RTEMS 6.1-rc1
stm32h7xx_hal_smartcard_ex.c File Reference
SMARTCARD HAL module driver. This file provides extended firmware functions to manage the following functionalities of the SmartCard. More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • Peripheral Control functions
Attention
             ##### SMARTCARD peripheral extended features  #####
The Extended SMARTCARD HAL driver can be used as follows:
  (#) After having configured the SMARTCARD basic features with HAL_SMARTCARD_Init(),
      then program SMARTCARD advanced features if required (TX/RX pins swap, TimeOut,
      auto-retry counter,...) in the hsmartcard AdvancedInit structure.
  (#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming.
      -@- When SMARTCARD operates in FIFO mode, FIFO mode must be enabled prior
          starting RX/TX transfers. Also RX/TX FIFO thresholds must be
          configured prior starting RX/TX transfers.
