
2317#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_WIDTH 2
2318/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field value. */
2319#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_SET_MSK 0x00000006
2320/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field value. */
2321#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_CLR_MSK 0xfffffff9
2322/* The reset value of the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field is UNKNOWN. */
2323#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_RESET 0x0
2324/* Extracts the ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK field value from a register. */
2325#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_GET(value) (((value) & 0x00000006) >> 1)
2326/* Produces a ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK register field value suitable for setting the register. */
2327#define ALT_SDR_CTL_LOWPWREQ_DEEPPWRDNMSK_SET(value) (((value) << 1) & 0x00000006)
2328
2329/*
2330 * Field : Self-refresh Request - selfrshreq
2331 *
2332 * Write a one to this bit to request the RAM be put into a self refresh state.
2333 * This bit is treated as a static value so the RAM will remain in self-refresh as
2334 * long as this register bit is set to a one. This power down mode can be selected
2335 * for all DRAMs supported by the controller.
2336 *
2337 * Field Access Macros:
2338 *
2339 */
2340/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field. */
2341#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_LSB 3
2342/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field. */
2343#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_MSB 3
2344/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field. */
2345#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_WIDTH 1
2346/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field value. */
2347#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_SET_MSK 0x00000008
2348/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field value. */
2349#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_CLR_MSK 0xfffffff7
2350/* The reset value of the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field is UNKNOWN. */
2351#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_RESET 0x0
2352/* Extracts the ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ field value from a register. */
2353#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_GET(value) (((value) & 0x00000008) >> 3)
2354/* Produces a ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ register field value suitable for setting the register. */
2355#define ALT_SDR_CTL_LOWPWREQ_SELFRSHREQ_SET(value) (((value) << 3) & 0x00000008)
2356
2357/*
2358 * Field : Self-refresh Chip Select Mask - selfrfshmask
2359 *
2360 * Write a one to each bit of this field to have a self refresh request apply to
2361 * both chips.
2362 *
2363 * Field Access Macros:
2364 *
2365 */
2366/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field. */
2367#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_LSB 4
2368/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field. */
2369#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_MSB 5
2370/* The width in bits of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field. */
2371#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_WIDTH 2
2372/* The mask used to set the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field value. */
2373#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_SET_MSK 0x00000030
2374/* The mask used to clear the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field value. */
2375#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_CLR_MSK 0xffffffcf
2376/* The reset value of the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field is UNKNOWN. */
2377#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_RESET 0x0
2378/* Extracts the ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK field value from a register. */
2379#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_GET(value) (((value) & 0x00000030) >> 4)
2380/* Produces a ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK register field value suitable for setting the register. */
2381#define ALT_SDR_CTL_LOWPWREQ_SELFRFSHMSK_SET(value) (((value) << 4) & 0x00000030)
2382
2383#ifndef __ASSEMBLY__
2384/*
2385 * WARNING: The C register and register group struct declarations are provided for
2386 * convenience and illustrative purposes. They should, however, be used with
2387 * caution as the C language standard provides no guarantees about the alignment or
2388 * atomicity of device memory accesses. The recommended practice for writing
2389 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2390 * alt_write_word() functions.
2391 *
2392 * The struct declaration for register ALT_SDR_CTL_LOWPWREQ.
2393 */
2395{
2396 uint32_t deeppwrdnreq : 1; /* Deep Power Down Request */
2397 uint32_t deeppwrdnmask : 2; /* Deep Power Down Chip Select Mask */
2398 uint32_t selfrshreq : 1; /* Self-refresh Request */
2399 uint32_t selfrfshmask : 2; /* Self-refresh Chip Select Mask */
2400 uint32_t : 26; /* *UNDEFINED* */
2401};
2402
2403/* The typedef declaration for register ALT_SDR_CTL_LOWPWREQ. */
2404typedef volatile struct ALT_SDR_CTL_LOWPWREQ_s ALT_SDR_CTL_LOWPWREQ_t;
2405#endif /* __ASSEMBLY__ */
2406
2407/* The byte offset of the ALT_SDR_CTL_LOWPWREQ register from the beginning of the component. */
2408#define ALT_SDR_CTL_LOWPWREQ_OFST 0x54
2409
2410/*
2411 * Register : Low Power Acknowledge Register - lowpwrack
2412 *
2413 * This register gives the status of the power down commands requested by the Low
2414 * Power Control register.
2415 *
2416 * Register Layout
2417 *
2418 * Bits | Access | Reset | Description
2419 * :-------|:-------|:--------|:----------------------------
2420 * [0] | RW | Unknown | Deep Power Down Acknowledge
2421 * [1] | RW | Unknown | Self-refresh Acknowledge
2422 * [31:2] | ??? | 0x0 | *UNDEFINED*
2423 *
2424 */
2425/*
2426 * Field : Deep Power Down Acknowledge - deeppwrdnack
2427 *
2428 * This bit is set to a one after a deep power down has been executed
2429 *
2430 * Field Access Macros:
2431 *
2432 */
2433/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field. */
2434#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_LSB 0
2435/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field. */
2436#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_MSB 0
2437/* The width in bits of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field. */
2438#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_WIDTH 1
2439/* The mask used to set the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field value. */
2440#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_SET_MSK 0x00000001
2441/* The mask used to clear the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field value. */
2442#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_CLR_MSK 0xfffffffe
2443/* The reset value of the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field is UNKNOWN. */
2444#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_RESET 0x0
2445/* Extracts the ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK field value from a register. */
2446#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_GET(value) (((value) & 0x00000001) >> 0)
2447/* Produces a ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK register field value suitable for setting the register. */
2448#define ALT_SDR_CTL_LOWPWRACK_DEEPPWRDNACK_SET(value) (((value) << 0) & 0x00000001)
2449
2450/*
2451 * Field : Self-refresh Acknowledge - selfrfshack
2452 *
2453 * This bit is a one to indicate that the controller is in a self-refresh state.
2454 *
2455 * Field Access Macros:
2456 *
2457 */
2458/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field. */
2459#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_LSB 1
2460/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field. */
2461#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_MSB 1
2462/* The width in bits of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field. */
2463#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_WIDTH 1
2464/* The mask used to set the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field value. */
2465#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_SET_MSK 0x00000002
2466/* The mask used to clear the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field value. */
2467#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_CLR_MSK 0xfffffffd
2468/* The reset value of the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field is UNKNOWN. */
2469#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_RESET 0x0
2470/* Extracts the ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK field value from a register. */
2471#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_GET(value) (((value) & 0x00000002) >> 1)
2472/* Produces a ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK register field value suitable for setting the register. */
2473#define ALT_SDR_CTL_LOWPWRACK_SELFRFSHACK_SET(value) (((value) << 1) & 0x00000002)
2474
2475#ifndef __ASSEMBLY__
2476/*
2477 * WARNING: The C register and register group struct declarations are provided for
2478 * convenience and illustrative purposes. They should, however, be used with
2479 * caution as the C language standard provides no guarantees about the alignment or
2480 * atomicity of device memory accesses. The recommended practice for writing
2481 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2482 * alt_write_word() functions.
2483 *
2484 * The struct declaration for register ALT_SDR_CTL_LOWPWRACK.
2485 */
2487{
2488 uint32_t deeppwrdnack : 1; /* Deep Power Down Acknowledge */
2489 uint32_t selfrfshack : 1; /* Self-refresh Acknowledge */
2490 uint32_t : 30; /* *UNDEFINED* */
2491};
2492
2493/* The typedef declaration for register ALT_SDR_CTL_LOWPWRACK. */
2494typedef volatile struct ALT_SDR_CTL_LOWPWRACK_s ALT_SDR_CTL_LOWPWRACK_t;
2495#endif /* __ASSEMBLY__ */
2496
2497/* The byte offset of the ALT_SDR_CTL_LOWPWRACK register from the beginning of the component. */
2498#define ALT_SDR_CTL_LOWPWRACK_OFST 0x58
2499
2500/*
2501 * Register : Static Configuration Register - staticcfg
2502 *
2503 * This register controls configuration values which cannot be updated while
2504 * transactions are flowing.
2505 *
2506 * You should write once to this register with the membl and eccen fields set to
2507 * your desired configuration, and then write to the register again with membl and
2508 * eccen and the applycfg bit set. The applycfg bit is write only.
2509 *
2510 * Register Layout
2511 *
2512 * Bits | Access | Reset | Description
2513 * :-------|:-------|:--------|:----------------------------
2514 * [1:0] | RW | Unknown | Memory Burst Length
2515 * [2] | RW | Unknown | Use ECC Bits As Data
2516 * [3] | RW | Unknown | Apply Configuration Changes
2517 * [31:4] | ??? | 0x0 | *UNDEFINED*
2518 *
2519 */
2520/*
2521 * Field : Memory Burst Length - membl
2522 *
2523 * This field specifies the DRAM burst length. Write the following values to set
2524 * the a burst length appropriate for the specific DRAM being used. &quot;00&quot;
2525 * for burst length 2, &quot;01&quot; for burst length 4, &quot;10&quot; for burst
2526 * length 8. If you set this, you must also set the membl field in the ctrlcfg
2527 * register.
2528 *
2529 * Field Access Macros:
2530 *
2531 */
2532/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_STATICCFG_MEMBL register field. */
2533#define ALT_SDR_CTL_STATICCFG_MEMBL_LSB 0
2534/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_STATICCFG_MEMBL register field. */
2535#define ALT_SDR_CTL_STATICCFG_MEMBL_MSB 1
2536/* The width in bits of the ALT_SDR_CTL_STATICCFG_MEMBL register field. */
2537#define ALT_SDR_CTL_STATICCFG_MEMBL_WIDTH 2
2538/* The mask used to set the ALT_SDR_CTL_STATICCFG_MEMBL register field value. */
2539#define ALT_SDR_CTL_STATICCFG_MEMBL_SET_MSK 0x00000003
2540/* The mask used to clear the ALT_SDR_CTL_STATICCFG_MEMBL register field value. */
2541#define ALT_SDR_CTL_STATICCFG_MEMBL_CLR_MSK 0xfffffffc
2542/* The reset value of the ALT_SDR_CTL_STATICCFG_MEMBL register field is UNKNOWN. */
2543#define ALT_SDR_CTL_STATICCFG_MEMBL_RESET 0x0
2544/* Extracts the ALT_SDR_CTL_STATICCFG_MEMBL field value from a register. */
2545#define ALT_SDR_CTL_STATICCFG_MEMBL_GET(value) (((value) & 0x00000003) >> 0)
2546/* Produces a ALT_SDR_CTL_STATICCFG_MEMBL register field value suitable for setting the register. */
2547#define ALT_SDR_CTL_STATICCFG_MEMBL_SET(value) (((value) << 0) & 0x00000003)
2548
2549/*
2550 * Field : Use ECC Bits As Data - useeccasdata
2551 *
2552 * This field allows the FPGA ports to directly access the extra data bits that are
2553 * normally used to hold the ECC code. The interface width must be set to 24 or 40
2554 * in the dramifwidth register. If you set this, you must clear the eccen field in
2555 * the ctrlcfg register.
