RTEMS 6.1-rc1
SWPMI HAL module driver. This file provides firmware functions to manage the following functionalities of the Single Wire Protocol Master Interface (SWPMI). More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### How to use this driver ##### =============================================================================== [..] The SWPMI HAL driver can be used as follows: (#) Declare a SWPMI_HandleTypeDef handle structure (eg. SWPMI_HandleTypeDef hswpmi). (#) Initialize the SWPMI low level resources by implementing the HAL_SWPMI_MspInit() API: (##) Enable the SWPMIx interface clock with __HAL_RCC_SWPMIx_CLK_ENABLE(). (##) SWPMI IO configuration: (+++) Enable the clock for the SWPMI GPIO. (+++) Configure these SWPMI pins as alternate function pull-up. (##) NVIC configuration if you need to use interrupt process (HAL_SWPMI_Transmit_IT() and HAL_SWPMI_Receive_IT() APIs): (+++) Configure the SWPMIx interrupt priority with HAL_NVIC_SetPriority(). (+++) Enable the NVIC SWPMI IRQ handle with HAL_NVIC_EnableIRQ(). (##) DMA Configuration if you need to use DMA process (HAL_SWPMI_Transmit_DMA() and HAL_SWPMI_Receive_DMA() APIs): (+++) Declare a DMA handle structure for the Tx/Rx streams. (+++) Enable the DMAx interface clock. (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters. (+++) Configure the DMA Tx/Rx streams and requests. (+++) Associate the initialized DMA handle to the SWPMI DMA Tx/Rx handle. (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx/Rx streams. (#) Program the Bite Rate, Tx Buffering mode, Rx Buffering mode in the Init structure. (#) Enable the SWPMI peripheral by calling the HAL_SWPMI_Init() function. [..] Three operation modes are available within this driver : *** Polling mode IO operation *** ================================= [..] (+) Send an amount of data in blocking mode using HAL_SWPMI_Transmit() (+) Receive an amount of data in blocking mode using HAL_SWPMI_Receive() *** Interrupt mode IO operation *** =================================== [..] (+) Send an amount of data in non-blocking mode using HAL_SWPMI_Transmit_IT() (+) At transmission end of transfer HAL_SWPMI_TxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SWPMI_TxCpltCallback() (+) Receive an amount of data in non-blocking mode using HAL_SWPMI_Receive_IT() (+) At reception end of transfer HAL_SWPMI_RxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SWPMI_RxCpltCallback() (+) In case of flag error, HAL_SWPMI_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_SWPMI_ErrorCallback() *** DMA mode IO operation *** ============================= [..] (+) Send an amount of data in non-blocking mode (DMA) using HAL_SWPMI_Transmit_DMA() (+) At transmission end of transfer HAL_SWPMI_TxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SWPMI_TxCpltCallback() (+) Receive an amount of data in non-blocking mode (DMA) using HAL_SWPMI_Receive_DMA() (+) At reception end of transfer HAL_SWPMI_RxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SWPMI_RxCpltCallback() (+) In case of flag error, HAL_SWPMI_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_SWPMI_ErrorCallback() (+) Stop the DMA Transfer using HAL_SWPMI_DMAStop() *** SWPMI HAL driver additional function list *** =============================================== [..] Below the list the others API available SWPMI HAL driver : (+) HAL_SWPMI_EnableLoopback(): Enable the loopback mode for test purpose only (+) HAL_SWPMI_DisableLoopback(): Disable the loopback mode *** SWPMI HAL driver macros list *** ================================== [..] Below the list of most used macros in SWPMI HAL driver : (+) __HAL_SWPMI_ENABLE(): Enable the SWPMI peripheral (+) __HAL_SWPMI_DISABLE(): Disable the SWPMI peripheral (+) __HAL_SWPMI_TRANSCEIVER_ENABLE(): Enable the SWPMI peripheral transceiver (+) __HAL_SWPMI_TRANSCEIVER_DISABLE(): Disable the SWPMI peripheral transceiver (+) __HAL_SWPMI_ENABLE_IT(): Enable the specified SWPMI interrupts (+) __HAL_SWPMI_DISABLE_IT(): Disable the specified SWPMI interrupts (+) __HAL_SWPMI_GET_IT_SOURCE(): Check if the specified SWPMI interrupt source is enabled or disabled (+) __HAL_SWPMI_GET_FLAG(): Check whether the specified SWPMI flag is set or not *** Callback registration *** ============================= [..] The compilation define USE_HAL_SWPMI_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. [..] Use function HAL_SWPMI_RegisterCallback() to register a user callback. It allows to register the following callbacks: (+) RxCpltCallback : SWPMI receive complete. (+) RxHalfCpltCallback : SWPMI receive half complete. (+) TxCpltCallback : SWPMI transmit complete. (+) TxHalfCpltCallback : SWPMI transmit half complete. (+) ErrorCallback : SWPMI error. (+) MspInitCallback : SWPMI MspInit. (+) MspDeInitCallback : SWPMI MspDeInit. [..] This function takes as parameters the HAL peripheral handle, the callback ID and a pointer to the user callback function. [..] Use function HAL_SWPMI_UnRegisterCallback() to reset a callback to the default weak (surcharged) function. HAL_SWPMI_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the callback ID. This function allows to reset following callbacks: (+) RxCpltCallback : SWPMI receive complete. (+) RxHalfCpltCallback : SWPMI receive half complete. (+) TxCpltCallback : SWPMI transmit complete. (+) TxHalfCpltCallback : SWPMI transmit half complete. (+) ErrorCallback : SWPMI error. (+) MspInitCallback : SWPMI MspInit. (+) MspDeInitCallback : SWPMI MspDeInit. [..] By default, after the HAL_SWPMI_Init and if the state is HAL_SWPMI_STATE_RESET all callbacks are reset to the corresponding legacy weak (surcharged) functions: examples HAL_SWPMI_RxCpltCallback(), HAL_SWPMI_ErrorCallback(). Exception done for MspInit and MspDeInit callbacks that are respectively reset to the legacy weak (surcharged) functions in the HAL_SWPMI_Init and HAL_SWPMI_DeInit only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_SWPMI_Init and HAL_SWPMI_DeInit keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in READY state only. Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_SWPMI_RegisterCallback before calling HAL_SWPMI_DeInit or HAL_SWPMI_Init function. [..] When the compilation define USE_HAL_SWPMI_REGISTER_CALLBACKS is set to 0 or not defined, the callback registering feature is not available and weak (surcharged) callbacks are used.
