20#ifndef LIBBSP_ARM_RASPBERRYPI_VC_DEFINES_H
21#define LIBBSP_ARM_RASPBERRYPI_VC_DEFINES_H
41#define BCM2835_MBOX_BUF_CODE_PROCESS_REQUEST 0x00000000
42#define BCM2835_MBOX_BUF_CODE_REQUEST_SUCCEED 0x80000000
43#define BCM2835_MBOX_BUF_CODE_REQUEST_PARSING_ERROR 0x80000001
44#define BCM2835_MBOX_TAG_VAL_LEN_REQUEST 0x00000000
45#define BCM2835_MBOX_TAG_VAL_LEN_RESPONSE 0x80000000
99#define BCM2835_MBOX_TAG_REPLY_IS_SET( _t_ ) \
100 ( ( _t_ )->tag_hdr.val_len & 0x80000000 )
102#define BCM2835_MBOX_INIT_BUF( _m_ ) { \
103 memset( ( _m_ ), 0, sizeof( *( _m_ ) ) ); \
104 ( _m_ )->hdr.buf_size = (void *)&(( _m_ )->end_tag) + 4 - (void *)( _m_ ); \
105 ( _m_ )->hdr.buf_code = BCM2835_MBOX_BUF_CODE_PROCESS_REQUEST; \
106 ( _m_ )->end_tag = 0; \
109#define BCM2835_MBOX_INIT_TAG( _t_, _id_ ) { \
110 ( _t_ )->tag_hdr.tag = _id_; \
111 ( _t_ )->tag_hdr.val_buf_size = sizeof( ( _t_ )->body ); \
112 ( _t_ )->tag_hdr.val_len = sizeof( ( _t_ )->body.req ); \
115#define BCM2835_MBOX_INIT_TAG_NO_REQ( _t_, _id_ ) { \
116 ( _t_ )->tag_hdr.tag = _id_; \
117 ( _t_ )->tag_hdr.val_buf_size = sizeof( ( _t_ )->body ); \
118 ( _t_ )->tag_hdr.val_len = 0; \
137#define BCM2835_MBOX_BUF_ALIGN_ATTRIBUTE __attribute__( ( aligned( 64 ) ) )
140#define BCM2835_MAILBOX_TAG_FIRMWARE_REVISION 0x00000001
153#define BCM2835_MAILBOX_TAG_GET_BOARD_MODEL 0x00010001
154#define BCM2835_MAILBOX_TAG_GET_BOARD_VERSION 0x00010002
166#if (BSP_IS_RPI2 == 1)
167#define BCM2836_MAILBOX_BOARD_V_2_B 0x4
169#define BCM2835_MAILBOX_BOARD_V_B_I2C0_2 0x2
170#define BCM2835_MAILBOX_BOARD_V_B_I2C0_3 0x3
171#define BCM2835_MAILBOX_BOARD_V_B_I2C1_4 0x4
172#define BCM2835_MAILBOX_BOARD_V_B_I2C1_5 0x5
173#define BCM2835_MAILBOX_BOARD_V_B_I2C1_6 0x6
174#define BCM2835_MAILBOX_BOARD_V_A_7 0x7
175#define BCM2835_MAILBOX_BOARD_V_A_8 0x8
176#define BCM2835_MAILBOX_BOARD_V_A_9 0x9
177#define BCM2835_MAILBOX_BOARD_V_B_REV2_d 0xd
178#define BCM2835_MAILBOX_BOARD_V_B_REV2_e 0xe
179#define BCM2835_MAILBOX_BOARD_V_B_REV2_f 0xf
180#define BCM2835_MAILBOX_BOARD_V_B_PLUS 0x10
181#define BCM2835_MAILBOX_BOARD_V_CM 0x11
182#define BCM2835_MAILBOX_BOARD_V_A_PLUS 0x12
185#define BCM2835_MAILBOX_TAG_GET_BOARD_MAC 0x00010003
186#define BCM2835_MAILBOX_TAG_GET_BOARD_SERIAL 0x00010004
193 uint64_t board_serial;
198#define BCM2835_MAILBOX_TAG_GET_ARM_MEMORY 0x00010005
211#define BCM2835_MAILBOX_TAG_GET_VC_MEMORY 0x00010006
224#define BCM2835_MAILBOX_TAG_GET_CLOCKS 0x00010007
239#define BCM2835_MAILBOX_TAG_GET_CMD_LINE 0x00050001
246 uint8_t cmdline[ 1024 ];
252#define BCM2835_MAILBOX_TAG_GET_DMA_CHANNELS 0x00060001
255#define BCM2835_MAILBOX_POWER_UDID_SD_Card 0x00000000
256#define BCM2835_MAILBOX_POWER_UDID_UART0 0x00000001
257#define BCM2835_MAILBOX_POWER_UDID_UART1 0x00000002
258#define BCM2835_MAILBOX_POWER_UDID_USB_HCD 0x00000003
259#define BCM2835_MAILBOX_POWER_UDID_I2C0 0x00000004
260#define BCM2835_MAILBOX_POWER_UDID_I2C1 0x00000005
261#define BCM2835_MAILBOX_POWER_UDID_I2C2 0x00000006
262#define BCM2835_MAILBOX_POWER_UDID_SPI 0x00000007
