RTEMS 6.1-rc1
userext.h
2
13/*
14 * COPYRIGHT (c) 1989-2009.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_SCORE_USEREXT_H
40#define _RTEMS_SCORE_USEREXT_H
41
42#include <rtems/score/interr.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif
47
48struct _Thread_Control;
49
93 struct _Thread_Control *executing,
94 struct _Thread_Control *created
95);
96
113 struct _Thread_Control *executing,
114 struct _Thread_Control *deleted
115);
116
133 struct _Thread_Control *executing,
134 struct _Thread_Control *started
135);
136
155 struct _Thread_Control *executing,
156 struct _Thread_Control *restarted
157);
158
178 struct _Thread_Control *executing,
179 struct _Thread_Control *heir
180);
181
193 struct _Thread_Control *executing
194);
195
207 struct _Thread_Control *executing
208);
209
226 bool always_set_to_false,
227 Internal_errors_t code
228);
229
247 struct _Thread_Control *terminated
248);
249
253typedef struct {
264
267#ifdef __cplusplus
268}
269#endif
270
271#endif
272/* end of include file */
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
void(* User_extensions_thread_begin_extension)(struct _Thread_Control *executing)
Task begin extension.
Definition: userext.h:192
bool(* User_extensions_thread_create_extension)(struct _Thread_Control *executing, struct _Thread_Control *created)
Task create extension.
Definition: userext.h:92
void(* User_extensions_thread_start_extension)(struct _Thread_Control *executing, struct _Thread_Control *started)
Task start extension.
Definition: userext.h:132
void(* User_extensions_thread_restart_extension)(struct _Thread_Control *executing, struct _Thread_Control *restarted)
Task restart extension.
Definition: userext.h:154
void(* User_extensions_thread_delete_extension)(struct _Thread_Control *executing, struct _Thread_Control *deleted)
Task delete extension.
Definition: userext.h:112
void(* User_extensions_thread_switch_extension)(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition: userext.h:177
void(* User_extensions_thread_terminate_extension)(struct _Thread_Control *terminated)
Task termination extension.
Definition: userext.h:246
void(* User_extensions_fatal_extension)(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Fatal error extension.
Definition: userext.h:224
void(* User_extensions_thread_exitted_extension)(struct _Thread_Control *executing)
Task exitted extension.
Definition: userext.h:206
This header file provides the interfaces of the Internal Error Handler.
User extension table.
Definition: userext.h:253
Definition: thread.h:812
Definition: inftrees.h:24
