RTEMS 6.1-rc1
tr-object-ident.h
2
9/*
10 * Copyright (C) 2020 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/*
35 * This file is part of the RTEMS quality process and was automatically
36 * generated. If you find something that needs to be fixed or
37 * worded better please post a report or patch to an RTEMS mailing list
38 * or raise a bug report:
39 *
40 * https://www.rtems.org/bugs.html
41 *
42 * For information on updating and regenerating please refer to the How-To
43 * section in the Software Requirements Engineering chapter of the
44 * RTEMS Software Engineering manual. The manual is provided as a part of
45 * a release. For development sources please refer to the online
46 * documentation at:
47 *
48 * https://docs.rtems.org
49 */
50
51#ifndef _TR_OBJECT_IDENT_H
52#define _TR_OBJECT_IDENT_H
53
54#include <rtems.h>
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
66typedef enum {
67 RtemsReqIdent_Pre_Name_Invalid,
68 RtemsReqIdent_Pre_Name_Valid,
69 RtemsReqIdent_Pre_Name_NA
70} RtemsReqIdent_Pre_Name;
71
72typedef enum {
73 RtemsReqIdent_Pre_Node_Local,
74 RtemsReqIdent_Pre_Node_Remote,
75 RtemsReqIdent_Pre_Node_Invalid,
76 RtemsReqIdent_Pre_Node_SearchAll,
77 RtemsReqIdent_Pre_Node_SearchOther,
78 RtemsReqIdent_Pre_Node_SearchLocal,
79 RtemsReqIdent_Pre_Node_NA
80} RtemsReqIdent_Pre_Node;
81
82typedef enum {
83 RtemsReqIdent_Pre_Id_Valid,
84 RtemsReqIdent_Pre_Id_Null,
85 RtemsReqIdent_Pre_Id_NA
86} RtemsReqIdent_Pre_Id;
87
88typedef enum {
89 RtemsReqIdent_Post_Status_Ok,
90 RtemsReqIdent_Post_Status_InvAddr,
91 RtemsReqIdent_Post_Status_InvName,
92 RtemsReqIdent_Post_Status_InvNode,
93 RtemsReqIdent_Post_Status_NA
94} RtemsReqIdent_Post_Status;
95
96typedef enum {
97 RtemsReqIdent_Post_Id_Nop,
98 RtemsReqIdent_Post_Id_Null,
99 RtemsReqIdent_Post_Id_LocalObj,
100 RtemsReqIdent_Post_Id_RemoteObj,
101 RtemsReqIdent_Post_Id_NA
102} RtemsReqIdent_Post_Id;
103
116 rtems_id id_local_object,
117 rtems_name name_local_object,
118 rtems_status_code ( *action )( rtems_name, uint32_t, rtems_id * )
119);
120
123#ifdef __cplusplus
124}
125#endif
126
127#endif /* _TR_OBJECT_IDENT_H */
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
void RtemsReqIdent_Run(rtems_id id_local_object, rtems_name name_local_object, rtems_status_code(*action)(rtems_name, uint32_t, rtems_id *))
Runs the parameterized test case.
Definition: tr-object-ident.c:462
