RTEMS 6.1-rc1
threadsup.h
2
11/*
12 * COPYRIGHT (c) 1989-2014.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_POSIX_THREADSUP_H
38#define _RTEMS_POSIX_THREADSUP_H
39
40#include <rtems/score/thread.h>
42
43#include <pthread.h>
44#include <signal.h>
45
53#ifdef __cplusplus
54extern "C" {
55#endif
56
57#if defined(RTEMS_POSIX_API)
62typedef struct {
66 struct {
68 Thread_Control *thread;
69
74 Watchdog_Control Timer;
75
80 Priority_Node Low_priority;
81
85 struct timespec sched_ss_repl_period;
86
90 struct timespec sched_ss_init_budget;
91
97 int sched_ss_max_repl;
98 } Sporadic;
99
101 sigset_t signals_unblocked;
103 sigset_t signals_pending;
104
108 Thread_Action Signal_action;
109} POSIX_API_Control;
110#endif
111
114#ifdef __cplusplus
115}
116#endif
117
118#endif
119/* end of include file */
This header file provides interfaces of the Watchdog Handler which are used by the implementation and...
POSIX Threads Private Support.
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
The priority node to build up a priority aggregation.
Definition: priority.h:112
Thread action.
Definition: thread.h:681
The control block used to manage each watchdog timer.
Definition: watchdog.h:109
Definition: thread.h:812