2556 *
2557 * Field Access Macros:
2558 *
2559 */
2560/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field. */
2561#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_LSB 2
2562/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field. */
2563#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_MSB 2
2564/* The width in bits of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field. */
2565#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_WIDTH 1
2566/* The mask used to set the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field value. */
2567#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_SET_MSK 0x00000004
2568/* The mask used to clear the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field value. */
2569#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_CLR_MSK 0xfffffffb
2570/* The reset value of the ALT_SDR_CTL_STATICCFG_USEECCASDATA register field is UNKNOWN. */
2571#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_RESET 0x0
2572/* Extracts the ALT_SDR_CTL_STATICCFG_USEECCASDATA field value from a register. */
2573#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_GET(value) (((value) & 0x00000004) >> 2)
2574/* Produces a ALT_SDR_CTL_STATICCFG_USEECCASDATA register field value suitable for setting the register. */
2575#define ALT_SDR_CTL_STATICCFG_USEECCASDATA_SET(value) (((value) << 2) & 0x00000004)
2576
2577/*
2578 * Field : Apply Configuration Changes - applycfg
2579 *
2580 * Write with this bit set to apply all the settings loaded in SDR registers to the
2581 * memory interface. This bit is write-only and always returns 0 if read.
2582 *
2583 * Field Access Macros:
2584 *
2585 */
2586/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field. */
2587#define ALT_SDR_CTL_STATICCFG_APPLYCFG_LSB 3
2588/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field. */
2589#define ALT_SDR_CTL_STATICCFG_APPLYCFG_MSB 3
2590/* The width in bits of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field. */
2591#define ALT_SDR_CTL_STATICCFG_APPLYCFG_WIDTH 1
2592/* The mask used to set the ALT_SDR_CTL_STATICCFG_APPLYCFG register field value. */
2593#define ALT_SDR_CTL_STATICCFG_APPLYCFG_SET_MSK 0x00000008
2594/* The mask used to clear the ALT_SDR_CTL_STATICCFG_APPLYCFG register field value. */
2595#define ALT_SDR_CTL_STATICCFG_APPLYCFG_CLR_MSK 0xfffffff7
2596/* The reset value of the ALT_SDR_CTL_STATICCFG_APPLYCFG register field is UNKNOWN. */
2597#define ALT_SDR_CTL_STATICCFG_APPLYCFG_RESET 0x0
2598/* Extracts the ALT_SDR_CTL_STATICCFG_APPLYCFG field value from a register. */
2599#define ALT_SDR_CTL_STATICCFG_APPLYCFG_GET(value) (((value) & 0x00000008) >> 3)
2600/* Produces a ALT_SDR_CTL_STATICCFG_APPLYCFG register field value suitable for setting the register. */
2601#define ALT_SDR_CTL_STATICCFG_APPLYCFG_SET(value) (((value) << 3) & 0x00000008)
2602
2603#ifndef __ASSEMBLY__
2604/*
2605 * WARNING: The C register and register group struct declarations are provided for
2606 * convenience and illustrative purposes. They should, however, be used with
2607 * caution as the C language standard provides no guarantees about the alignment or
2608 * atomicity of device memory accesses. The recommended practice for writing
2609 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2610 * alt_write_word() functions.
2611 *
2612 * The struct declaration for register ALT_SDR_CTL_STATICCFG.
2613 */
2615{
2616 uint32_t membl : 2; /* Memory Burst Length */
2617 uint32_t useeccasdata : 1; /* Use ECC Bits As Data */
2618 uint32_t applycfg : 1; /* Apply Configuration Changes */
2619 uint32_t : 28; /* *UNDEFINED* */
2620};
2621
2622/* The typedef declaration for register ALT_SDR_CTL_STATICCFG. */
2623typedef volatile struct ALT_SDR_CTL_STATICCFG_s ALT_SDR_CTL_STATICCFG_t;
2624#endif /* __ASSEMBLY__ */
2625
2626/* The byte offset of the ALT_SDR_CTL_STATICCFG register from the beginning of the component. */
2627#define ALT_SDR_CTL_STATICCFG_OFST 0x5c
2628
2629/*
2630 * Register : Memory Controller Width Register - ctrlwidth
2631 *
2632 * This register controls the width of the physical DRAM interface.
2633 *
2634 * Register Layout
2635 *
2636 * Bits | Access | Reset | Description
2637 * :-------|:-------|:--------|:---------------------------
2638 * [1:0] | RW | Unknown | Controller Interface Width
2639 * [31:2] | ??? | 0x0 | *UNDEFINED*
2640 *
2641 */
2642/*
2643 * Field : Controller Interface Width - ctrlwidth
2644 *
2645 * Specifies controller DRAM interface width, with the following encoding.
2646 * &quot;00&quot; for 8-bit, &quot;01&quot; for 16-bit (no ECC) or 24-bit (ECC
2647 * enabled), &quot;10&quot; for 32-bit (no ECC) or 40-bit (ECC enabled). You must
2648 * also program the dramifwidth register.
2649 *
2650 * Field Access Macros:
2651 *
2652 */
2653/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field. */
2654#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_LSB 0
2655/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field. */
2656#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_MSB 1
2657/* The width in bits of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field. */
2658#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_WIDTH 2
2659/* The mask used to set the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field value. */
2660#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_SET_MSK 0x00000003
2661/* The mask used to clear the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field value. */
2662#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_CLR_MSK 0xfffffffc
2663/* The reset value of the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field is UNKNOWN. */
2664#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_RESET 0x0
2665/* Extracts the ALT_SDR_CTL_CTLWIDTH_CTLWIDTH field value from a register. */
2666#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_GET(value) (((value) & 0x00000003) >> 0)
2667/* Produces a ALT_SDR_CTL_CTLWIDTH_CTLWIDTH register field value suitable for setting the register. */
2668#define ALT_SDR_CTL_CTLWIDTH_CTLWIDTH_SET(value) (((value) << 0) & 0x00000003)
2669
2670#ifndef __ASSEMBLY__
2671/*
2672 * WARNING: The C register and register group struct declarations are provided for
2673 * convenience and illustrative purposes. They should, however, be used with
2674 * caution as the C language standard provides no guarantees about the alignment or
2675 * atomicity of device memory accesses. The recommended practice for writing
2676 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2677 * alt_write_word() functions.
2678 *
2679 * The struct declaration for register ALT_SDR_CTL_CTLWIDTH.
2680 */
2682{
2683 uint32_t ctrlwidth : 2; /* Controller Interface Width */
2684 uint32_t : 30; /* *UNDEFINED* */
2685};
2686
2687/* The typedef declaration for register ALT_SDR_CTL_CTLWIDTH. */
2688typedef volatile struct ALT_SDR_CTL_CTLWIDTH_s ALT_SDR_CTL_CTLWIDTH_t;
2689#endif /* __ASSEMBLY__ */
2690
2691/* The byte offset of the ALT_SDR_CTL_CTLWIDTH register from the beginning of the component. */
2692#define ALT_SDR_CTL_CTLWIDTH_OFST 0x60
2693
2694/*
2695 * Register : Port Configuration Register - portcfg
2696 *
2697 * This register should be set to a zero in any bit which corresponds to a port
2698 * which does mostly sequential memory accesses. For ports with highly random
2699 * accesses, the bit should be set to a one.
2700 *
2701 * Register Layout
2702 *
2703 * Bits | Access | Reset | Description
2704 * :--------|:-------|:--------|:----------------------
2705 * [9:0] | ??? | Unknown | *UNDEFINED*
2706 * [19:10] | RW | Unknown | Auto-precharge Enable
2707 * [31:20] | ??? | 0x0 | *UNDEFINED*
2708 *
2709 */
2710/*
2711 * Field : Auto-precharge Enable - autopchen
2712 *
2713 * One bit per control port. Set bit N to a 1 to have the controller request an
2714 * automatic precharge following bus command completion (close the row
2715 * automatically). Set to a zero to request that the controller attempt to keep a
2716 * row open. For random dominated operations this register should be set to a 1
2717 * for all active ports.
2718 *
2719 * Field Access Macros:
2720 *
2721 */
2722/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field. */
2723#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_LSB 10
2724/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field. */
2725#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_MSB 19
2726/* The width in bits of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field. */
2727#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_WIDTH 10
2728/* The mask used to set the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field value. */
2729#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_SET_MSK 0x000ffc00
2730/* The mask used to clear the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field value. */
2731#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_CLR_MSK 0xfff003ff
2732/* The reset value of the ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field is UNKNOWN. */
2733#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_RESET 0x0
2734/* Extracts the ALT_SDR_CTL_PORTCFG_AUTOPCHEN field value from a register. */
2735#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_GET(value) (((value) & 0x000ffc00) >> 10)
2736/* Produces a ALT_SDR_CTL_PORTCFG_AUTOPCHEN register field value suitable for setting the register. */
2737#define ALT_SDR_CTL_PORTCFG_AUTOPCHEN_SET(value) (((value) << 10) & 0x000ffc00)
2738
2739#ifndef __ASSEMBLY__
2740/*
2741 * WARNING: The C register and register group struct declarations are provided for
2742 * convenience and illustrative purposes. They should, however, be used with
2743 * caution as the C language standard provides no guarantees about the alignment or
2744 * atomicity of device memory accesses. The recommended practice for writing
2745 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2746 * alt_write_word() functions.
2747 *
2748 * The struct declaration for register ALT_SDR_CTL_PORTCFG.
2749 */
2751{
2752 uint32_t : 10; /* *UNDEFINED* */
2753 uint32_t autopchen : 10; /* Auto-precharge Enable */
2754 uint32_t : 12; /* *UNDEFINED* */
2755};
2756
2757/* The typedef declaration for register ALT_SDR_CTL_PORTCFG. */
2758typedef volatile struct ALT_SDR_CTL_PORTCFG_s ALT_SDR_CTL_PORTCFG_t;
2759#endif /* __ASSEMBLY__ */
2760
2761/* The byte offset of the ALT_SDR_CTL_PORTCFG register from the beginning of the component. */
2762#define ALT_SDR_CTL_PORTCFG_OFST 0x7c
2763
2764/*
2765 * Register : FPGA Ports Reset Control Register - fpgaportrst
2766 *
2767 * This register implements functionality to allow the CPU to control when the MPFE
2768 * will enable the ports to the FPGA fabric.
