RTEMS 6.1-rc2
MCD_dma.h
1/*
2 * File: MCD_dma.h
3 * Purpose: Main header file for multi-channel DMA API.
4 *
5 * Notes:
6 */
7#ifndef _MCD_API_H
8#define _MCD_API_H
9
10/*
11 * Turn Execution Unit tasks ON (#define) or OFF (#undef)
12 */
13#define MCD_INCLUDE_EU
14
15/*
16 * Number of DMA channels
17 */
18#define NCHANNELS 16
19
20/*
21 * Total number of variants
22 */
23#ifdef MCD_INCLUDE_EU
24#define NUMOFVARIANTS 6
25#else
26#define NUMOFVARIANTS 4
27#endif
28
29/*
30 * Define sizes of the various tables
31 */
32#define TASK_TABLE_SIZE (NCHANNELS*32)
33#define VAR_TAB_SIZE (128)
34#define CONTEXT_SAVE_SIZE (128)
35#define FUNCDESC_TAB_SIZE (256)
36
37#ifdef MCD_INCLUDE_EU
38#define FUNCDESC_TAB_NUM 16
39#else
40#define FUNCDESC_TAB_NUM 1
41#endif
42
43
44#ifndef DEFINESONLY
45
46/*
47 * Portability typedefs
48 */
49typedef int s32;
50typedef unsigned int u32;
51typedef short s16;
52typedef unsigned short u16;
53typedef char s8;
54typedef unsigned char u8;
55
56/*
57 * These structures represent the internal registers of the
58 * multi-channel DMA
59 */
60struct dmaRegs_s {
61 u32 taskbar; /* task table base address register */
62 u32 currPtr;
63 u32 endPtr;
64 u32 varTablePtr;
65 u16 dma_rsvd0;
66 u16 ptdControl; /* ptd control */
67 u32 intPending; /* interrupt pending register */
68 u32 intMask; /* interrupt mask register */
69 u16 taskControl[16]; /* task control registers */
70 u8 priority[32]; /* priority registers */
71 u32 initiatorMux; /* initiator mux control */
72 u32 taskSize0; /* task size control register 0. */
73 u32 taskSize1; /* task size control register 1. */
74 u32 dma_rsvd1; /* reserved */
75 u32 dma_rsvd2; /* reserved */
76 u32 debugComp1; /* debug comparator 1 */
77 u32 debugComp2; /* debug comparator 2 */
78 u32 debugControl; /* debug control */
79 u32 debugStatus; /* debug status */
80 u32 ptdDebug; /* priority task decode debug */
81 u32 dma_rsvd3[31]; /* reserved */
82};
83typedef volatile struct dmaRegs_s dmaRegs;
84
85#endif
86
87/*
88 * PTD contrl reg bits
89 */
90#define PTD_CTL_TSK_PRI 0x8000
91#define PTD_CTL_COMM_PREFETCH 0x0001
92
93/*
94 * Task Control reg bits and field masks
95 */
96#define TASK_CTL_EN 0x8000
97#define TASK_CTL_VALID 0x4000
98#define TASK_CTL_ALWAYS 0x2000
99#define TASK_CTL_INIT_MASK 0x1f00
100#define TASK_CTL_ASTRT 0x0080
101#define TASK_CTL_HIPRITSKEN 0x0040
102#define TASK_CTL_HLDINITNUM 0x0020
103#define TASK_CTL_ASTSKNUM_MASK 0x000f
104
105/*
106 * Priority reg bits and field masks
107 */
108#define PRIORITY_HLD 0x80
109#define PRIORITY_PRI_MASK 0x07
110
111/*
112 * Debug Control reg bits and field masks
113 */
114#define DBG_CTL_BLOCK_TASKS_MASK 0xffff0000
115#define DBG_CTL_AUTO_ARM 0x00008000
116#define DBG_CTL_BREAK 0x00004000
117#define DBG_CTL_COMP1_TYP_MASK 0x00003800
118#define DBG_CTL_COMP2_TYP_MASK 0x00000070
119#define DBG_CTL_EXT_BREAK 0x00000004
120#define DBG_CTL_INT_BREAK 0x00000002
121
122/*
123 * PTD Debug reg selector addresses
124 * This reg must be written with a value to show the contents of
125 * one of the desired internal register.
