RTEMS 6.1-rc1
SMARTCARD HAL module driver. This file provides firmware functions to manage the following functionalities of the SMARTCARD peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The SMARTCARD HAL driver can be used as follows: (#) Declare a SMARTCARD_HandleTypeDef handle structure (eg. SMARTCARD_HandleTypeDef hsmartcard). (#) Associate a USART to the SMARTCARD handle hsmartcard. (#) Initialize the SMARTCARD low level resources by implementing the HAL_SMARTCARD_MspInit() API: (++) Enable the USARTx interface clock. (++) USART pins configuration: (+++) Enable the clock for the USART GPIOs. (+++) Configure the USART pins (TX as alternate function pull-up, RX as alternate function Input). (++) NVIC configuration if you need to use interrupt process (HAL_SMARTCARD_Transmit_IT() and HAL_SMARTCARD_Receive_IT() APIs): (+++) Configure the USARTx interrupt priority. (+++) Enable the NVIC USART IRQ handle. (++) DMA Configuration if you need to use DMA process (HAL_SMARTCARD_Transmit_DMA() and HAL_SMARTCARD_Receive_DMA() APIs): (+++) Declare a DMA handle structure for the Tx/Rx channel. (+++) Enable the DMAx interface clock. (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters. (+++) Configure the DMA Tx/Rx channel. (+++) Associate the initialized DMA handle to the SMARTCARD DMA Tx/Rx handle. (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx/Rx channel. (#) Program the Baud Rate, Parity, Mode(Receiver/Transmitter), clock enabling/disabling and accordingly, the clock parameters (parity, phase, last bit), prescaler value, guard time and NACK on transmission error enabling or disabling in the hsmartcard handle Init structure. (#) If required, program SMARTCARD advanced features (TX/RX pins swap, TimeOut, auto-retry counter,...) in the hsmartcard handle AdvancedInit structure. (#) Initialize the SMARTCARD registers by calling the HAL_SMARTCARD_Init() API: (++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc) by calling the customized HAL_SMARTCARD_MspInit() API. [..] (@) The specific SMARTCARD interrupts (Transmission complete interrupt, RXNE interrupt and Error Interrupts) will be managed using the macros __HAL_SMARTCARD_ENABLE_IT() and __HAL_SMARTCARD_DISABLE_IT() inside the transmit and receive process. [..] [..] Three operation modes are available within this driver : *** Polling mode IO operation *** ================================= [..] (+) Send an amount of data in blocking mode using HAL_SMARTCARD_Transmit() (+) Receive an amount of data in blocking mode using HAL_SMARTCARD_Receive() *** Interrupt mode IO operation *** =================================== [..] (+) Send an amount of data in non-blocking mode using HAL_SMARTCARD_Transmit_IT() (+) At transmission end of transfer HAL_SMARTCARD_TxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SMARTCARD_TxCpltCallback() (+) Receive an amount of data in non-blocking mode using HAL_SMARTCARD_Receive_IT() (+) At reception end of transfer HAL_SMARTCARD_RxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SMARTCARD_RxCpltCallback() (+) In case of transfer Error, HAL_SMARTCARD_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_SMARTCARD_ErrorCallback() *** DMA mode IO operation *** ============================== [..] (+) Send an amount of data in non-blocking mode (DMA) using HAL_SMARTCARD_Transmit_DMA() (+) At transmission end of transfer HAL_SMARTCARD_TxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SMARTCARD_TxCpltCallback() (+) Receive an amount of data in non-blocking mode (DMA) using HAL_SMARTCARD_Receive_DMA() (+) At reception end of transfer HAL_SMARTCARD_RxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_SMARTCARD_RxCpltCallback() (+) In case of transfer Error, HAL_SMARTCARD_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_SMARTCARD_ErrorCallback() *** SMARTCARD HAL driver macros list *** ======================================== [..] Below the list of most used macros in SMARTCARD HAL driver. (+) __HAL_SMARTCARD_GET_FLAG : Check whether or not the specified SMARTCARD flag is set (+) __HAL_SMARTCARD_CLEAR_FLAG : Clear the specified SMARTCARD pending flag (+) __HAL_SMARTCARD_ENABLE_IT: Enable the specified SMARTCARD interrupt (+) __HAL_SMARTCARD_DISABLE_IT: Disable the specified SMARTCARD interrupt (+) __HAL_SMARTCARD_GET_IT_SOURCE: Check whether or not the specified SMARTCARD interrupt is enabled [..] (@) You can refer to the SMARTCARD HAL driver header file for more useful macros ##### Callback registration ##### ================================== [..] The compilation define USE_HAL_SMARTCARD_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. [..] Use Function HAL_SMARTCARD_RegisterCallback() to register a user callback. Function HAL_SMARTCARD_RegisterCallback() allows to register following callbacks: (+) TxCpltCallback : Tx Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback. (+) AbortReceiveCpltCallback : Abort Receive Complete Callback. (+) RxFifoFullCallback : Rx Fifo Full Callback. (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) MspInitCallback : SMARTCARD MspInit. (+) MspDeInitCallback : SMARTCARD MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function HAL_SMARTCARD_UnRegisterCallback() to reset a callback to the default weak (surcharged) function. HAL_SMARTCARD_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxCpltCallback : Tx Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback. (+) AbortReceiveCpltCallback : Abort Receive Complete Callback. (+) RxFifoFullCallback : Rx Fifo Full Callback. (+) TxFifoEmptyCallback : Tx Fifo Empty Callback. (+) MspInitCallback : SMARTCARD MspInit. (+) MspDeInitCallback : SMARTCARD MspDeInit. [..] By default, after the HAL_SMARTCARD_Init() and when the state is HAL_SMARTCARD_STATE_RESET all callbacks are set to the corresponding weak (surcharged) functions: examples HAL_SMARTCARD_TxCpltCallback(), HAL_SMARTCARD_RxCpltCallback(). Exception done for MspInit and MspDeInit functions that are respectively reset to the legacy weak (surcharged) functions in the HAL_SMARTCARD_Init() and HAL_SMARTCARD_DeInit() only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_SMARTCARD_Init() and HAL_SMARTCARD_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in HAL_SMARTCARD_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_SMARTCARD_STATE_READY or HAL_SMARTCARD_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_SMARTCARD_RegisterCallback() before calling HAL_SMARTCARD_DeInit() or HAL_SMARTCARD_Init() function. [..] When The compilation define USE_HAL_SMARTCARD_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and weak (surcharged) callbacks are used.