2769 *
2770 * Register Layout
2771 *
2772 * Bits | Access | Reset | Description
2773 * :--------|:-------|:--------|:-------------------
2774 * [13:0] | RW | Unknown | Port Reset Control
2775 * [31:14] | ??? | 0x0 | *UNDEFINED*
2776 *
2777 */
2778/*
2779 * Field : Port Reset Control - portrstn
2780 *
2781 * This register should be written to with a 1 to enable the selected FPGA port to
2782 * exit reset. Writing a bit to a zero will stretch the port reset until the
2783 * register is written. Read data ports are connected to bits 3:0, with read data
2784 * port 0 at bit 0 to read data port 3 at bit 3. Write data ports 0 to 3 are mapped
2785 * to 4 to 7, with write data port 0 connected to bit 4 to write data port 3 at bit
2786 * 7. Command ports are connected to bits 8 to 13, with command port 0 at bit 8 to
2787 * command port 5 at bit 13. Expected usage would be to set all the bits at the
2788 * same time but setting some bits to a zero and others to a one is supported.
2789 *
2790 * Field Access Macros:
2791 *
2792 */
2793/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field. */
2794#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_LSB 0
2795/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field. */
2796#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_MSB 13
2797/* The width in bits of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field. */
2798#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_WIDTH 14
2799/* The mask used to set the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field value. */
2800#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_SET_MSK 0x00003fff
2801/* The mask used to clear the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field value. */
2802#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_CLR_MSK 0xffffc000
2803/* The reset value of the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field is UNKNOWN. */
2804#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_RESET 0x0
2805/* Extracts the ALT_SDR_CTL_FPGAPORTRST_PORTRSTN field value from a register. */
2806#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_GET(value) (((value) & 0x00003fff) >> 0)
2807/* Produces a ALT_SDR_CTL_FPGAPORTRST_PORTRSTN register field value suitable for setting the register. */
2808#define ALT_SDR_CTL_FPGAPORTRST_PORTRSTN_SET(value) (((value) << 0) & 0x00003fff)
2809
2810#ifndef __ASSEMBLY__
2811/*
2812 * WARNING: The C register and register group struct declarations are provided for
2813 * convenience and illustrative purposes. They should, however, be used with
2814 * caution as the C language standard provides no guarantees about the alignment or
2815 * atomicity of device memory accesses. The recommended practice for writing
2816 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2817 * alt_write_word() functions.
2818 *
2819 * The struct declaration for register ALT_SDR_CTL_FPGAPORTRST.
2820 */
2822{
2823 uint32_t portrstn : 14; /* Port Reset Control */
2824 uint32_t : 18; /* *UNDEFINED* */
2825};
2826
2827/* The typedef declaration for register ALT_SDR_CTL_FPGAPORTRST. */
2829#endif /* __ASSEMBLY__ */
2830
2831/* The byte offset of the ALT_SDR_CTL_FPGAPORTRST register from the beginning of the component. */
2832#define ALT_SDR_CTL_FPGAPORTRST_OFST 0x80
2833
2834/*
2835 * Register : Memory Protection Port Default Register - protportdefault
2836 *
2837 * This register controls the default protection assignment for a port. Ports
2838 * which have explicit rules which define regions which are illegal to access
2839 * should set the bits to pass by default. Ports which have explicit rules which
2840 * define legal areas should set the bit to force all transactions to fail.
2841 * Leaving this register to all zeros should be used for systems which do not
2842 * desire any protection from the memory controller.
2843 *
2844 * Register Layout
2845 *
2846 * Bits | Access | Reset | Description
2847 * :--------|:-------|:--------|:--------------------
2848 * [9:0] | RW | Unknown | Port Default Action
2849 * [31:10] | ??? | 0x0 | *UNDEFINED*
2850 *
2851 */
2852/*
2853 * Field : Port Default Action - portdefault
2854 *
2855 * Determines the default action for a transactions from a port. Set a bit to a
2856 * zero to indicate that all accesses from the port should pass by default, set a
2857 * bit to a one if the default protection is to fail the access.
2858 *
2859 * Field Access Macros:
2860 *
2861 */
2862/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field. */
2863#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_LSB 0
2864/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field. */
2865#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_MSB 9
2866/* The width in bits of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field. */
2867#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_WIDTH 10
2868/* The mask used to set the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field value. */
2869#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_SET_MSK 0x000003ff
2870/* The mask used to clear the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field value. */
2871#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_CLR_MSK 0xfffffc00
2872/* The reset value of the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field is UNKNOWN. */
2873#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_RESET 0x0
2874/* Extracts the ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT field value from a register. */
2875#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_GET(value) (((value) & 0x000003ff) >> 0)
2876/* Produces a ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT register field value suitable for setting the register. */
2877#define ALT_SDR_CTL_PROTPORTDEFAULT_PORTDEFAULT_SET(value) (((value) << 0) & 0x000003ff)
2878
2879#ifndef __ASSEMBLY__
2880/*
2881 * WARNING: The C register and register group struct declarations are provided for
2882 * convenience and illustrative purposes. They should, however, be used with
2883 * caution as the C language standard provides no guarantees about the alignment or
2884 * atomicity of device memory accesses. The recommended practice for writing
2885 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2886 * alt_write_word() functions.
2887 *
2888 * The struct declaration for register ALT_SDR_CTL_PROTPORTDEFAULT.
2889 */
2891{
2892 uint32_t portdefault : 10; /* Port Default Action */
2893 uint32_t : 22; /* *UNDEFINED* */
2894};
2895
2896/* The typedef declaration for register ALT_SDR_CTL_PROTPORTDEFAULT. */
2898#endif /* __ASSEMBLY__ */
2899
2900/* The byte offset of the ALT_SDR_CTL_PROTPORTDEFAULT register from the beginning of the component. */
2901#define ALT_SDR_CTL_PROTPORTDEFAULT_OFST 0x8c
2902
2903/*
2904 * Register : Memory Protection Address Register - protruleaddr
2905 *
2906 * This register is used to control the memory protection for port 0 transactions.
2907 * Address ranges can either be used to allow access to memory regions or disallow
2908 * access to memory regions. If trustzone is being used, access can be enabled for
2909 * protected transactions or disabled for unprotected transactions. The default
2910 * state of this register is to allow all access. Address values used for
2911 * protection are only physical addresses.
2912 *
2913 * Register Layout
2914 *
2915 * Bits | Access | Reset | Description
2916 * :--------|:-------|:--------|:-------------
2917 * [11:0] | RW | Unknown | Low Address
2918 * [23:12] | RW | Unknown | High Address
2919 * [31:24] | ??? | 0x0 | *UNDEFINED*
2920 *
2921 */
2922/*
2923 * Field : Low Address - lowaddr
2924 *
2925 * Lower 12 bits of the address for a check. Address is compared to be less than
2926 * or equal to the address of a transaction. Note that since AXI transactions
2927 * cannot cross a 4K byte boundary, the transaction start and transaction end
2928 * address must also fall within the same 1MByte block pointed to by this address
2929 * pointer.
2930 *
2931 * Field Access Macros:
2932 *
2933 */
2934/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field. */
2935#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_LSB 0
2936/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field. */
2937#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_MSB 11
2938/* The width in bits of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field. */
2939#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_WIDTH 12
2940/* The mask used to set the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field value. */
2941#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_SET_MSK 0x00000fff
2942/* The mask used to clear the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field value. */
2943#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_CLR_MSK 0xfffff000
2944/* The reset value of the ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field is UNKNOWN. */
2945#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_RESET 0x0
2946/* Extracts the ALT_SDR_CTL_PROTRULEADDR_LOWADDR field value from a register. */
2947#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_GET(value) (((value) & 0x00000fff) >> 0)
2948/* Produces a ALT_SDR_CTL_PROTRULEADDR_LOWADDR register field value suitable for setting the register. */
2949#define ALT_SDR_CTL_PROTRULEADDR_LOWADDR_SET(value) (((value) << 0) & 0x00000fff)
2950
2951/*
2952 * Field : High Address - highaddr
2953 *
2954 * Upper 12 bits of the address for a check. Address is compared to be greater
2955 * than or equal to the address of a transaction. Note that since AXI transactions
2956 * cannot cross a 4K byte boundary, the transaction start and transaction end
2957 * address must also fall within the same 1MByte block pointed to by this address
2958 * pointer.
2959 *
2960 * Field Access Macros:
2961 *
2962 */
2963/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field. */
2964#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_LSB 12
2965/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field. */
2966#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_MSB 23
2967/* The width in bits of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field. */
2968#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_WIDTH 12
2969/* The mask used to set the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field value. */
2970#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_SET_MSK 0x00fff000
2971/* The mask used to clear the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field value. */
2972#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_CLR_MSK 0xff000fff
2973/* The reset value of the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field is UNKNOWN. */
2974#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_RESET 0x0
2975/* Extracts the ALT_SDR_CTL_PROTRULEADDR_HIGHADDR field value from a register. */
2976#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_GET(value) (((value) & 0x00fff000) >> 12)
2977/* Produces a ALT_SDR_CTL_PROTRULEADDR_HIGHADDR register field value suitable for setting the register. */
2978#define ALT_SDR_CTL_PROTRULEADDR_HIGHADDR_SET(value) (((value) << 12) & 0x00fff000)
2979
2980#ifndef __ASSEMBLY__
2981/*
2982 * WARNING: The C register and register group struct declarations are provided for
2983 * convenience and illustrative purposes. They should, however, be used with
2984 * caution as the C language standard provides no guarantees about the alignment or
2985 * atomicity of device memory accesses. The recommended practice for writing
2986 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2987 * alt_write_word() functions.
2988 *
2989 * The struct declaration for register ALT_SDR_CTL_PROTRULEADDR.
2990 */
2992{
2993 uint32_t lowaddr : 12; /* Low Address */
2994 uint32_t highaddr : 12; /* High Address */
2995 uint32_t : 8; /* *UNDEFINED* */
2996};
2997
2998/* The typedef declaration for register ALT_SDR_CTL_PROTRULEADDR. */
3000#endif /* __ASSEMBLY__ */
3001
3002/* The byte offset of the ALT_SDR_CTL_PROTRULEADDR register from the beginning of the component. */
3003#define ALT_SDR_CTL_PROTRULEADDR_OFST 0x90
3004
3005/*
3006 * Register : Memory Protection ID Register - protruleid
3007 *
3008 *
3009 * Register Layout
3010 *
3011 * Bits | Access | Reset | Description
3012 * :--------|:-------|:--------|:------------
3013 * [11:0] | RW | Unknown | Low ID
3014 * [23:12] | RW | Unknown | High ID
3015 * [31:24] | ??? | 0x0 | *UNDEFINED*
3016 *
3017 */
3018/*
3019 * Field : Low ID - lowid
3020 *
3021 * AxID for the protection rule. Incoming AxID needs to be greater than or equal
3022 * to this value. For all AxIDs from a port, AxID high should be programmed to all
3023 * ones.
