RTEMS 6.1-rc1
symbols.h
2
11/*
12 * COPYRIGHT (c) 1989-2022. On-Line Applications Research Corporation (OAR).
13 *
16 * are met:
22 *
34 */
35
36#ifndef _INCLUDE_SYMBOLS_H
37#define _INCLUDE_SYMBOLS_H
38
39#include <rtems/monitor.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
46 uint32_t value;
47 char *name;
48} ;
49
50#define SYMBOL_STRING_BLOCK_SIZE 4080
52 struct rtems_symbol_string_block_s *next;
53 char buffer[SYMBOL_STRING_BLOCK_SIZE];
55
57
58 uint32_t sorted; /* are symbols sorted right now? */
59 uint32_t growth_factor; /* % to grow by when needed */
60 uint32_t next; /* next symbol slot to use when adding */
61 uint32_t size; /* max # of symbols */
62
63 /*
64 * Symbol list -- sorted by address (when we do a lookup)
65 */
66
67 rtems_symbol_t *addresses; /* symbol array by address */
68
69 /*
70 * String pool, unsorted, a list of blocks of string data
71 */
72
73 rtems_symbol_string_block_t *string_buffer_head;
74 rtems_symbol_string_block_t *string_buffer_current;
75 uint32_t strings_next; /* next byte to use in this block */
76
77} ;
78
79#define rtems_symbol_name(sp) ((sp)->name)
80#define rtems_symbol_value(sp) ((sp)->value)
81
82#ifdef __cplusplus
83}
84#endif
85
86#endif /* ! _INCLUDE_SYMBOLS_H */
The RTEMS Monitor Task.
Definition: symbols.h:45
Definition: symbols.h:56
Definition: symbols.h:51