263#define BCM2835_MAILBOX_POWER_UDID_CCP2TX 0x00000008
265#define BCM2835_MAILBOX_TAG_GET_POWER_STATE 0x00020001
279#define BCM2835_MAILBOX_POWER_STATE_RESP_ON (1 << 0)
280#define BCM2835_MAILBOX_POWER_STATE_RESP_NODEV (1 << 1)
282#define BCM2835_MAILBOX_TAG_GET_TIMING 0x00020002
283#define BCM2835_MAILBOX_TAG_SET_POWER_STATE 0x00028001
298#ifndef BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON
300#define BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON (1 << 0)
301#define BCM2835_MAILBOX_SET_POWER_STATE_REQ_WAIT (1 << 1)
305#define BCM2835_MAILBOX_UCID_CLOCK_RESERVED 0x000000000
306#define BCM2835_MAILBOX_UCID_CLOCK_EMMC 0x000000001
307#define BCM2835_MAILBOX_UCID_CLOCK_UART 0x000000002
308#define BCM2835_MAILBOX_UCID_CLOCK_ARM 0x000000003
309#define BCM2835_MAILBOX_UCID_CLOCK_CORE 0x000000004
310#define BCM2835_MAILBOX_UCID_CLOCK_V3D 0x000000005
311#define BCM2835_MAILBOX_UCID_CLOCK_H264 0x000000006
312#define BCM2835_MAILBOX_UCID_CLOCK_ISP 0x000000007
313#define BCM2835_MAILBOX_UCID_CLOCK_SDRAM 0x000000008
314#define BCM2835_MAILBOX_UCID_CLOCK_PIXEL 0x000000009
315#define BCM2835_MAILBOX_UCID_CLOCK_PWM 0x00000000a
317#define BCM2835_MAILBOX_TAG_GET_CLOCK_STATE 0x00030001
318#define BCM2835_MAILBOX_TAG_SET_CLOCK_STATE 0x00038001
319#define BCM2835_MAILBOX_TAG_GET_CLOCK_RATE 0x00030002
320#define BCM2835_MAILBOX_TAG_SET_CLOCK_RATE 0x00038002
321#define BCM2835_MAILBOX_TAG_GET_MAX_CLOCK_RATE 0x00030004
322#define BCM2835_MAILBOX_TAG_GET_MIN_CLOCK_RATE 0x00030007
323#define BCM2835_MAILBOX_TAG_GET_TRUBO 0x00030009
324#define BCM2835_MAILBOX_TAG_SET_TURBO 0x00038009
326#define BCM2835_MAILBOX_TAG_GET_DOMAIN_STATE 0x00030030
327#define BCM2835_MAILBOX_TAG_SET_DOMAIN_STATE 0x00038030
330#define BCM2835_MAILBOX_VOLTAGE_RESERVED_UVID 0x000000000
331#define BCM2835_MAILBOX_VOLTAGE_CORE_UVID 0x000000001
332#define BCM2835_MAILBOX_VOLTAGE_SDRAM_C_UVID 0x000000002
333#define BCM2835_MAILBOX_VOLTAGE_SDRAM_P_UVID 0x000000003
334#define BCM2835_MAILBOX_VOLTAGE_SDRAM_I_UVID 0x000000004
336#define BCM2835_MAILBOX_TAG_GET_VOLTAGE 0x00030003
337#define BCM2835_MAILBOX_TAG_SET_VOLTAGE 0x00038003
338#define BCM2835_MAILBOX_TAG_GET_MAX_VOLTAGE 0x00030005
339#define BCM2835_MAILBOX_TAG_GET_MIN_VOLTAGE 0x00030008
340#define BCM2835_MAILBOX_TAG_GET_TEMPERATURE 0x00030006
341#define BCM2835_MAILBOX_TAG_GET_MAX_TEMPERATURE 0x0003000a
344#define BCM2835_MAILBOX_TAG_ALLOCATE_MEMORY 0x0003000c
345#define BCM2835_MAILBOX_TAG_LOCK_MEMORY 0x0003000d
346#define BCM2835_MAILBOX_TAG_UNLOCK_MEMORY 0x0003000e
347#define BCM2835_MAILBOX_TAG_RELEASE_MEMORY 0x0003000f
348#define BCM2835_MAILBOX_TAG_EXECUTE_CODE 0x00030010
349#define BCM2835_MAILBOX_TAG_GET_DISPMANX_RESOURCE_MEM_HANDLE 0x00030014
351#define BCM2835_MAILBOX_TAG_GET_EDID_BLOCK 0x00030020
354#define BCM2835_MAILBOX_TAG_ALLOCATE_BUFFER 0x00040001
368#define BCM2835_MAILBOX_TAG_RELEASE_BUFFER 0x00048001
370#define BCM2835_MAILBOX_TAG_BLANK_SCREEN 0x00040002
372#define BCM2835_MAILBOX_TAG_GET_DISPLAY_SIZE 0x00040003