3024 *
3025 * Field Access Macros:
3026 *
3027 */
3028/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEID_LOWID register field. */
3029#define ALT_SDR_CTL_PROTRULEID_LOWID_LSB 0
3030/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEID_LOWID register field. */
3031#define ALT_SDR_CTL_PROTRULEID_LOWID_MSB 11
3032/* The width in bits of the ALT_SDR_CTL_PROTRULEID_LOWID register field. */
3033#define ALT_SDR_CTL_PROTRULEID_LOWID_WIDTH 12
3034/* The mask used to set the ALT_SDR_CTL_PROTRULEID_LOWID register field value. */
3035#define ALT_SDR_CTL_PROTRULEID_LOWID_SET_MSK 0x00000fff
3036/* The mask used to clear the ALT_SDR_CTL_PROTRULEID_LOWID register field value. */
3037#define ALT_SDR_CTL_PROTRULEID_LOWID_CLR_MSK 0xfffff000
3038/* The reset value of the ALT_SDR_CTL_PROTRULEID_LOWID register field is UNKNOWN. */
3039#define ALT_SDR_CTL_PROTRULEID_LOWID_RESET 0x0
3040/* Extracts the ALT_SDR_CTL_PROTRULEID_LOWID field value from a register. */
3041#define ALT_SDR_CTL_PROTRULEID_LOWID_GET(value) (((value) & 0x00000fff) >> 0)
3042/* Produces a ALT_SDR_CTL_PROTRULEID_LOWID register field value suitable for setting the register. */
3043#define ALT_SDR_CTL_PROTRULEID_LOWID_SET(value) (((value) << 0) & 0x00000fff)
3044
3045/*
3046 * Field : High ID - highid
3047 *
3048 * AxID for the protection rule. Incoming AxID needs to be less than or equal to
3049 * this value. For all AxIDs from a port, AxID high should be programmed to all
3050 * ones.
3051 *
3052 * Field Access Macros:
3053 *
3054 */
3055/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEID_HIGHID register field. */
3056#define ALT_SDR_CTL_PROTRULEID_HIGHID_LSB 12
3057/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEID_HIGHID register field. */
3058#define ALT_SDR_CTL_PROTRULEID_HIGHID_MSB 23
3059/* The width in bits of the ALT_SDR_CTL_PROTRULEID_HIGHID register field. */
3060#define ALT_SDR_CTL_PROTRULEID_HIGHID_WIDTH 12
3061/* The mask used to set the ALT_SDR_CTL_PROTRULEID_HIGHID register field value. */
3062#define ALT_SDR_CTL_PROTRULEID_HIGHID_SET_MSK 0x00fff000
3063/* The mask used to clear the ALT_SDR_CTL_PROTRULEID_HIGHID register field value. */
3064#define ALT_SDR_CTL_PROTRULEID_HIGHID_CLR_MSK 0xff000fff
3065/* The reset value of the ALT_SDR_CTL_PROTRULEID_HIGHID register field is UNKNOWN. */
3066#define ALT_SDR_CTL_PROTRULEID_HIGHID_RESET 0x0
3067/* Extracts the ALT_SDR_CTL_PROTRULEID_HIGHID field value from a register. */
3068#define ALT_SDR_CTL_PROTRULEID_HIGHID_GET(value) (((value) & 0x00fff000) >> 12)
3069/* Produces a ALT_SDR_CTL_PROTRULEID_HIGHID register field value suitable for setting the register. */
3070#define ALT_SDR_CTL_PROTRULEID_HIGHID_SET(value) (((value) << 12) & 0x00fff000)
3071
3072#ifndef __ASSEMBLY__
3073/*
3074 * WARNING: The C register and register group struct declarations are provided for
3075 * convenience and illustrative purposes. They should, however, be used with
3076 * caution as the C language standard provides no guarantees about the alignment or
3077 * atomicity of device memory accesses. The recommended practice for writing
3078 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3079 * alt_write_word() functions.
3080 *
3081 * The struct declaration for register ALT_SDR_CTL_PROTRULEID.
3082 */
3084{
3085 uint32_t lowid : 12; /* Low ID */
3086 uint32_t highid : 12; /* High ID */
3087 uint32_t : 8; /* *UNDEFINED* */
3088};
3089
3090/* The typedef declaration for register ALT_SDR_CTL_PROTRULEID. */
3092#endif /* __ASSEMBLY__ */
3093
3094/* The byte offset of the ALT_SDR_CTL_PROTRULEID register from the beginning of the component. */
3095#define ALT_SDR_CTL_PROTRULEID_OFST 0x94
3096
3097/*
3098 * Register : Memory Protection Rule Data Register - protruledata
3099 *
3100 *
3101 * Register Layout
3102 *
3103 * Bits | Access | Reset | Description
3104 * :--------|:-------|:--------|:----------------------
3105 * [1:0] | RW | Unknown | Security Bit Behavior
3106 * [2] | RW | Unknown | Valid Rule
3107 * [12:3] | RW | Unknown | Port Mask
3108 * [13] | RW | Unknown | Rule Results
3109 * [31:14] | ??? | 0x0 | *UNDEFINED*
3110 *
3111 */
3112/*
3113 * Field : Security Bit Behavior - security
3114 *
3115 * A value of 2'b00 will make the rule apply to secure transactions.
3116 *
3117 * A value of 2'b01 will make the rule apply to non-secure transactions.
3118 *
3119 * A value of 2'b10 or 2'b11 will make the rule apply to secure and non-secure
3120 * transactions.
3121 *
3122 * Field Access Macros:
3123 *
3124 */
3125/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field. */
3126#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_LSB 0
3127/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field. */
3128#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_MSB 1
3129/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field. */
3130#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_WIDTH 2
3131/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field value. */
3132#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_SET_MSK 0x00000003
3133/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field value. */
3134#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_CLR_MSK 0xfffffffc
3135/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_SECURITY register field is UNKNOWN. */
3136#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_RESET 0x0
3137/* Extracts the ALT_SDR_CTL_PROTRULEDATA_SECURITY field value from a register. */
3138#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_GET(value) (((value) & 0x00000003) >> 0)
3139/* Produces a ALT_SDR_CTL_PROTRULEDATA_SECURITY register field value suitable for setting the register. */
3140#define ALT_SDR_CTL_PROTRULEDATA_SECURITY_SET(value) (((value) << 0) & 0x00000003)
3141
3142/*
3143 * Field : Valid Rule - validrule
3144 *
3145 * Set to bit to a one to make a rule valid, set to a zero to invalidate a rule.
3146 *
3147 * Field Access Macros:
3148 *
3149 */
3150/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field. */
3151#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_LSB 2
3152/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field. */
3153#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_MSB 2
3154/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field. */
3155#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_WIDTH 1
3156/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field value. */
3157#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_SET_MSK 0x00000004
3158/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field value. */
3159#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_CLR_MSK 0xfffffffb
3160/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field is UNKNOWN. */
3161#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_RESET 0x0
3162/* Extracts the ALT_SDR_CTL_PROTRULEDATA_VALIDRULE field value from a register. */
3163#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_GET(value) (((value) & 0x00000004) >> 2)
3164/* Produces a ALT_SDR_CTL_PROTRULEDATA_VALIDRULE register field value suitable for setting the register. */
3165#define ALT_SDR_CTL_PROTRULEDATA_VALIDRULE_SET(value) (((value) << 2) & 0x00000004)
3166
3167/*
3168 * Field : Port Mask - portmask
3169 *
3170 * Set bit x to a one to have this rule apply to port x, set bit x to a zero to
3171 * have the rule not apply to a port.&#10;Note that port 0-port 5 are the FPGA
3172 * fabric ports, port 6 is L3 read, port 7 is CPU read, port 8 is L3 write, port 9
3173 * is CPU write.
3174 *
3175 * Field Access Macros:
3176 *
3177 */
3178/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field. */
3179#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_LSB 3
3180/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field. */
3181#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_MSB 12
3182/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field. */
3183#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_WIDTH 10
3184/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field value. */
3185#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_SET_MSK 0x00001ff8
3186/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field value. */
3187#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_CLR_MSK 0xffffe007
3188/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field is UNKNOWN. */
3189#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_RESET 0x0
3190/* Extracts the ALT_SDR_CTL_PROTRULEDATA_PORTMSK field value from a register. */
3191#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_GET(value) (((value) & 0x00001ff8) >> 3)
3192/* Produces a ALT_SDR_CTL_PROTRULEDATA_PORTMSK register field value suitable for setting the register. */
3193#define ALT_SDR_CTL_PROTRULEDATA_PORTMSK_SET(value) (((value) << 3) & 0x00001ff8)
3194
3195/*
3196 * Field : Rule Results - ruleresult
3197 *
3198 * Set this bit to a one to force a protection failure, zero to allow the access
3199 * the succeed
3200 *
3201 * Field Access Macros:
3202 *
3203 */
3204/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field. */
3205#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_LSB 13
3206/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field. */
3207#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_MSB 13
3208/* The width in bits of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field. */
3209#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_WIDTH 1
3210/* The mask used to set the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field value. */
3211#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_SET_MSK 0x00002000
3212/* The mask used to clear the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field value. */
3213#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_CLR_MSK 0xffffdfff
3214/* The reset value of the ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field is UNKNOWN. */
3215#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_RESET 0x0
3216/* Extracts the ALT_SDR_CTL_PROTRULEDATA_RULERESULT field value from a register. */
3217#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_GET(value) (((value) & 0x00002000) >> 13)
3218/* Produces a ALT_SDR_CTL_PROTRULEDATA_RULERESULT register field value suitable for setting the register. */
3219#define ALT_SDR_CTL_PROTRULEDATA_RULERESULT_SET(value) (((value) << 13) & 0x00002000)
3220
3221#ifndef __ASSEMBLY__
3222/*
3223 * WARNING: The C register and register group struct declarations are provided for
3224 * convenience and illustrative purposes. They should, however, be used with
3225 * caution as the C language standard provides no guarantees about the alignment or
3226 * atomicity of device memory accesses. The recommended practice for writing
3227 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3228 * alt_write_word() functions.
3229 *
3230 * The struct declaration for register ALT_SDR_CTL_PROTRULEDATA.
3231 */
3233{
3234 uint32_t security : 2; /* Security Bit Behavior */
3235 uint32_t validrule : 1; /* Valid Rule */
3236 uint32_t portmask : 10; /* Port Mask */
3237 uint32_t ruleresult : 1; /* Rule Results */
3238 uint32_t : 18; /* *UNDEFINED* */
3239};
3240
3241/* The typedef declaration for register ALT_SDR_CTL_PROTRULEDATA. */
3243#endif /* __ASSEMBLY__ */
3244
3245/* The byte offset of the ALT_SDR_CTL_PROTRULEDATA register from the beginning of the component. */
3246#define ALT_SDR_CTL_PROTRULEDATA_OFST 0x98
3247
3248/*
3249 * Register : Memory Protection Rule Read-Write Register - protrulerdwr
3250 *
3251 * This register is used to perform read and write operations to the internal
3252 * protection table.
3253 *
3254 * Register Layout
3255 *
3256 * Bits | Access | Reset | Description
3257 * :-------|:-------|:--------|:------------
3258 * [4:0] | RW | Unknown | Rule Offset
3259 * [5] | RW | Unknown | Rule Write
3260 * [6] | RW | Unknown | Rule Read
3261 * [31:7] | ??? | 0x0 | *UNDEFINED*
3262 *
3263 */
3264/*
3265 * Field : Rule Offset - ruleoffset
3266 *
3267 * This field defines which of the 20 rules in the protection table you want to
3268 * read or write.
