RTEMS 6.1-rc1
Helper file to verify the requirements towards the basedefs. More...
#include "tc-basedefs-pendant.h"
#define | __USER_LABEL_PREFIX__ SyMbOl_ |
#define | SyMbOl_symbol_id prefix_symbol_id |
#define | SYMBOL_NAME symbol_name |
uintptr_t | basedefs_get_global_symbol (void) |
int | basedefs_use_prefixed_symbol_name (void) |
int | basedefs_use_prefixed_upper_symbol_name (void) |
int | basedefs_use_prefixed_symbol_id (void) |
int | basedefs_weak_alias_1_func (int i) |
int | basedefs_weak_1_func (void) |
void * | basedefs_alloc_align_func (size_t size, void **p, size_t alignment) |
void * | basedefs_alloc_size_func (size_t size) |
void * | basedefs_alloc_size_2_func (size_t size0, size_t size1) |
void | basedefs_free (void *ptr) |
const volatile int | basedefs_weak_1_var = 62 |
The specification items in (rtems-central/)spec/rtems/basedefs/req/[*] represent requirements towards the basedefs in (rtems/)cpukit/include/rtems/score/basedefs.h. There are automated verification tests generated from (rtems-central/)spec/rtems/basedefs/val/[*] and placed in (rtems/)testsuites/validation/tc-basedefs-0.c.
Yet, not every test can be placed in the same compilation unit (tc-basedefs-0.c). Hence, the code which must be placed in an extra compilation unit is put here and this file is linked to tc-basedefs-0.c to be accessible from the tests.
