27. Self-Contained Objects¶
27.1. Introduction¶
One of the original design goals of RTEMS was the support for heterogeneous computing based on message passing. This was realized by synchronization objects with an architecture-independent identifier provided by the system during object creation (a 32-bit unsigned integer used as a bitfield) and a user-defined four character name. This approach in the so called Classic API has some weaknesses:
Dynamic memory (the workspace) is used to allocate object pools. This requires a complex configuration with heavy use of the C pre-processor. The unlimited objects support optionally expands and shrinks the object pool. Dynamic memory is strongly discouraged by some coding standards, e.g. MISRA C:2012 [BBB+13].
Objects are created via function calls which return an object identifier. The object operations use this identifier and map it internally to an object representation.
The object identifier is only known at run-time. This hinders compiler optimizations and static analysis.
The objects reside in a table, e.g. they are subject to false sharing of cache lines [Dre07].
The object operations use a rich set of options and attributes. For each object operation these parameters must be evaluated and validated at run-time to figure out what to do exactly for this operation.
For applications that use fine grained locking the mapping of the identifier to the object representation and the parameter evaluation are a significant overhead that may degrade the performance dramatically. An example is the new network stack (libbsd) which uses hundreds of locks in a basic setup. Another example is the OpenMP support (libgomp).
To overcome these issues new self-contained synchronization objects are available since RTEMS 4.11. Self-contained synchronization objects encapsulate all their state in exactly one data structure. The user must provide the storage space for this structure and nothing more. The user is responsible for the object life-cycle. Initialization and destruction of self-contained synchronization objects cannot fail provided all function parameters are valid. In particular, a not enough memory error cannot happen. It is possible to statically initialize self-contained synchronization objects. This allows an efficient use of static analysis tools.
Several header files define self-contained synchronization objects. The Newlib
<sys/lock.h>
header file provides
mutexes,
recursive mutexes,
condition variables,
counting semaphores,
binary semaphores, and
Futex synchronization [FRK02].
They are used internally in Newlib (e.g. for FILE objects), for the C++11
threads and the OpenMP support (libgomp). The Newlib provided self-contained
synchronization objects focus on performance. There are no error checks to
catch software errors, e.g. invalid parameters. The application configuration
is significantly simplified, since it is no longer necessary to account for
lock objects used by Newlib and GCC. The Newlib defined self-contained
synchronization objects can be a statically initialized and reside in the
.bss
section. Destruction is a no-operation.
The header file <pthread.h>
provides
POSIX barriers (
pthread_barrier_t
),POSIX condition variables (
pthread_cond_t
),POSIX mutexes (
pthread_mutex_t
),POSIX reader/writer locks (
pthread_rwlock_t
), andPOSIX spinlocks (
pthread_spinlock_t
as self-contained synchronization objects. The POSIX synchronization objects are
used for example by the Ada run-time support. The header file
<semaphore.h>
provides self-contained
POSIX unnamed semaphores (
sem_t
initialized viasem_init()
27.2. RTEMS Thread API¶
To give RTEMS users access to self-contained synchronization objects an API is necessary. One option would be to simply use the POSIX threads API (pthreads), C11 threads or C++11 threads. However, these standard APIs lack for example binary semaphores which are important for task/interrupt synchronization. The timed operations use in general time values specified by seconds and nanoseconds. Setting up the time values in seconds (time_t has 64 bits) and nanoseconds is burdened with a high overhead compared to time values in clock ticks for relative timeouts. The POSIX API mutexes can be configured for various protocols and options, this adds a run-time overhead. There are a variety of error conditions. This is a problem in combination with some coding standards, e.g. MISRA C:2012. APIs used by Linux (e.g. <linux/mutex.h>) or the FreeBSD kernel (e.g. MUTEX(9)) are better suited as a template for high-performance synchronization objects. The goal of the RTEMS Thread API is to offer the highest performance with the lowest space-overhead on RTEMS. It should be suitable for device drivers.
27.3. Mutual Exclusion¶
The rtems_mutex
and rtems_recursive_mutex
objects provide
mutual-exclusion synchronization using the Priority Inheritance Protocol in
uniprocessor configurations or the O(m) Independence-Preserving Protocol (OMIP) in SMP configurations.