126 */
127#define PTD_DBG_REQ 0x00 /* shows the state of 31 initiators */
128#define PTD_DBG_TSK_VLD_INIT 0x01 /* shows which 16 tasks are valid and
129 have initiators asserted */
130
131
132/*
133 * General return values
134 */
135#define MCD_OK 0
136#define MCD_ERROR -1
137#define MCD_TABLE_UNALIGNED -2
138#define MCD_CHANNEL_INVALID -3
139
140/*
141 * MCD_initDma input flags
142 */
143#define MCD_RELOC_TASKS 0x00000001
144#define MCD_NO_RELOC_TASKS 0x00000000
145#define MCD_COMM_PREFETCH_EN 0x00000002 /* Commbus Prefetching - MCF547x/548x ONLY */
146
147/*
148 * MCD_dmaStatus Status Values for each channel
149 */
150#define MCD_NO_DMA 1 /* No DMA has been requested since reset */
151#define MCD_IDLE 2 /* DMA active, but the initiator is currently inactive */
152#define MCD_RUNNING 3 /* DMA active, and the initiator is currently active */
153#define MCD_PAUSED 4 /* DMA active but it is currently paused */
154#define MCD_HALTED 5 /* the most recent DMA has been killed with MCD_killTask() */
155#define MCD_DONE 6 /* the most recent DMA has completed. */
156
157
158/*
159 * MCD_startDma parameter defines
160 */
161
162/*
163 * Constants for the funcDesc parameter
164 */
165/* Byte swapping: */
166#define MCD_NO_BYTE_SWAP 0x00045670 /* to disable byte swapping. */
167#define MCD_BYTE_REVERSE 0x00076540 /* to reverse the bytes of each u32 of the DMAed data. */
168#define MCD_U16_REVERSE 0x00067450 /* to reverse the 16-bit halves of
169 each 32-bit data value being DMAed.*/
170#define MCD_U16_BYTE_REVERSE 0x00054760 /* to reverse the byte halves of each
171 16-bit half of each 32-bit data value DMAed */
172#define MCD_NO_BIT_REV 0x00000000 /* do not reverse the bits of each byte DMAed. */
173#define MCD_BIT_REV 0x00088880 /* reverse the bits of each byte DMAed */
174/* CRCing: */
175#define MCD_CRC16 0xc0100000 /* to perform CRC-16 on DMAed data. */
176#define MCD_CRCCCITT 0xc0200000 /* to perform CRC-CCITT on DMAed data. */
177#define MCD_CRC32 0xc0300000 /* to perform CRC-32 on DMAed data. */
178#define MCD_CSUMINET 0xc0400000 /* to perform internet checksums on DMAed data.*/
179#define MCD_NO_CSUM 0xa0000000 /* to perform no checksumming. */
180
181#define MCD_FUNC_NOEU1 (MCD_NO_BYTE_SWAP | MCD_NO_BIT_REV | MCD_NO_CSUM)
182#define MCD_FUNC_NOEU2 (MCD_NO_BYTE_SWAP | MCD_NO_CSUM)
183
184/*
185 * Constants for the flags parameter
186 */
187#define MCD_TT_FLAGS_RL 0x00000001 /* Read line */
188#define MCD_TT_FLAGS_CW 0x00000002 /* Combine Writes */
189#define MCD_TT_FLAGS_SP 0x00000004 /* Speculative prefetch(XLB) MCF547x/548x ONLY */
190#define MCD_TT_FLAGS_MASK 0x000000ff
191#define MCD_TT_FLAGS_DEF (MCD_TT_FLAGS_RL | MCD_TT_FLAGS_CW)
192
193#define MCD_SINGLE_DMA 0x00000100 /* Unchained DMA */
194#define MCD_CHAIN_DMA /* TBD */
195#define MCD_EU_DMA /* TBD */
196#define MCD_FECTX_DMA 0x00001000 /* FEC TX ring DMA */
197#define MCD_FECRX_DMA 0x00002000 /* FEC RX ring DMA */
198
199
200/* these flags are valid for MCD_startDma and the chained buffer descriptors */
201#define MCD_BUF_READY 0x80000000 /* indicates that this buffer is now under the DMA's control */
202#define MCD_WRAP 0x20000000 /* to tell the FEC Dmas to wrap to the first BD */
203#define MCD_INTERRUPT 0x10000000 /* to generate an interrupt after completion of the DMA. */
204#define MCD_END_FRAME 0x08000000 /* tell the DMA to end the frame when transferring
205 last byte of data in buffer */
206#define MCD_CRC_RESTART 0x40000000 /* to empty out the accumulated checksum
207 prior to performing the DMA. */
208
209/* Defines for the FEC buffer descriptor control/status word*/
210#define MCD_FEC_BUF_READY 0x8000
211#define MCD_FEC_WRAP 0x2000
212#define MCD_FEC_INTERRUPT 0x1000
213#define MCD_FEC_END_FRAME 0x0800
214
215
216/*
217 * Defines for general intuitiveness
218 */
219
220#define MCD_TRUE 1
221#define MCD_FALSE 0
222
223/*
224 * Three different cases for destination and source.
