RTEMS 6.1-rc1
z8036.h
2
15/*
16 * COPYRIGHT (c) 1989-2011.
17 * On-Line Applications Research Corporation (OAR).
18 *
19 * Redistribution and use in source and binary forms, with or without
20 * modification, are permitted provided that the following conditions
21 * are met:
22 * 1. Redistributions of source code must retain the above copyright
23 * notice, this list of conditions and the following disclaimer.
24 * 2. Redistributions in binary form must reproduce the above copyright
25 * notice, this list of conditions and the following disclaimer in the
26 * documentation and/or other materials provided with the distribution.
27 *
28 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
29 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
32 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
33 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
34 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
35 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
36 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
37 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
38 * POSSIBILITY OF SUCH DAMAGE.
39 */
40
41#ifndef _RTEMS_ZILOG_Z8036_H
42#define _RTEMS_ZILOG_Z8036_H
43
44#ifdef __cplusplus
45extern "C" {
46#endif
47
48/* macros */
49
50#define Z8036( ptr ) ((volatile struct z8036_map *)(ptr))
51
52#define Z8x36_STATE0 ( z8036 ) \
53 { /*char *garbage = *(Z8036(z8036))->???; */ }
54
55
56#define Z8x36_WRITE( z8036, reg, data ) \
57 (Z8036(z8036))->reg = (data)
58
59
60#define Z8x36_READ( z8036, reg, data ) \
61 (Z8036(z8036))->reg = (data)
62
63/* structures */
64
65struct z8036_map {
66/* MAIN CONTROL REGISTERS (0x00-0x07) */
67 uint8_t MASTER_INTR; /* Master Interrupt Ctl Reg */
68 uint8_t MASTER_CFG; /* Master Configuration Ctl Reg */
69 uint8_t PORTA_VECTOR; /* Port A - Interrupt Vector */
70 uint8_t PORTB_VECTOR; /* Port B - Interrupt Vector */
71 uint8_t CNT_TMR_VECTOR; /* Counter/Timer Interrupt Vector */
72 uint8_t PORTC_DATA_POLARITY; /* Port C - Data Path Polarity */
73 uint8_t PORTC_DIRECTION; /* Port C - Data Direction */
74 uint8_t PORTC_SPECIAL_IO_CTL; /* Port C - Special IO Control */
75/* MOST OFTEN ACCESSED REGISTERS (0x08 - 0x0f) */
76 uint8_t PORTA_CMD_STATUS; /* Port A - Command Status Reg */
77 uint8_t PORTB_CMD_STATUS; /* Port B - Command Status Reg */
78 uint8_t CT1_CMD_STATUS; /* Ctr/Timer 1 - Command Status Reg */
79 uint8_t CT2_CMD_STATUS; /* Ctr/Timer 2 - Command Status Reg */
80 uint8_t CT3_CMD_STATUS; /* Ctr/Timer 3 - Command Status Reg */
81 uint8_t PORTA_DATA; /* Port A - Data */
82 uint8_t PORTB_DATA; /* Port B - Data */
83 uint8_t PORTC_DATA; /* Port C - Data */
84/* COUNTER/TIMER RELATED REGISTERS (0x10-0x1f) */
85 uint8_t CT1_CUR_CNT_MSB; /* Ctr/Timer 1 - Current Count (MSB) */
86 uint8_t CT1_CUR_CNT_LSB; /* Ctr/Timer 1 - Current Count (LSB) */
87 uint8_t CT2_CUR_CNT_MSB; /* Ctr/Timer 2 - Current Count (MSB) */
88 uint8_t CT2_CUR_CNT_LSB; /* Ctr/Timer 2 - Current Count (LSB) */
89 uint8_t CT3_CUR_CNT_MSB; /* Ctr/Timer 3 - Current Count (MSB) */
90 uint8_t CT3_CUR_CNT_LSB; /* Ctr/Timer 3 - Current Count (LSB) */
91 uint8_t CT1_TIME_CONST_MSB; /* Ctr/Timer 1 - Time Constant (MSB) */
92 uint8_t CT1_TIME_CONST_LSB; /* Ctr/Timer 1 - Time Constant (LSB) */
93 uint8_t CT2_TIME_CONST_MSB; /* Ctr/Timer 2 - Time Constant (MSB) */
94 uint8_t CT2_TIME_CONST_LSB; /* Ctr/Timer 2 - Time Constant (LSB) */
95 uint8_t CT3_TIME_CONST_MSB; /* Ctr/Timer 3 - Time Constant (MSB) */
96 uint8_t CT3_TIME_CONST_LSB; /* Ctr/Timer 3 - Time Constant (LSB) */
97 uint8_t CT1_MODE_SPEC; /* Ctr/Timer 1 - Mode Specification */
98 uint8_t CT2_MODE_SPEC; /* Ctr/Timer 2 - Mode Specification */
99 uint8_t CT3_MODE_SPEC; /* Ctr/Timer 3 - Mode Specification */
100 uint8_t CURRENT_VECTOR; /* Current Vector */
101/* PORT A SPECIFICATION REGISTERS (0x20 -0x27) */
102 uint8_t PORTA_MODE; /* Port A - Mode Specification */
103 uint8_t PORTA_HANDSHAKE; /* Port A - Handshake Specification */
104 uint8_t PORTA_DATA_POLARITY; /* Port A - Data Path Polarity */
105 uint8_t PORTA_DIRECTION; /* Port A - Data Direction */
106 uint8_t PORTA_SPECIAL_IO_CTL; /* Port A - Special IO Control */
107 uint8_t PORTA_PATT_POLARITY; /* Port A - Pattern Polarity */
108 uint8_t PORTA_PATT_TRANS; /* Port A - Pattern Transition */
109 uint8_t PORTA_PATT_MASK; /* Port A - Pattern Mask */
110/* PORT B SPECIFICATION REGISTERS (0x28-0x2f) */
111 uint8_t PORTB_MODE; /* Port B - Mode Specification */
112 uint8_t PORTB_HANDSHAKE; /* Port B - Handshake Specification */
113 uint8_t PORTB_DATA_POLARITY; /* Port B - Data Path Polarity */
114 uint8_t PORTB_DIRECTION; /* Port B - Data Direction */
115 uint8_t PORTB_SPECIAL_IO_CTL; /* Port B - Special IO Control */
116 uint8_t PORTB_PATT_POLARITY; /* Port B - Pattern Polarity */
117 uint8_t PORTB_PATT_TRANS; /* Port B - Pattern Transition */
118 uint8_t PORTB_PATT_MASK; /* Port B - Pattern Mask */
119};
120
121#ifdef __cplusplus
122}
123#endif
124
125#endif
Definition: z8036.h:65
