RTEMS 6.1-rc1
This file provides firmware functions to manage the following functionalities of the SPDIFRX audio interface: More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### How to use this driver ##### =============================================================================== [..] The SPDIFRX HAL driver can be used as follow: (#) Declare SPDIFRX_HandleTypeDef handle structure. (#) Initialize the SPDIFRX low level resources by implement the HAL_SPDIFRX_MspInit() API: (##) Enable the SPDIFRX interface clock. (##) SPDIFRX pins configuration: (+++) Enable the clock for the SPDIFRX GPIOs. (+++) Configure these SPDIFRX pins as alternate function pull-up. (##) NVIC configuration if you need to use interrupt process (HAL_SPDIFRX_ReceiveCtrlFlow_IT() and HAL_SPDIFRX_ReceiveDataFlow_IT() API's). (+++) Configure the SPDIFRX interrupt priority. (+++) Enable the NVIC SPDIFRX IRQ handle. (##) DMA Configuration if you need to use DMA process (HAL_SPDIFRX_ReceiveDataFlow_DMA() and HAL_SPDIFRX_ReceiveCtrlFlow_DMA() API's). (+++) Declare a DMA handle structure for the reception of the Data Flow channel. (+++) Declare a DMA handle structure for the reception of the Control Flow channel. (+++) Enable the DMAx interface clock. (+++) Configure the declared DMA handle structure CtrlRx/DataRx with the required parameters. (+++) Configure the DMA Channel. (+++) Associate the initialized DMA handle to the SPDIFRX DMA CtrlRx/DataRx handle. (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA CtrlRx/DataRx channel. (#) Program the input selection, re-tries number, wait for activity, channel status selection, data format, stereo mode and masking of user bits using HAL_SPDIFRX_Init() function. -@- The specific SPDIFRX interrupts (RXNE/CSRNE and Error Interrupts) will be managed using the macros __SPDIFRX_ENABLE_IT() and __SPDIFRX_DISABLE_IT() inside the receive process. -@- Make sure that ck_spdif clock is configured. (#) Three operation modes are available within this driver : *** Polling mode for reception operation (for debug purpose) *** ================================================================ [..] (+) Receive data flow in blocking mode using HAL_SPDIFRX_ReceiveDataFlow() (+) Receive control flow of data in blocking mode using HAL_SPDIFRX_ReceiveCtrlFlow() *** Interrupt mode for reception operation *** ========================================= [..] (+) Receive an amount of data (Data Flow) in non blocking mode using HAL_SPDIFRX_ReceiveDataFlow_IT() (+) Receive an amount of data (Control Flow) in non blocking mode using HAL_SPDIFRX_ReceiveCtrlFlow_IT() (+) At reception end of half transfer HAL_SPDIFRX_RxHalfCpltCallback is executed and user can add his own code by customization of function pointer HAL_SPDIFRX_RxHalfCpltCallback (+) At reception end of transfer HAL_SPDIFRX_RxCpltCallback is executed and user can add his own code by customization of function pointer HAL_SPDIFRX_RxCpltCallback (+) In case of transfer Error, HAL_SPDIFRX_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_SPDIFRX_ErrorCallback *** DMA mode for reception operation *** ======================================== [..] (+) Receive an amount of data (Data Flow) in non blocking mode (DMA) using HAL_SPDIFRX_ReceiveDataFlow_DMA() (+) Receive an amount of data (Control Flow) in non blocking mode (DMA) using HAL_SPDIFRX_ReceiveCtrlFlow_DMA() (+) At reception end of half transfer HAL_SPDIFRX_RxHalfCpltCallback is executed and user can add his own code by customization of function pointer HAL_SPDIFRX_RxHalfCpltCallback (+) At reception end of transfer HAL_SPDIFRX_RxCpltCallback is executed and user can add his own code by customization of function pointer HAL_SPDIFRX_RxCpltCallback (+) In case of transfer Error, HAL_SPDIFRX_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_SPDIFRX_ErrorCallback (+) Stop the DMA Transfer using HAL_SPDIFRX_DMAStop() *** SPDIFRX HAL driver macros list *** ============================================= [..] Below the list of most used macros in SPDIFRX HAL driver. (+) __HAL_SPDIFRX_IDLE: Disable the specified SPDIFRX peripheral (IDEL State) (+) __HAL_SPDIFRX_SYNC: Enable the synchronization state of the specified SPDIFRX peripheral (SYNC State) (+) __HAL_SPDIFRX_RCV: Enable the receive state of the specified SPDIFRX peripheral (RCV State) (+) __HAL_SPDIFRX_ENABLE_IT : Enable the specified SPDIFRX interrupts (+) __HAL_SPDIFRX_DISABLE_IT : Disable the specified SPDIFRX interrupts (+) __HAL_SPDIFRX_GET_FLAG: Check whether the specified SPDIFRX flag is set or not. [..] (@) You can refer to the SPDIFRX HAL driver header file for more useful macros *** Callback registration *** ============================================= The compilation define USE_HAL_SPDIFRX_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use HAL_SPDIFRX_RegisterCallback() function to register an interrupt callback. The HAL_SPDIFRX_RegisterCallback() function allows to register the following callbacks: (+) RxHalfCpltCallback : SPDIFRX Data flow half completed callback. (+) RxCpltCallback : SPDIFRX Data flow completed callback. (+) CxHalfCpltCallback : SPDIFRX Control flow half completed callback. (+) CxCpltCallback : SPDIFRX Control flow completed callback. (+) ErrorCallback : SPDIFRX error callback. (+) MspInitCallback : SPDIFRX MspInit. (+) MspDeInitCallback : SPDIFRX MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. Use HAL_SPDIFRX_UnRegisterCallback() function to reset a callback to the default weak function. The HAL_SPDIFRX_UnRegisterCallback() function takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset the following callbacks: (+) RxHalfCpltCallback : SPDIFRX Data flow half completed callback. (+) RxCpltCallback : SPDIFRX Data flow completed callback. (+) CxHalfCpltCallback : SPDIFRX Control flow half completed callback. (+) CxCpltCallback : SPDIFRX Control flow completed callback. (+) ErrorCallback : SPDIFRX error callback. (+) MspInitCallback : SPDIFRX MspInit. (+) MspDeInitCallback : SPDIFRX MspDeInit. By default, after the HAL_SPDIFRX_Init() and when the state is HAL_SPDIFRX_STATE_RESET all callbacks are set to the corresponding weak functions : HAL_SPDIFRX_RxHalfCpltCallback() , HAL_SPDIFRX_RxCpltCallback(), HAL_SPDIFRX_CxHalfCpltCallback(), HAL_SPDIFRX_CxCpltCallback() and HAL_SPDIFRX_ErrorCallback() Exception done for MspInit and MspDeInit functions that are reset to the legacy weak function in the HAL_SPDIFRX_Init()/ HAL_SPDIFRX_DeInit() only when these callbacks pointers are NULL (not registered beforehand). If not, MspInit or MspDeInit callbacks pointers are not null, the HAL_SPDIFRX_Init() / HAL_SPDIFRX_DeInit() keep and use the user MspInit/MspDeInit functions (registered beforehand) Callbacks can be registered/unregistered in HAL_SPDIFRX_STATE_READY state only. Exception done MspInit/MspDeInit callbacks that can be registered/unregistered in HAL_SPDIFRX_STATE_READY or HAL_SPDIFRX_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_SPDIFRX_RegisterCallback() before calling HAL_SPDIFRX_DeInit() or HAL_SPDIFRX_Init() function. When The compilation define USE_HAL_SPDIFRX_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
