RTEMS 6.1-rc1
tr-object-ident-local.h
2
9/*
10 * Copyright (C) 2020 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/*
35 * This file is part of the RTEMS quality process and was automatically
36 * generated. If you find something that needs to be fixed or
37 * worded better please post a report or patch to an RTEMS mailing list
38 * or raise a bug report:
39 *
40 * https://www.rtems.org/bugs.html
41 *
42 * For information on updating and regenerating please refer to the How-To
43 * section in the Software Requirements Engineering chapter of the
44 * RTEMS Software Engineering manual. The manual is provided as a part of
45 * a release. For development sources please refer to the online
46 * documentation at:
47 *
48 * https://docs.rtems.org
49 */
50
51#ifndef _TR_OBJECT_IDENT_LOCAL_H
52#define _TR_OBJECT_IDENT_LOCAL_H
53
54#include <rtems.h>
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
66typedef enum {
67 RtemsReqIdentLocal_Pre_Name_Invalid,
68 RtemsReqIdentLocal_Pre_Name_Valid,
69 RtemsReqIdentLocal_Pre_Name_NA
70} RtemsReqIdentLocal_Pre_Name;
71
72typedef enum {
73 RtemsReqIdentLocal_Pre_Id_Valid,
74 RtemsReqIdentLocal_Pre_Id_Null,
75 RtemsReqIdentLocal_Pre_Id_NA
76} RtemsReqIdentLocal_Pre_Id;
77
78typedef enum {
79 RtemsReqIdentLocal_Post_Status_Ok,
80 RtemsReqIdentLocal_Post_Status_InvAddr,
81 RtemsReqIdentLocal_Post_Status_InvName,
82 RtemsReqIdentLocal_Post_Status_NA
83} RtemsReqIdentLocal_Post_Status;
84
85typedef enum {
86 RtemsReqIdentLocal_Post_Id_Nop,
87 RtemsReqIdentLocal_Post_Id_Null,
88 RtemsReqIdentLocal_Post_Id_Id,
89 RtemsReqIdentLocal_Post_Id_NA
90} RtemsReqIdentLocal_Post_Id;
91
104 rtems_id id_local_object,
105 rtems_name name_local_object,
106 rtems_status_code ( *action )( rtems_name, rtems_id * )
107);
108
111#ifdef __cplusplus
112}
113#endif
114
115#endif /* _TR_OBJECT_IDENT_LOCAL_H */
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
void RtemsReqIdentLocal_Run(rtems_id id_local_object, rtems_name name_local_object, rtems_status_code(*action)(rtems_name, rtems_id *))
Runs the parameterized test case.
Definition: tr-object-ident-local.c:358
