RTEMS
6.1-rc1
bsps
aarch64
xilinx-versal
include
dev
serial
versal-uart.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2021 Gedare Bloom <gedare@rtems.org>
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_XILINX_VERSAL_UART_H
37
#define LIBBSP_ARM_XILINX_VERSAL_UART_H
38
39
rtems/termiostypes.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
54
typedef
struct
55
rtems_termios_device_context
base;
56
volatile
struct
versal_uart
*regs;
57
volatile
size_t
tx_queued;
58
volatile
bool
transmitting;
59
bool
first_send;
60
rtems_vector_number
irq;
61
versal_uart_context
62
63
extern
const
rtems_termios_device_handler
versal_uart_handler;
64
65
#define VERSAL_UART_DEFAULT_BAUD 115200
66
67
int
versal_uart_initialize(
*base);
68
69
int
versal_uart_read_polled(
*base);
70
71
void
versal_uart_write_polled(
72
*base,
73
char
75
79
void
versal_uart_reset_tx_flush
*base);
80
81
int
versal_cal_baud_rate(
82
uint32_t baudrate,
83
uint32_t maxerror,
84
uint32_t* ibdiv,
85
uint32_t* fbdiv
86
87
88
#ifdef __cplusplus
89
90
#endif
/* __cplusplus */
91
92
#endif
/* LIBBSP_ARM_XILINX_VERSAL_UART_H */
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition:
intr.h:102
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
versal_uart_context
Definition:
versal-uart.h:54
versal_uart
Definition:
versal-uart-regs.h:51
termiostypes.h
void versal_uart_reset_tx_flush(rtems_termios_device_context *base)
Definition:
versal-uart-polled.c:180