3269 *
3270 * Field Access Macros:
3271 *
3272 */
3273/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field. */
3274#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_LSB 0
3275/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field. */
3276#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_MSB 4
3277/* The width in bits of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field. */
3278#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_WIDTH 5
3279/* The mask used to set the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field value. */
3280#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_SET_MSK 0x0000001f
3281/* The mask used to clear the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field value. */
3282#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_CLR_MSK 0xffffffe0
3283/* The reset value of the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field is UNKNOWN. */
3284#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_RESET 0x0
3285/* Extracts the ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET field value from a register. */
3286#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_GET(value) (((value) & 0x0000001f) >> 0)
3287/* Produces a ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET register field value suitable for setting the register. */
3288#define ALT_SDR_CTL_PROTRULERDWR_RULEOFFSET_SET(value) (((value) << 0) & 0x0000001f)
3289
3290/*
3291 * Field : Rule Write - writerule
3292 *
3293 * Write to this bit to have the memory_prot_data register to the table at the
3294 * offset specified by port_offset. Bit automatically clears after a single cycle
3295 * and the write operation is complete.
3296 *
3297 * Field Access Macros:
3298 *
3299 */
3300/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field. */
3301#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_LSB 5
3302/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field. */
3303#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_MSB 5
3304/* The width in bits of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field. */
3305#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_WIDTH 1
3306/* The mask used to set the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field value. */
3307#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_SET_MSK 0x00000020
3308/* The mask used to clear the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field value. */
3309#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_CLR_MSK 0xffffffdf
3310/* The reset value of the ALT_SDR_CTL_PROTRULERDWR_WRRULE register field is UNKNOWN. */
3311#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_RESET 0x0
3312/* Extracts the ALT_SDR_CTL_PROTRULERDWR_WRRULE field value from a register. */
3313#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_GET(value) (((value) & 0x00000020) >> 5)
3314/* Produces a ALT_SDR_CTL_PROTRULERDWR_WRRULE register field value suitable for setting the register. */
3315#define ALT_SDR_CTL_PROTRULERDWR_WRRULE_SET(value) (((value) << 5) & 0x00000020)
3316
3317/*
3318 * Field : Rule Read - readrule
3319 *
3320 * Write to this bit to have the memory_prot_data register loaded with the value
3321 * from the internal protection table at offset. Table value will be loaded before
3322 * a rdy is returned so read data from the register will be correct for any follow-
3323 * on reads to the memory_prot_data register.
3324 *
3325 * Field Access Macros:
3326 *
3327 */
3328/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field. */
3329#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_LSB 6
3330/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field. */
3331#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_MSB 6
3332/* The width in bits of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field. */
3333#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_WIDTH 1
3334/* The mask used to set the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field value. */
3335#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_SET_MSK 0x00000040
3336/* The mask used to clear the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field value. */
3337#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_CLR_MSK 0xffffffbf
3338/* The reset value of the ALT_SDR_CTL_PROTRULERDWR_RDRULE register field is UNKNOWN. */
3339#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_RESET 0x0
3340/* Extracts the ALT_SDR_CTL_PROTRULERDWR_RDRULE field value from a register. */
3341#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_GET(value) (((value) & 0x00000040) >> 6)
3342/* Produces a ALT_SDR_CTL_PROTRULERDWR_RDRULE register field value suitable for setting the register. */
3343#define ALT_SDR_CTL_PROTRULERDWR_RDRULE_SET(value) (((value) << 6) & 0x00000040)
3344
3345#ifndef __ASSEMBLY__
3346/*
3347 * WARNING: The C register and register group struct declarations are provided for
3348 * convenience and illustrative purposes. They should, however, be used with
3349 * caution as the C language standard provides no guarantees about the alignment or
3350 * atomicity of device memory accesses. The recommended practice for writing
3351 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3352 * alt_write_word() functions.
3353 *
3354 * The struct declaration for register ALT_SDR_CTL_PROTRULERDWR.
3355 */
3357{
3358 uint32_t ruleoffset : 5; /* Rule Offset */
3359 uint32_t writerule : 1; /* Rule Write */
3360 uint32_t readrule : 1; /* Rule Read */
3361 uint32_t : 25; /* *UNDEFINED* */
3362};
3363
3364/* The typedef declaration for register ALT_SDR_CTL_PROTRULERDWR. */
3366#endif /* __ASSEMBLY__ */
3367
3368/* The byte offset of the ALT_SDR_CTL_PROTRULERDWR register from the beginning of the component. */
3369#define ALT_SDR_CTL_PROTRULERDWR_OFST 0x9c
3370
3371/*
3372 * Register : QOS Control Register - qoslowpri
3373 *
3374 * This register controls the mapping of AXI4 QOS received from the FPGA fabric to
3375 * the internal priority used for traffic prioritization.
3376 *
3377 * Register Layout
3378 *
3379 * Bits | Access | Reset | Description
3380 * :--------|:-------|:--------|:-----------------------
3381 * [19:0] | RW | Unknown | Low Priority QoS Value
3382 * [31:20] | ??? | 0x0 | *UNDEFINED*
3383 *
3384 */
3385/*
3386 * Field : Low Priority QoS Value - lowpriorityval
3387 *
3388 * This 20 bit field is a 2 bit field for each of the 10 ports. The field used for
3389 * each port in this register controls the priority used for a port
3390 *
3391 * Field Access Macros:
3392 *
3393 */
3394/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field. */
3395#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_LSB 0
3396/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field. */
3397#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_MSB 19
3398/* The width in bits of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field. */
3399#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_WIDTH 20
3400/* The mask used to set the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field value. */
3401#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_SET_MSK 0x000fffff
3402/* The mask used to clear the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field value. */
3403#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_CLR_MSK 0xfff00000
3404/* The reset value of the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field is UNKNOWN. */
3405#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_RESET 0x0
3406/* Extracts the ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL field value from a register. */
3407#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_GET(value) (((value) & 0x000fffff) >> 0)
3408/* Produces a ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL register field value suitable for setting the register. */
3409#define ALT_SDR_CTL_QOSLOWPRI_LOWPRIORITYVAL_SET(value) (((value) << 0) & 0x000fffff)
3410
3411#ifndef __ASSEMBLY__
3412/*
3413 * WARNING: The C register and register group struct declarations are provided for
3414 * convenience and illustrative purposes. They should, however, be used with
3415 * caution as the C language standard provides no guarantees about the alignment or
3416 * atomicity of device memory accesses. The recommended practice for writing
3417 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3418 * alt_write_word() functions.
3419 *
3420 * The struct declaration for register ALT_SDR_CTL_QOSLOWPRI.
3421 */
3423{
3424 uint32_t lowpriorityval : 20; /* Low Priority QoS Value */
3425 uint32_t : 12; /* *UNDEFINED* */
3426};
3427
3428/* The typedef declaration for register ALT_SDR_CTL_QOSLOWPRI. */
3429typedef volatile struct ALT_SDR_CTL_QOSLOWPRI_s ALT_SDR_CTL_QOSLOWPRI_t;
3430#endif /* __ASSEMBLY__ */
3431
3432/* The byte offset of the ALT_SDR_CTL_QOSLOWPRI register from the beginning of the component. */
3433#define ALT_SDR_CTL_QOSLOWPRI_OFST 0xa0
3434
3435/*
3436 * Register : qoshighpri Register - qoshighpri
3437 *
3438 *
3439 * Register Layout
3440 *
3441 * Bits | Access | Reset | Description
3442 * :--------|:-------|:--------|:------------------------
3443 * [19:0] | RW | Unknown | High Priority QoS Value
3444 * [31:20] | ??? | 0x0 | *UNDEFINED*
3445 *
3446 */
3447/*
3448 * Field : High Priority QoS Value - highpriorityval
3449 *
3450 * This 20 bit field is a 2 bit field for each of the 10 ports. The field used for
3451 * each port in this register controls the priority used for a port
3452 *
3453 * Field Access Macros:
3454 *
3455 */
3456/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field. */
3457#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_LSB 0
3458/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field. */
3459#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_MSB 19
3460/* The width in bits of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field. */
3461#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_WIDTH 20
3462/* The mask used to set the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field value. */
3463#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_SET_MSK 0x000fffff
3464/* The mask used to clear the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field value. */
3465#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_CLR_MSK 0xfff00000
3466/* The reset value of the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field is UNKNOWN. */
3467#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_RESET 0x0
3468/* Extracts the ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL field value from a register. */
3469#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_GET(value) (((value) & 0x000fffff) >> 0)
3470/* Produces a ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL register field value suitable for setting the register. */
3471#define ALT_SDR_CTL_QOSHIGHPRI_HIGHPRIORITYVAL_SET(value) (((value) << 0) & 0x000fffff)
3472
3473#ifndef __ASSEMBLY__
3474/*
3475 * WARNING: The C register and register group struct declarations are provided for
3476 * convenience and illustrative purposes. They should, however, be used with
3477 * caution as the C language standard provides no guarantees about the alignment or
3478 * atomicity of device memory accesses. The recommended practice for writing
3479 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3480 * alt_write_word() functions.
3481 *
3482 * The struct declaration for register ALT_SDR_CTL_QOSHIGHPRI.
3483 */
3485{
3486 uint32_t highpriorityval : 20; /* High Priority QoS Value */
3487 uint32_t : 12; /* *UNDEFINED* */
3488};
3489
3490/* The typedef declaration for register ALT_SDR_CTL_QOSHIGHPRI. */
3492#endif /* __ASSEMBLY__ */
3493
3494/* The byte offset of the ALT_SDR_CTL_QOSHIGHPRI register from the beginning of the component. */
3495#define ALT_SDR_CTL_QOSHIGHPRI_OFST 0xa4
3496
3497/*
3498 * Register : qospriorityen Register - qospriorityen
3499 *
3500 *
3501 * Register Layout
3502 *
3503 * Bits | Access | Reset | Description
3504 * :--------|:-------|:--------|:--------------------
3505 * [9:0] | RW | Unknown | Per-Port QoS Enable
3506 * [31:10] | ??? | 0x0 | *UNDEFINED*
3507 *
3508 */
3509/*
3510 * Field : Per-Port QoS Enable - priorityen
3511 *
3512 * This 10 bit field is set to a one to enable QOS usage for a port.