Recursive locking should be used with care [Wil12]. The
storage space for these object must be provided by the user. There are no
defined comparison or assignment operators for these type. Only the object
itself may be used for performing synchronization. The result of referring to
copies of the object in calls to
rtems_mutex_lock()
,rtems_recursive_mutex_lock()
,rtems_mutex_try_lock()
,rtems_recursive_mutex_try_lock()
,rtems_mutex_unlock()
,rtems_recursive_mutex_unlock()
,rtems_mutex_set_name()
,rtems_recursive_mutex_set_name()
,rtems_mutex_get_name()
,rtems_recursive_mutex_get_name()
,rtems_mutex_destroy()
, andrtems_recursive_mutex_destroy()
is undefined. Objects of the type rtems_mutex
must be initialized
via
RTEMS_MUTEX_INITIALIZER()
, orrtems_mutex_init()
They must be destroyed via
Objects of the type rtems_recursive_mutex
must be initialized via
RTEMS_RECURSIVE_MUTEX_INITIALIZER()
, orrtems_recursive_mutex_init()
27.3.1. Static mutex initialization¶
- CALLING SEQUENCE:
rtems_mutex mutex = RTEMS_MUTEX_INITIALIZER( name ); rtems_recursive_mutex mutex = RTEMS_RECURSIVE_MUTEX_INITIALIZER( name );
- DESCRIPTION:
An initializer for static initialization. It is equivalent to a call to
rtems_mutex_init()
respectively.- NOTES:
Global mutexes with a
name
ofNULL
may reside in the.bss
section.
27.3.2. Run-time mutex initialization¶
- CALLING SEQUENCE:
void rtems_mutex_init( rtems_mutex *mutex, const char *name ); void rtems_recursive_mutex_init( rtems_recursive_mutex *mutex, const char *name );
- DESCRIPTION:
Initializes the
mutex
with the specifiedname
.- NOTES:
The
name
must be persistent throughout the life-time of the mutex. Aname
ofNULL
is valid. The mutex is unlocked after initialization.
27.3.3. Lock the mutex¶
- CALLING SEQUENCE:
void rtems_mutex_lock( rtems_mutex *mutex ); void rtems_recursive_mutex_lock( rtems_recursive_mutex *mutex );
- DESCRIPTION:
Locks the
mutex
.- NOTES:
This function must be called from thread context with interrupts enabled. In case the mutex is currently locked by another thread, then the thread is blocked until it becomes the mutex owner. Threads wait in priority order.
A recursive lock happens in case the mutex owner tries to lock the mutex again. The result of recursively locking a mutex depends on the mutex variant. For a normal (non-recursive) mutex (
rtems_mutex
) the result is unpredictable. It could block the owner indefinetly or lead to a fatal deadlock error. A recursive mutex (rtems_recursive_mutex
) can be locked recursively by the mutex owner.Each mutex lock operation must have a corresponding unlock operation.
27.3.4. Try to lock the mutex¶
- CALLING SEQUENCE:
int rtems_mutex_try_lock( rtems_mutex *mutex ); int rtems_recursive_mutex_try_lock( rtems_recursive_mutex *mutex );
- DESCRIPTION:
Tries to lock the
mutex
. In case the mutex is not locked, it will be locked and the function returns with a return value of0
. If the mutex is already locked, the function will return with a value ofEBUSY
.- NOTES:
For recursively locking a mutex, please also see the notes for
rtems_mutex_lock()
andrtems_recursive_mutex_lock()
27.3.5. Unlock the mutex¶
- CALLING SEQUENCE:
void rtems_mutex_unlock( rtems_mutex *mutex ); void rtems_recursive_mutex_unlock( rtems_recursive_mutex *mutex );
- DESCRIPTION:
Unlocks the
mutex
.- NOTES:
This function must be called from thread context with interrupts enabled. In case the currently executing thread is not the owner of the
mutex
, then the result is unpredictable.Exactly the outer-most unlock will make a recursive mutex available to other threads.
