RTEMS 6.1-rc1
UART HAL module driver. This file provides firmware functions to manage the following functionalities of the Universal Asynchronous Receiver Transmitter Peripheral (UART). More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### How to use this driver ##### =============================================================================== [..] The UART HAL driver can be used as follows: (#) Declare a UART_HandleTypeDef handle structure (eg. UART_HandleTypeDef huart). (#) Initialize the UART low level resources by implementing the HAL_UART_MspInit() API: (++) Enable the USARTx interface clock. (++) UART pins configuration: (+++) Enable the clock for the UART GPIOs. (+++) Configure these UART pins as alternate function pull-up. (++) NVIC configuration if you need to use interrupt process (HAL_UART_Transmit_IT() and HAL_UART_Receive_IT() APIs): (+++) Configure the USARTx interrupt priority. (+++) Enable the NVIC USART IRQ handle. (++) UART interrupts handling: -@@- The specific UART interrupts (Transmission complete interrupt, RXNE interrupt, RX/TX FIFOs related interrupts and Error Interrupts) are managed using the macros __HAL_UART_ENABLE_IT() and __HAL_UART_DISABLE_IT() inside the transmit and receive processes. (++) DMA Configuration if you need to use DMA process (HAL_UART_Transmit_DMA() and HAL_UART_Receive_DMA() APIs): (+++) Declare a DMA handle structure for the Tx/Rx channel. (+++) Enable the DMAx interface clock. (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters. (+++) Configure the DMA Tx/Rx channel. (+++) Associate the initialized DMA handle to the UART DMA Tx/Rx handle. (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx/Rx channel. (#) Program the Baud Rate, Word Length, Stop Bit, Parity, Prescaler value , Hardware flow control and Mode (Receiver/Transmitter) in the huart handle Init structure. (#) If required, program UART advanced features (TX/RX pins swap, auto Baud rate detection,...) in the huart handle AdvancedInit structure. (#) For the UART asynchronous mode, initialize the UART registers by calling the HAL_UART_Init() API. (#) For the UART Half duplex mode, initialize the UART registers by calling the HAL_HalfDuplex_Init() API. (#) For the UART LIN (Local Interconnection Network) mode, initialize the UART registers by calling the HAL_LIN_Init() API. (#) For the UART Multiprocessor mode, initialize the UART registers by calling the HAL_MultiProcessor_Init() API. (#) For the UART RS485 Driver Enabled mode, initialize the UART registers by calling the HAL_RS485Ex_Init() API. [..] (@) These API's (HAL_UART_Init(), HAL_HalfDuplex_Init(), HAL_LIN_Init(), HAL_MultiProcessor_Init(), also configure the low level Hardware GPIO, CLOCK, CORTEX...etc) by calling the customized HAL_UART_MspInit() API. ##### Callback registration ##### ================================== [..] The compilation define USE_HAL_UART_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. [..] Use Function HAL_UART_RegisterCallback() to register a user callback. Function HAL_UART_RegisterCallback() allows to register following callbacks: (+) TxHalfCpltCallback : Tx Half Complete Callback. (+) TxCpltCallback : Tx Complete Callback. (+) RxHalfCpltCallback : Rx Half Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback. (+) AbortReceiveCpltCallback : Abort Receive Complete Callback. (+) WakeupCallback : Wakeup Callback. (+) RxFifoFullCallback : Rx Fifo Full Callback. (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) MspInitCallback : UART MspInit. (+) MspDeInitCallback : UART MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function HAL_UART_UnRegisterCallback() to reset a callback to the default weak (surcharged) function. HAL_UART_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxHalfCpltCallback : Tx Half Complete Callback. (+) TxCpltCallback : Tx Complete Callback. (+) RxHalfCpltCallback : Rx Half Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback. (+) AbortReceiveCpltCallback : Abort Receive Complete Callback. (+) WakeupCallback : Wakeup Callback. (+) RxFifoFullCallback : Rx Fifo Full Callback. (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) MspInitCallback : UART MspInit. (+) MspDeInitCallback : UART MspDeInit. [..] For specific callback RxEventCallback, use dedicated registration/reset functions: respectively HAL_UART_RegisterRxEventCallback() , HAL_UART_UnRegisterRxEventCallback(). [..] By default, after the HAL_UART_Init() and when the state is HAL_UART_STATE_RESET all callbacks are set to the corresponding weak (surcharged) functions: examples HAL_UART_TxCpltCallback(), HAL_UART_RxHalfCpltCallback(). Exception done for MspInit and MspDeInit functions that are respectively reset to the legacy weak (surcharged) functions in the HAL_UART_Init() and HAL_UART_DeInit() only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_UART_Init() and HAL_UART_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in HAL_UART_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_UART_STATE_READY or HAL_UART_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_UART_RegisterCallback() before calling HAL_UART_DeInit() or HAL_UART_Init() function. [..] When The compilation define USE_HAL_UART_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and weak (surcharged) callbacks are used.