3513 *
3514 * Field Access Macros:
3515 *
3516 */
3517/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field. */
3518#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_LSB 0
3519/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field. */
3520#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_MSB 9
3521/* The width in bits of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field. */
3522#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_WIDTH 10
3523/* The mask used to set the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field value. */
3524#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_SET_MSK 0x000003ff
3525/* The mask used to clear the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field value. */
3526#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_CLR_MSK 0xfffffc00
3527/* The reset value of the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field is UNKNOWN. */
3528#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_RESET 0x0
3529/* Extracts the ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN field value from a register. */
3530#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_GET(value) (((value) & 0x000003ff) >> 0)
3531/* Produces a ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN register field value suitable for setting the register. */
3532#define ALT_SDR_CTL_QOSPRIORITYEN_PRIORITYEN_SET(value) (((value) << 0) & 0x000003ff)
3533
3534#ifndef __ASSEMBLY__
3535/*
3536 * WARNING: The C register and register group struct declarations are provided for
3537 * convenience and illustrative purposes. They should, however, be used with
3538 * caution as the C language standard provides no guarantees about the alignment or
3539 * atomicity of device memory accesses. The recommended practice for writing
3540 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3541 * alt_write_word() functions.
3542 *
3543 * The struct declaration for register ALT_SDR_CTL_QOSPRIORITYEN.
3544 */
3546{
3547 uint32_t priorityen : 10; /* Per-Port QoS Enable */
3548 uint32_t : 22; /* *UNDEFINED* */
3549};
3550
3551/* The typedef declaration for register ALT_SDR_CTL_QOSPRIORITYEN. */
3553#endif /* __ASSEMBLY__ */
3554
3555/* The byte offset of the ALT_SDR_CTL_QOSPRIORITYEN register from the beginning of the component. */
3556#define ALT_SDR_CTL_QOSPRIORITYEN_OFST 0xa8
3557
3558/*
3559 * Register : Scheduler priority Register - mppriority
3560 *
3561 * This register is used to configure the DRAM burst operation scheduling.
3562 *
3563 * Register Layout
3564 *
3565 * Bits | Access | Reset | Description
3566 * :--------|:-------|:--------|:---------------------
3567 * [29:0] | RW | Unknown | Port User Priorities
3568 * [31:30] | ??? | 0x0 | *UNDEFINED*
3569 *
3570 */
3571/*
3572 * Field : Port User Priorities - userpriority
3573 *
3574 * Set absolute user priority of the port. Each port is represented by a 3 bit
3575 * value, 000=lowest priority, 111=highest priority. Port 0 is bits 2:0. Port
3576 * number offset corresponds to the control port assignment.
3577 *
3578 * Field Access Macros:
3579 *
3580 */
3581/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field. */
3582#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_LSB 0
3583/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field. */
3584#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_MSB 29
3585/* The width in bits of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field. */
3586#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_WIDTH 30
3587/* The mask used to set the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field value. */
3588#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_SET_MSK 0x3fffffff
3589/* The mask used to clear the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field value. */
3590#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_CLR_MSK 0xc0000000
3591/* The reset value of the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field is UNKNOWN. */
3592#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_RESET 0x0
3593/* Extracts the ALT_SDR_CTL_MPPRIORITY_USERPRIORITY field value from a register. */
3594#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_GET(value) (((value) & 0x3fffffff) >> 0)
3595/* Produces a ALT_SDR_CTL_MPPRIORITY_USERPRIORITY register field value suitable for setting the register. */
3596#define ALT_SDR_CTL_MPPRIORITY_USERPRIORITY_SET(value) (((value) << 0) & 0x3fffffff)
3597
3598#ifndef __ASSEMBLY__
3599/*
3600 * WARNING: The C register and register group struct declarations are provided for
3601 * convenience and illustrative purposes. They should, however, be used with
3602 * caution as the C language standard provides no guarantees about the alignment or
3603 * atomicity of device memory accesses. The recommended practice for writing
3604 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3605 * alt_write_word() functions.
3606 *
3607 * The struct declaration for register ALT_SDR_CTL_MPPRIORITY.
3608 */
3610{
3611 uint32_t userpriority : 30; /* Port User Priorities */
3612 uint32_t : 2; /* *UNDEFINED* */
3613};
3614
3615/* The typedef declaration for register ALT_SDR_CTL_MPPRIORITY. */
3617#endif /* __ASSEMBLY__ */
3618
3619/* The byte offset of the ALT_SDR_CTL_MPPRIORITY register from the beginning of the component. */
3620#define ALT_SDR_CTL_MPPRIORITY_OFST 0xac
3621
3622/*
3623 * Register : Controller Command Pool Priority Remap Register - remappriority
3624 *
3625 * This register controls the priority for transactions in the controller command
3626 * pool.
3627 *
3628 * Register Layout
3629 *
3630 * Bits | Access | Reset | Description
3631 * :-------|:-------|:--------|:---------------
3632 * [7:0] | RW | Unknown | Priority Remap
3633 * [31:8] | ??? | 0x0 | *UNDEFINED*
3634 *
3635 */
3636/*
3637 * Field : Priority Remap - priorityremap
3638 *
3639 * Set bit N of this register to the value to a one to enable the controller
3640 * command pool priority bit of a transaction from MPFE priority N
3641 *
3642 * Field Access Macros:
3643 *
3644 */
3645/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field. */
3646#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_LSB 0
3647/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field. */
3648#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_MSB 7
3649/* The width in bits of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field. */
3650#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_WIDTH 8
3651/* The mask used to set the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field value. */
3652#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_SET_MSK 0x000000ff
3653/* The mask used to clear the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field value. */
3654#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_CLR_MSK 0xffffff00
3655/* The reset value of the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field is UNKNOWN. */
3656#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_RESET 0x0
3657/* Extracts the ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP field value from a register. */
3658#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_GET(value) (((value) & 0x000000ff) >> 0)
3659/* Produces a ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP register field value suitable for setting the register. */
3660#define ALT_SDR_CTL_REMAPPRIORITY_PRIORITYREMAP_SET(value) (((value) << 0) & 0x000000ff)
3661
3662#ifndef __ASSEMBLY__
3663/*
3664 * WARNING: The C register and register group struct declarations are provided for
3665 * convenience and illustrative purposes. They should, however, be used with
3666 * caution as the C language standard provides no guarantees about the alignment or
3667 * atomicity of device memory accesses. The recommended practice for writing
3668 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3669 * alt_write_word() functions.
3670 *
3671 * The struct declaration for register ALT_SDR_CTL_REMAPPRIORITY.
3672 */
3674{
3675 uint32_t priorityremap : 8; /* Priority Remap */
3676 uint32_t : 24; /* *UNDEFINED* */
3677};
3678
3679/* The typedef declaration for register ALT_SDR_CTL_REMAPPRIORITY. */
3681#endif /* __ASSEMBLY__ */
3682
3683/* The byte offset of the ALT_SDR_CTL_REMAPPRIORITY register from the beginning of the component. */
3684#define ALT_SDR_CTL_REMAPPRIORITY_OFST 0xe0
3685
3686/*
3687 * Register Group : Port Sum of Weight Register - ALT_SDR_CTL_MPWT
3688 * Port Sum of Weight Register
3689 *
3690 * This register is used to configure the DRAM burst operation scheduling.
3691 *
3692 */
3693/*
3694 * Register : Port Sum of Weight Register[1/4] - mpweight_0_4
3695 *
3696 * This register is used to configure the DRAM burst operation scheduling.
3697 *
3698 * Register Layout
3699 *
3700 * Bits | Access | Reset | Description
3701 * :-------|:-------|:--------|:--------------------------
3702 * [31:0] | RW | Unknown | Port Static Weights[31:0]
3703 *
3704 */
3705/*
3706 * Field : Port Static Weights[31:0] - staticweight_31_0
3707 *
3708 * Set static weight of the port. Each port is programmed with a 5 bit value.
3709 * Port 0 is bits 4:0, port 1 is bits 9:5, up to port 9 being bits 49:45
3710 *
3711 * Field Access Macros:
3712 *
3713 */
3714/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field. */
3715#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_LSB 0
3716/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field. */
3717#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_MSB 31
3718/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field. */
3719#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_WIDTH 32
3720/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field value. */
3721#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_SET_MSK 0xffffffff
3722/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field value. */
3723#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_CLR_MSK 0x00000000
3724/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field is UNKNOWN. */
3725#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_RESET 0x0
3726/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 field value from a register. */
3727#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_GET(value) (((value) & 0xffffffff) >> 0)
3728/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0 register field value suitable for setting the register. */
3729#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_STATICWEIGHT_31_0_SET(value) (((value) << 0) & 0xffffffff)
3730
3731#ifndef __ASSEMBLY__
3732/*
3733 * WARNING: The C register and register group struct declarations are provided for
3734 * convenience and illustrative purposes. They should, however, be used with
3735 * caution as the C language standard provides no guarantees about the alignment or
3736 * atomicity of device memory accesses. The recommended practice for writing
3737 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3738 * alt_write_word() functions.
3739 *
3740 * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_0_4.
3741 */
3743{
3744 uint32_t staticweight_31_0 : 32; /* Port Static Weights[31:0] */
3745};
3746
3747/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_0_4. */
3749#endif /* __ASSEMBLY__ */
3750
3751/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 register from the beginning of the component. */
3752#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_OFST 0x0
3753/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 register. */
3754#define ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_OFST))
3755
3756/*
3757 * Register : Port Sum of Weight Register[2/4] - mpweight_1_4
3758 *
3759 * This register is used to configure the DRAM burst operation scheduling.
3760 *
3761 * Register Layout
3762 *
3763 * Bits | Access | Reset | Description
3764 * :--------|:-------|:--------|:---------------------------
3765 * [17:0] | RW | Unknown | Port Static Weights[49:32]
3766 * [31:18] | RW | Unknown | Port Sum of Weights[13:0]
3767 *
3768 */
3769/*
3770 * Field : Port Static Weights[49:32] - staticweight_49_32
3771 *
3772 * Set static weight of the port. Each port is programmed with a 5 bit value.
3773 * Port 0 is bits 4:0, port 1 is bits 9:5, up to port 9 being bits 49:45
3774 *
3775 * Field Access Macros:
3776 *
3777 */
3778/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field. */
3779#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_LSB 0
3780/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field. */
3781#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_MSB 17
3782/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field. */
3783#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_WIDTH 18
3784/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field value. */
3785#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_SET_MSK 0x0003ffff
3786/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field value. */
3787#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_CLR_MSK 0xfffc0000
3788/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field is UNKNOWN. */
3789#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_RESET 0x0
3790/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 field value from a register. */
3791#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_GET(value) (((value) & 0x0003ffff) >> 0)
3792/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32 register field value suitable for setting the register. */
3793#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_STATICWEIGHT_49_32_SET(value) (((value) << 0) & 0x0003ffff)
3794
3795/*
3796 * Field : Port Sum of Weights[13:0] - sumofweights_13_0
3797 *
3798 * Set the sum of static weights for particular user priority. This register is
3799 * used as part of the deficit round robin implementation. It should be set to the
3800 * sum of the weights for the ports
3801 *
3802 * Field Access Macros:
3803 *
3804 */
3805/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field. */
3806#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_LSB 18
3807/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field. */
3808#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_MSB 31
3809/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field. */
3810#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_WIDTH 14
3811/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field value. */
3812#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_SET_MSK 0xfffc0000
3813/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field value. */
3814#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_CLR_MSK 0x0003ffff
3815/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field is UNKNOWN. */
3816#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_RESET 0x0
3817/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 field value from a register. */
3818#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_GET(value) (((value) & 0xfffc0000) >> 18)
3819/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0 register field value suitable for setting the register. */
3820#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_SUMOFWEIGHTS_13_0_SET(value) (((value) << 18) & 0xfffc0000)
3821
3822#ifndef __ASSEMBLY__
3823/*
3824 * WARNING: The C register and register group struct declarations are provided for
3825 * convenience and illustrative purposes. They should, however, be used with
3826 * caution as the C language standard provides no guarantees about the alignment or
3827 * atomicity of device memory accesses. The recommended practice for writing
3828 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3829 * alt_write_word() functions.