27.3.6. Set mutex name¶
- CALLING SEQUENCE:
void rtems_mutex_set_name( rtems_mutex *mutex, const char *name ); void rtems_recursive_mutex_set_name( rtems_recursive_mutex *mutex, const char *name );
- DESCRIPTION:
Sets the
mutex
name toname
.- NOTES:
The
name
ofNULL
is valid.
27.3.7. Get mutex name¶
- CALLING SEQUENCE:
const char *rtems_mutex_get_name( const rtems_mutex *mutex ); const char *rtems_recursive_mutex_get_name( const rtems_recursive_mutex *mutex );
- DESCRIPTION:
Returns the
mutex
name.- NOTES:
The name may be
NULL
27.3.8. Mutex destruction¶
- CALLING SEQUENCE:
void rtems_mutex_destroy( rtems_mutex *mutex ); void rtems_recursive_mutex_destroy( rtems_recursive_mutex *mutex );
- DESCRIPTION:
Destroys the
mutex
.- NOTES:
In case the mutex is locked or still in use, then the result is unpredictable.
27.4. Condition Variables¶
The rtems_condition_variable
object provides a condition variable
synchronization object. The storage space for this object must be provided by
the user. There are no defined comparison or assignment operators for this
type. Only the object itself may be used for performing synchronization. The
result of referring to copies of the object in calls to
rtems_condition_variable_wait()
,rtems_condition_variable_signal()
,rtems_condition_variable_broadcast()
,rtems_condition_variable_set_name()
,rtems_condition_variable_get_name()
, andrtems_condition_variable_destroy()
is undefined. Objects of this type must be initialized via
RTEMS_CONDITION_VARIABLE_INITIALIZER()
, orrtems_condition_variable_init()
27.4.1. Static condition variable initialization¶
- CALLING SEQUENCE:
rtems_condition_variable condition_variable = RTEMS_CONDITION_VARIABLE_INITIALIZER( name );
- DESCRIPTION:
.- NOTES:
Global condition variables with a
name
ofNULL
section.
27.4.2. Run-time condition variable initialization¶
- CALLING SEQUENCE:
void rtems_condition_variable_init( rtems_condition_variable *condition_variable, const char *name );
- DESCRIPTION:
Initializes the
condition_variable
.- NOTES:
The
name
must be persistent throughout the life-time of the condition variable. Aname
ofNULL
is valid.
27.4.3. Wait for condition signal¶
- CALLING SEQUENCE:
void rtems_condition_variable_wait( rtems_condition_variable *condition_variable, rtems_mutex *mutex );
- DESCRIPTION:
Atomically waits for a condition signal and unlocks the mutex. Once the condition is signalled to the thread it wakes up and locks the mutex again.
- NOTES:
This function must be called from thread context with interrupts enabled. Threads wait in priority order.
27.4.4. Signals a condition change¶
- CALLING SEQUENCE:
void rtems_condition_variable_signal( rtems_condition_variable *condition_variable );
- DESCRIPTION:
Signals a condition change to the highest priority waiting thread. If no threads wait currently on this condition variable, then nothing happens.
27.4.5. Broadcasts a condition change¶
- CALLING SEQUENCE:
void rtems_condition_variable_broadcast( rtems_condition_variable *condition_variable );
- DESCRIPTION:
Signals a condition change to all waiting thread. If no threads wait currently on this condition variable, then nothing happens.
27.4.6. Set condition variable name¶
- CALLING SEQUENCE:
void rtems_condition_variable_set_name( rtems_condition_variable *condition_variable, const char *name );
- DESCRIPTION:
Sets the
condition_variable
name toname
.- NOTES:
The
name
ofNULL
is valid.
27.4.7. Get condition variable name¶
- CALLING SEQUENCE:
const char *rtems_condition_variable_get_name( const rtems_condition_variable *condition_variable );
- DESCRIPTION:
Returns the
condition_variable
name.- NOTES:
The name may be
NULL
27.4.8. Condition variable destruction¶
- CALLING SEQUENCE:
void rtems_condition_variable_destroy( rtems_condition_variable *condition_variable );
- DESCRIPTION:
Destroys the
condition_variable
.- NOTES:
In case the condition variable still in use, then the result is unpredictable.