373#define BCM2835_MAILBOX_TAG_TEST_DISPLAY_SIZE 0x00044003
374#define BCM2835_MAILBOX_TAG_SET_DISPLAY_SIZE 0x00048003
389#define BCM2835_MAILBOX_TAG_GET_VIRTUAL_SIZE 0x00040004
390#define BCM2835_MAILBOX_TAG_TEST_VIRTUAL_SIZE 0x00044004
391#define BCM2835_MAILBOX_TAG_SET_VIRTUAL_SIZE 0x00048004
406#define BCM2835_MAILBOX_TAG_GET_DEPTH 0x00040005
407#define BCM2835_MAILBOX_TAG_TEST_DEPTH 0x00044005
408#define BCM2835_MAILBOX_TAG_SET_DEPTH 0x00048005
421#define BCM2835_MAILBOX_TAG_GET_PIXEL_ORDER 0x00040006
422#define BCM2835_MAILBOX_TAG_TEST_PIXEL_ORDER 0x00044006
423#define BCM2835_MAILBOX_TAG_SET_PIXEL_ORDER 0x00048006
425#define BCM2835_MAILBOX_PIXEL_ORDER_BGR 0
426#define BCM2835_MAILBOX_PIXEL_ORDER_RGB 1
431 uint32_t pixel_order;
434 uint32_t pixel_order;
439#define BCM2835_MAILBOX_TAG_GET_ALPHA_MODE 0x00040007
440#define BCM2835_MAILBOX_TAG_TEST_ALPHA_MODE 0x00044007
441#define BCM2835_MAILBOX_TAG_SET_ALPHA_MODE 0x00048007
454#define BCM2835_MAILBOX_ALPHA_MODE_0_OPAQUE 0
455#define BCM2835_MAILBOX_ALPHA_MODE_0_TRANSPARENT 1
456#define BCM2835_MAILBOX_ALPHA_MODE_IGNORED 2
458#define BCM2835_MAILBOX_TAG_GET_PITCH 0x00040008
470#define BCM2835_MAILBOX_TAG_GET_VIRTUAL_OFFSET 0x00040009
471#define BCM2835_MAILBOX_TAG_TEST_VIRTUAL_OFFSET 0x00044009
472#define BCM2835_MAILBOX_TAG_SET_VIRTUAL_OFFSET 0x00048009
487#define BCM2835_MAILBOX_TAG_GET_OVERSCAN 0x0004000a
488#define BCM2835_MAILBOX_TAG_TEST_OVERSCAN 0x0004400a
489#define BCM2835_MAILBOX_TAG_SET_OVERSCAN 0x0004800a
494 uint32_t overscan_top;
495 uint32_t overscan_bottom;
496 uint32_t overscan_left;
497 uint32_t overscan_right;
500 uint32_t overscan_top;
501 uint32_t overscan_bottom;
502 uint32_t overscan_left;
503 uint32_t overscan_right;
508#define BCM2835_MAILBOX_TAG_GET_PALETTE 0x0004000b
509#define BCM2835_MAILBOX_TAG_TEST_PALETTE 0x0004400b
510#define BCM2835_MAILBOX_TAG_SET_PALETTE 0x0004800b
511#define BCM2835_MAILBOX_TAG_SET_CURSOR_INFO 0x00008011
512#define BCM2835_MAILBOX_TAG_SET_CURSOR_STATE 0x00008010
Buffer Header.
Definition: vc_defines.h:55
uint32_t buf_code
Buffer Code.
Definition: vc_defines.h:71
uint32_t buf_size
Buffer Size.
Definition: vc_defines.h:62
Definition: vc_defines.h:355
Definition: vc_defines.h:442
Definition: vc_defines.h:409
Definition: vc_defines.h:375
Definition: vc_defines.h:199
Definition: vc_defines.h:187
Definition: vc_defines.h:155
Definition: vc_defines.h:225
Definition: vc_defines.h:240
Definition: vc_defines.h:141
Definition: vc_defines.h:459
Definition: vc_defines.h:266
Definition: vc_defines.h:212
Tag Header.
Definition: vc_defines.h:82
uint32_t tag
Property Tag ID.
Definition: vc_defines.h:86
uint32_t val_buf_size
The size of request qnd responce buffer.
Definition: vc_defines.h:90
uint32_t val_len
The size of response buffer set by videocore.
Definition: vc_defines.h:96
Definition: vc_defines.h:490
Definition: vc_defines.h:427
Definition: vc_defines.h:284
Definition: vc_defines.h:473
Definition: vc_defines.h:392
unsigned size
Definition: tte.h:1
