RTEMS 6.1-rc1
Public Member Functions | |
SPIN_DECLARE (devlock) | |
Data Fields | |
struct drvmgr_dev * | dev |
char | devName [52] |
pelican_regs * | regs |
int | byte_regs |
int | irq |
occan_speed_regs | timing |
int | channel |
int | single_mode |
unsigned int | sys_freq_hz |
rtems_id | devsem |
rtems_id | txsem |
rtems_id | rxsem |
int | open |
int | started |
int | rxblk |
int | txblk |
int | sending |
unsigned int | status |
occan_stats | stats |
occan_fifo * | rxfifo |
occan_fifo * | txfifo |
unsigned int | speed |
unsigned char | acode [4] |
unsigned char | amask [4] |