27.5. Counting Semaphores¶
The rtems_counting_semaphore
object provides a counting semaphore
rtems_counting_semaphore_wait()
,rtems_counting_semaphore_post()
,rtems_counting_semaphore_set_name()
,rtems_counting_semaphore_get_name()
, andrtems_counting_semaphore_destroy()
RTEMS_COUNTING_SEMAPHORE_INITIALIZER()
, orrtems_counting_semaphore_init()
27.5.1. Static counting semaphore initialization¶
- CALLING SEQUENCE:
rtems_counting_semaphore counting_semaphore = RTEMS_COUNTING_SEMAPHORE_INITIALIZER( name, value );
- DESCRIPTION:
.- NOTES:
Global counting semaphores with a
name
ofNULL
section.
27.5.2. Run-time counting semaphore initialization¶
- CALLING SEQUENCE:
void rtems_counting_semaphore_init( rtems_counting_semaphore *counting_semaphore, const char *name, unsigned int value );
- DESCRIPTION:
Initializes the
counting_semaphore
andvalue
. The initial value is set tovalue
.- NOTES:
The
name
must be persistent throughout the life-time of the counting semaphore. Aname
ofNULL
is valid.
27.5.3. Wait for a counting semaphore¶
- CALLING SEQUENCE:
void rtems_counting_semaphore_wait( rtems_counting_semaphore *counting_semaphore );
- DESCRIPTION:
Waits for the
counting_semaphore
. In case the current semaphore value is positive, then the value is decremented and the function returns immediately, otherwise the thread is blocked waiting for a semaphore post.- NOTES:
27.5.4. Post a counting semaphore¶
- CALLING SEQUENCE:
void rtems_counting_semaphore_post( rtems_counting_semaphore *counting_semaphore );
- DESCRIPTION:
Posts the
counting_semaphore
. In case at least one thread is waiting on the counting semaphore, then the highest priority thread is woken up, otherwise the current value is incremented.- NOTES:
This function may be called from interrupt context. In case it is called from thread context, then interrupts must be enabled.
27.5.5. Set counting semaphore name¶
- CALLING SEQUENCE:
void rtems_counting_semaphore_set_name( rtems_counting_semaphore *counting_semaphore, const char *name );
- DESCRIPTION:
Sets the
counting_semaphore
name toname
.- NOTES:
The
name
ofNULL
is valid.
27.5.6. Get counting semaphore name¶
- CALLING SEQUENCE:
const char *rtems_counting_semaphore_get_name( const rtems_counting_semaphore *counting_semaphore );
- DESCRIPTION:
Returns the
counting_semaphore
name.- NOTES:
The name may be
NULL
27.5.7. Counting semaphore destruction¶
- CALLING SEQUENCE:
void rtems_counting_semaphore_destroy( rtems_counting_semaphore *counting_semaphore );
- DESCRIPTION:
Destroys the
counting_semaphore
.- NOTES:
In case the counting semaphore still in use, then the result is unpredictable.
27.6. Binary Semaphores¶
The rtems_binary_semaphore
object provides a binary semaphore
rtems_binary_semaphore_wait()
,rtems_binary_semaphore_wait_timed_ticks()
,rtems_binary_semaphore_try_wait()
,rtems_binary_semaphore_post()
,rtems_binary_semaphore_set_name()
,rtems_binary_semaphore_get_name()
, andrtems_binary_semaphore_destroy()
RTEMS_BINARY_SEMAPHORE_INITIALIZER()
, orrtems_binary_semaphore_init()
27.6.1. Static binary semaphore initialization¶
- CALLING SEQUENCE:
rtems_binary_semaphore binary_semaphore = RTEMS_BINARY_SEMAPHORE_INITIALIZER( name );
- DESCRIPTION:
.- NOTES:
Global binary semaphores with a
name
ofNULL
section.
27.6.2. Run-time binary semaphore initialization¶
- CALLING SEQUENCE:
void rtems_binary_semaphore_init( rtems_binary_semaphore *binary_semaphore, const char *name );
- DESCRIPTION:
Initializes the
binary_semaphore
. The initial value is set to zero.- NOTES:
The
name
must be persistent throughout the life-time of the binary semaphore. Aname
ofNULL
is valid.