3830 *
3831 * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_1_4.
3832 */
3834{
3835 uint32_t staticweight_49_32 : 18; /* Port Static Weights[49:32] */
3836 uint32_t sumofweights_13_0 : 14; /* Port Sum of Weights[13:0] */
3837};
3838
3839/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_1_4. */
3841#endif /* __ASSEMBLY__ */
3842
3843/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 register from the beginning of the component. */
3844#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_OFST 0x4
3845/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 register. */
3846#define ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_OFST))
3847
3848/*
3849 * Register : Port Sum of Weight Register[3/4] - mpweight_2_4
3850 *
3851 * This register is used to configure the DRAM burst operation scheduling.
3852 *
3853 * Register Layout
3854 *
3855 * Bits | Access | Reset | Description
3856 * :-------|:-------|:--------|:---------------------------
3857 * [31:0] | RW | Unknown | Port Sum of Weights[45:14]
3858 *
3859 */
3860/*
3861 * Field : Port Sum of Weights[45:14] - sumofweights_45_14
3862 *
3863 * Set the sum of static weights for particular user priority. This register is
3864 * used as part of the deficit round robin implementation. It should be set to the
3865 * sum of the weights for the ports
3866 *
3867 * Field Access Macros:
3868 *
3869 */
3870/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field. */
3871#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_LSB 0
3872/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field. */
3873#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_MSB 31
3874/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field. */
3875#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_WIDTH 32
3876/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field value. */
3877#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_SET_MSK 0xffffffff
3878/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field value. */
3879#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_CLR_MSK 0x00000000
3880/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field is UNKNOWN. */
3881#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_RESET 0x0
3882/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 field value from a register. */
3883#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_GET(value) (((value) & 0xffffffff) >> 0)
3884/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14 register field value suitable for setting the register. */
3885#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_SUMOFWEIGHTS_45_14_SET(value) (((value) << 0) & 0xffffffff)
3886
3887#ifndef __ASSEMBLY__
3888/*
3889 * WARNING: The C register and register group struct declarations are provided for
3890 * convenience and illustrative purposes. They should, however, be used with
3891 * caution as the C language standard provides no guarantees about the alignment or
3892 * atomicity of device memory accesses. The recommended practice for writing
3893 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3894 * alt_write_word() functions.
3895 *
3896 * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_2_4.
3897 */
3899{
3900 uint32_t sumofweights_45_14 : 32; /* Port Sum of Weights[45:14] */
3901};
3902
3903/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_2_4. */
3905#endif /* __ASSEMBLY__ */
3906
3907/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 register from the beginning of the component. */
3908#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_OFST 0x8
3909/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 register. */
3910#define ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_OFST))
3911
3912/*
3913 * Register : Port Sum of Weight Register[4/4] - mpweight_3_4
3914 *
3915 * This register is used to configure the DRAM burst operation scheduling.
3916 *
3917 * Register Layout
3918 *
3919 * Bits | Access | Reset | Description
3920 * :--------|:-------|:--------|:---------------------------
3921 * [17:0] | RW | Unknown | Port Sum of Weights[63:46]
3922 * [31:18] | ??? | 0x0 | *UNDEFINED*
3923 *
3924 */
3925/*
3926 * Field : Port Sum of Weights[63:46] - sumofweights_63_46
3927 *
3928 * Set the sum of static weights for particular user priority. This register is
3929 * used as part of the deficit round robin implementation. It should be set to the
3930 * sum of the weights for the ports
3931 *
3932 * Field Access Macros:
3933 *
3934 */
3935/* The Least Significant Bit (LSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field. */
3936#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_LSB 0
3937/* The Most Significant Bit (MSB) position of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field. */
3938#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_MSB 17
3939/* The width in bits of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field. */
3940#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_WIDTH 18
3941/* The mask used to set the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field value. */
3942#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_SET_MSK 0x0003ffff
3943/* The mask used to clear the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field value. */
3944#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_CLR_MSK 0xfffc0000
3945/* The reset value of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field is UNKNOWN. */
3946#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_RESET 0x0
3947/* Extracts the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 field value from a register. */
3948#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_GET(value) (((value) & 0x0003ffff) >> 0)
3949/* Produces a ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46 register field value suitable for setting the register. */
3950#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_SUMOFWEIGHTS_63_46_SET(value) (((value) << 0) & 0x0003ffff)
3951
3952#ifndef __ASSEMBLY__
3953/*
3954 * WARNING: The C register and register group struct declarations are provided for
3955 * convenience and illustrative purposes. They should, however, be used with
3956 * caution as the C language standard provides no guarantees about the alignment or
3957 * atomicity of device memory accesses. The recommended practice for writing
3958 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3959 * alt_write_word() functions.
3960 *
3961 * The struct declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_3_4.
3962 */
3964{
3965 uint32_t sumofweights_63_46 : 18; /* Port Sum of Weights[63:46] */
3966 uint32_t : 14; /* *UNDEFINED* */
3967};
3968
3969/* The typedef declaration for register ALT_SDR_CTL_MPWT_MPWEIGHT_3_4. */
3971#endif /* __ASSEMBLY__ */
3972
3973/* The byte offset of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 register from the beginning of the component. */
3974#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_OFST 0xc
3975/* The address of the ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 register. */
3976#define ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_OFST))
3977
3978#ifndef __ASSEMBLY__
3979/*
3980 * WARNING: The C register and register group struct declarations are provided for
3981 * convenience and illustrative purposes. They should, however, be used with
3982 * caution as the C language standard provides no guarantees about the alignment or
3983 * atomicity of device memory accesses. The recommended practice for writing
3984 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3985 * alt_write_word() functions.
3986 *
3987 * The struct declaration for register group ALT_SDR_CTL_MPWT.
3988 */
3990{
3991 volatile ALT_SDR_CTL_MPWT_MPWEIGHT_0_4_t mpweight_0_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 */
3992 volatile ALT_SDR_CTL_MPWT_MPWEIGHT_1_4_t mpweight_1_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 */
3993 volatile ALT_SDR_CTL_MPWT_MPWEIGHT_2_4_t mpweight_2_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 */
3994 volatile ALT_SDR_CTL_MPWT_MPWEIGHT_3_4_t mpweight_3_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 */
3995};
3996
3997/* The typedef declaration for register group ALT_SDR_CTL_MPWT. */
3998typedef volatile struct ALT_SDR_CTL_MPWT_s ALT_SDR_CTL_MPWT_t;
3999/* The struct declaration for the raw register contents of register group ALT_SDR_CTL_MPWT. */
4001{
4002 volatile uint32_t mpweight_0_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_0_4 */
4003 volatile uint32_t mpweight_1_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_1_4 */
4004 volatile uint32_t mpweight_2_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_2_4 */
4005 volatile uint32_t mpweight_3_4; /* ALT_SDR_CTL_MPWT_MPWEIGHT_3_4 */
4006};
4007
4008/* The typedef declaration for the raw register contents of register group ALT_SDR_CTL_MPWT. */
4009typedef volatile struct ALT_SDR_CTL_MPWT_raw_s ALT_SDR_CTL_MPWT_raw_t;
4010#endif /* __ASSEMBLY__ */
4011
4012
4013#ifndef __ASSEMBLY__
4014/*
4015 * WARNING: The C register and register group struct declarations are provided for
4016 * convenience and illustrative purposes. They should, however, be used with
4017 * caution as the C language standard provides no guarantees about the alignment or
4018 * atomicity of device memory accesses. The recommended practice for writing
4019 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4020 * alt_write_word() functions.
4021 *
4022 * The struct declaration for register group ALT_SDR_CTL.
