RTEMS 6.1-rc1
stm32h7xx_hal_tim.c File Reference
TIM HAL module driver. This file provides firmware functions to manage the following functionalities of the Timer (TIM) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • TIM Time Base Initialization
  • TIM Time Base Start
  • TIM Time Base Start Interruption
  • TIM Time Base Start DMA
  • TIM Output Compare/PWM Initialization
  • TIM Output Compare/PWM Channel Configuration
  • TIM Output Compare/PWM Start
  • TIM Output Compare/PWM Start Interruption
  • TIM Output Compare/PWM Start DMA
  • TIM Input Capture Initialization
  • TIM Input Capture Channel Configuration
  • TIM Input Capture Start
  • TIM Input Capture Start Interruption
  • TIM Input Capture Start DMA
  • TIM One Pulse Initialization
  • TIM One Pulse Channel Configuration
  • TIM One Pulse Start
  • TIM Encoder Interface Initialization
  • TIM Encoder Interface Start
  • TIM Encoder Interface Start Interruption
  • TIM Encoder Interface Start DMA
  • Commutation Event configuration with Interruption and DMA
  • TIM OCRef clear configuration
  • TIM External Clock configuration
Attention
                      ##### TIMER Generic features #####
  [..] The Timer features include:
       (#) 16-bit up, down, up/down auto-reload counter.
       (#) 16-bit programmable prescaler allowing dividing (also on the fly) the
           counter clock frequency either by any factor between 1 and 65536.
       (#) Up to 4 independent channels for:
           (++) Input Capture
           (++) Output Compare
           (++) PWM generation (Edge and Center-aligned Mode)
           (++) One-pulse mode output
       (#) Synchronization circuit to control the timer with external signals and to interconnect
            several timers together.
       (#) Supports incremental encoder for positioning purposes
            ##### How to use this driver #####
     (#) Initialize the TIM low level resources by implementing the following functions
         depending on the selected feature:
           (++) Time Base : HAL_TIM_Base_MspInit()
           (++) Input Capture : HAL_TIM_IC_MspInit()
           (++) Output Compare : HAL_TIM_OC_MspInit()
           (++) PWM generation : HAL_TIM_PWM_MspInit()
           (++) One-pulse mode output : HAL_TIM_OnePulse_MspInit()
           (++) Encoder mode output : HAL_TIM_Encoder_MspInit()
     (#) Initialize the TIM low level resources :
        (##) Enable the TIM interface clock using __HAL_RCC_TIMx_CLK_ENABLE();
        (##) TIM pins configuration
            (+++) Enable the clock for the TIM GPIOs using the following function:
             __HAL_RCC_GPIOx_CLK_ENABLE();
            (+++) Configure these TIM pins in Alternate function mode using HAL_GPIO_Init();
     (#) The external Clock can be configured, if needed (the default clock is the
         internal clock from the APBx), using the following function:
         HAL_TIM_ConfigClockSource, the clock configuration should be done before
         any start function.
     (#) Configure the TIM in the desired functioning mode using one of the
       Initialization function of this driver:
       (++) HAL_TIM_Base_Init: to use the Timer to generate a simple time base
       (++) HAL_TIM_OC_Init and HAL_TIM_OC_ConfigChannel: to use the Timer to generate an
            Output Compare signal.
       (++) HAL_TIM_PWM_Init and HAL_TIM_PWM_ConfigChannel: to use the Timer to generate a
            PWM signal.
       (++) HAL_TIM_IC_Init and HAL_TIM_IC_ConfigChannel: to use the Timer to measure an
            external signal.
       (++) HAL_TIM_OnePulse_Init and HAL_TIM_OnePulse_ConfigChannel: to use the Timer
            in One Pulse Mode.
       (++) HAL_TIM_Encoder_Init: to use the Timer Encoder Interface.
     (#) Activate the TIM peripheral using one of the start functions depending from the feature used:
           (++) Time Base : HAL_TIM_Base_Start(), HAL_TIM_Base_Start_DMA(), HAL_TIM_Base_Start_IT()
           (++) Input Capture :  HAL_TIM_IC_Start(), HAL_TIM_IC_Start_DMA(), HAL_TIM_IC_Start_IT()
           (++) Output Compare : HAL_TIM_OC_Start(), HAL_TIM_OC_Start_DMA(), HAL_TIM_OC_Start_IT()
           (++) PWM generation : HAL_TIM_PWM_Start(), HAL_TIM_PWM_Start_DMA(), HAL_TIM_PWM_Start_IT()
           (++) One-pulse mode output : HAL_TIM_OnePulse_Start(), HAL_TIM_OnePulse_Start_IT()
           (++) Encoder mode output : HAL_TIM_Encoder_Start(), HAL_TIM_Encoder_Start_DMA(), HAL_TIM_Encoder_Start_IT().