27.6.3. Wait for a binary semaphore¶
- CALLING SEQUENCE:
void rtems_binary_semaphore_wait( rtems_binary_semaphore *binary_semaphore );
- DESCRIPTION:
Waits for the
binary_semaphore
. In case the current semaphore value is one, then the value is set to zero and the function returns immediately, otherwise the thread is blocked waiting for a semaphore post.- NOTES:
27.6.4. Wait for a binary semaphore with timeout in ticks¶
- CALLING SEQUENCE:
int rtems_binary_semaphore_wait_timed_ticks( rtems_binary_semaphore *binary_semaphore, uint32_t ticks );
- DIRECTIVE STATUS CODES:
0
The semaphore wait was successful.
ETIMEDOUT
The semaphore wait timed out.
- DESCRIPTION:
Waits for the
binary_semaphore
with a timeout inticks
. In case the current semaphore value is one, then the value is set to zero and the function returns immediately with a return value of0
, otherwise the thread is blocked waiting for a semaphore post. The time waiting for a semaphore post is limited byticks
. Aticks
value of zero specifies an infinite timeout.- NOTES:
27.6.5. Tries to wait for a binary semaphore¶
- CALLING SEQUENCE:
int rtems_binary_semaphore_try_wait( rtems_binary_semaphore *binary_semaphore );
0
EAGAIN
The semaphore wait failed.
- DESCRIPTION:
Tries to wait for the
binary_semaphore
, otherwise it returns immediately with a return value ofEAGAIN
.- NOTES:
27.6.6. Post a binary semaphore¶
- CALLING SEQUENCE:
void rtems_binary_semaphore_post( rtems_binary_semaphore *binary_semaphore );
- DESCRIPTION:
Posts the
binary_semaphore
. In case at least one thread is waiting on the binary semaphore, then the highest priority thread is woken up, otherwise the current value is set to one.- NOTES:
27.6.7. Set binary semaphore name¶
- CALLING SEQUENCE:
void rtems_binary_semaphore_set_name( rtems_binary_semaphore *binary_semaphore, const char *name );
- DESCRIPTION:
Sets the
binary_semaphore
name toname
.- NOTES:
The
name
ofNULL
is valid.
27.6.8. Get binary semaphore name¶
- CALLING SEQUENCE:
const char *rtems_binary_semaphore_get_name( const rtems_binary_semaphore *binary_semaphore );
- DESCRIPTION:
Returns the
binary_semaphore
name.- NOTES:
The name may be
NULL
27.6.9. Binary semaphore destruction¶
- CALLING SEQUENCE:
void rtems_binary_semaphore_destroy( rtems_binary_semaphore *binary_semaphore );
- DESCRIPTION:
Destroys the
binary_semaphore
.- NOTES:
In case the binary semaphore still in use, then the result is unpredictable.
27.7. Threads¶
Warning
The self-contained threads support is work in progress. In contrast to the synchronization objects the self-contained thread support is not just an API glue layer to already existing implementations.
The rtems_thread
object provides a thread of execution.
- CALLING SEQUENCE:
RTEMS_THREAD_INITIALIZER( name, thread_size, priority, flags, entry, arg ); void rtems_thread_start( rtems_thread *thread, const char *name, size_t thread_size, uint32_t priority, uint32_t flags, void ( *entry )( void * ), void *arg ); void rtems_thread_restart( rtems_thread *thread, void *arg ) RTEMS_NO_RETURN; void rtems_thread_event_send( rtems_thread *thread, uint32_t events ); uint32_t rtems_thread_event_poll( rtems_thread *thread, uint32_t events_of_interest ); uint32_t rtems_thread_event_wait_all( rtems_thread *thread, uint32_t events_of_interest ); uint32_t rtems_thread_event_wait_any( rtems_thread *thread, uint32_t events_of_interest ); void rtems_thread_destroy( rtems_thread *thread ); void rtems_thread_destroy_self( void ) RTEMS_NO_RETURN;
