RTEMS 6.1-rc1
FMC Low Layer HAL module driver. More...
#include "stm32h7xx_hal.h"
============================================================================== ##### FMC peripheral features ##### ============================================================================== [..] The Flexible memory controller (FMC) includes following memory controllers: (+) The NOR/PSRAM memory controller (+) The NAND memory controller (+) The Synchronous DRAM (SDRAM) controller [..] The FMC functional block makes the interface with synchronous and asynchronous static memories and SDRAM memories. Its main purposes are: (+) to translate AHB transactions into the appropriate external device protocol (+) to meet the access time requirements of the external memory devices [..] All external memories share the addresses, data and control signals with the controller. Each external device is accessed by means of a unique Chip Select. The FMC performs only one access at a time to an external device. The main features of the FMC controller are the following: (+) Interface with static-memory mapped devices including: (++) Static random access memory (SRAM) (++) Read-only memory (ROM) (++) NOR Flash memory/OneNAND Flash memory (++) PSRAM (4 memory banks) (++) Two banks of NAND Flash memory with ECC hardware to check up to 8 Kbytes of data (+) Interface with synchronous DRAM (SDRAM) memories (+) Independent Chip Select control for each memory bank (+) Independent configuration for each memory bank