     (#) The DMA Burst is managed with the two following functions:
         HAL_TIM_DMABurst_WriteStart()
         HAL_TIM_DMABurst_ReadStart()
    *** Callback registration ***
  The compilation define  USE_HAL_TIM_REGISTER_CALLBACKS when set to 1
  allows the user to configure dynamically the driver callbacks.
  Use Function HAL_TIM_RegisterCallback() to register a callback.
  HAL_TIM_RegisterCallback() takes as parameters the HAL peripheral handle,
  the Callback ID and a pointer to the user callback function.
  Use function HAL_TIM_UnRegisterCallback() to reset a callback to the default
  weak function.
  HAL_TIM_UnRegisterCallback takes as parameters the HAL peripheral handle,
  and the Callback ID.
  These functions allow to register/unregister following callbacks:
    (+) Base_MspInitCallback              : TIM Base Msp Init Callback.
    (+) Base_MspDeInitCallback            : TIM Base Msp DeInit Callback.
    (+) IC_MspInitCallback                : TIM IC Msp Init Callback.
    (+) IC_MspDeInitCallback              : TIM IC Msp DeInit Callback.
    (+) OC_MspInitCallback                : TIM OC Msp Init Callback.
    (+) OC_MspDeInitCallback              : TIM OC Msp DeInit Callback.
    (+) PWM_MspInitCallback               : TIM PWM Msp Init Callback.
    (+) PWM_MspDeInitCallback             : TIM PWM Msp DeInit Callback.
    (+) OnePulse_MspInitCallback          : TIM One Pulse Msp Init Callback.
    (+) OnePulse_MspDeInitCallback        : TIM One Pulse Msp DeInit Callback.
    (+) Encoder_MspInitCallback           : TIM Encoder Msp Init Callback.
    (+) Encoder_MspDeInitCallback         : TIM Encoder Msp DeInit Callback.
    (+) HallSensor_MspInitCallback        : TIM Hall Sensor Msp Init Callback.
    (+) HallSensor_MspDeInitCallback      : TIM Hall Sensor Msp DeInit Callback.
    (+) PeriodElapsedCallback             : TIM Period Elapsed Callback.
    (+) PeriodElapsedHalfCpltCallback     : TIM Period Elapsed half complete Callback.
    (+) TriggerCallback                   : TIM Trigger Callback.
    (+) TriggerHalfCpltCallback           : TIM Trigger half complete Callback.
    (+) IC_CaptureCallback                : TIM Input Capture Callback.
    (+) IC_CaptureHalfCpltCallback        : TIM Input Capture half complete Callback.
    (+) OC_DelayElapsedCallback           : TIM Output Compare Delay Elapsed Callback.
    (+) PWM_PulseFinishedCallback         : TIM PWM Pulse Finished Callback.
    (+) PWM_PulseFinishedHalfCpltCallback : TIM PWM Pulse Finished half complete Callback.
    (+) ErrorCallback                     : TIM Error Callback.
    (+) CommutationCallback               : TIM Commutation Callback.
    (+) CommutationHalfCpltCallback       : TIM Commutation half complete Callback.
    (+) BreakCallback                     : TIM Break Callback.
    (+) Break2Callback                    : TIM Break2 Callback.
By default, after the Init and when the state is HAL_TIM_STATE_RESET
all interrupt callbacks are set to the corresponding weak functions:
  examples HAL_TIM_TriggerCallback(), HAL_TIM_ErrorCallback().
  Exception done for MspInit and MspDeInit functions that are reset to the legacy weak
  functionalities in the Init / DeInit only when these callbacks are null
  (not registered beforehand). If not, MspInit or MspDeInit are not null, the Init / DeInit
    keep and use the user MspInit / MspDeInit callbacks(registered beforehand)
    Callbacks can be registered / unregistered in HAL_TIM_STATE_READY state only.
    Exception done MspInit / MspDeInit that can be registered / unregistered
    in HAL_TIM_STATE_READY or HAL_TIM_STATE_RESET state,
    thus registered(user) MspInit / DeInit callbacks can be used during the Init / DeInit.
  In that case first register the MspInit/MspDeInit user callbacks
      using HAL_TIM_RegisterCallback() before calling DeInit or Init function.
      When The compilation define USE_HAL_TIM_REGISTER_CALLBACKS is set to 0 or
      not defined, the callback registration feature is not available and all callbacks
      are set to the corresponding weak functions.