225 */
226#define MINUS1 -1
227#define ZERO 0
228#define PLUS1 1
229
230#ifndef DEFINESONLY
231
232/* Task Table Entry struct*/
233typedef struct {
234 u32 TDTstart; /* task descriptor table start */
235 u32 TDTend; /* task descriptor table end */
236 u32 varTab; /* variable table start */
237 u32 FDTandFlags; /* function descriptor table start and flags */
238 volatile u32 descAddrAndStatus;
239 volatile u32 modifiedVarTab;
240 u32 contextSaveSpace; /* context save space start */
241 u32 literalBases;
243
244
245/* Chained buffer descriptor */
246typedef volatile struct MCD_bufDesc_struct MCD_bufDesc;
247struct MCD_bufDesc_struct {
248 u32 flags; /* flags describing the DMA */
249 u32 csumResult; /* checksum from checksumming performed since last checksum reset */
250 s8 *srcAddr; /* the address to move data from */
251 s8 *destAddr; /* the address to move data to */
252 s8 *lastDestAddr; /* the last address written to */
253 u32 dmaSize; /* the number of bytes to transfer independent of the transfer size */
254 MCD_bufDesc *next; /* next buffer descriptor in chain */
255 u32 info; /* private information about this descriptor; DMA does not affect it */
256};
257
258/* Progress Query struct */
259typedef volatile struct MCD_XferProg_struct {
260 s8 *lastSrcAddr; /* the most-recent or last, post-increment source address */
261 s8 *lastDestAddr; /* the most-recent or last, post-increment destination address */
262 u32 dmaSize; /* the amount of data transferred for the current buffer */
263 MCD_bufDesc *currBufDesc;/* pointer to the current buffer descriptor being DMAed */
265
266
267/* FEC buffer descriptor */
268typedef volatile struct MCD_bufDescFec_struct {
269 u16 statCtrl;
270 u16 length;
271 u32 dataPointer;
273
274
275/*************************************************************************/
276/*
277 * API function Prototypes - see MCD_dmaApi.c for further notes
278 */
279
280/*
281 * MCD_startDma starts a particular kind of DMA .
282 */
283int MCD_startDma (
284 int channel, /* the channel on which to run the DMA */
285 s8 *srcAddr, /* the address to move data from, or buffer-descriptor address */
286 s16 srcIncr, /* the amount to increment the source address per transfer */
287 s8 *destAddr, /* the address to move data to */
288 s16 destIncr, /* the amount to increment the destination address per transfer */
289 u32 dmaSize, /* the number of bytes to transfer independent of the transfer size */
290 u32 xferSize, /* the number bytes in of each data movement (1, 2, or 4) */
291 u32 initiator, /* what device initiates the DMA */
292 int priority, /* priority of the DMA */
293 u32 flags, /* flags describing the DMA */
294 u32 funcDesc /* a description of byte swapping, bit swapping, and CRC actions */
295);
296
297/*
298 * MCD_initDma() initializes the DMA API by setting up a pointer to the DMA
299 * registers, relocating and creating the appropriate task structures, and
300 * setting up some global settings
301 */
302int MCD_initDma (dmaRegs *sDmaBarAddr, void *taskTableDest, u32 flags);
303
304/*
305 * MCD_dmaStatus() returns the status of the DMA on the requested channel.
306 */
307int MCD_dmaStatus (int channel);
308
309/*
310 * MCD_XferProgrQuery() returns progress of DMA on requested channel
311 */
312int MCD_XferProgrQuery (int channel, MCD_XferProg *progRep);
313
314/*
315 * MCD_killDma() halts the DMA on the requested channel, without any
316 * intention of resuming the DMA.
317 */
318int MCD_killDma (int channel);
319
320/*
321 * MCD_continDma() continues a DMA which as stopped due to encountering an
322 * unready buffer descriptor.
323 */
324int MCD_continDma (int channel);
325
326/*
327 * MCD_pauseDma() pauses the DMA on the given channel ( if any DMA is
328 * running on that channel).
329 */
330int MCD_pauseDma (int channel);
331
332/*
333 * MCD_resumeDma() resumes the DMA on a given channel (if any DMA is
334 * running on that channel).
335 */
336int MCD_resumeDma (int channel);
337
338/*
339 * MCD_csumQuery provides the checksum/CRC after performing a non-chained DMA
340 */
341int MCD_csumQuery (int channel, u32 *csum);
342
343/*
344 * MCD_getCodeSize provides the packed size required by the microcoded task
345 * and structures.
346 */
347int MCD_getCodeSize(void);
348
349/*
350 * MCD_getVersion provides a pointer to a version string and returns a
351 * version number.
352 */
353int MCD_getVersion(char **longVersion);
354
355/* macro for setting a location in the variable table */
356#define MCD_SET_VAR(taskTab,idx,value) ((u32 *)(taskTab)->varTab)[idx] = value
357 /* Note that MCD_SET_VAR() is invoked many times in firing up a DMA function,
358 so I'm avoiding surrounding it with "do {} while(0)" */
359
360#endif /* DEFINESONLY */
361
362#endif /* _MCD_API_H */
Definition: MCD_dma.h:254
Definition: MCD_dma.h:263
Definition: MCD_dma.h:242
Definition: MCD_dma.h:228
Definition: MCD_dma.h:60
