RTEMS 6.1-rc1
stm32h7xx_hal_uart_ex.c File Reference
Extended UART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Asynchronous Receiver Transmitter Peripheral (UART). More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • Peripheral Control functions
Attention
             ##### UART peripheral extended features  #####
  (#) Declare a UART_HandleTypeDef handle structure.
  (#) For the UART RS485 Driver Enable mode, initialize the UART registers
      by calling the HAL_RS485Ex_Init() API.
  (#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming.
      -@- When UART operates in FIFO mode, FIFO mode must be enabled prior
          starting RX/TX transfers. Also RX/TX FIFO thresholds must be
          configured prior starting RX/TX transfers.
