RTEMS 6.1-rc1
Data Fields | |
struct drvmgr_dev * | dev |
struct grpci_regs * | regs |
int | irq |
int | minor |
uint32_t | bar1_pci_adr |
uint32_t | bar1_size |
int | bt_enabled |
unsigned int | pci_area |
unsigned int | pci_area_end |
unsigned int | pci_io |
unsigned int | pci_conf |
unsigned int | pci_conf_end |
uint32_t | devVend |
struct drvmgr_map_entry | maps_up [2] |
struct drvmgr_map_entry | maps_down [2] |
struct pcibus_config | config |