4023 */
4025{
4026 volatile ALT_SDR_CTL_CTLCFG_t ctrlcfg; /* ALT_SDR_CTL_CTLCFG */
4027 volatile ALT_SDR_CTL_DRAMTIMING1_t dramtiming1; /* ALT_SDR_CTL_DRAMTIMING1 */
4028 volatile ALT_SDR_CTL_DRAMTIMING2_t dramtiming2; /* ALT_SDR_CTL_DRAMTIMING2 */
4029 volatile ALT_SDR_CTL_DRAMTIMING3_t dramtiming3; /* ALT_SDR_CTL_DRAMTIMING3 */
4030 volatile ALT_SDR_CTL_DRAMTIMING4_t dramtiming4; /* ALT_SDR_CTL_DRAMTIMING4 */
4031 volatile ALT_SDR_CTL_LOWPWRTIMING_t lowpwrtiming; /* ALT_SDR_CTL_LOWPWRTIMING */
4032 volatile ALT_SDR_CTL_DRAMODT_t dramodt; /* ALT_SDR_CTL_DRAMODT */
4033 volatile uint32_t _pad_0x1c_0x2b[4]; /* *UNDEFINED* */
4034 volatile ALT_SDR_CTL_DRAMADDRW_t dramaddrw; /* ALT_SDR_CTL_DRAMADDRW */
4035 volatile ALT_SDR_CTL_DRAMIFWIDTH_t dramifwidth; /* ALT_SDR_CTL_DRAMIFWIDTH */
4036 volatile ALT_SDR_CTL_DRAMDEVWIDTH_t dramdevwidth; /* ALT_SDR_CTL_DRAMDEVWIDTH */
4037 volatile ALT_SDR_CTL_DRAMSTS_t dramsts; /* ALT_SDR_CTL_DRAMSTS */
4038 volatile ALT_SDR_CTL_DRAMINTR_t dramintr; /* ALT_SDR_CTL_DRAMINTR */
4039 volatile ALT_SDR_CTL_SBECOUNT_t sbecount; /* ALT_SDR_CTL_SBECOUNT */
4040 volatile ALT_SDR_CTL_DBECOUNT_t dbecount; /* ALT_SDR_CTL_DBECOUNT */
4041 volatile ALT_SDR_CTL_ERRADDR_t erraddr; /* ALT_SDR_CTL_ERRADDR */
4042 volatile ALT_SDR_CTL_DROPCOUNT_t dropcount; /* ALT_SDR_CTL_DROPCOUNT */
4043 volatile ALT_SDR_CTL_DROPADDR_t dropaddr; /* ALT_SDR_CTL_DROPADDR */
4044 volatile ALT_SDR_CTL_LOWPWREQ_t lowpwreq; /* ALT_SDR_CTL_LOWPWREQ */
4045 volatile ALT_SDR_CTL_LOWPWRACK_t lowpwrack; /* ALT_SDR_CTL_LOWPWRACK */
4046 volatile ALT_SDR_CTL_STATICCFG_t staticcfg; /* ALT_SDR_CTL_STATICCFG */
4047 volatile ALT_SDR_CTL_CTLWIDTH_t ctrlwidth; /* ALT_SDR_CTL_CTLWIDTH */
4048 volatile uint32_t _pad_0x64_0x7b[6]; /* *UNDEFINED* */
4049 volatile ALT_SDR_CTL_PORTCFG_t portcfg; /* ALT_SDR_CTL_PORTCFG */
4050 volatile ALT_SDR_CTL_FPGAPORTRST_t fpgaportrst; /* ALT_SDR_CTL_FPGAPORTRST */
4051 volatile uint32_t _pad_0x84_0x8b[2]; /* *UNDEFINED* */
4052 volatile ALT_SDR_CTL_PROTPORTDEFAULT_t protportdefault; /* ALT_SDR_CTL_PROTPORTDEFAULT */
4053 volatile ALT_SDR_CTL_PROTRULEADDR_t protruleaddr; /* ALT_SDR_CTL_PROTRULEADDR */
4054 volatile ALT_SDR_CTL_PROTRULEID_t protruleid; /* ALT_SDR_CTL_PROTRULEID */
4055 volatile ALT_SDR_CTL_PROTRULEDATA_t protruledata; /* ALT_SDR_CTL_PROTRULEDATA */
4056 volatile ALT_SDR_CTL_PROTRULERDWR_t protrulerdwr; /* ALT_SDR_CTL_PROTRULERDWR */
4057 volatile ALT_SDR_CTL_QOSLOWPRI_t qoslowpri; /* ALT_SDR_CTL_QOSLOWPRI */
4058 volatile ALT_SDR_CTL_QOSHIGHPRI_t qoshighpri; /* ALT_SDR_CTL_QOSHIGHPRI */
4059 volatile ALT_SDR_CTL_QOSPRIORITYEN_t qospriorityen; /* ALT_SDR_CTL_QOSPRIORITYEN */
4060 volatile ALT_SDR_CTL_MPPRIORITY_t mppriority; /* ALT_SDR_CTL_MPPRIORITY */
4061 volatile ALT_SDR_CTL_MPWT_t ctrlgrp_mpweight; /* ALT_SDR_CTL_MPWT */
4062 volatile uint32_t _pad_0xc0_0xdf[8]; /* *UNDEFINED* */
4063 volatile ALT_SDR_CTL_REMAPPRIORITY_t remappriority; /* ALT_SDR_CTL_REMAPPRIORITY */
4064 volatile uint32_t _pad_0xe4_0x1000[967]; /* *UNDEFINED* */
4065};
4066
4067/* The typedef declaration for register group ALT_SDR_CTL. */
4068typedef volatile struct ALT_SDR_CTL_s ALT_SDR_CTL_t;
4069/* The struct declaration for the raw register contents of register group ALT_SDR_CTL. */
4071{
4072 volatile uint32_t ctrlcfg; /* ALT_SDR_CTL_CTLCFG */
4073 volatile uint32_t dramtiming1; /* ALT_SDR_CTL_DRAMTIMING1 */
4074 volatile uint32_t dramtiming2; /* ALT_SDR_CTL_DRAMTIMING2 */
4075 volatile uint32_t dramtiming3; /* ALT_SDR_CTL_DRAMTIMING3 */
4076 volatile uint32_t dramtiming4; /* ALT_SDR_CTL_DRAMTIMING4 */
4077 volatile uint32_t lowpwrtiming; /* ALT_SDR_CTL_LOWPWRTIMING */
4078 volatile uint32_t dramodt; /* ALT_SDR_CTL_DRAMODT */
4079 volatile uint32_t _pad_0x1c_0x2b[4]; /* *UNDEFINED* */
4080 volatile uint32_t dramaddrw; /* ALT_SDR_CTL_DRAMADDRW */
4081 volatile uint32_t dramifwidth; /* ALT_SDR_CTL_DRAMIFWIDTH */
4082 volatile uint32_t dramdevwidth; /* ALT_SDR_CTL_DRAMDEVWIDTH */
4083 volatile uint32_t dramsts; /* ALT_SDR_CTL_DRAMSTS */
4084 volatile uint32_t dramintr; /* ALT_SDR_CTL_DRAMINTR */
4085 volatile uint32_t sbecount; /* ALT_SDR_CTL_SBECOUNT */
4086 volatile uint32_t dbecount; /* ALT_SDR_CTL_DBECOUNT */
4087 volatile uint32_t erraddr; /* ALT_SDR_CTL_ERRADDR */
4088 volatile uint32_t dropcount; /* ALT_SDR_CTL_DROPCOUNT */
4089 volatile uint32_t dropaddr; /* ALT_SDR_CTL_DROPADDR */
4090 volatile uint32_t lowpwreq; /* ALT_SDR_CTL_LOWPWREQ */
4091 volatile uint32_t lowpwrack; /* ALT_SDR_CTL_LOWPWRACK */
4092 volatile uint32_t staticcfg; /* ALT_SDR_CTL_STATICCFG */
4093 volatile uint32_t ctrlwidth; /* ALT_SDR_CTL_CTLWIDTH */
4094 volatile uint32_t _pad_0x64_0x7b[6]; /* *UNDEFINED* */
4095 volatile uint32_t portcfg; /* ALT_SDR_CTL_PORTCFG */
4096 volatile uint32_t fpgaportrst; /* ALT_SDR_CTL_FPGAPORTRST */
4097 volatile uint32_t _pad_0x84_0x8b[2]; /* *UNDEFINED* */
4098 volatile uint32_t protportdefault; /* ALT_SDR_CTL_PROTPORTDEFAULT */
4099 volatile uint32_t protruleaddr; /* ALT_SDR_CTL_PROTRULEADDR */
4100 volatile uint32_t protruleid; /* ALT_SDR_CTL_PROTRULEID */
4101 volatile uint32_t protruledata; /* ALT_SDR_CTL_PROTRULEDATA */
4102 volatile uint32_t protrulerdwr; /* ALT_SDR_CTL_PROTRULERDWR */
4103 volatile uint32_t qoslowpri; /* ALT_SDR_CTL_QOSLOWPRI */
4104 volatile uint32_t qoshighpri; /* ALT_SDR_CTL_QOSHIGHPRI */
4105 volatile uint32_t qospriorityen; /* ALT_SDR_CTL_QOSPRIORITYEN */
4106 volatile uint32_t mppriority; /* ALT_SDR_CTL_MPPRIORITY */
4107 volatile ALT_SDR_CTL_MPWT_raw_t ctrlgrp_mpweight; /* ALT_SDR_CTL_MPWT */
4108 volatile uint32_t _pad_0xc0_0xdf[8]; /* *UNDEFINED* */
4109 volatile uint32_t remappriority; /* ALT_SDR_CTL_REMAPPRIORITY */
4110 volatile uint32_t _pad_0xe4_0x1000[967]; /* *UNDEFINED* */
4111};
4112
4113/* The typedef declaration for the raw register contents of register group ALT_SDR_CTL. */
4114typedef volatile struct ALT_SDR_CTL_raw_s ALT_SDR_CTL_raw_t;
4115#endif /* __ASSEMBLY__ */
4116
4117
4118#ifndef __ASSEMBLY__
4119/*
4120 * WARNING: The C register and register group struct declarations are provided for
4121 * convenience and illustrative purposes. They should, however, be used with
4122 * caution as the C language standard provides no guarantees about the alignment or
4123 * atomicity of device memory accesses. The recommended practice for writing
4124 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4125 * alt_write_word() functions.
4126 *
4127 * The struct declaration for register group ALT_SDR.
4128 */
4130{
4131 volatile uint32_t _pad_0x0_0x4fff[5120]; /* *UNDEFINED* */
4132 volatile ALT_SDR_CTL_t ctrlgrp; /* ALT_SDR_CTL */
4133 volatile uint32_t _pad_0x6000_0x20000[26624]; /* *UNDEFINED* */
4134};
4135
4136/* The typedef declaration for register group ALT_SDR. */
4137typedef volatile struct ALT_SDR_s ALT_SDR_t;
4138/* The struct declaration for the raw register contents of register group ALT_SDR. */
4140{
4141 volatile uint32_t _pad_0x0_0x4fff[5120]; /* *UNDEFINED* */
4142 volatile ALT_SDR_CTL_raw_t ctrlgrp; /* ALT_SDR_CTL */
4143 volatile uint32_t _pad_0x6000_0x20000[26624]; /* *UNDEFINED* */
4144};
4145
4146/* The typedef declaration for the raw register contents of register group ALT_SDR. */
4147typedef volatile struct ALT_SDR_raw_s ALT_SDR_raw_t;
4148#endif /* __ASSEMBLY__ */
4149
4150
4151#ifdef __cplusplus
4152}
4153#endif /* __cplusplus */
4154#endif /* __ALTERA_ALT_SDR_H__ */
4155
Definition: alt_sdr.h:474
Definition: alt_sdr.h:2682
Definition: alt_sdr.h:2066
Definition: alt_sdr.h:1472
Definition: alt_sdr.h:1600
Definition: alt_sdr.h:1538
Definition: alt_sdr.h:1938
Definition: alt_sdr.h:1328
Definition: alt_sdr.h:1766
Definition: alt_sdr.h:679
Definition: alt_sdr.h:850
Definition: alt_sdr.h:1021
Definition: alt_sdr.h:1141
Definition: alt_sdr.h:2247
Definition: alt_sdr.h:2187
Definition: alt_sdr.h:2126
Definition: alt_sdr.h:2822
Definition: alt_sdr.h:2487
Definition: alt_sdr.h:2395
Definition: alt_sdr.h:1234
Definition: alt_sdr.h:3610
Definition: alt_sdr.h:3743
Definition: alt_sdr.h:3834
Definition: alt_sdr.h:3899
Definition: alt_sdr.h:3964
Definition: alt_sdr.h:4001
Definition: alt_sdr.h:3990
Definition: alt_sdr.h:2751
Definition: alt_sdr.h:2891
Definition: alt_sdr.h:2992
Definition: alt_sdr.h:3233
Definition: alt_sdr.h:3084
Definition: alt_sdr.h:3357
Definition: alt_sdr.h:3485
Definition: alt_sdr.h:3423
Definition: alt_sdr.h:3546
Definition: alt_sdr.h:3674
Definition: alt_sdr.h:2004
Definition: alt_sdr.h:2615
Definition: alt_sdr.h:4071
Definition: alt_sdr.h:4025
Definition: alt_sdr.h:4140
Definition: alt_sdr.h:4130
