51#ifndef _TR_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER_H
52#define _TR_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER_H
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition: extension.h:161
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
void ScoreSmpValFatalBootProcessorNotAssignedToScheduler_Run(rtems_fatal_source source, rtems_fatal_code code)
Runs the parameterized test case.
Definition: tr-fatal-boot-processor-not-assigned-to-scheduler.c:136
Definition: inftrees.h:24
